Hi
I understand that WDS is essentially using the wireless card as both a client and a server at the same time.
can you use WDS against any primary router or do BOTH ends have to be set up to use it? i am shortly to be in an environment where i will need to use my 7270 as router etc locally but where the modem connected to adsl is quite a long way away. the modem is wifi enabled so i was hoping that I could use the 7270 in repeater mode to connect to the modem and my wireless clients at the same time. this is not strictly necessary, it would be acceptable for the 7270 to be purely in client mode too (as it's the router/ata functions that are important).
thanks
Justin
thanks
Justin
