Using another modem ADSL
Very good Help in this Connection i have the same 7141 Annex b
Now i can made voip calls :) Thanks for your Post
But i have face another problem. :confused:
I have no number from voip provider so i need to receive calls from fixed line.
When i connect the fixed line PTSN to Fon2 on Fritz!box 7141 the line change to busy!!! Like Fritz!box pikup the Phone.
How can i avoid this? The box is German Language i have difilculty to understand.:(
Best Regards
From Lisbon Portugal
I don't know if I understand you rightly.
You should connect telephone line to white port (first from left). If your line is for RJ-11 you need a transistional converter (I had it with router).
You connect phones to FON1 or FON2.
In panel you can choose which line you want to use first.
Raviz, Can you help a noobie explain how you managed to use voip. I have 7141, but was unable to convert to AnnexA and therefore is lying around. And I dont understand german, so screenshots may be th eonly way to help, if u dont mind. Cheers mate
