Voipbox Capi incoming
Daverichter
25 Jul 2005
ich wollte heute mal die Voipbox testen, soweit so gut funktioniert auch soweit alles, bis auf die kleinigkeit das ISDN (CAPI) incoming nicht funzt, ich bin mir allerdings auch nicht sicher ob meine config so passt...
; CAPI config
; general section
[general]
nationalprefix=0
internationalprefix=00
rxgain=0.8
txgain=0.8
;ulaw=yes ;set this, if you live in u-law world instead of a-law
; interface sections ...
[ISDN1] ;this example interface gets name 'ISDN1' and may be any
;name not starting with 'g' or 'contr'.
;ntmode=yes ;if isdn card operates in nt mode, set this to yes
isdnmode=msn ;'MSN' (point-to-multipoint) or 'DID' (direct inward dial)
;when using NT-mode, 'DID' should be set in any case
incomingmsn=* ;allow incoming calls to this list of MSNs/DIDs, * = any
;defaultcid=123 ;set a default caller id to that interface for dial-out,
;this caller id will be used when dial option 'd' is set.
;controller=0 ;ISDN4BSD default
;controller=7 ;ISDN4BSD USB default
controller=1 ;capi controller number to use
group=1 ;dialout group
;prefix=0 ;set a prefix to calling number on incoming calls
softdtmf=on ;enable/disable software dtmf detection, recommended for AVM cards
relaxdtmf=on ;in addition to softdtmf, you can use relaxed dtmf detection
accountcode= ;Asterisk accountcode to use in CDRs
context=capi-in ;context for incoming calls
holdtype=hold ;when Asterisk puts the call on hold, ISDN HOLD will be used. If
;set to 'local' (default value), no hold is done and Asterisk may
;play MOH.
;immediate=yes ;DID: immediate start of pbx with extension 's' if no digits were
; received on incoming call (no destination number yet)
;MSN: start pbx on CONNECT_IND and don't wait for SETUP/SENDING-COMPLETE.
; info like REDIRECTINGNUMBER may be lost, but this is necessary for
; drivers/pbx/telco which does not send SETUP or SENDING-COMPLETE.
;echosquelch=1 ;_VERY_PRIMITIVE_ echo suppression
;echocancel=yes ;EICON DIVA SERVER (CAPI) echo cancelation
;(possible values: 'no', 'yes', 'force', 'g164', 'g165')
echocancelold=yes;use facility selector 6 instead of correct 8 (necessary for older eicon drivers)
;echotail=64 ;echo cancel tail setting
;bridge=yes ;native bridging (CAPI line interconnect) if available
;callgroup=1 ;Asterisk call group
devices=2 ;number of concurrent calls on this controller
;(2 makes sense for single BRI, 30 for PRI)
Extensions.conf
[capi-in]
exten => 8592xx,1,Dial(Sip/704,60)
exten => 8592xx,2,Hangup()
wenn sich die config mal jemand anschauen könnte währe ich sehr dankbar.
MFG
Dave
Und auch grosse 'X'...
Armin
HI,
danke für die tipps...
ich habe den fehler allerdings an anderer stelle gefunden
das Modul chan-capi war nicht geladen.
MFG
Dave
Manni80
