##### BEGIN SECTION PCP
/var/tmp/pcpserver
netlink 192.168.178.1
netlink 2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f
ctlmgr[933] dump (Sun Jan 2 19:59:51 2022)
CTX AF_INET max_lifetime 600 [192.168.178.1] :0
MAP TCP [192.168.178.1]:54889 [192.168.178.1]:54889, lifetime 120 secs, renew in 35 secs
wanted [0.0.0.0]:54889
uniqid 0
used_ifacenr 0
desc "argo.TCP.54889"
nonce 17e507b0ffb994b97820c3eb active
wanted_lifetime 184549375 lifetime 120
age 390 lasttime 33 endtime 35 nsent 0
last actions: req 33 reply 33 (secs ago)
MAP TCP [192.168.178.1]:47699 [192.168.178.1]:47699, lifetime 120 secs, renew in 20 secs
wanted [0.0.0.0]:47699
uniqid 0, cfgflags ignore_proxy_errors
used_ifacenr 0
desc "https.TCP.2.47699"
nonce f9371655653d304bab327b38 active
age 390 lasttime 49 endtime 20 nsent 0
last actions: req 49 reply 49 (secs ago)
MAP TCP [192.168.178.1]:52134 [192.0.0.2]:52134, lifetime 120 secs, renew in 35 secs
wanted [0.0.0.0]:52134
uniqid 0
ifacenr 0, used_ifacenr 0
desc "tr069.TCP.52134"
nonce 065fa2ae01cfe218944ea542 active
age 390 lasttime 32 endtime 35 nsent 0
last actions: req 32 reply 32 (secs ago)
CTX AF_INET6 max_lifetime 600 [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f] :0
MAP TCP [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:54889 [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:54889, lifetime 120 secs, renew in 40 secs
wanted [::]:54889
uniqid 0
use_ifaceaddr, used_ifacenr 0
nonce 4468023fc606a26c42a5c031 active
age 390 lasttime 32 endtime 40 nsent 0
MAP TCP [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:47699 [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:47699, lifetime 120 secs, renew in 9 secs
wanted [::]:47699
nonce e8956f97d1b866e586fea0c4 active
age 390 lasttime 61 endtime 9 nsent 0
last actions: req 61 reply 61 (secs ago)
MAP TCP [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:52134 [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:52134, lifetime 120 secs, renew in 50 secs
wanted [::]:52134
uniqid 0
nonce 3c731dbee748e2ce8d897d38 active
age 390 lasttime 12 endtime 50 nsent 0
last actions: req 12 reply 12 (secs ago)
dsld[1079] dump (Sun Jan 2 19:59:51 2022)
Groups: IGD 0v4/exposed/1381 0v6/[LOCAL-wan] 0v6/[LOCAL-lan]
0v4/exposed/1384 0v6/linux/1381 0v4/iface-normal
0v4/normal/1381 0v4/voip 0v4/normal/1384 0v4/pm 0v4/normal
0v4/in-nat 0v4/out-nat 0v6/wan/VOIP 0v6/lan/VOIP
MAP TCP [192.168.178.115]:80 [192.168.178.115]:80, lifetime 120 secs, renew in 22 secs
wanted [0.0.0.0]:80
uniqid 1381, cfgflags ignore_proxy_errors
used_ifacenr 0
group "0v4/normal/1381" desc "HTTP-Server"
nonce 8bf25177b89adbcded985b13 active
age 281547 lasttime 43 endtime 22 nsent 0
last actions: req 43 reply 43 (secs ago)
MAP TCP [192.168.178.115]:443 [192.168.178.115]:443, lifetime 120 secs, renew in 13 secs
wanted [0.0.0.0]:443
used_ifacenr 0
group "0v4/normal/1381" desc "HTTPS-Server"
nonce c391d0c85a9b435569296d6d active
age 281547 lasttime 52 endtime 13 nsent 0
last actions: req 52 reply 52 (secs ago)
MAP TCP [192.168.178.115]:25565 [192.168.178.115]:25565, lifetime 120 secs, renew in 59 secs
wanted [0.0.0.0]:25565
used_ifacenr 0
group "0v4/normal/1381" desc "Minecraft"
nonce 578685e390db52a193f7a8ad active
age 281547 lasttime 1 endtime 59 nsent 0
last actions: req 1 reply 1 (secs ago)
MAP UDP [192.168.178.115]:9 [192.168.178.115]:9, lifetime 120 secs, renew in 39 secs
wanted [0.0.0.0]:9
used_ifacenr 0
group "0v4/normal/1381" desc "WoL"
nonce e69521039a9524b8a48085f6 active
age 281547 lasttime 23 endtime 39 nsent 0
last actions: req 23 reply 23 (secs ago)
MAP UDP [192.168.178.115]:7 [192.168.178.115]:7, lifetime 120 secs, renew in 2 secs
wanted [0.0.0.0]:7
used_ifacenr 0
nonce e50a73bc1b6465b5b4bfa824 active
age 281547 lasttime 69 endtime 2 nsent 0
last actions: req 69 reply 69 (secs ago)
MAP UDP [192.168.178.1]:5060 [192.168.178.1]:5060, lifetime 120 secs, renew in 41 secs
wanted [0.0.0.0]:5060
used_ifacenr 0
group "0v4/voip" desc "VOIP"
nonce 648cd8c64925a93ae3c6982a active
age 281543 lasttime 31 endtime 41 nsent 0
last actions: req 31 reply 31 (secs ago)
MAP TCP [192.168.178.1]:5060 [192.168.178.1]:5060, lifetime 120 secs, renew in 13 secs
used_ifacenr 0
nonce e1e124667b3ea51a2a7678ab active
age 281543 lasttime 52 endtime 13 nsent 0
MAP UDP [192.168.178.1]:7078 [192.168.178.1]:7078, lifetime 120 secs, renew in 6 secs
wanted [0.0.0.0]:7078
used_ifacenr 0
nonce fbbb8bcc9f3fcaeb63791d13 active
port set: wanted 20p got 20p (7078)
age 281543 lasttime 62 endtime 6 nsent 0
last actions: req 62 reply 62 (secs ago)
MAP UDP [192.168.178.115]:40407 [192.168.178.115]:40407, lifetime 120 secs, renew in 14 secs
wanted [0.0.0.0]:40407
used_ifacenr 0
group "0v4/normal/1381" desc "WakeUp"
nonce 3047c7123d9074f4bc1986fe active
age 245666 lasttime 49 endtime 14 nsent 0
MAP UDP [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:5060 [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:5060, lifetime 120 secs, renew in 28 secs
wanted [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:5060
used_ifacenr 0
group "0v6/wan/VOIP" desc "SIP"
nonce 9d290edb787bfc548c494a8d active
age 60323 lasttime 39 endtime 28 nsent 0
last actions: req 39 reply 39 (secs ago)
MAP TCP [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:5060 [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:5060, lifetime 120 secs, renew in 55 secs
used_ifacenr 0
nonce e60ba87880481d9b99d25b90 active
age 60323 lasttime 18 endtime 55 nsent 0
last actions: req 18 reply 18 (secs ago)
MAP UDP [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:7078 [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:7078, lifetime 120 secs, renew in 38 secs
wanted [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:7078
used_ifacenr 0
group "0v6/wan/VOIP" desc "RTP"
nonce ed6bcdc17fc44d64e7058b8b active
age 60323 lasttime 35 endtime 38 nsent 0
last actions: req 35 reply 35 (secs ago)
MAP ICMPv6 [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:128 [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:128, lifetime 120 secs, renew in 6 secs
wanted [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:128
used_ifacenr 0
group "0v6/linux/1381" desc "Ping linux"
nonce 86f607f364ca1d65dc218fbe active
age 60323 lasttime 56 endtime 6 nsent 0
last actions: req 56 reply 56 (secs ago)
MAP TCP [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:80 [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:80, lifetime 120 secs, renew in 25 secs
wanted [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:80
used_ifacenr 0
group "0v6/linux/1381" desc "HTTP-Server"
nonce 9c281a49c84978eff87d863c active
age 60323 lasttime 41 endtime 25 nsent 0
last actions: req 41 reply 41 (secs ago)
MAP TCP [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:443 [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:443, lifetime 120 secs, renew in 36 secs
wanted [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:443
used_ifacenr 0
group "0v6/linux/1381" desc "HTTPS-Server"
nonce 726f9aa9db7cb5cb4d0bd84b active
age 60323 lasttime 28 endtime 36 nsent 0
last actions: req 28 reply 28 (secs ago)
MAP TCP [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:25565 [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:25565, lifetime 120 secs, renew in 29 secs
wanted [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:25565
used_ifacenr 0
group "0v6/linux/1381" desc "Minecraft"
nonce 9aa76eafc8997afda110c366 active
age 60323 lasttime 43 endtime 29 nsent 0
MAP UDP [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:9 [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:9, lifetime 120 secs, renew in 4 secs
wanted [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:9
used_ifacenr 0
group "0v6/linux/1381" desc "WoL"
nonce 56436074db4d8d4ff549859a active
age 60323 lasttime 58 endtime 4 nsent 0
last actions: req 58 reply 58 (secs ago)
MAP UDP [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:7 [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:7, lifetime 120 secs, renew in 5 secs
wanted [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:7
used_ifacenr 0
nonce 64a4e18d8bf9dcd7ad62af42 active
age 60323 lasttime 67 endtime 5 nsent 0
last actions: req 67 reply 67 (secs ago)
MAP UDP [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:40407 [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:40407, lifetime 120 secs, renew in 50 secs
wanted [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:40407
used_ifacenr 0
group "0v6/linux/1381" desc "WakeUp"
nonce b271dc2c74181ee7deeea4bf active
age 60323 lasttime 20 endtime 50 nsent 0
last actions: req 20 reply 20 (secs ago)
MAP UDP [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:5060 [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:5060, lifetime 120 secs, renew in 16 secs
wanted [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:5060
used_ifacenr 0
group "0v6/lan/VOIP" desc "SIP"
nonce 388c04a9d0d747e5edc53582 active
age 60323 lasttime 57 endtime 16 nsent 0
last actions: req 57 reply 57 (secs ago)
MAP TCP [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:5060 [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:5060, lifetime 120 secs, renew in 66 secs
used_ifacenr 0
nonce b82bc7c4db0f2107df2d6e75 active
age 60323 lasttime 7 endtime 66 nsent 0
last actions: req 7 reply 7 (secs ago)
MAP UDP [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:7078 [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:7078, lifetime 120 secs, renew in 1 secs
wanted [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:7078
used_ifacenr 0
group "0v6/lan/VOIP" desc "RTP"
nonce cf64cd0a4c1e500318253ef1 active
age 60323 lasttime 62 endtime 1 nsent 0
multid[963] dump (Sun Jan 2 19:59:51 2022)
Groups: prefixes IGDPROBE
MAP TCP [192.168.178.1]:9 [192.0.0.2]:9, lifetime 120 secs, renew in 53 secs
wanted [0.0.0.0]:0
uniqid 0
group "IGDPROBE" desc "IGDPROBE4"
nonce 8e5d24bef712a03f99ff49f0 active
<= [192.0.0.1]/128 port 9
filter version: wanted 1 sent 1 installed 1
age 281549 lasttime 12 endtime 53 nsent 0
pcpd[1058] dump (Sun Jan 2 19:59:51 2022)
CTX AF_INET max_lifetime 600 [192.168.178.1] :0 proxy
CTX AF_INET6 max_lifetime 600 [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f] :0 proxy
internet v4
-------- pcp44 ----------------------------------------
MAP TCP [192.168.178.1]:5060 [192.168.178.1]:5060 use 1, lifetime 120 secs, expire in 68 secs
desc "VOIP"
wanted_lifetime 120 lifetime 120
pid 1073 caddr [192.168.178.1]
MAP TCP [192.0.0.2]:9 [192.0.0.2]:9 use 1, lifetime 120 secs, expire in 108 secs
wanted [0.0.0.0]:9
uniqid 0
desc "IGDPROBE4"
filter version 1
pid 963 caddr [192.168.178.1]
MAP TCP [192.168.178.115]:25565 [192.168.178.115]:25565 use 1, lifetime 120 secs, expire in 119 secs
desc "Minecraft"
MAP TCP [192.168.178.115]:443 [192.168.178.115]:443 use 1, lifetime 120 secs, expire in 68 secs
desc "HTTPS-Server"
MAP UDP [192.168.178.1]:5060 [192.168.178.1]:5060 use 1, lifetime 120 secs, expire in 89 secs
desc "VOIP"
MAP TCP [192.168.178.1]:54889 [192.168.178.1]:54889 use 1, lifetime 120 secs, expire in 87 secs
uniqid 0
pid 933 caddr [192.168.178.1]
MAP TCP [192.0.0.2]:52134 [192.0.0.2]:52134 use 1, lifetime 120 secs, expire in 88 secs
uniqid 0
MAP UDP [192.168.178.115]:9 [192.168.178.115]:9 use 1, lifetime 120 secs, expire in 97 secs
wanted [0.0.0.0]:9
desc "WoL"
MAP UDP [192.168.178.115]:40407 [192.168.178.115]:40407 use 1, lifetime 120 secs, expire in 71 secs
desc "WakeUp"
MAP TCP [192.168.178.1]:47699 [192.168.178.1]:47699 use 1, lifetime 120 secs, expire in 71 secs
MAP UDP [192.168.178.1]:7078 [192.168.178.1]:7078 use 1, lifetime 120 secs, expire in 58 secs
desc "VOIP"
port set: 20p
MAP TCP [192.168.178.115]:80 [192.168.178.115]:80 use 1, lifetime 120 secs, expire in 77 secs
wanted [0.0.0.0]:80
desc "HTTP-Server"
MAP UDP [192.168.178.115]:7 [192.168.178.115]:7 use 1, lifetime 120 secs, expire in 51 secs
wanted [0.0.0.0]:7
desc "WoL"
-------- pcpitems -------------------------------------
-------- pcp map counter ------------------------------
renew_network_failure : 30
renew_ok : 53442
new_network_failure : 170
new_local : 50
-------- pcp peer counter -----------------------------
internet v6
-------- pcp66 ----------------------------------------
MAP TCP [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:5060 [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:5060 use 1, lifetime 120 secs, expire in 113 secs
desc "SIP"
pid 1073 caddr [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]
MAP TCP [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:5060 [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:5060 use 1, lifetime 120 secs, expire in 102 secs
uniqid 0, cfgflags ignore_proxy_errors iaddr_is_ifaceaddr
desc "SIP"
MAP UDP [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:5060 [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:5060 use 1, lifetime 120 secs, expire in 81 secs
desc "SIP"
MAP UDP [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:5060 [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:5060 use 1, lifetime 120 secs, expire in 63 secs
desc "SIP"
MAP UDP [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:7 [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:7 use 1, lifetime 120 secs, expire in 53 secs
desc "WoL"
MAP TCP [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:80 [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:80 use 1, lifetime 120 secs, expire in 79 secs
desc "HTTP-Server"
MAP UDP [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:9 [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:9 use 1, lifetime 120 secs, expire in 62 secs
desc "WoL"
MAP UDP [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:40407 [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:40407 use 1, lifetime 120 secs, expire in 100 secs
desc "WakeUp"
MAP TCP [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:54889 [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:54889 use 1, lifetime 120 secs, expire in 88 secs
wanted [::]:54889
uniqid 0, cfgflags iaddr_is_ifaceaddr
pid 933 caddr [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]
MAP TCP [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:52134 [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:52134 use 1, lifetime 120 secs, expire in 108 secs
wanted [::]:52134
MAP TCP [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:25565 [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:25565 use 1, lifetime 120 secs, expire in 77 secs
desc "Minecraft"
MAP ICMPv6 [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:128 [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:128 use 1, lifetime 120 secs, expire in 64 secs
desc "Ping linux"
MAP UDP [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:7078 [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:7078 use 1, lifetime 120 secs, expire in 58 secs
desc "RTP"
port set: 20p
MAP TCP [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:47699 [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:47699 use 1, lifetime 120 secs, expire in 59 secs
wanted [::]:47699
MAP TCP [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:443 [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:443 use 1, lifetime 120 secs, expire in 92 secs
desc "HTTPS-Server"
MAP UDP [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:7078 [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:7078 use 1, lifetime 120 secs, expire in 85 secs
desc "RTP"
port set: 20p
nonce_neq_ok : 18
renew_network_failure : 50
renew_ok : 65979
new_network_failure : 212
new_wrong_prefix : 23
new_local : 139
2022-01-02 03:14:22.301 - MAP complete FORW UDP [2001:16b8:4624:7900:dabb:c1ff:fe63:2625]:7 iface 0 "WoL" - error (network failure)
2022-01-02 03:14:22.302 - MAP complete FORW UDP [2001:16b8:4624:7900:dabb:c1ff:fe63:2625]:40407 iface 0 "WakeUp" - error (network failure)
2022-01-02 03:14:22.303 - MAP complete VOIP UDP [2001:16b8:4624:7900:3ea6:2fff:fe36:9f0f]:5060 iface 0 "SIP" - error (network failure)
2022-01-02 03:14:22.304 - MAP complete VOIP TCP [2001:16b8:4624:7900:3ea6:2fff:fe36:9f0f]:5060 iface 0 "SIP" - error (network failure)
2022-01-02 03:14:22.305 - MAP complete VOIP UDP [2001:16b8:4624:7900:3ea6:2fff:fe36:9f0f]:7078-7097 iface 0 "RTP" - error (network failure)
2022-01-02 03:14:28.075 - MAP complete VOIP UDP [192.168.178.1]:5060 iface 0 "VOIP" - error (network failure)
2022-01-02 03:14:28.878 - MAP complete ARGO TCP [2001:16b8:4624:7900:3ea6:2fff:fe36:9f0f]:54889 iface 0 use_ifaceaddr "argo.TCP.54889": external [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:54889
2022-01-02 03:14:28.879 - MAP complete HTTPS TCP [2001:16b8:4624:7900:3ea6:2fff:fe36:9f0f]:47699 iface 0 use_ifaceaddr "https.TCP.2.47699": external [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:47699
2022-01-02 03:14:28.879 - MAP complete TR069 TCP [2001:16b8:4624:7900:3ea6:2fff:fe36:9f0f]:55145 iface 0 "tr069.TCP.55145": external [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:55145
2022-01-02 03:14:28.883 - MAP deleted VOIP UDP [2001:16b8:4302:7fe9:3ea6:2fff:fe36:9f0c]:5060 iface 0 "SIP": external [2001:16b8:4302:7fe9:3ea6:2fff:fe36:9f0c]:5060
2022-01-02 03:14:28.883 - MAP deleted VOIP TCP [2001:16b8:4302:7fe9:3ea6:2fff:fe36:9f0c]:5060 iface 0 "SIP": external [2001:16b8:4302:7fe9:3ea6:2fff:fe36:9f0c]:5060
2022-01-02 03:14:28.883 - MAP deleted VOIP UDP [2001:16b8:4302:7fe9:3ea6:2fff:fe36:9f0c]:7078-7097 iface 0 "RTP": external [2001:16b8:4302:7fe9:3ea6:2fff:fe36:9f0c]:7078-7097p
2022-01-02 03:14:28.887 - MAP complete VOIP UDP [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:5060 iface 0 "SIP": external [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:5060
2022-01-02 03:14:28.888 - MAP complete VOIP TCP [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:5060 iface 0 "SIP": external [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:5060
2022-01-02 03:14:28.888 - MAP complete VOIP UDP [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:7078-7097 iface 0 "RTP": external [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:7078-7097p
2022-01-02 03:14:28.918 - MAP complete ARGO TCP [2001:16b8:4624:7900:3ea6:2fff:fe36:9f0f]:54889 iface 0 use_ifaceaddr "argo.TCP.54889" - error (network failure)
2022-01-02 03:14:28.919 - MAP complete TR069 TCP [2001:16b8:4624:7900:3ea6:2fff:fe36:9f0f]:55145 iface 0 "tr069.TCP.55145" - error (network failure)
2022-01-02 03:14:28.920 - MAP complete HTTPS TCP [2001:16b8:4624:7900:3ea6:2fff:fe36:9f0f]:47699 iface 0 use_ifaceaddr "https.TCP.2.47699" - error (network failure)
2022-01-02 03:14:28.920 - MAP complete VOIP TCP [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:5060 iface 0 "SIP" - error (network failure)
2022-01-02 03:14:28.921 - MAP complete VOIP UDP [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:5060 iface 0 "SIP" - error (network failure)
2022-01-02 03:14:28.921 - MAP complete ARGO TCP [2001:16b8:4624:7900:3ea6:2fff:fe36:9f0f]:54889 iface 0 use_ifaceaddr "argo.TCP.54889": external [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:54889
2022-01-02 03:14:28.922 - MAP complete VOIP UDP [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:7078-7097 iface 0 "RTP" - error (network failure)
2022-01-02 03:14:28.922 - MAP complete HTTPS TCP [2001:16b8:4624:7900:3ea6:2fff:fe36:9f0f]:47699 iface 0 use_ifaceaddr "https.TCP.2.47699": external [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:47699
2022-01-02 03:14:28.924 - MAP complete TR069 TCP [2001:16b8:4624:7900:3ea6:2fff:fe36:9f0f]:55145 iface 0 "tr069.TCP.55145": external [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:55145
2022-01-02 03:14:28.947 - MAP deleted FORW ICMPv6 [2001:16b8:4624:7900:dabb:c1ff:fe63:2625]:128 iface 0 "Ping linux": external [2001:16b8:4624:7900:dabb:c1ff:fe63:2625]:128
2022-01-02 03:14:28.947 - MAP deleted FORW TCP [2001:16b8:4624:7900:dabb:c1ff:fe63:2625]:80 iface 0 "HTTP-Server": external [2001:16b8:4624:7900:dabb:c1ff:fe63:2625]:80
2022-01-02 03:14:28.947 - MAP deleted FORW TCP [2001:16b8:4624:7900:dabb:c1ff:fe63:2625]:443 iface 0 "HTTPS-Server": external [2001:16b8:4624:7900:dabb:c1ff:fe63:2625]:443
2022-01-02 03:14:28.947 - MAP deleted FORW TCP [2001:16b8:4624:7900:dabb:c1ff:fe63:2625]:25565 iface 0 "Minecraft": external [2001:16b8:4624:7900:dabb:c1ff:fe63:2625]:25565
2022-01-02 03:14:28.947 - MAP deleted FORW UDP [2001:16b8:4624:7900:dabb:c1ff:fe63:2625]:9 iface 0 "WoL": external [2001:16b8:4624:7900:dabb:c1ff:fe63:2625]:9
2022-01-02 03:14:28.947 - MAP deleted FORW UDP [2001:16b8:4624:7900:dabb:c1ff:fe63:2625]:7 iface 0 "WoL": external [2001:16b8:4624:7900:dabb:c1ff:fe63:2625]:7
2022-01-02 03:14:28.947 - MAP deleted FORW UDP [2001:16b8:4624:7900:dabb:c1ff:fe63:2625]:40407 iface 0 "WakeUp": external [2001:16b8:4624:7900:dabb:c1ff:fe63:2625]:40407
2022-01-02 03:14:28.947 - MAP deleted VOIP UDP [2001:16b8:4624:7900:3ea6:2fff:fe36:9f0f]:5060 iface 0 "SIP": external [2001:16b8:4624:7900:3ea6:2fff:fe36:9f0f]:5060
2022-01-02 03:14:28.948 - MAP deleted VOIP TCP [2001:16b8:4624:7900:3ea6:2fff:fe36:9f0f]:5060 iface 0 "SIP": external [2001:16b8:4624:7900:3ea6:2fff:fe36:9f0f]:5060
2022-01-02 03:14:28.948 - MAP deleted VOIP UDP [2001:16b8:4624:7900:3ea6:2fff:fe36:9f0f]:7078-7097 iface 0 "RTP": external [2001:16b8:4624:7900:3ea6:2fff:fe36:9f0f]:7078-7097p
2022-01-02 03:14:28.961 - MAP complete VOIP UDP [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:5060 iface 0 "SIP": external [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:5060
2022-01-02 03:14:28.962 - MAP complete VOIP TCP [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:5060 iface 0 "SIP": external [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:5060
2022-01-02 03:14:28.964 - MAP complete VOIP UDP [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:7078-7097 iface 0 "RTP": external [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:7078-7097p
2022-01-02 03:14:28.964 - MAP complete FORW ICMPv6 [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:128 iface 0 "Ping linux": external [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:128
2022-01-02 03:14:28.965 - MAP complete FORW TCP [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:80 iface 0 "HTTP-Server": external [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:80
2022-01-02 03:14:28.966 - MAP complete FORW TCP [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:443 iface 0 "HTTPS-Server": external [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:443
2022-01-02 03:14:28.967 - MAP complete FORW TCP [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:25565 iface 0 "Minecraft": external [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:25565
2022-01-02 03:14:28.968 - MAP complete FORW UDP [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:9 iface 0 "WoL": external [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:9
2022-01-02 03:14:28.969 - MAP complete FORW UDP [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:7 iface 0 "WoL": external [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:7
2022-01-02 03:14:28.970 - MAP complete FORW UDP [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:40407 iface 0 "WakeUp": external [2001:16b8:465e:ba00:dabb:c1ff:fe63:2625]:40407
2022-01-02 03:14:28.971 - MAP complete VOIP UDP [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:5060 iface 0 "SIP": external [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:5060
2022-01-02 03:14:28.972 - MAP complete VOIP TCP [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:5060 iface 0 "SIP": external [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:5060
2022-01-02 03:14:28.973 - MAP complete VOIP UDP [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:7078-7097 iface 0 "RTP": external [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:7078-7097p
2022-01-02 03:14:28.974 - MAP complete VOIP UDP [192.168.178.1]:5060 iface 0 "VOIP": external [192.168.178.1]:5060
2022-01-02 03:14:36.661 - MAP complete TR069 TCP [192.168.178.1]:52134 iface 0 "tr069.TCP.52134": external [192.0.0.2]:52134
2022-01-02 03:14:36.663 - MAP complete TR069 TCP [2001:16b8:465e:ba00:3ea6:2fff:fe36:9f0f]:52134 iface 0 "tr069.TCP.52134": external [2001:16b8:4303:67e6:3ea6:2fff:fe36:9f0c]:52134
##### END SECTION PCP
##### END SECTION Networking
