- Mitglied seit
- 1 Aug 2022
- Beiträge
- 1,189
- Punkte für Reaktionen
- 212
- Punkte
- 63
Die Änderungen sind ziemlich umfangreich. Leider haben aber auch zwei Geräte das EOL erreicht und bekommen keine weiteren Updates mehr.
"End Of Life Notice! This is the last software release for the snom D345 and snom D725 phones. These devices already reached the end-of-life cycle."
Quelle: https://service.snom.com/display/wiki/10.1.175.10+Release
[B]Changelog[/B]
Changes since release version 10.1.169.13
[B]New features:[/B]
XQI-732: Activation of keypad lock @D86x
XQI-2548: Introduced support for presentation of Broadsoft Call Center Call Card information with new settings: call_center_call_info_timeout and call_center_call_info @D86x #Broadsoft
XQI-3061: The "IP Settings" menu is missing from the "Connections" PUI settings @D86x
XQI-3080: Missing Identity menu to configure SIP identity on the PUI @D86x
XQI-3257: Function key is visible, if a BLF receives a call.
XQI-3654: On and Off Hoook events support now action URL on @D86x
XQI-3889: "Quick Transfer" submenu under "Call features" on PUI settings @D86x
XQI-3972: Telefon indicates whether the call is using TLS/SRTP by displaying lock symbols @D86x
XQI-3991: Navigation keys are configurable @D86x
XQI-3994: Supporting multiple subscription with authentication with XML definition
XQI-4014: With two new settings: user_secondary_host & user_secondary_outbound the failover support is extented for concurrent registration with different servers
XQI-4059: Additional debug pages were added to the PM/WUI Maintenance Menu @D86x
XQI-4122: SIP registration can re-use the previous address.
XQI-4190: Support for subscriptions with type message-summary in XML definitions
XQI-4320: Infobox can control if the time needs to be shown together with the message
XQI-4334: Set correct default input modes in function key edit screen @D86x
XQI-4424: Support voicemail info key @D86x
XQI-4433: Silent Mode key is now supported @D86x
XQI-4474: Create Wizard to set credentials on PUI (SB-327) @D86x
XQI-4643: Failover on application error
XQI-4677: IPPhoneMenu supports multiple columns
XQI-4810: The call records are saved on flash after each call. Refer to save_latest_callrecords_to_flash to disable that feature.
XQI-4815: "^" and "v" trigger TDDL menu even when redefined (if needed) @D86x
[B]Improvements and modifications:[/B]
XQI-3552: Remove the duplicated "Redial" key type and revise the presented text for Missed/Received/Dialed Calls key types. @D86x
XQI-3637: Changed default values on @SP800
XQI-3661: Phone Manager displays the correct call duration after the page is refreshed with the outgoing conference. @D86x
XQI-3979: We now apply the Group "Add contact" flow to Favorites and Blacklist to allow user to select one or more Local contact entries to be added. @D86x
XQI-4355: Double Column Layout: Allow up/down and left/right key to scroll among pages @D86x
XQI-4818: Enable Contact Pool for Call Transfer @D86x
XQI-4821: SIP MESSAGE is not displayed during a call, or in a conference @D86x
XQI-4947: Adding Hungarian translation @D86x
XQI-4958: Snom phones supports SB-327. With this the phone can operate only with a valid, enough strong password
[B]Corrections:[/B]
XQI-1648: DUT doesn't show Toast message "Checking for update...". @D86x
XQI-2476: Partial Number Lookup was extended to find numbers in the local TBook @D3xx @D7xx @D8xx
XQI-2480: The date for call history entries older than one week ignored timezone, and thus was always determined for UTC+0 @D86x
XQI-3033: Left softkey at the conference detail screen was "Cancel" instead of "Back" @D86x
XQI-3046: The ringer volume preview tone should be played when the setting is changed via PUI @D86x
XQI-3137: Missing LINE key association with established local conference @D86x
XQI-3326: Using VLAN "101 & 102" no outgoing audio. @D865
XQI-3335: During an active call, no digit displays on the PUI when key pressing (0-9, * or #) @D86x
XQI-3413: Unable to access D865 Line keys webpage @D86x
XQI-3458: contact menu: Issues when filling the form content and available options @D86x
XQI-3543: Attended transfer cancel operation unified @D86x
XQI-3769: sip_cancel_reasons_to_ignore_missed_call did not react on reason cause
XQI-3877: UI issues with BLF based attended transfer @D86x
XQI-3892: minibrowser behavior after incoming call was incorrect @D86x
XQI-3965: PUI and PM/WUI local directory isn't always in sync. @D86x
XQI-3969: No element was highlighted in "Contact Details" when returning from submenu @D86x
XQI-4007: "Page Next" cannot be set in fkey9 (Default setting)
XQI-4081: Bluetooth headsets were no more working @D86x
XQI-4192: Preventing addition of participant to a local conference in an attended way while there's still unanswered blindly-invited participants @D8xx
XQI-4205: US number formatting is disregarding the timezone. @D86x
XQI-4259: NTP and other popups (also if sticky) could not be cleared
XQI-4261: With 2 accounts registered, the predial digits are dialed out using the wrong identity. @D86x
XQI-4279: Updated BT device name changes to default name after reboot @D865
XQI-4337: Menu "Call Waiting" / "Hide outgoing ID" did not match specification @D86x
XQI-4350: Edit key was visible on read only directory screens
XQI-4352: LDAP directory matching is not working properly on incoming call. @D86x
XQI-4353: LDAP directory matching is not working properly on outgoing call. @D86x
XQI-4366: 'Dial' soft key is not available upon selecting 'Edit Dial' option @D86x
XQI-4368: The termination tones were not played @D1xx @D3xx @D7xx
XQI-4373: Remove unexpected "Fwd by:" from call card @D86x
XQI-4378: Incoming call was answered by default @SP800
XQI-4394: Date was not completely visible, in some rare cases when the PFKs were set to full @D86x
XQI-4417: The dialing DTMFs were heard even if they were not allowed @D86x
XQI-4425: The "usb-expansion module connected" icon is shown to the user when one or more expansion module is connected @D7xx @D8xx
XQI-4426: The "usb-expansion module connected" notification should not be shown to the user @D7xx @D8xx
XQI-4430: Save input mode for each field to history @D86x
XQI-4434: CPU Load increases abnormally with call duration @D1xx @D3xx @D7xx
XQI-4440: user_subscription_expiry doesn't turn off subscriptions @D1xx @D3xx @D7xx @D8xx
XQI-4441: PFK Edit screen - highlightning was wrong. @D86x
XQI-4444: PhoneManager is blocked during the provisioning. @D86x
XQI-4466: DUT shows blank screen after headset controls are used to dial a call @D86x
XQI-4513: Provisioning was triggered to often but should be triggered only, if really needed, like: on check-sync, boot, refresh timer, URL change @D1xx, @D3xx, @D7xx, @D8xx
XQI-4521: Multicast stream cannot be heared via handset @D3xx, @D7xx
XQI-4535: Directory Search w/ firstname and lastname via WUI does not work as expected @D86x
XQI-4546: The ringback tone of a second call was still played even though the second call is cancelled @D86x
XQI-4649: References to Settings Menu in PUI did not have matching terminology
XQI-4660: The dialtone was not stopped while doing call transfer scenario or local conference setup. @D86x
XQI-4668: 'Dial' soft key is not available upon selecting 'Edit Dial' option @D1xx @D3xx @D7xx
XQI-4704: wrong "locale" was used for "Norsk (Norway)" @D86x
XQI-4725: Unmuting participants in large local conference was not working. @D86x
XQI-4743: unexpected re-invite after refer when performing a blind transfer @D86x
XQI-4751: Displays wrong "Date" info (1 day faster) @D86x
XQI-4757: The emergency_proxy was not used if offer_outbound was enabled @D86x
XQI-4758: Remove invalid fields from LDAP details screen. @D86x
XQI-4773: The UxmConnected status message was blocked by default @D7xx @D3xx
XQI-4781: A(DUT) call ended when press Speed Dial key
XQI-4785: Muted participants stayed muted after a local conference teardown. @D86x
XQI-4786: Speaker icon disappear when press "Remove" softkey
XQI-4789: The screen isn't dimmed on idle after boot until the dim screen timeout on idle has expired. @D86x
XQI-4791: After reboot/reset home screen is not coming up. @D86x
XQI-4793: How to handle empty vs non empty passwords on PhoneManger @D86x
XQI-4803: Do not auto-disconnect call on @SP800 by default.
XQI-4805: Dynamic more key handling was wrong
XQI-4827: Improve volume screen values and key event synchronization. @D86x
XQI-4828: show_ivr_digits was masking the entered digits. The "brief" mode is added to existing "on" and "off" modes @D86x
XQI-4859: When autohide is enabled and the PFK's are activated, the softkey menu is not updated to show "Cancel". @D86x
XQI-4873: Minibrowser List Menu Item don't match designs
XQI-4880: After entering a password for a selected WIFI network, the correct network is used. @D865
XQI-4889: The call history was showing missed calls as received calls too @D86x
XQI-4933: Removing PFK setup - confirmation and toast message was missing. @D86x
XQI-4942: Audio device selection for outgoing call was no considered in every case
XQI-4949: Popup message was not removed when it is set to "false"
XQI-4955: Dialplan blocks outging calls
XQI-5013: TR-369 client was forced to retry at every 5s on MQTT failure @D140 @D150 @D713 @D717 @D735 @D8xx #SRAPS
XQI-5022: The displayed icon top-left corner on concurrent incoming call cards was wrong @D86x
XQI-5024: No Syslog packets could be send over the network in specific network setups. @D86x
XQI-5042: Xfer: Softkey "Directory" did not work when Directory was active while incoming call was received
XQI-5052: Don't show status info softkey in idle on monochrome phones without unread status messages @315 @D712 @715 @725
XQI-5073: Local conference was not working after certain phone usages @D86x
XQI-5092: Language change via Preferences menu doesn't change the language instantly. @D86x
