Welchen Treiber für HFC? Probleme mit mISDN und LCR
Ja alles klar, danke auf jeden Fall für deine Hilfe :) Ich berichte dann Anfang nächster Woche, wies gelaufen ist ;)
Hat alles nichts gebracht :(
CLI Output
*CLI> console dial 015771360963
[Jul 16 15:40:20] WARNING[2123]: chan_oss.c:486 setformat: Unable to re-open DSP device /dev/dsp: No such file or directory
[Jul 16 15:40:20] -- Executing [015771360963@default:1] Dial("Console/dsp", "LCR/Ext/015771360963") in new stack
[Jul 16 15:40:20] NOTICE[2157]: chan_lcr.c:1800 lcr_request: [call=NULL ast=NULL] Received request from Asterisk. (data=Ext/015771360963)
[Jul 16 15:40:20] NOTICE[2157]: chan_lcr.c:328 alloc_call: [call=0 ast=NULL] Call instance allocated.
[Jul 16 15:40:20] NOTICE[2157]: chan_lcr.c:1902 lcr_call: [call=NULL ast=lcr/1] Received call from Asterisk.
[Jul 16 15:40:20] NOTICE[2157]: chan_lcr.c:364 send_message: [call=NULL ast=NULL] Sending (null) to socket.
[Jul 16 15:40:20] NOTICE[2136]: chan_lcr.c:1361 receive_message: [call=NULL ast=NULL] Received new ref by LCR, as requested from chan_lcr. (ref=3)
[Jul 16 15:40:20] NOTICE[2136]: chan_lcr.c:620 send_setup_to_lcr: [call=3 ast=lcr/1] Sending setup to LCR. (interface=Ext dialstring=015771360963, cid=)
[Jul 16 15:40:20] NOTICE[2136]: chan_lcr.c:364 send_message: [call=NULL ast=NULL] Sending MESSAGE_SETUP to socket.
[Jul 16 15:40:20] -- Called Ext/015771360963
[Jul 16 15:40:20] NOTICE[2123]: console_video.c:133 console_video_start: voice only, console video support not present
*CLI> [Jul 16 15:40:20] NOTICE[2136]: chan_lcr.c:1070 lcr_in_release: [call=3 ast=lcr/1] Incomming release from LCR, releasing ref. (cause=34)
[Jul 16 15:40:20] NOTICE[2136]: chan_lcr.c:1688 handle_queue: [call=0 ast=lcr/1] Sending queued HANGUP to Asterisk.
[Jul 16 15:40:20] NOTICE[2157]: chan_lcr.c:2123 lcr_hangup: [call=0 ast=lcr/1] Received hangup from Asterisk thread.
[Jul 16 15:40:20] NOTICE[2157]: chan_lcr.c:2146 lcr_hangup: [call=0 ast=lcr/1] Freeing call instance, because we have no ref AND we are requesting no ref.
[Jul 16 15:40:20] NOTICE[2157]: chan_lcr.c:302 free_call: [call=0 ast=NULL] Call instance freed.
[Jul 16 15:40:20] == Everyone is busy/congested at this time (1:0/1/0)
[Jul 16 15:40:20] -- Auto fallthrough, channel 'Console/dsp' status is 'CONGESTION'
[Jul 16 15:40:21] WARNING[2157]: chan_oss.c:486 setformat: Unable to re-open DSP device /dev/dsp: No such file or directory
[Jul 16 15:40:22] WARNING[2157]: chan_oss.c:486 setformat: Unable to re-open DSP device /dev/dsp: No such file or directory
[Jul 16 15:40:23] WARNING[2157]: chan_oss.c:486 setformat: Unable to re-open DSP device /dev/dsp: No such file or directory
[Jul 16 15:40:24] WARNING[2157]: chan_oss.c:486 setformat: Unable to re-open DSP device /dev/dsp: No such file or directory
[Jul 16 15:40:25] WARNING[2157]: chan_oss.c:486 setformat: Unable to re-open DSP device /dev/dsp: No such file or directory
[Jul 16 15:40:26] WARNING[2157]: chan_oss.c:486 setformat: Unable to re-open DSP device /dev/dsp: No such file or directory
[Jul 16 15:40:27] WARNING[2157]: chan_oss.c:486 setformat: Unable to re-open DSP device /dev/dsp: No such file or directory
[Jul 16 15:40:28] WARNING[2157]: chan_oss.c:486 setformat: Unable to re-open DSP device /dev/dsp: No such file or directory
[Jul 16 15:40:29] WARNING[2157]: chan_oss.c:486 setformat: Unable to re-open DSP device /dev/dsp: No such file or directory
[Jul 16 15:40:30] WARNING[2157]: chan_oss.c:486 setformat: Unable to re-open DSP device /dev/dsp: No such file or directory
lcradmin state zeigt mir das an:
16.07.10 15:38:09.271 EP(2): CHANNEL SELECTION (port's layer 2 is down, skipping) port 0 position 0
16.07.10 15:38:09.271 EP(2): INTERFACE (too busy) interface Ext
16.07.10 15:38:09.271 EP(2): INTERFACE (no free ports found)
16.07.10 15:40:13.689 --: REMOTE APP release app name=asterisk
16.07.10 15:40:16.011 --: REMOTE APP registers app name=asterisk
16.07.10 15:40:20.670 EP(3): CHANNEL SELECTION (found given interface) interface Ext
16.07.10 15:40:20.670 EP(3): CHANNEL SELECTION (port's layer 2 is down, skipping) port 0 position 0
16.07.10 15:40:20.670 EP(3): INTERFACE (too busy) interface Ext
16.07.10 15:40:20.670 EP(3): INTERFACE (no free ports found)
Aber auch das hier
Ext(port 0: hfc-pci.1) TE ptp l2hold use:0 L2 unkn L1 UP
Remote: asterisk
L1 UP, damit zeigt er mir ja, dass er weiß, dass eine Karte da ist und die am ISDN Netz angescchlossen ist..
Noch irgendwelche Vorschläge?
hast du tatsaechlich einen ISDN Anlagenanschluss (keinen gewoehnlichen Mehrgerateanschluss)?
Dann sollte die 'interface.conf' so aussehen:
[Ext]
extern
portnum 0
ptp
layer2hold yes
- die 2. unbenutzte Karte wuerde ich erstmal ausbauen
- ist die ISDN Leitung an beiden Enden sauber terminiert? Ich habe da frueher geschlampt und das hat die tollsten Effekte gegeben. Besonders bei Leitungslaengen > 30m.
- wenn es ein Anlagenanschluss ist darf ausser der HFC nichts sonst angeschlossen sein.
- sparkie
Morgen! Ja es ist in der Tat ein Anlagenanschluss und es sollte auch alles richtig angeschlossen sein (Layer 1 scheint ja zu funktionieren, sonst würde LCR nicht anzeigen, dass es ISDN Netz hat?!)
Der Layer 2 Eintrag scheint vielleicht hilfreich, da in den Fehlermeldungen auch irgendetwas von Layer 2 Problemen steht. Ich mache mal die entsprechenden Einträge und baue mal eine Karte aus.
Ich werde diesen Eintrag 'layer2hold yes' mal ausprobieren, blöderweise bin ich momentan noch mit anderen Sachen beschäftigt und werd das wohl erst morgen oder übermorgen hinkriegen :/
Melde mich dann
