Voicemailansage und Mailtext
alexshh
19 Apr 2005
Wie kann ich den Mailtext der mit übertragen wird ins deutche editieren :
"...Just wanted to let you know you were just left a 0:05 long message (number 10) in mailbox hotline from, on Tuesday, April 26, 2005 at 11:23:08 AM so you might want to check it when you get a chance. Thanks!
Warum fehlt bei der Ansage der Mailbox "der Teilnehmer mit der Rufnummer ist immoment" die Rufnummer welcher eintrag fehlt habe in der voicemail.conf schon den Eintrag saycid = yes benutze das deutsche paket von pforzheim hier sind die einzelnen rufnummern dabei
in der voicemail.conf steht der drin
; Voicemail Configuration
[general]
; Default formats for writing Voicemail
;format=g723sf|wav49|wav
;format=wav|gsm|wav49
format=wav
; Who the e-mail notification should appear to come from
serveremail=asterisk
;[email protected]
; Should the email contain the voicemail as an attachment
attach=yes
; Maximum length of a voicemail message in seconds
maxmessage=180
; Minimum length of a voicemail message in seconds
minmessage=3
; Maximum length of greetings in seconds
;maxgreet=60
; How many miliseconds to skip forward/back when rew/ff in message playback
skipms=3000
; How many seconds of silence before we end the recording
maxsilence=10
; Silence threshold (what we consider silence, the lower, the more sensitive)
silencethreshold=128
; Max number of failed login attempts
maxlogins=3
; If you need to have an external program, i.e. /usr/bin/myapp
; called when a voicemail is left, delivered, or your voicemailbox
; is checked, uncomment this:
;externnotify=/usr/bin/myapp
; called when a voicemail password is changed,
; uncomment this:
;externpass=/usr/bin/myapp
; For the directory, you can override the intro file if you want
;directoryintro=dir-intro
; The character set for voicemail messages can be specified here
charset=ISO-8859-1
; The ADSI feature descriptor number to download to
;adsifdn=0000000F
; The ADSI security lock code
;adsisec=9BDBF7AC
; The ADSI voicemail application version number.
;adsiver=1
; Skip the "[PBX]:" string from the message title
;pbxskip=yes
; Change the From: string
fromstring=The Asterisk PBX
;Change the From: string for pager messages
;pagerfromstring=The Asterisk PBX
; Change the email body and/or subject, variables:
;     VM_NAME, VM_DUR, VM_MSGNUM, VM_MAILBOX, VM_CALLERID, VM_DATE
; Note: The emailbody config row can be up to 512 characters due to a limitation in
;       asterisk config files.
emailsubject=[PBX]: Neue Nachricht ${VM_MSGNUM} fuer ${VM_NAME} in Mailbox ${VM_MAILBOX}
; The following definition is very close to the default, but the default shows just
; the CIDNAME, if it is not null, else just the CIDNUM, or "an unknown caller" if they are both null.
emailbody=Hallo ${VM_NAME},\n\nwollte Dich nur wissen lassen, das eine ${VM_DUR} lange Nachricht (Nummer ${VM_MSGNUM})\nin deiner Mailbox ${VM_MAILBOX} von
${VM_CALLERID}, am ${VM_DATE}, hinterlassen wurde.\nDanke!\n\n\t\t\t\t--Asterisk\n
Voicemailtext
Hi, habe in der voicemail.conf
den emailbody=.............
von dir eingefügt, kommt trotzdem der englische text an. Hatte vorher die voicemail.conf mit den Beispielen gelöscht muss hier noch ein Eintrag gesetzt werden das er den emailbody Eintrag auch nimmt ?
Danke für jeden TIP.
also bei mir funktionierts mit dem deutschen Text:
hier mal der entsprechende Ausschnitt aus der voicemail.conf
;emailsubject=[PBX]: New message ${VM_MSGNUM} in mailbox ${VM_MAILBOX}
;emailbody=Dear ${VM_NAME}:\n\n\tjust wanted to let you know you were just left a ${VM_DUR} long message (number ${VM_MSGNUM})\nin mailbox ${VM_MAILBOX} fro
m ${VM_CALLERID}, on ${VM_DATE}, so you might\nwant to check it when you get a chance.  Thanks!\n\n\t\t\t\t--Asterisk\n
;********************** Notification Email für neues Soundfile in der Voicemailbox ***********************************
;********************** Stand 17.05.2005,  auf deutsch by Frank  *****************************************
emailbody=Hallo ${VM_NAME},\n\nich wollte Sie nur wissen lassen, das eine ${VM_DUR} Minuten lange Nachricht (Nummer ${VM_MSGNUM})\nin Ihrer Mailbox ${VM_MAI
LBOX} von ${VM_CALLERID}, am ${VM_DATE}, hinterlassen wurde.\nDanke!\n\n\t--Ihre freundliche Asterisk-Telefonanlage\n
Du musst natürlich auch drauf achten dass der text nicht mit einen ";" auskommentiert ist (so wie die englische Beschreibung oben). ;-)
Gruss
Frank
Hallo zusammen
Bei mir funktionierts zwar super, aber ein kleiner Schönheitsfehler hats noch.
Z.b. werden unter anderem die Wochentage ( Variable ${VM_DATE} ) noch in Engisch angezeigt und ich finde den Parameter nicht wo man dies auf deutsch umschalten kann.
Mail Ausschnitt:
HTML:
Die Nachricht (Länge = 0:18min) wurde am Friday, November 17, 2006 at 11:40:04 AM in deiner Mailbox gespeichert
Kann mir jemand ein Stichwort geben?
Wäre mega!
Viele Grüsse Stäubel
wie bekommt man die ${VM_DATE} in Deutsch?
voicemail.conf schrieb:
; Users may be located in different timezones, or may have different
; message announcements for their introductory message when they enter
; the voicemail system. Set the message and the timezone each user
; hears here. Set the user into one of these zones with the tz= attribute
; in the options field of the mailbox. [COLOR="Red"]Of course, language substitution
; still applies here so you may have several directory trees that have
; alternate language choices. [/COLOR]
; Look in /usr/share/zoneinfo/ for names of timezones.
; Look at the manual page for strftime for a quick tutorial on how the
; variable substitution is done on the values below.
Sieht also danach aus, daß man die timezone im jeweilgen Mailboxeintrag entsprechend richtig setzen muß.
habe folgendes gesetzt
PHP:
tz=germany		; Timezone from zonemessages above.  Irrelevant if envelope=no.
[zonemessages]
germany=Europe/Berlin|'vm-received' Q 'digits/at' kM
geht aber nicht
-> Asterisk 1.2.18
oli50
