.........(passt leider nicht alles in den Buffer von Putty)...........
Sun Sep 2 09:10:32 2007 us=490000 remote_cert_ku[i] = 0
Sun Sep 2 09:10:32 2007 us=510000 remote_cert_ku[i] = 0
Sun Sep 2 09:10:32 2007 us=520000 remote_cert_ku[i] = 0
Sun Sep 2 09:10:32 2007 us=520000 remote_cert_eku = '[UNDEF]'
Sun Sep 2 09:10:32 2007 us=520000 tls_timeout = 2
Sun Sep 2 09:10:32 2007 us=520000 renegotiate_bytes = 0
Sun Sep 2 09:10:32 2007 us=520000 renegotiate_packets = 0
Sun Sep 2 09:10:32 2007 us=520000 renegotiate_seconds = 3600
Sun Sep 2 09:10:32 2007 us=520000 handshake_window = 60
Sun Sep 2 09:10:32 2007 us=520000 transition_window = 3600
Sun Sep 2 09:10:32 2007 us=530000 single_session = DISABLED
Sun Sep 2 09:10:32 2007 us=530000 tls_exit = DISABLED
Sun Sep 2 09:10:32 2007 us=530000 tls_auth_file = '/var/tmp/client.key'
Sun Sep 2 09:10:32 2007 us=530000 pkcs11_slot_type = '[UNDEF]'
Sun Sep 2 09:10:32 2007 us=530000 pkcs11_slot = '[UNDEF]'
Sun Sep 2 09:10:32 2007 us=530000 pkcs11_id_type = '[UNDEF]'
Sun Sep 2 09:10:32 2007 us=530000 pkcs11_id = '[UNDEF]'
Sun Sep 2 09:10:32 2007 us=530000 pkcs11_pin_cache_period = -1
Sun Sep 2 09:10:32 2007 us=530000 pkcs11_protected_authentication = DISABLED
Sun Sep 2 09:10:32 2007 us=530000 pkcs11_cert_private = DISABLED
Sun Sep 2 09:10:32 2007 us=530000 server_network = 0.0.0.0
Sun Sep 2 09:10:32 2007 us=530000 server_netmask = 0.0.0.0
Sun Sep 2 09:10:32 2007 us=530000 server_bridge_ip = 0.0.0.0
Sun Sep 2 09:10:32 2007 us=530000 server_bridge_netmask = 0.0.0.0
Sun Sep 2 09:10:32 2007 us=530000 server_bridge_pool_start = 0.0.0.0
Sun Sep 2 09:10:32 2007 us=530000 server_bridge_pool_end = 0.0.0.0
Sun Sep 2 09:10:32 2007 us=530000 ifconfig_pool_defined = DISABLED
Sun Sep 2 09:10:32 2007 us=530000 ifconfig_pool_start = 0.0.0.0
Sun Sep 2 09:10:32 2007 us=530000 ifconfig_pool_end = 0.0.0.0
Sun Sep 2 09:10:32 2007 us=540000 ifconfig_pool_netmask = 0.0.0.0
Sun Sep 2 09:10:32 2007 us=540000 ifconfig_pool_persist_filename = '[UNDEF]'
Sun Sep 2 09:10:32 2007 us=540000 ifconfig_pool_persist_refresh_freq = 600
Sun Sep 2 09:10:32 2007 us=540000 n_bcast_buf = 256
Sun Sep 2 09:10:32 2007 us=540000 tcp_queue_limit = 64
Sun Sep 2 09:10:32 2007 us=540000 real_hash_size = 256
Sun Sep 2 09:10:32 2007 us=540000 virtual_hash_size = 256
Sun Sep 2 09:10:32 2007 us=540000 client_connect_script = '[UNDEF]'
Sun Sep 2 09:10:32 2007 us=540000 learn_address_script = '[UNDEF]'
Sun Sep 2 09:10:32 2007 us=540000 client_disconnect_script = '[UNDEF]'
Sun Sep 2 09:10:32 2007 us=540000 client_config_dir = '[UNDEF]'
Sun Sep 2 09:10:32 2007 us=540000 ccd_exclusive = DISABLED
Sun Sep 2 09:10:32 2007 us=540000 tmp_dir = '[UNDEF]'
Sun Sep 2 09:10:32 2007 us=540000 push_ifconfig_defined = DISABLED
Sun Sep 2 09:10:32 2007 us=540000 push_ifconfig_local = 0.0.0.0
Sun Sep 2 09:10:32 2007 us=540000 push_ifconfig_remote_netmask = 0.0.0.0
Sun Sep 2 09:10:32 2007 us=540000 enable_c2c = DISABLED
Sun Sep 2 09:10:32 2007 us=540000 duplicate_cn = DISABLED
Sun Sep 2 09:10:32 2007 us=540000 cf_max = 0
Sun Sep 2 09:10:32 2007 us=540000 cf_per = 0
Sun Sep 2 09:10:32 2007 us=540000 max_clients = 1024
Sun Sep 2 09:10:32 2007 us=550000 max_routes_per_client = 256
Sun Sep 2 09:10:32 2007 us=550000 client_cert_not_required = DISABLED
Sun Sep 2 09:10:32 2007 us=550000 username_as_common_name = DISABLED
Sun Sep 2 09:10:32 2007 us=550000 auth_user_pass_verify_script = '[UNDEF]'
Sun Sep 2 09:10:32 2007 us=550000 auth_user_pass_verify_script_via_file = DISABLED
Sun Sep 2 09:10:32 2007 us=560000 client = DISABLED
Sun Sep 2 09:10:32 2007 us=570000 pull = ENABLED
Sun Sep 2 09:10:32 2007 us=570000 auth_user_pass_file = '[UNDEF]'
Sun Sep 2 09:10:32 2007 us=580000 OpenVPN 2.1_beta8 mipsel-linux [SSL] [LZO2] built on Feb 11 2006
Sun Sep 2 09:10:32 2007 us=580000 PO_INIT maxevents=4 flags=0x00000002
Sun Sep 2 09:10:32 2007 us=600000 WARNING: file '/var/tmp/ca.key' is group or others accessible
Sun Sep 2 09:10:32 2007 us=630000 WARNING: file '/var/tmp/client.key' is group or others accessible
Sun Sep 2 09:10:32 2007 us=630000 Control Channel Authentication: using '/var/tmp/client.key' as a free-form passphrase file
Sun Sep 2 09:10:32 2007 us=640000 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Sun Sep 2 09:10:32 2007 us=640000 Outgoing Control Channel Authentication: HMAC KEY: 94e4d1b7 fd5949d5 4ec5d7db 33967a47 bbccc087
Sun Sep 2 09:10:32 2007 us=650000 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Sun Sep 2 09:10:32 2007 us=650000 Incoming Control Channel Authentication: HMAC KEY: 94e4d1b7 fd5949d5 4ec5d7db 33967a47 bbccc087
Sun Sep 2 09:10:32 2007 us=650000 LZO compression initialized
Sun Sep 2 09:10:32 2007 us=650000 MTU DYNAMIC mtu=0, flags=1, 0 -> 166
Sun Sep 2 09:10:32 2007 us=650000 PID packet_id_init seq_backtrack=64 time_backtrack=15
Sun Sep 2 09:10:32 2007 us=660000 PID packet_id_init seq_backtrack=64 time_backtrack=15
Sun Sep 2 09:10:32 2007 us=660000 Control Channel MTU parms [ L:1558 D:166 EF:66 EB:0 ET:0 EL:0 ]
Sun Sep 2 09:10:32 2007 us=660000 MTU DYNAMIC mtu=1450, flags=2, 1558 -> 1450
Sun Sep 2 09:10:32 2007 us=660000 REMOTE_LIST len=1 current=0
Sun Sep 2 09:10:32 2007 us=660000 [0] wirtz.homedns.org:1194
Sun Sep 2 09:10:39 2007 us=200000 RESOLVE_REMOTE flags=0x0001 phase=1 rrs=0 sig=-1 status=1
Sun Sep 2 09:10:39 2007 us=200000 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
Sun Sep 2 09:10:39 2007 us=210000 Local Options String: 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client'
Sun Sep 2 09:10:39 2007 us=210000 Expected Remote Options String: 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-server'
Sun Sep 2 09:10:39 2007 us=210000 Local Options hash (VER=V4): '5b243d85'
Sun Sep 2 09:10:39 2007 us=210000 Expected Remote Options hash (VER=V4): '0b024030'
Sun Sep 2 09:10:39 2007 us=210000 Socket Buffers: R=[65535->131070] S=[65535->131070]
Sun Sep 2 09:10:39 2007 us=210000 UDPv4 link local: [undef]
Sun Sep 2 09:10:39 2007 us=210000 UDPv4 link remote: 91.21.139.192:1194
Sun Sep 2 09:10:39 2007 us=210000 SENT PING
Sun Sep 2 09:10:39 2007 us=210000 TIMER: coarse timer wakeup 1 seconds
Sun Sep 2 09:10:39 2007 us=210000 ACK mark active outgoing ID 0
Sun Sep 2 09:10:39 2007 us=210000 ACK reliable_can_send active=1 current=1 : [1] 0
Sun Sep 2 09:10:39 2007 us=210000 ACK reliable_send ID 0 (size=4 to=2)
Sun Sep 2 09:10:39 2007 us=220000 ACK reliable_send_timeout 2 [1] 0
Sun Sep 2 09:10:39 2007 us=220000 RANDOM USEC=250025
Sun Sep 2 09:10:39 2007 us=220000 PO_CTL rwflags=0x0003 ev=4 arg=0x0057f9c8
Sun Sep 2 09:10:39 2007 us=220000 I/O WAIT T?|T?|SR|SW [1/250025]
Sun Sep 2 09:10:39 2007 us=220000 PO_WAIT[0,0] fd=4 rev=0x00000004 rwflags=0x0002 arg=0x0057f9c8
Sun Sep 2 09:10:39 2007 us=230000 I/O WAIT status=0x0002
Sun Sep 2 09:10:39 2007 us=230000 UDPv4 WRITE [42] to 91.21.139.192:1194: P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 pid=[ #1 ] [ ] pid=0 DATA len=0
Sun Sep 2 09:10:39 2007 us=230000 ACK reliable_can_send active=1 current=0 : [1] 0
Sun Sep 2 09:10:39 2007 us=230000 SSL state (connect): before/connect initialization
Sun Sep 2 09:10:39 2007 us=230000 SSL state (connect): SSLv3 write client hello A
Sun Sep 2 09:10:39 2007 us=230000 ACK reliable_send_timeout 2 [1] 0
Sun Sep 2 09:10:39 2007 us=230000 PO_CTL rwflags=0x0001 ev=4 arg=0x0057f9c8
Sun Sep 2 09:10:39 2007 us=240000 I/O WAIT T?|T?|SR|Sw [1/250025]
Sun Sep 2 09:10:40 2007 us=500000 I/O WAIT status=0x0020
Sun Sep 2 09:10:40 2007 us=500000 TIMER: coarse timer wakeup 1 seconds
Sun Sep 2 09:10:40 2007 us=500000 ACK reliable_can_send active=1 current=0 : [1] 0
Sun Sep 2 09:10:40 2007 us=510000 ACK reliable_send_timeout 1 [1] 0
Sun Sep 2 09:10:40 2007 us=510000 PO_CTL rwflags=0x0001 ev=4 arg=0x0057f9c8
Sun Sep 2 09:10:40 2007 us=520000 I/O WAIT T?|T?|SR|Sw [1/250025]
Sun Sep 2 09:10:41 2007 us=780000 I/O WAIT status=0x0020
Sun Sep 2 09:10:41 2007 us=780000 TIMER: coarse timer wakeup 1 seconds
Sun Sep 2 09:10:41 2007 us=780000 ACK reliable_can_send active=1 current=1 : [1] 0
Sun Sep 2 09:10:41 2007 us=790000 ACK reliable_send ID 0 (size=4 to=2)
Sun Sep 2 09:10:41 2007 us=790000 ACK reliable_send_timeout 2 [1] 0
Sun Sep 2 09:10:41 2007 us=800000 PO_CTL rwflags=0x0003 ev=4 arg=0x0057f9c8
Sun Sep 2 09:10:41 2007 us=800000 I/O WAIT T?|T?|SR|SW [1/250025]
Sun Sep 2 09:10:41 2007 us=810000 PO_WAIT[0,0] fd=4 rev=0x00000004 rwflags=0x0002 arg=0x0057f9c8
Sun Sep 2 09:10:41 2007 us=810000 I/O WAIT status=0x0002
Sun Sep 2 09:10:41 2007 us=820000 UDPv4 WRITE [42] to 91.21.139.192:1194: P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 pid=[ #2 ] [ ] pid=0 DATA len=0
Sun Sep 2 09:10:41 2007 us=820000 ACK reliable_can_send active=1 current=0 : [1] 0
Sun Sep 2 09:10:41 2007 us=820000 ACK reliable_send_timeout 2 [1] 0
Sun Sep 2 09:10:41 2007 us=820000 PO_CTL rwflags=0x0001 ev=4 arg=0x0057f9c8
Sun Sep 2 09:10:41 2007 us=820000 I/O WAIT T?|T?|SR|Sw [1/250025]
Sun Sep 2 09:10:43 2007 us=80000 I/O WAIT status=0x0020
Sun Sep 2 09:10:43 2007 us=80000 TIMER: coarse timer wakeup 1 seconds
Sun Sep 2 09:10:43 2007 us=80000 ACK reliable_can_send active=1 current=1 : [1] 0
Sun Sep 2 09:10:43 2007 us=80000 ACK reliable_send ID 0 (size=4 to=2)
Sun Sep 2 09:10:43 2007 us=80000 ACK reliable_send_timeout 2 [1] 0
Sun Sep 2 09:10:43 2007 us=80000 PO_CTL rwflags=0x0003 ev=4 arg=0x0057f9c8
Sun Sep 2 09:10:43 2007 us=80000 I/O WAIT T?|T?|SR|SW [1/250025]
Sun Sep 2 09:10:43 2007 us=80000 PO_WAIT[0,0] fd=4 rev=0x00000004 rwflags=0x0002 arg=0x0057f9c8
Sun Sep 2 09:10:43 2007 us=80000 I/O WAIT status=0x0002
Sun Sep 2 09:10:43 2007 us=80000 UDPv4 WRITE [42] to 91.21.139.192:1194: P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 pid=[ #3 ] [ ] pid=0 DATA len=0
Sun Sep 2 09:10:43 2007 us=80000 ACK reliable_can_send active=1 current=0 : [1] 0
Sun Sep 2 09:10:43 2007 us=80000 PO_CTL rwflags=0x0001 ev=4 arg=0x0057f9c8
Sun Sep 2 09:10:43 2007 us=80000 I/O WAIT T?|T?|SR|Sw [1/250025]
Sun Sep 2 09:10:44 2007 us=340000 I/O WAIT status=0x0020
Sun Sep 2 09:10:44 2007 us=340000 TIMER: coarse timer wakeup 1 seconds
Sun Sep 2 09:10:44 2007 us=340000 ACK reliable_can_send active=1 current=0 : [1] 0
Sun Sep 2 09:10:44 2007 us=340000 ACK reliable_send_timeout 1 [1] 0
Sun Sep 2 09:10:44 2007 us=340000 PO_CTL rwflags=0x0001 ev=4 arg=0x0057f9c8
Sun Sep 2 09:10:44 2007 us=340000 I/O WAIT T?|T?|SR|Sw [1/250025]
Sun Sep 2 09:10:45 2007 us=600000 I/O WAIT status=0x0020
Sun Sep 2 09:10:45 2007 us=600000 TIMER: coarse timer wakeup 1 seconds
Sun Sep 2 09:10:45 2007 us=600000 ACK reliable_can_send active=1 current=1 : [1] 0
Sun Sep 2 09:10:45 2007 us=600000 ACK reliable_send ID 0 (size=4 to=2)
Sun Sep 2 09:10:45 2007 us=600000 ACK reliable_send_timeout 2 [1] 0
Sun Sep 2 09:10:45 2007 us=600000 PO_CTL rwflags=0x0003 ev=4 arg=0x0057f9c8
Sun Sep 2 09:10:45 2007 us=600000 I/O WAIT T?|T?|SR|SW [1/250025]
Sun Sep 2 09:10:45 2007 us=600000 PO_WAIT[0,0] fd=4 rev=0x00000004 rwflags=0x0002 arg=0x0057f9c8
Sun Sep 2 09:10:45 2007 us=600000 I/O WAIT status=0x0002
Sun Sep 2 09:10:45 2007 us=600000 UDPv4 WRITE [42] to 91.21.139.192:1194: P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 pid=[ #4 ] [ ] pid=0 DATA len=0
Sun Sep 2 09:10:45 2007 us=600000 ACK reliable_can_send active=1 current=0 : [1] 0
Sun Sep 2 09:10:45 2007 us=600000 PO_CTL rwflags=0x0001 ev=4 arg=0x0057f9c8
Sun Sep 2 09:10:45 2007 us=600000 I/O WAIT T?|T?|SR|Sw [1/250025]
Sun Sep 2 09:10:46 2007 us=860000 I/O WAIT status=0x0020
Sun Sep 2 09:10:46 2007 us=860000 TIMER: coarse timer wakeup 1 seconds
Sun Sep 2 09:10:46 2007 us=860000 ACK reliable_can_send active=1 current=0 : [1] 0
Sun Sep 2 09:10:46 2007 us=860000 ACK reliable_send_timeout 1 [1] 0
Sun Sep 2 09:10:46 2007 us=860000 PO_CTL rwflags=0x0001 ev=4 arg=0x0057f9c8
Sun Sep 2 09:10:46 2007 us=860000 I/O WAIT T?|T?|SR|Sw [1/250025]
Sun Sep 2 09:10:48 2007 us=120000 I/O WAIT status=0x0020
Sun Sep 2 09:10:48 2007 us=120000 TIMER: coarse timer wakeup 1 seconds
Sun Sep 2 09:10:48 2007 us=120000 ACK reliable_can_send active=1 current=1 : [1] 0
Sun Sep 2 09:10:48 2007 us=120000 ACK reliable_send ID 0 (size=4 to=2)
Sun Sep 2 09:10:48 2007 us=120000 ACK reliable_send_timeout 2 [1] 0
Sun Sep 2 09:10:48 2007 us=120000 PO_CTL rwflags=0x0003 ev=4 arg=0x0057f9c8
Sun Sep 2 09:10:48 2007 us=120000 I/O WAIT T?|T?|SR|SW [1/250025]
Sun Sep 2 09:10:48 2007 us=120000 PO_WAIT[0,0] fd=4 rev=0x00000004 rwflags=0x0002 arg=0x0057f9c8
Sun Sep 2 09:10:48 2007 us=120000 I/O WAIT status=0x0002
Sun Sep 2 09:10:48 2007 us=120000 UDPv4 WRITE [42] to 91.21.139.192:1194: P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 pid=[ #5 ] [ ] pid=0 DATA len=0
Sun Sep 2 09:10:48 2007 us=120000 ACK reliable_can_send active=1 current=0 : [1] 0
Sun Sep 2 09:10:48 2007 us=120000 PO_CTL rwflags=0x0001 ev=4 arg=0x0057f9c8
Sun Sep 2 09:10:48 2007 us=120000 I/O WAIT T?|T?|SR|Sw [1/250025]
/var/mod/root # killall openvpnSun Sep 2 09:10:49 2007 us=390000 I/O WAIT status=0x0020
Sun Sep 2 09:10:49 2007 us=390000 TIMER: coarse timer wakeup 1 seconds
Sun Sep 2 09:10:49 2007 us=390000 ACK reliable_can_send active=1 current=0 : [1] 0
Sun Sep 2 09:10:49 2007 us=390000 ACK reliable_send_timeout 1 [1] 0
Sun Sep 2 09:10:49 2007 us=390000 RANDOM USEC=80127
Sun Sep 2 09:10:49 2007 us=390000 PO_CTL rwflags=0x0001 ev=4 arg=0x0057f9c8
Sun Sep 2 09:10:49 2007 us=390000 I/O WAIT T?|T?|SR|Sw [1/80127]
Sun Sep 2 09:10:49 2007 us=680000 event_wait : Interrupted system call (code=4)
Sun Sep 2 09:10:49 2007 us=680000 I/O WAIT status=0x0010
Sun Sep 2 09:10:49 2007 us=680000 PID packet_id_free
Sun Sep 2 09:10:49 2007 us=690000 TCP/UDP: Closing socket
Sun Sep 2 09:10:49 2007 us=690000 PID packet_id_free
Sun Sep 2 09:10:49 2007 us=690000 SIGTERM[hard,] received, process exiting
