Fritzbox 7520 Bootloader in mtd1 zurückschreiben.
Insti
Aktives Mitglied
19 Aug 2016
ich habe eine 7520 die nach dem schreiben des mtd1 nicht mehr startet :(
Habe einen seriellen Adapter angeschlossen und so sieht der Startlog aus:
Format: Log Type - Time(microsec) - Message - Optional Info
Log Type: B - Since Boot(Power On Reset),  D - Delta,  S - Statistic
S - QC_IMAGE_VERSION_STRING=AVM_BOOT.BF.3.1.1
S - IMAGE_VARIANT_STRING=DAABANAZA
S - OEM_IMAGE_VERSION_STRING=1204
S - Boot Config, 0x00000025
S - Reset status Config, 0x00000000
S - Core 0 Frequency, 0 MHz
B -       261 - PBL, Start
B -      1339 - bootable_media_detect_entry, Start
B -      2612 - bootable_media_detect_success, Start
B -      2626 - elf_loader_entry, Start
B -      4044 - auth_hash_seg_entry, Start
B -      5975 - auth_hash_seg_exit, Start
B -    110185 - elf_segs_hash_verify_entry, Start
B -    301613 - PBL, End
B -         0 - SBL1, Start
B -    401997 - pm_device_init, Start
D -         9 - pm_device_init, Delta
B -    403122 - boot_flash_init, Start
D -     80146 - boot_flash_init, Delta
B -    487612 - boot_config_data_table_init, Start
D -     13964 - boot_config_data_table_init, Delta - (419 Bytes)
B -    504033 - clock_init, Start
D -      7430 - clock_init, Delta
B -    514437 - CDT version:2,Platform ID:8,Major
B -    515742 - sbl1_ddr_set_params, Start
B -    520450 - cpr_init, Start
D -         4 - cpr_init, Delta
B -    525528 - Pre_DDR_clock_init, Start
D -         5 - Pre_DDR_clock_init, Delta
D -     13021 - sbl1_ddr_set_params, Delta
B -    538923 - pm_driver_init, Start
D -         4 - pm_driver_init, Delta
B -    574161 - sbl1_wait_for_ddr_training, Start
D -        30 - sbl1_wait_for_ddr_training, Delta
B -    590282 - Image Verify, Start 0:QSEE
D -    283753 - QSEE Image Loaded, Delta - (293144 Bytes)
B -    874350 - Image Verify, Start 0:QSEE_B
D -    286531 - QSEE Image Loaded, Delta - (293144 Bytes)
B -   1161237 - Selected TZ0: 10228 (0:QSEE)
B -   1164298 - Image Load, Start
D -    286442 - QSEE Image Loaded, Delta - (293144 Bytes)
B -   1451053 - Image Load, Start
D -      2029 - SEC Image Loaded, Delta - (2048 Bytes)
B -   1464613 - Image Verify, Start 0:APPSBL
B -   1589146 - Image Verification failed (689)
D -    124890 - APPSBL Image Loaded, Delta - (118924 Bytes)
B -   1593278 - Image Verify, Start 0:APPSBL_B
B -   1721701 - Image Verification failed (689)
D -    128781 - APPSBL Image Loaded, Delta - (118924 Bytes)
B -   1725781 - No verified EVA in flash!!! Booting not possible!!!
Original mtd1 ist vorhanden, aber wie bekomme ich den drauf? Eingabe ist keine möglich.
Jedenfalls nicht per RS232-Schnittstelle. Wenn dann wäre es per (E)JTAG-Schnittstelle denkbar oder aber man beschreibt den NAND-Flashbaustein mit einem anderen Gerät direkt.
Reaktionen: Insti
Dann landet die Box auf dem Recyclinghof da von EJTAG ich kein Plan habe.
Reaktionen: lubi
@Insti:
Die Box ist nicht sinnlos gestorben, dein Log war sehr hilfreich bei der Forschung:
Du hattest 2 kaputte EVA instanzen. Keine Ahnung wie das passieren kann. Vielleicht marodes Flash, weil normal ost extra die zweite Instanz da zur Sicherheit...
Vielen Dank.
PS: Beim nächsten Mal schick mir so was statt es zu entsorgen. Zahle Porto und symbolischen Preis.
Maverick2024
