JFritz 2 Google Contacts (Convert JFritz Contacts for Google)
Giulioski
14 Okt 2009
ENGLISH
A program for FritzBox to export the JFritz contacts so that you can import them into Google Address Book.
Google address books can also be read with a DECT phone or even with a VOIP phone.
I use e.g. Zoiper on my cell phone and PC connected to the FritzBox.
ITALIANO
Un programma per FritzBox per esportare i contatti di JFritz in modo da poterli importare nella Rubrica di Google.
Le rubriche di Google possono essere lette anche con un telefono DECT o un telefono VOIP.
Io uso ad esempio Zoiper sul mio cellulare e sul PC collegato al FritzBox.
FRANÇAIS
Un logiciel pour FritzBox pour exporter les contacts JFritz afin de pouvoir les importer dans le carnet d'adresses Google.
Les carnets d'adresses Google peuvent aussi être lus avec un téléphone DECT ou un téléphone VOIP.
J'utilise par exemple Zoiper sur mon téléphone portable et mon PC connecté au FritzBox.
DEUTSCH
Ein Programm für FritzBox um die JFritz-Kontakte exportieren zu koennen so dass man diese in Google Adressbuch importieren kann.
Google Adressbücher können auch mit einem DECT phone oder auch mit einem VOIP-Phone gelesen.
Ich benutzte z.B. Zoiper auf'm Handy und PC das mit der FritzBox verbunden ist.
LINK PER WINDOWS & SOURCECODE
https://www.centromedia.com/download/JFritz_2_Google_Contacts.zip
Version History:
2024-01-04 Compatible with New Google CSV format 2024, added support for email and all phone numbers
2023-07-07 Added step to order alphabetically before converting
2023-06-23 Added alert if Google's limit is exceeded
2023-06-10 Add button to open Google Contacts webpage after conversion
2023-04-20 Updated websites and fixed compiler bug
2023-04-10 Sourcode update to latest version of Xojo API2. Source code is in the zip archive.
2023-03-15 some UI fix
2023-03-14 Double spaces and empty space at begin and end of strings can be cleaned
2023-02-10 First basic versione
2024-01-07 Compatible with New Google CSV format 2024, added support for email and all phone numbers
Atze2701
