KunterBunter
IPPF-Urgestein
- Mitglied seit
- 12 Okt 2005
- Beiträge
- 30,015
- Punkte für Reaktionen
- 1,332
- Punkte
- 113
Bei "Authentifizierungspasswort" sind jetzt auf einmal nur noch vier schwarze Punkte, vorher waren es neun. Woran kann das liegen?
0421112027|app1 |*|03|Manual Reboot
0421112028|so |*|03|SoNcasC::procMsg: Client service shutdown complete
0421112028|wdog |*|03|Watchdog Expired: tSup
0421112028|ssps |*|03|sspsAlive: DSP Monitor Turning Off
000005.908|log |*|03|---------- Initial log entry ----------
000005.908|so |*|03|Platform: Model=SoundStation IP 7000, Assembly=3111-40000-001 Rev=P Region=
000005.908|so |*|03|Platform: Interface eth0 MAC=0004f2f9e9c0
000005.908|so |*|03|Platform: BootBlock=3.0.4.0001 (40000-001) 11-Jul-12 08:53
000005.908|so |*|03|Platform: BootL1=Standalone.0002 15-Jan-07 15:05:00
000005.909|so |*|03|Platform: Updater=5.0.5.2324 09-Dec-13 14:37
000005.909|so |*|03|Application, main: Label=SIP, Version=Mink 4.0.15.1009 07-Feb-20 13:21
000005.909|so |*|03|Application, main: P/N=3150-11530-409
000005.909|rdisk|*|03|RAM disk created, size: 8,388,608 bytes
000005.909|ocsp |*|03|O.C.S.P. Enabled = 0
000005.910|tls |*|03|Initial log entry. Current logging level 4
000005.928|pmt |*|03|Initial log entry. Current logging level 4
000005.928|wdog |*|03|Initial log entry. Current logging level 4
000005.928|ethf |*|03|Initial log entry. Current logging level 4
000005.928|hw |*|03|Initial log entry. Current logging level 4
000005.928|ares |*|03|Initial log entry. Current logging level 4
000005.928|dns |*|03|Initial log entry. Current logging level 4
000005.928|cfg |*|03|Initial log entry. Current logging level 4
000005.929|dot1x|*|03|Initial log entry. Current logging level 4
000005.929|lic |*|03|Initial log entry. Current logging level 4
000005.929|lic |4|03|cfgCfsFlashKeyScratchLoad: key is blank
000006.030|cfg |*|03|RT|Network eth0 link went up
000006.030|cfg |*|03|RT|cfgRtNetInterfaceUpdate: Network not initialized
000006.214|pnetm|*|03|Initial log entry. Current logging level 4
000006.214|clink|*|03|Initial log entry. Current logging level 4
000006.346|curl |*|03|Initial log entry. Current logging level 4
000006.346|utilm|*|03|Initial log entry. Current logging level 4
000006.346|copy |*|03|Initial log entry. Current logging level 4
000006.346|rtos |*|03|Initial log entry. Current logging level 4
000006.346|sec |*|03|Initial log entry. Current logging level 4
000006.347|so |*|03|Configuration files: 000000000000_profile.cfg
000006.347|so |*|03|Configuration file "000000000000_profile.cfg" SHA1 digest: A618F0C579EC37196B4EDE0155871F1C49296DBC
000006.350|log |*|03|Log render level set to 1
000006.708|srtp |*|03|Initial log entry. Current logging level 4
000006.708|res |*|03|Initial log entry. Current logging level 4
000006.709|httpa|*|03|Initial log entry. Current logging level 4
000006.709|lldp |*|03|Initial log entry. Current logging level 4
000006.709|cdp |*|03|Initial log entry. Current logging level 4
000006.755|ssps |*|03|Initial log entry. Current logging level 4
000006.843|so |*|03|System Info Reports:
000006.843|so |*|03| CPU is pnx1700/TM5250, rev 0 running at 399MHz with memory at 199MHz.
000006.843|so |*|03| CAS latency (dram): 0x133; CAS latency (proc): 0x6; refresh rate: 0x616
000006.843|so |*|03| Board is identified as PLCM PNX1700 Onyx (ID 0x1004fb2c):
000006.843|so |*|03| DRAM_LO: 0x40000000. DRAM_HI: 0x44000000. C_LIMIT: 0x43ff0000.
000006.843|so |*|03| APERT1_LO: 0x1c000000. APERT1_HI: 0x20000000.
000006.843|so |*|03| PCSW: 0x20001e02
000006.843|so |*|03| Application built in ASSERT mode.
000006.843|so |*|03| NOR flash detected is 14
000006.843|key |*|03|Initial log entry. Current logging level 4
000006.845|httpd|*|03|Initial log entry. Current logging level 4
000006.845|poll |*|03|Initial log entry. Current logging level 4
000006.845|push |*|03|Initial log entry. Current logging level 4
000006.846|poll |*|03|Initial log entry. Current logging level 4
000006.846|ht |*|03|Initial log entry. Current logging level 4
000006.846|dbuf |*|03|Initial log entry. Current logging level 4
000006.848|pps |*|03|Initial log entry. Current logging level 4
000006.848|sip |*|03|Initial log entry. Current logging level 4
000006.848|peer |*|03|Initial log entry. Current logging level 4
000006.848|mobil|*|03|Initial log entry. Current logging level 4
000006.848|ptt |*|03|Initial log entry. Current logging level 4
000006.868|ssps |*|03|Application, comp. 1: Label=PolyDSP PNX1700 Mem1 FS1, Version=6.2.0.0117 23-Jan-13 15:46
000006.868|ssps |*|03|Application, comp. 1: P/N=3150-11580-620.
000006.939|so |5|03|soCoreAudio compiledOffsetsApply error: unrecognized verAudio 6 for headset
000007.068|ssps |5|03|sspsHdiMsgProc: id=210 (SspsHdiMsgDtHAck), len=12, seq=23, req=24, extra=-1, extraRep=-2, resType=3, desc=3147.
000007.088|ssps |5|03|sspsHdiMsgProc: id=210 (SspsHdiMsgDtHAck), len=12, seq=26, req=27, extra=-1, extraRep=-2, resType=3, desc=3148.
000007.088|ssps |5|03|sspsHdiMsgProc: id=210 (SspsHdiMsgDtHAck), len=12, seq=32, req=33, extra=-1, extraRep=-2, resType=3, desc=3147.
000007.108|ssps |5|03|sspsHdiMsgProc: id=210 (SspsHdiMsgDtHAck), len=12, seq=35, req=36, extra=-1, extraRep=-2, resType=3, desc=3148.
000007.128|so |*|03|Using TCP IP Media Port, configured initial RTP port 5104
000007.136|sshc |*|03|Initial log entry. Current logging level 4
000007.137|cmp |*|03|Initial log entry. Current logging level 4
000007.137|wmgr |*|03|Initial log entry. Current logging level 4
000007.137|pnetm|*|03|WaitForProvisioningOverClink2(), returning 1 in task tSup (5505024)
000007.139|slog |*|03|Initial log entry. Current logging level 3
000007.148|ssps |5|03|sspsHdiMsgProc: id=210 (SspsHdiMsgDtHAck), len=12, seq=40, req=41, extra=-1, extraRep=-2, resType=3, desc=3147.
000007.339|app1 |*|03|Initial log entry. Current logging level 4
000007.339|pnetm|*|03|pnetModule::attach() VGA status call back:0x40538b40, appPtr:0x42da7080
000007.344|app1 |4|03|StatusBar is disabled
000007.346|app1 |4|03|mb.main.home parameter is empty
000007.351|mb |*|03|Initial log entry. Current logging level 4
000007.419|ldap |*|03|Initial log entry. Current logging level 4
000007.419|ldap |4|03|cDynamicData::cDynamicData:cDynamicData:Failed
000007.673|efk |*|03|Initial log entry. Current logging level 4
000521.615|cfg |*|03|RT|cfgRtNetInterfaceUpdate: Network not initialized
000521.615|app1 |4|03|[AppUserLoginC::Init]:flushing user cache file failed
000521.668|utilm|4|03|uBLFCompressed: File /ffs0/local/local-directory_xml.zzz does not exist or is empty
000521.669|cfg |4|03|Edit|Error 0x2 loading local cfg /ffs0/local/local-directory_xml.zzz
000521.884|app1 |*|03|Ctx [2] Registered [false]
000521.885|app1 |*|03|Ctx [2] Registered [true]
000521.896|app1 |*|03|Ctx [1] Registered [false]
000524.063|cfg |*|03|RT|Do not do DHCP VLAN Discovery.
000603.873|cfg |*|03|RT| Phone IP address is 192.168.178.150.
000603.873|cfg |*|03|RT| Subnet mask is 255.255.255.0.
000603.873|cfg |*|03|RT| Gateway address is 192.168.178.1.
000603.873|cfg |*|03|RT|DHCP: Alternate DNS server is not specified
000603.873|cfg |*|03|RT| DNS server is 192.168.178.1.
0421091521|cfg |*|03|RT| DNS domain is fritz.box.
0421091521|cfg |*|03|RT| Time server is 192.168.178.1.
0421091521|cfg |*|03|RT| GMT offset is 3600 seconds.
0421091521|dns |*|03|DNS resolver servers are '192.168.178.1' '0.0.0.0'
0421091521|dns |*|03|DNS resolver search domain is 'fritz.box'
0421091521|cfg |*|03|RT|Primary IP changed to 192.168.178.150 subnet mask 255.255.255.0
0421091521|cfg |*|03|RT|cfgRtNetInterfaceUpdate: bfeng -- calling network status callback
0421091521|so |*|03|Network initialized. Starting network tasks.
0421091521|log |*|03|Install file upload callback for 'so'
0421091521|cfg |5|03|Prm|Parameter reg.x.outboundProxy.port requested type 0 but is of type 2
0421091521|sip |*|03|Fast Boot Measurement Point: Ready for Call, uptime: 363.890 sec.
0421091521|app1 |4|03|[AppPhoneC]::LineInit(), attempting to initialize line 1 (protocol 1) multiple times.
0421091521|app1 |4|03|[AppPhoneC]::LineInit(), attempting to initialize line 2 (protocol 2) multiple times.
0421091521|app1 |*|03|Ctx [0] Registered [false]
0421091521|app1 |5|03|Corporate directory instance does not exists.
0421091521|copy |4|03|Configuration of URL failed
0421091521|utilm|4|03|uBLFCompressed: File /ffs0/local/local-directory_xml.zzz does not exist or is empty
0421091521|cfg |4|03|Edit|Error 0x2 loading local cfg /ffs0/local/local-directory_xml.zzz
0421091521|res |4|03|[ResFinderC]: Download - Failed to download file SoundPointIPLocalization/German_Germany/SoundPointIP-dictionary.xml, errno 0x2.
0421091521|so |4|03|[SoLangC]: Failed to load new language - Rolling back to default language
0421112709|copy |*|03|Server 'downloads.polycom.com' said 'voice/software/UC_Software_4_0_15_release_sig_split/3111-40000-001.updater.ld' is not present
0421112709|cfg |*|03|Prov|Starting to update
0421112709|copy |*|03|Server 'downloads.polycom.com' said 'voice/software/UC_Software_4_0_15_release_sig_split/updater.ld' is not present
0421112710|copy |4|03|Configuration of URL failed
0421112710|cfg |4|03|Prov|Download of master configuration file failed
0421112710|cfg |4|03|Prov|Trying to boot from existing configuration
0421112710|cfg |4|03|Prov|Not setting device parameters since configuration was not updated.
0421112710|cfg |*|03|Prov|Finished updating configuration
0421112710|log |4|03|UtilLogC::uploadFifoLog: upload error. protocol 0 result = 8
0421112740|sip |4|03|Registration failed User: 620, Error Code:480 Temporarily not available
0421112746|copy |4|03|Configuration of URL failed
0421112746|cfg |4|03|Web|[cfgSaProcessRequestC] Failed to download language file from provisioning server, request path Website_dictionary_language_de-de.xml
0421112746|utilm|4|03|uBLFCompressed: File /ffs0/languages/Website_dictionary_language_de-de.xml.zzz does not exist or is empty
0421112746|cfg |4|03|Web|[cfgSaProcessRequestC] Website_dictionary_language_de-de.xml Language file doesn't exist in cache
0421112746|cfg |4|03|Web|[cfgSaProcessRequestC] Website_dictionary_language_de-de.xml Language file doesn't exist in phone flash
[CODE] TAG [/CODE]
gesetzt by stoneyDann erkläre mir mal, warum du vor dem Ende bei Line1 Address "620" eingetragen hast.ich bin leider auch mit meinem Latein am Ende.
Die 620 ist die Interne Nummer die das Telefon von der FritzBox bekommen hat, daher dachte ich ist dies die Adresse des Telefons.Auf jeden Fall nicht 620. Deshalb fragte ich ja, warum du das da eingetragen hast. Das war ja wohl noch vor dem Ende deines Lateins.
Was war denn bei dir nun der richtige Eintrag?Ah jetzt gehts...
