7320: Kernel Panic beim Firmware Update
olistudent
IPPF-Urgestein
19 Okt 2004
Beim Update einer 7320 mit Freetz Firmware bekomm ich auf der Konsole folgenden Output. Mit original AVM Firmware gibts keine Probleme. Es sind keine zusätzlichen Module geladen und es laufen keine Freetz Daemons.
System init finished ...
Please press Enter to activate this console.
PID USER       VSZ STAT COMMAND
    1 root      1108 S    init
    2 root         0 SW<  [kthreadd]
    3 root         0 SW<  [ksoftirqd/0]
    4 root         0 SW<  [events/0]
    5 root         0 SW<  [khelper]
    6 root         0 SW<  [kblockd/0]
    7 root         0 SW   [pdflush]
    8 root         0 SW   [pdflush]
    9 root         0 SW<  [kswapd0]
   10 root         0 SW<  [aio/0]
   11 root         0 SW<  [nfsiod]
   12 root         0 SWN  [avmdebug]
   13 root         0 SW   [pm_info]
   46 root         0 SW<  [CPMAC workqueue]
   47 root         0 SW<  [mtdblockd]
   48 root         0 SW<  [kondemand/0]
   49 root         0 SW<  [rpciod/0]
   50 root         0 SW   [tffsd_mtd_0]
  101 root         0 SW   [cleanup_timer_f]
  201 root         0 SW<  [capi_oslib]
  202 root         0 RW<  [capi_oslib]
  203 root         0 SW   [capitransp]
  206 root         0 RW<  [avm_dect_thread]
  207 root         0 SW   [ksock tcp worke]
  208 root         0 SW   [ksock tcp serve]
  387 root      1084 S <  /sbin/udevd --daemon
  426 root         0 SW<  [khubd]
  491 root      1084 S <  /sbin/udevd --daemon
  492 root      1084 S <  /sbin/udevd --daemon
  548 root      3672 S    /bin/configd
  550 root      1072 S    oamd
  602 root         0 SW   [autbtex]
  603 root         0 SW   [ceocex_ne]
  604 root         0 DW   [pmex_ne]
  605 root         0 DW   [pmex_fe]
  660 root         0 SWN  [dectuart_route]
  667 root     10596 S N  ctlmgr
  672 root      5384 S    upnpd
  687 root      4272 S    multid -t
  760 root      4272 S    multid -t
  816 root      1196 S    /sbin/chronyd -f /var/tmp/chrony.conf
 1286 root      5384 S    upnpd
 1287 root      5384 S    upnpd
 1290 root      5384 S    upnpd
 1293 root     10596 S N  ctlmgr
 1294 root     10596 S N  ctlmgr
 1295 root     10596 S N  ctlmgr
 1367 root      4200 S    telefon a127.0.0.1
 1376 root      3628 S    pbd
 1377 root      3628 S    pbd
 1378 root      3628 S    pbd
 1379 root      3628 S    pbd
 1380 root      3628 S    pbd
 2456 root       888 S    /bin/run_clock -c /dev/tffs -d
 2465 root      1108 S    init
 2656 root      4016 S N  /cgi-bin/firmwarecfg
 2659 root      1124 S N  /bin/sh /bin/prepare_fwupgrade start UPNP
 2661 root      1104 R N  ps
Fri Feb 18 15:18:02 CET 2011
Fri Feb 18 15:18:04 CET 2011
killall: ftpd: no process killed
killall: smbd: no process killed
rmmod: can't unload 'vfat': unknown symbol in module, or unknown parameter
rmmod: can't unload 'fat': unknown symbol in module, or unknown parameter
rmmod: can't unload 'nls_cp437': unknown symbol in module, or unknown parameter
rmmod: can't unload 'nls_iso8859_1': unknown symbol in module, or unknown parameter
rmmod: can't unload 'sd_mod': unknown symbol in module, or unknown parameter
rmmod: can't unload 'ext2': unknown symbol in module, or unknown parameter
rmmod: can't unload 'usb_storage': unknown symbol in module, or unknown parameter
rmmod: can't unload 'scsi_mod': unknown symbol in module, or unknown parameter
ar9 USB 2.0 Host stopped
cat: can't open '/proc/bus/usb/devices': No such file or directory
Fri Feb 18 15:18:07 CET 2011
    1 root      1108 S    init
  602 root         0 RW   [autbtex]
 2839 root      1084 S <  /sbin/udevd --daemon
 2882 root      1104 R N  ps
TERMINATING inetd capiotcp_server pbd faxd telefon dtrace printserv smbd mailer
killall: dect_manager: no process killed
Fri Feb 18 15:18:11 CET 2011
TERMINATING audiod pictured feedd playerd
TERMINATING configd
TERMINATING lltdd maild voipd usermand mediasrv avmlogd tr069discover contfiltd avmik
Fri Feb 18 15:18:12 CET 2011
    1 root      1108 S    init
  101 root         0 RW   [cleanup_timer_f]
  667 root     10512 S N  ctlmgr
  672 root      5284 S    upnpd
  687 root      4288 S    multid -t
  760 root      4288 S    multid -t
 1286 root      5284 S    upnpd
 1287 root      5284 S    upnpd
 1290 root      5284 S    upnpd
 1293 root     10512 S N  ctlmgr
 1294 root     10512 S N  ctlmgr
 1295 root     10512 S N  ctlmgr
 3192 root      4728 S N  /cgi-bin/firmwarecfg
 3195 root      1124 S N  /bin/sh /bin/prepare_fwupgrade end UPNP
 3197 root      1104 R N  ps
Fri Feb 18 15:19:53 CET 2011
rmmod: can't unload 'ifxusb_host': unknown symbol in module, or unknown parameter
Fri Feb 18 15:19:56 CET 2011
unmounting '/var/media/ftp/*' ..
unload dsl and dependend driver ..
rmmod: can't unload 'rfcntl': unknown symbol in module, or unknown parameter
rmmod: can't unload 'isdn_fbox_fon4': unknown symbol in module, or unknown parameter
rmmod: can't unload 'isdn_fbox_fon3': unknown symbol in module, or unknown parameter
rmmod: can't unload 'isdn_fbox_fon2': unknown symbol in module, or unknown parameter
rmmod: can't unload 'isdn_fbox_fon': unknown symbol in module, or unknown parameter
rmmod: can't unload 'ulpcmlink': unknown symbol in module, or unknown parameter
rmmod: can't unload 'userman': unknown symbol in module, or unknown parameter
rmmod: can't unload 'userman_mod': unknown symbol in module, or unknown parameter
rmmod: can't unload 'ubik2': unknown symbol in module, or unknown parameter
rmmod: can't unload 'tiatm': unknown symbol in module, or unknown parameter
    1 root      1108 S    init
 4034 root      1100 S    /bin/sh -c /var/post_install
 4035 root      1112 S    /bin/sh /var/post_install
 4253 root      1132 R    /bin/sh /etc/init.d/rc.dsl.sh stop
 4286 root      1100 R    ps
Module                  Size  Used by    Tainted: P
dsl_ar9               300672  0
usbcore               125552  1
ramzswap               16448  1
Piglet_noemif          23264  0
lzo_compress            2080  1 ramzswap
lzo_decompress          2272  1 ramzswap
rtc_avm                 5520  0
led_modul_Fritz_Box_7320    68368  0
system is going down ..
/var/post_install: start
skip deleting language from env
disablstill running:
    1 root      1108 S    init
 4035 root      1112 R    /bin/sh /var/post_install
 4307 root      1100 R    ps
dsl_ar9               300672  0
usbcore               125552  1
ramzswap               16448  1
rtc_avm                 5520  0
FLASH_UPDATE
[flash_update] file /var/tmp/kernel.image address 0x10020000 len 15335424 crc 0x1
[flash_read_file] filelen 14008584
[flash_read_file] read 14008576 crc 0x23E5B6EE 0x23E5B6EE
[flash_update] disable Interrupts
[FLASH:] MACRONIX Uniform-Flash 16MB 64 Bytes WriteBuffer
[FLASH:](Eraseregion [0] 128 sectors a 128kB)
[make_checksum] no filesystem_len found
ROM VER: 1.1.3
CFG 01
Reserved instruction in kernel code[#1]:
Cpu 0
$ 0   : 00000000 00000001 be100b20 fffffff7
$ 4   : 00000481 00001107 00000004 80003fe0
$ 8   : 9e1a1288 9e1a1a20 9e1a19e0 9fc000c4
$12   : 9fc000c4 00000000 00000000 00000000
$16   : 00000000 00000000 00000000 00000000
$20   : 00000000 00000000 00000000 00000000
$24   : 00000000 00000000
$28   : 00000000 9e1a1de4 c0c90000 90002d64
Hi    : 00000000
Lo    : 00004000
BUG: scheduling while atomic: busybox/4310/0xf6fffedf
Modules linked in: flash_update(P+) dsl_ar9 usbcore ramzswap Piglet_noemif(P) lzo_compress lzo_decompress rtc_avm led_modul_Fritz_Box_7320(P) [last unloaded: kdsldmod]
Unhandled kernel unaligned access[#2]:
Cpu 0
$ 0   : 00000000 00000001 00000000 00000000
$ 4   : 00030001 00000000 400000b1 801d32a0
$ 8   : 11000000 1000001e 8031ee90 0000005a
$12   : 9fc000c4 fff70000 0000000d 00000005
$16   : 000000b1 00000005 9e1540f4 803e0000
$20   : 80436ca0 80390000 80440000 803b0000
$24   : 00000009 00000006
$28   : 9e154000 9e154024 80390000 80002400
Hi    : 00000000
Lo    : 00000016
epc   : 80022c1c do_page_fault+0x50/0x3f4
    Tainted: P
ra    : 80002400 _stext+0x0/0xc
Status: 11000002    KERNEL EXL
Cause : 00001810
BadVA : 00000000
PrId  : 0001954c (MIPS 34Kc)
Process  (pid: 0, threadinfo=9e150000, task=9e154024, tls=11000002)
Stack : 00000000 9e1548d4 400000b1 801d32a0 11000000 1000001e 8031ee90 0000005a
        9fc000c4 fff70000 0000000d 00000005 00000000 8e3600ac 000000b1 803e0000
        80436ca0 80390000 80440000 803b0000 00000009 00000006 00000016 000000b1
        9e154000 9e1548ac 80390000 80002400 11000002 00000000 00000016 000000b1
        00001808 8001e54c 9fc000c4 fff70000 0000000d 00000005 00000000 8e3600ac
Call Trace:
[<80022c1c>] do_page_fault+0x50/0x3f4
Code: 3c040003  34840001  00c3182b <8e3600ac> 00a0a821  146000c3  afa4002c  8f830014  3c02efff
------------[ cut here ]------------
WARNING: at kernel/exit.c:1004 do_exit+0x58/0x74c()
Call Trace:
[<8000b484>] dump_stack+0x8/0x34
---[ end trace 803e41e45c14c471 ]---
Call Trace:
Kernel panic - not syncing: Attempted to kill the idle task!
Rebooting in 5 seconds..
Hat jemand eine Idee wie ich den Fehler eingrenzen könnte?
Oliver
edit: Update mit original AVM Firmware im Flash
Feb 18 17:41:09 telefon[1272]: set initial telefon time from linux time to 17:41:09 18.02 2011!
Feb 18 17:41:24 telefon[1272]: SIGCHILD killdectpid
DSL[00]: Reboot on training timeout (60)!!!cat: read error: Broken pipe
Feb 18 17:41:55 chronyd[1050]: Trimming RTC, error = -1298050827.196 seconds
    1 root      1584 S    init
  110 root         0 SW   [cleanup_timer_f]
  203 root         0 SWN  [jffs2_gcd_mtd5]
  209 root         0 SW<  [capi_oslib]
  210 root         0 RW<  [capi_oslib]
  211 root         0 SW   [capitransp]
  215 root         0 RW<  [avm_dect_thread]
  216 root         0 SW   [ksock tcp worke]
  217 root         0 SW   [ksock tcp serve]
  305 root      1324 S <  /sbin/udevd --daemon
  337 root         0 SW<  [khubd]
  401 root      1324 S <  /sbin/udevd --daemon
  406 root      1324 S <  /sbin/udevd --daemon
  460 root      3924 S    /bin/configd
  464 root       888 S    dsl_control -i10_00_10_40_00_04_01_00 -f/lib/modules/
  465 root      1312 S    oamd
  470 root       888 S    dsl_control -i10_00_10_40_00_04_01_00 -f/lib/modules/
  471 root       888 S    dsl_control -i10_00_10_40_00_04_01_00 -f/lib/modules/
  472 root       888 S    dsl_control -i10_00_10_40_00_04_01_00 -f/lib/modules/
  474 root       888 S    dsl_control -i10_00_10_40_00_04_01_00 -f/lib/modules/
  476 root       888 S    dsl_control -i10_00_10_40_00_04_01_00 -f/lib/modules/
  551 root         0 SW   [autbtex]
  552 root         0 SW   [ceocex_ne]
  553 root         0 SW   [pmex_ne]
  554 root         0 SW   [pmex_fe]
  597 root         0 SWN  [dectuart_route]
  604 root     10836 S N  ctlmgr
  609 root      5620 S    upnpd
  624 root      4480 S    multid -t
 1050 root      1436 S    /sbin/chronyd -f /var/tmp/chrony.conf
 1056 root      4480 S    multid -t
 1219 root     10836 S N  ctlmgr
 1220 root     10836 S N  ctlmgr
 1221 root     10836 S N  ctlmgr
 1265 root      5620 S    upnpd
 1266 root      5620 S    upnpd
 1268 root      5620 S    upnpd
 1272 root      5408 S    telefon a127.0.0.1
 1283 root      3852 S    pbd
 1284 root      3852 S    pbd
 1288 root      3852 S    pbd
 1289 root      3852 S    pbd
 1829 root      1576 S    /usr/sbin/inetd
 1839 root      1128 S    /bin/run_clock -c /dev/tffs -d
 1848 root      1584 S    init
 2015 root      4328 S N  /cgi-bin/firmwarecfg
 2018 root      1592 S N  /bin/sh /bin/prepare_fwupgrade start UPNP
 2021 root      1576 R N  ps
Fri Feb 18 17:42:59 CET 2011
Feb 18 17:42:59 chronyd[1050]: chronyd exiting on signal
Fri Feb 18 17:43:00 CET 2011
rmmod: cannot unload 'vfat': unknown symbol in module, or unknown parameter
rmmod: cannot unload 'fat': unknown symbol in module, or unknown parameter
rmmod: cannot unload 'nls_cp437': unknown symbol in module, or unknown parameter
rmmod: cannot unload 'nls_iso8859_1': unknown symbol in module, or unknown parameter
rmmod: cannot unload 'sd_mod': unknown symbol in module, or unknown parameter
rmmod: cannot unload 'ext2': unknown symbol in module, or unknown parameter
rmmod: cannot unload 'usb_storage': unknown symbol in module, or unknown parameter
rmmod: cannot unload 'scsi_mod': unknown symbol in module, or unknown parameter
Fri Feb 18 17:43:03 CET 2011
    1 root      1584 S    init
 2018 root      1596 S N  /bin/sh /bin/prepare_fwupgrade start UPNP
 2122 root      1324 S <  /sbin/udevd --daemon
 2169 root      1576 R N  ps
Feb 18 17:43:03 pbd[1283]: received signal: Terminated.
Feb 18 17:43:03 pbd[1288]: received signal: Terminated.
Feb 18 17:43:03 pbd[1289]: received signal: Terminated.
Feb 18 17:43:03 telefon[1272]: SIGTERM received!
Feb 18 17:43:03 telefon[1272]: wdt release failed
Feb 18 17:43:04 telefon[1272]: SIGCHLD received!
Feb 18 17:43:06 pbd[1283]: terminating.
Fri Feb 18 17:43:08 CET 2011
TERMINATING configd
TERMINATING lltdd maild voipd usermand mediasrv avmlogd tr069discover contfiltd avmike dsld
Fri Feb 18 17:43:09 CET 2011
    1 root      1584 S    init
  210 root         0 SW<  [capi_oslib]
  215 root         0 SW<  [avm_dect_thread]
  604 root     10804 S N  ctlmgr
  609 root      5520 S    upnpd
  624 root      4496 S    multid -t
 1056 root      4496 S    multid -t
 1219 root     10804 S N  ctlmgr
 1220 root     10804 S N  ctlmgr
 1221 root     10804 S N  ctlmgr
 1265 root      5520 S    upnpd
 1266 root      5520 S    upnpd
 1268 root      5520 S    upnpd
 2427 root      4844 S N  /cgi-bin/firmwarecfg
 2430 root      1592 S N  /bin/sh /bin/prepare_fwupgrade end UPNP
 2433 root      1576 R N  ps
Fri Feb 18 17:43:40 CET 2011
killall: inetd: no process killed
rmmod: cannot unload 'ifxusb_host': unknown symbol in module, or unknown parameter
Fri Feb 18 17:43:43 CET 2011
starting pid 3230, tty '/dev/ttyS1': '/bin/sh -c /var/post_install'
rmmod: cannot unload 'rfcntl': unknown symbol in module, or unknown parameter
rmmod: cannot unload 'isdn_fbox_fon4': unknown symbol in module, or unknown parameter
rmmod: cannot unload 'isdn_fbox_fon3': unknown symbol in module, or unknown parameter
rmmod: cannot unload 'isdn_fbox_fon2': unknown symbol in module, or unknown parameter
rmmod: cannot unload 'isdn_fbox_fon': unknown symbol in module, or unknown parameter
rmmod: cannot unload 'ulpcmlink': unknown symbol in module, or unknown parameter
rmmod: cannot unload 'userman': unknown symbol in module, or unknown parameter
rmmod: cannot unload 'userman_mod': unknown symbol in module, or unknown parameter
rmmod: cannot unload 'ubik2': unknown symbol in module, or unknown parameter
rmmod: cannot unload 'tiatm': unknown symbol in module, or unknown parameter
    1 root      1584 S    init
 3230 root      1572 S    /bin/sh -c /var/post_install
 3231 root      1584 S    /bin/sh /var/post_install
 3462 root      1596 R    /bin/sh /etc/init.d/rc.dsl.sh stop
 3496 root      1572 R    ps
dsl_ar9               300672  0
usbcore               125552  1
ramzswap               16448  1
rtc_avm                 5520  0
led_modul_Fritz_Box_7320    68368  2
still running:
    1 root      1584 S    init
 3517 root      1572 R    ps
dsl_ar9               300672  0
usbcore               125552  1
ramzswap               16448  1
rtc_avm                 5520  0
FLASH_UPDATE
[flash_update] file /var/tmp/kernel.image address 0x10020000 len 15466496 crc 0x1
[flash_read_file] filelen 12846813
[flash_read_file] read 12846805 crc 0x25ED20D7 0x25ED20D7
Also, ich hatte bei der vorherigen Version Probleme, nach dem Update blinkte die Info-LED nur noch rot, habe Recovery gemacht und erst mal die alte Version eingespielt. Nun das freetz-Verzeichnis geleert und vollkommen von vorne angefangen mit Callmonitor und Samba, und es scheint zu gehen (bis auf den Patch chronyd, den ich vergessen habe und gerade noch mal neu bauen lasse). Ich hatte vorher das Original-Update (.91) über das AVM-Interface online eingespielt, nur noch als Hinweis, bin also von freetz .89 über Original-AVM .91 auf freetz .91 devel 6562 gegangen.
Edit: mit Patch hat funktioniert auch.
@sven
Es geht hier um die 7320 und nicht um die 7390...
Oliver
:blonk:Ach, ich hab die Zahlen irgendwie falsch gelesen, sorry. Kommt davon wenn man den ganzen Tag im Quelltext und Datenbanken rumfummelt.
