diff -d make/sudo/Config.in /home/freetz/sudo.old/Config.in
2c2
< bool "sudo 1.7.10 (binary only)"
> bool "sudo 1.7.4p4 (binaries only)"
Only in /home/freetz/sudo.old: Config.in.orig
Only in /home/freetz/sudo.old: Config.in.rej
Only in /home/freetz/sudo.old: external.files.orig
Only in /home/freetz/sudo.old: external.files.rej
diff -d make/sudo/external.in /home/freetz/sudo.old/external.in
4c4
< default y
> default n
Common subdirectories: make/sudo/files and /home/freetz/sudo.old/files
diff -d make/sudo/sudo.mk /home/freetz/sudo.old/sudo.mk
1c1
< $(call PKG_INIT_BIN, 1.7.10p8)
> $(call PKG_INIT_BIN, 1.7.4p4)
3c3
< #$(PKG)_SOURCE_MD5:=d9002b306986fa7735ee6aa003624885
> $(PKG)_SOURCE_MD5:=55d9906535d70a1de347cd3d3550ee87
5,7c5,7
< $(PKG)_BINARIY:=$(pkg)
< $(PKG)_BINARY_BUILD_DIR:=$($(PKG)_DIR)/$(pkg)
< $(PKG)_BINARY_TARGET_DIR:=$($(PKG)_DEST_DIR)/usr/bin/$(pkg)
> $(PKG)_BINARIES:=$(pkg) vi$(pkg) $(pkg)replay
> $(PKG)_BINARIES_BUILD_DIR:=$($(PKG)_BINARIES:%=$($(PKG)_DIR)/%)
> $(PKG)_BINARIES_TARGET_DIR:=$($(PKG)_BINARIES:%=$($(PKG)_DEST_DIR)/usr/bin/%)
15,18c15
< $(PKG)_CONFIGURE_OPTIONS += --with-editor=/bin/nano \
< --without-lecture \
< --without-pam \
< --without-sendmail \
> $(PKG)_CONFIGURE_OPTIONS += --without-pam \
20,22c17,19
< --disable-root-mailer \
< --disable-root-sudo \
< --sysconfdir=/mod/etc \
> --with-timedir=/var/mod/usr/lib \
> --with-editor=/bin/vi \
> --without-lecture \
25a23
> $(PKG)_CONFIGURE_ENV += sudo_cv_func_unsetenv_void=no
31,32c29,30
< $($(PKG)_BINARY_BUILD_DIR) $($(PKG)_LIBS_BUILD_DIR): $($(PKG)_DIR)/.configured
< $(SUBMAKE1) -C $(SUDO_DIR)
> $($(PKG)_BINARIES_BUILD_DIR) $($(PKG)_LIBS_BUILD_DIR): $($(PKG)_DIR)/.configured
34c32
< $($(PKG)_BINARY_TARGET_DIR): $($(PKG)_DEST_DIR)/usr/bin/%: $($(PKG)_DIR)/%
> $($(PKG)_BINARIES_TARGET_DIR): $($(PKG)_DEST_DIR)/usr/bin/%: $($(PKG)_DIR)/%
36d33
< chmod +s $(SUDO_BINARY_TARGET_DIR)
43c40
< $(pkg)-precompiled: $($(PKG)_BINARY_TARGET_DIR) $($(PKG)_LIBS_TARGET_DIR)
> $(pkg)-precompiled: $($(PKG)_BINARIES_TARGET_DIR) $($(PKG)_LIBS_TARGET_DIR)
Only in /home/freetz/sudo.old: sudo.mk.orig
Only in /home/freetz/sudo.old: sudo.mk.rej
