- Mitglied seit
- 5 Apr 2005
- Beiträge
- 372
- Punkte für Reaktionen
- 0
- Punkte
- 16
Hallo Robert,
leider bricht jFritz bei der neuen Version mit einem Java-Fehler ab.
Ich habe jFritz wie mit java -jar jfritz.jar
Folgende Ausgabe erhalte ich dann
19.01.20 10:56:14|INFO |main|Main - JFritz v0.7.7 Rev. 4f1bb1c (c) 2005-2020 by all members of the JFritz-Team
19.01.20 10:56:14|INFO |main|Main - JFritz runs on Windows 10 [10.0]
19.01.20 10:56:14|INFO |main|Main - OS Language: de
19.01.20 10:56:14|INFO |main|Main - OS Country: DE
19.01.20 10:56:14|INFO |main|Main - Java version: 12.0.1 (on amd64)
19.01.20 10:56:14|INFO |main|Main - Working directory: P:\Prog\Jfritz/
19.01.20 10:56:14|INFO |main|Main - Data directory: P:\Prog\JFritz\Data\
19.01.20 10:56:14|INFO |main|Main - Selected language: de_DE
19.01.20 10:56:14|WARN |main|Main - Multiple instance lock: Another instance is already running.
19.01.20 10:56:18|WARN |main|Main - Multiple instance lock: User decided NOT to shut down this instance.
19.01.20 10:56:18|INFO |Thread-0|ReverseLookupAsyncThread - finished lookup thread, waiting for new jobs
19.01.20 10:56:24|INFO |main|Main - Detected firmware version: 113.07.12
SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
SLF4J: Defaulting to no-operation (NOP) logger implementation
SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details.
Exception in thread "main" java.lang.NoClassDefFoundError: javax/xml/bind/JAXBException
at de.bausdorf.avm.tr064.FritzConnection.readTR64(FritzConnection.java:122)
at de.bausdorf.avm.tr064.FritzConnection.init(FritzConnection.java:111)
at de.moonflower.jfritz.box.fritzbox.FritzBox.initTR064Connection(FritzBox.java:161)
at de.moonflower.jfritz.box.fritzbox.FritzBox.init(FritzBox.java:156)
at de.moonflower.jfritz.JFritz.initFritzBox(JFritz.java:163)
at de.moonflower.jfritz.Main.initJFritz(Main.java:594)
at de.moonflower.jfritz.Main.<init>(Main.java:311)
at de.moonflower.jfritz.Main.main(Main.java:379)
Caused by: java.lang.ClassNotFoundException: javax.xml.bind.JAXBException
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:583)
at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:178)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:521)
... 8 more
19.01.20 10:57:50|INFO |SIGINT handler|Main - Shutting down JFritz...
19.01.20 10:57:50|INFO |SIGINT handler|Main - Closing all open network connections
19.01.20 10:57:50|INFO |SIGINT handler|ReverseLookupAsyncThread - terminating lookup thread
19.01.20 10:57:50|INFO |SIGINT handler|ReverseLookupAsyncThread - resuming lookup thread to terminate it
Die alte Version 7.6 ist noch ohne Fehler gestart.
LG Jürgen
... 8 more
LG Jürgen
