[HowTo] ZABBIX Agentd für Freetz
Diese Zeile war schon da, weil ich 1.4 schon hatte.
Wie bekomme ich 1.8?
Aus dem trac:
http://freetz.org/raw-attachment/ticket/1883/freetz-zabbix_agentd-1.8.15.tgz
# tar -tvf freetz-zabbix_agentd-1.8.15.tgz
drwxr-xr-x marc/marc         0 2012-09-01 20:23 make/zabbix_agentd/
drwxr-xr-x marc/marc         0 2012-07-08 06:55 make/zabbix_agentd/patches/
-rw-r--r-- marc/marc      1265 2012-07-08 06:05 make/zabbix_agentd/patches/002-net.c-dn_skipname.patch
-rw-r--r-- marc/marc       955 2012-07-08 06:00 make/zabbix_agentd/patches/001-configure-long_long.patch
-rw-r--r-- marc/marc       567 2012-07-08 06:55 make/zabbix_agentd/patches/003-cpu.c-getloadavg.patch
-rw-r--r-- marc/marc       975 2012-09-01 20:23 make/zabbix_agentd/zabbix_agentd.mk
drwxr-xr-x marc/marc         0 2011-02-27 10:56 make/zabbix_agentd/files/
drwxr-xr-x marc/marc         0 2011-02-27 10:56 make/zabbix_agentd/files/root/
drwxr-xr-x marc/marc         0 2011-02-27 10:56 make/zabbix_agentd/files/root/usr/
drwxr-xr-x marc/marc         0 2011-02-27 10:56 make/zabbix_agentd/files/root/usr/lib/
drwxr-xr-x marc/marc         0 2012-07-15 17:18 make/zabbix_agentd/files/root/usr/lib/cgi-bin/
-rwxr-xr-x marc/marc      9327 2012-07-09 10:25 make/zabbix_agentd/files/root/usr/lib/cgi-bin/zabbix_agentd.cgi
drwxr-xr-x marc/marc         0 2011-02-27 10:56 make/zabbix_agentd/files/root/etc/
drwxr-xr-x marc/marc         0 2012-07-14 14:00 make/zabbix_agentd/files/root/etc/default.zabbix_agentd/
-rw-r--r-- marc/marc       828 2011-02-26 09:25 make/zabbix_agentd/files/root/etc/default.zabbix_agentd/zbx_agentd_user_parameters.examples
-rwxr-xr-x marc/marc      2630 2012-07-08 14:00 make/zabbix_agentd/files/root/etc/default.zabbix_agentd/zabbix_agentd_conf
-rw-r--r-- marc/marc       460 2012-07-13 20:44 make/zabbix_agentd/files/root/etc/default.zabbix_agentd/zbx_agentd_user_parameters.def
-rw-r--r-- marc/marc      1094 2012-07-08 14:06 make/zabbix_agentd/files/root/etc/default.zabbix_agentd/zabbix_agentd.cfg
drwxr-xr-x marc/marc         0 2012-07-14 08:08 make/zabbix_agentd/files/root/etc/init.d/
-rwxr-xr-x marc/marc      1331 2012-07-09 08:21 make/zabbix_agentd/files/root/etc/init.d/rc.zabbix_agentd
-rw-r--r-- marc/marc      1556 2012-09-01 20:16 make/zabbix_agentd/Config.in
-rw-r--r-- marc/marc        80 2011-02-26 05:57 make/zabbix_agentd/Makefile.in
Habe Freetz in der aktuellen Version auf einer 7330 installiert und bei Menuconfig Zabbix mit ausgewählt.
Jedoch bekomme ich die Seiten im Webinterface (Freetz) nicht angezeigt.
Was mache ich falsch?
Muß ich noch ein Modul per Hand rein kopieren?
Hat den wirklich keiner eine Idee für mich?
In freetz ist (nur) ein "binary only" zabbix Paket, ohne GUI.
Hi MaxMuster,
danke für deine Antwort, das erklärt ein wenig was :)
Trotzdem irritierend das im Ticket auf freetz.org eine GUI in den Screens hinterlegt ist.
Gibt es diesen Paket mit GUI auch für Zbx 2.2?
Falls nicht, wo kann ich die configs rebootfest in der Freetz binary hinterlegen?
Das Ticket enthält eine Erweiterung für Freetz.
Du kannst versuchen, sie zusätzlich zu installieren. Zumindest zum Zeitpunkt der Erstellung sollte es gepasst haben.
@Ralfriedl
Installiere bitte ein Zabbix Server!
Im Augenblick habe ich ungefähr 40 AVM-geräte im Monitoring und darauf läuft ein Zabbix Agent.
Ich sehe die ADSL geschwindigkeit, SNR und auch wieviel dieser ADSL genutzt wird.
Auch sehe ich ob alle SIP-clients funktionieren.
Probiere Es!
Ich habe scripts geschrieben womit man dieser Daten bekommen kannst...
Auch bitte sudo hinzufugen bei standard Freetz
Waldi2000
