Wlan erwacht nichtmehr aus Nachtschaltung
Verzweifelt
26 Feb 2007
Hallo ich habe hier leider das Problem das mein Wlan nichtmehr aus der Nachtschaltung erwacht (23:00-8:00)
Hier ein auszug aus der syslogd
30 22:47:36 fritz user.warn kernel: [speedup] -> 62.5 MHz
[B]Sep 30 23:00:44 fritz user.info kernel: lan: port 2(tiwlan0) entering disabled state
Sep 30 23:00:44 fritz user.info kernel: lan: port 3(wdsup0) entering disabled state
Sep 30 23:00:44 fritz user.info kernel: lan: port 4(wdsdw0) entering disabled state
Sep 30 23:00:44 fritz user.info kernel: lan: port 5(wdsdw1) entering disabled state
Sep 30 23:00:44 fritz user.info kernel: lan: port 6(wdsdw2) entering disabled state
Sep 30 23:00:44 fritz user.info kernel: lan: port 7(wdsdw3) entering disabled state
Sep 30 23:00:46 fritz user.warn kernel: [speedup] -> 125 MHz
Sep 30 23:00:46 fritz user.err kernel: Trying to free IRQ79
Sep 30 23:00:46 fritz user.info kernel: device tiwlan0 left promiscuous mode
Sep 30 23:00:46 fritz user.info kernel: lan: port 2(tiwlan0) entering disabled state
Sep 30 23:00:47 fritz user.info kernel: device wdsup0 left promiscuous mode
Sep 30 23:00:47 fritz user.info kernel: lan: port 3(wdsup0) entering disabled state
Sep 30 23:00:47 fritz user.info kernel: device wdsdw0 left promiscuous mode
Sep 30 23:00:47 fritz user.info kernel: lan: port 4(wdsdw0) entering disabled state
Sep 30 23:00:47 fritz user.info kernel: device wdsdw1 left promiscuous mode
Sep 30 23:00:47 fritz user.info kernel: lan: port 5(wdsdw1) entering disabled state
Sep 30 23:00:47 fritz user.info kernel: device wdsdw2 left promiscuous mode
Sep 30 23:00:47 fritz user.info kernel: lan: port 6(wdsdw2) entering disabled state
Sep 30 23:00:47 fritz user.info kernel: device wdsdw3 left promiscuous mode
Sep 30 23:00:47 fritz user.info kernel: lan: port 7(wdsdw3) entering disabled state
Sep 30 23:01:53 fritz user.warn kernel: [speedup] -> 62.5 MHz[/B]
Sep 30 23:14:44 fritz user.warn kernel: [speedup] -> 125 MHz
Sep 30 23:15:46 fritz user.warn kernel: [speedup] -> 62.5 MHz
Oct  1 00:02:50 fritz user.info kernel: lan: port 1(eth0) entering disabled state
Oct  1 00:02:52 fritz user.info kernel: lan: port 1(eth0) entering learning state
Oct  1 00:02:52 fritz user.info kernel: lan: topology change detected, propagating
Oct  1 00:02:52 fritz user.info kernel: lan: port 1(eth0) entering forwarding state
Oct  1 00:04:13 fritz user.err ctlmgr[448]: pushmail: no user config
Oct  1 00:04:26 fritz user.warn kernel: [speedup] -> 125 MHz
Oct  1 00:05:32 fritz user.warn kernel: [speedup] -> 62.5 MHz
Oct  1 03:38:06 fritz user.info kernel: kdsld: Channel 0 closed (physical)
Oct  1 03:38:06 fritz user.info kernel: kdsld: internet: disconnected
Oct  1 03:38:06 fritz user.debug kernel: mcfw: forward disabled ()
Oct  1 03:38:06 fritz user.info kernel: kdsld: PPP led: off (value=0)
Oct  1 03:38:06 fritz user.info kernel: kdsld: Channel 0 up (physical outgoing)
Oct  1 03:38:07 fritz user.info kernel: kdsld: internet: set_snd_ipaddr:
Oct  1 03:38:07 fritz user.info kernel: kdsld: internet: connected
Oct  1 03:38:07 fritz user.debug kernel: mcfw: forward enabled (, vlan 0, pppoe 12036)
Oct  1 03:38:07 fritz user.info kernel: kdsld: PPP led: on (value=1)
Oct  1 07:40:47 fritz user.warn kernel: [speedup] -> 125 MHz
[B]Oct  1 07:44:36 fritz user.warn kernel: [speedup] -> 62.5 MHz
Oct  1 08:00:07 fritz user.warn kernel: [speedup] -> 125 MHz
Oct  1 08:01:14 fritz user.warn kernel: [speedup] -> 62.5 MHz
Oct  1 10:37:24 fritz user.warn kernel: [speedup] -> 125 MHz[/B]
Oct  1 10:44:12 fritz user.warn kernel: [speedup] -> 62.5 MHz
Oct  1 14:45:27 fritz user.warn kernel: [speedup] -> 125 MHz
Oct  1 14:50:40 fritz user.warn kernel: [speedup] -> 62.5 MHz
weis jemand woran es liegen könnte?
ach ja das orginalwb-if der FB behauptet wlan sei online und auch aus der nachtschaltung aktiviert worden (pünktlich...)
Wlanled an der box blinkt aber und es ist kein Netzwerk aktiv.
[Edit wichard:
-Tags eingefügt][/COLOR][/I]
Weis den niemand wie sicher der wakeup impuls auslösen lässt? welches Skript wäre dafür verantwortlich ?
Das müsste doch jemand wissen?! DS ?
schon mal die Standardsachen probiert?
- Firmware aktualisieren
- Box auf die Werkseinstellungen zurücksetzten (Daten von Hand neu eingaben, nicht die Sicherung zurückspielen)
- wenn alle Sticke reißen das Recover-Image zurückspielen -> ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7170/x_misc/deutsch
Eventuell hängt das Problem auch mit deinen Modifikationen an der Box zusammen.
