Hello,
I hope you can help me regarding 2N EasyGate IP.
for some unknown reason, the device has a very weak 4G signal. signal strength is only 2 LEDs of 4. while on a smartphone the signal is of normal strength 100%.
also if for example I move the device 1 meter in any direction, very often it immediately loses the 4g signal. and sometimes it won't connect again.
Please tell me what could be a problem ? What I can try ? could it be a hardware problem ?
Thank you
Thank you
