5>0x00010000-0x00780000 : "kernel"
'nor-flash'
'Bits can be cleared (flash)'
'Has an erase function'
0x00000000-0x00010000 : "bootloader"
'nor-flash'
0x00780000-0x007c0000 : "tffs (1)"
'nor-flash'
0x007c0000-0x00800000 : "tffs (2)"
'nor-flash'
0x00770000-0x00780000 : "jffs2"
'nor-flash'
0x00010000-0x00770000 : "Kernel without jffs2"
'nor-flash'
partition_info[0]: name=filesystem offset=b5700 size=6ca900
partition_info[0]: 0xb00b5700: 0x73717368 0x977
partition_info[1]: name=kernel offset=10000 size=770000
partition_info[1]: 0xb0010000: 0xfeed1281 0xa56b1
partition_info[2]: name=bootloader offset=0 size=10000
partition_info[2]: 0xb0000000: 0x40809000 0x40809800
partition_info[3]: name=tffs (1) offset=780000 size=40000
partition_info[3]: 0xb0780000: 0x40001 0x9dffffff
partition_info[4]: name=tffs (2) offset=7c0000 size=40000
partition_info[4]: 0xb07c0000: 0x40001 0x9effffff
partition_info[5]: name=jffs2 offset=770000 size=10000
partition_info[5]: 0xb0770000: 0xffffffff 0xffffffff
partition_info[6]: name=Kernel without jffs2 offset=10000 size=760000
partition_info[6]: 0xb0010000: 0xfeed1281 0xa56b1
Calling initcall 0x941fbf40: kcapi_init+0x0/0x9c()
Calling initcall 0x941fc084: capi_oslib_init+0x0/0x8()
Calling initcall 0x941fcb50: blackhole_module_init+0x0/0xc()
Calling initcall 0x941fd840: inet_init+0x0/0x504()
NET: Registered protocol family 2
IP route cache hash table entries: 512 (order: -1, 2048 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
Calling initcall 0x94200258: init+0x0/0x8()
Calling initcall 0x94200260: bictcp_register+0x0/0xc()
TCP bic registered
Calling initcall 0x9420026c: mcfw_init_module+0x0/0x2c()
mcfw: IGMPv3 fast forwarding
Calling initcall 0x94200298: af_unix_init+0x0/0xa0()
NET: Registered protocol family 1
Calling initcall 0x94200338: packet_init+0x0/0x80()
NET: Registered protocol family 17
Calling initcall 0x942003b8: br_init+0x0/0x68()
Calling initcall 0x94200474: atm_init+0x0/0xec()
NET: Registered protocol family 8
NET: Registered protocol family 20
Calling initcall 0x94200618: br2684_init+0x0/0x54()
Calling initcall 0x941eb024: ohio_install_dummy_irq_functions+0x0/0x58()
[setup_irq]: irq 1 irqaction->handler 0x94001590 (dummy_timer_irq+0x0/0x14 )
[setup_irq]: irq 6 irqaction->handler 0x940015a4 (dummy_system_irq_2+0x0/0x14 )
Calling initcall 0x940017e4: ohio_late_init+0x0/0x3c()
[ohio_late_init]
Calling initcall 0x941eb160: ohio_clk_switch_init+0x0/0x60()
Calling initcall 0x941eb3dc: speedup_init+0x0/0x3c()
Calling initcall 0x941f881c: seqgen_init+0x0/0x20()
Calling initcall 0x940cdd00: avm_event_push_button_init+0x0/0x130()
[avm_new] push_button_gpio=8 value=1 enabled
Calling initcall 0x941f9adc: tffs_init+0x0/0x224()
TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
mount on mtd4 and mtd5 (double buffering)
Adam2 environment variables API installed.
Calling initcall 0x941fa92c: early_uart_console_switch+0x0/0xb4()
Calling initcall 0x941255b8: net_random_reseed+0x0/0x34()
Calling initcall 0x941fed60: ip_auto_config+0x0/0x1120()
[prepare_namespace] new mount root /dev/mtdblock1
use lzma compression
VFS: Mounted root (squashfs filesystem) readonly.
Freeing prom memory: 0kb freed
Freeing unused kernel memory: 112k freed (7569 free)
[setup_irq]: irq 15 irqaction->handler 0x940d9f2c (serial8250_interrupt+0x0/0x13c )
TFFS Name Table E
Piglet: module license '
(C) Copyright 2005 by AVM
' taints kernel.
[avm_new]push_button 'Wlan-Taster', released: GPIO=8 presses=1750 key=button_key_1
EMIF: asize=1 ta=3 r_hold=0 w_strobe=6 r_strobe=6 ew=1
usbcore: registered new driver usbfs
usbcore: registered new driver hub
AHCI RevisionID = 0x02, RamSize = 16384, NumPorts= 1
[setup_irq]: irq 9 irqaction->handler 0xc0006490 (ahci_irq+0x0/0x880 [usbahcicore] )
ahci : new USB bus registered, assigned bus number 1
SCSI subsystem initialized
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
usb 1-1: new full speed USB device using ahci and address 2
USB Mass Storage device (058f:6387) detected...
scsi0 : SCSI emulation for USB Mass Storage devices
usb-storage: device found at 2
usb-storage: waiting for device to settle before scanning
Vendor: JetFlash Model: TS1GJFV10 Rev: 8.07
Type: Direct-Access ANSI SCSI revision: 02
SCSI device sda: 2002942 512-byte hdwr sectors (1026 MB)
sda: Write Protect is off
sda: Mode Sense: 03 00 00 00
sda: assuming drive cache: write through
sda: sda1
Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
usb-storage: device scan complete
SQUASHFS error: Can't find a SQUASHFS superblock on sda1
EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended
EXT2-fs error (device sda1): ext2_check_page: bad entry in directory #7841: unaligned directory entry - offset=0, inode=4294967295, rec_len=65535, name_len=255
usb usb1: USB disconnect, address 1
usb 1-1: USB disconnect, address 2
scsi0 (0:0): rejecting I/O to device being removed
Buffer I/O error on device sda1, logical block 0
lost page write due to I/O error on sda1
Buffer I/O error on device sda1, logical block 1
Buffer I/O error on device sda1, logical block 32833
Buffer I/O error on device sda1, logical block 65536
Buffer I/O error on device sda1, logical block 65537
Buffer I/O error on device sda1, logical block 65540
ahci : USB bus 1 deregistered
AR7WDT: System Init UEberwachung 240 Sekunden
[avm_new]push_button 'Wlan-Taster' presses: GPIO=8 time=4294940547
[avm_new]push_button 'Wlan-Taster', released: GPIO=8 presses=260 key=button_key_1
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
jffs2: Too few erase blocks (1)
scsi0 (0:0): rejecting I/O to dead device
EXT2-fs error (device sda1): read_inode_bitmap: Cannot read inode bitmap - block_group = 2, inode_bitmap = 65537
registered device TI Avalanche SAR
tiatm driver (patch_annex=0xc014f46c)
[tiatm] Set StrictPriority=0
DSP binary filesize = 328180 bytes
[tiatm] INFO V2U-BRIDGEREGISTER: 0x00000019
[avm_power]Ohio250 detected -> overclocking possible
[avm_power]#### boostVoltage: DSP Core voltage set to 1,5 V ####
[setup_irq]: irq 23 irqaction->handler 0xc0136208 (tn7atm_sar_irq+0x0/0x30 [tiatm] )
[setup_irq]: irq 31 irqaction->handler 0xc0136238 (tn7atm_dsl_irq+0x0/0x28 [tiatm] )
[tiatm]: Powermanagment (States => 1,3,10) supported!
Texas Instruments ATM driver: version:[4.07.07.00]
[tiatm] AvmInterface length: 44
ubik2 driver (ubik2 - 0x10=0xc00aaaf4)
atm_dsp_register_ubik2: ubik2_ToMIPS_notify=0xc0099bfc
atm_dsp_register_ubik2: dsp mem pointer 0xa1c10b0c
ubik2_init_interface: DSP-Link Version v3 8480
driver params overwritten io_addr=0x0 irq_num=0
[setup_irq]: irq 28 irqaction->handler 0xc00a45f0 (soft_interrupt_handler+0x0/0x30 [ubik2] )
capicodec_init()
[capi_codec] support fax
[capi_codec] support Codecs
[tiatm] DSL in training!
[setup_irq]: irq 9 irqaction->handler 0xc0123490 (ahci_irq+0x0/0x880 [usbahcicore] )
kdsldmod: init start (Apr 29 2008 10:56:38) sizeof(struct sk_buff)=176
kdsldmod: init done
kdsld: PPP led: off (value=0)
avm_net_trace: New net trace device 'WLAN' registered with minor 0.
[avm_power] : ethernet port 0 status 2
[avm_power] : ethernet port 1 status 1
[avm_power] : ethernet port 2 status 1
[avm_power] : ethernet port 3 status 1
scsi1 : SCSI emulation for USB Mass Storage devices
[ohio_vlynq_init] device 0
[ohio_vlynq_startup_link]
[setup_irq]: irq 29 irqaction->handler 0x9400592c (vlynq_interrupt+0x0/0x34 )
[setup_irq]: irq 79 irqaction->handler 0xc033e39c (tiwlan_ddaVlynqIsr+0x0/0x28 [tiap] )
EXT2-fs error (device sda1): ext2_get_inode: unable to read inode block - inode=7841, block=32833
[tiatm] DSL in Sync
SCSI device sdb: 2002942 512-byte hdwr sectors (1026 MB)
sdb: Write Protect is off
sdb: Mode Sense: 03 00 00 00
sdb: assuming drive cache: write through
sdb: sdb1
Attached scsi removable disk sdb at scsi1, channel 0, id 0, lun 0
[setup_irq]: irq 27 irqaction->handler 0x940ea99c (cpmac_main_isr+0x0/0x78 )
[cpmac] cpmac_main_ioctl, unknown ioctl 35142
device eth0 entered promiscuous mode
device cpmac0 entered promiscuous mode
lan: port 1(eth0) entering learning state
lan: topology change detected, propagating
lan: port 1(eth0) entering forwarding state
device tiwlan0 entered promiscuous mode
lan: port 2(tiwlan0) entering learning state
lan: port 2(tiwlan0) entering forwarding state
device wdsup0 entered promiscuous mode
lan: port 3(wdsup0) entering learning state
lan: port 3(wdsup0) entering forwarding state
device wdsdw0 entered promiscuous mode
lan: port 4(wdsdw0) entering learning state
lan: port 4(wdsdw0) entering forwarding state
device wdsdw1 entered promiscuous mode
lan: port 5(wdsdw1) entering learning state
lan: port 5(wdsdw1) entering forwarding state
device wdsdw2 entered promiscuous mode
lan: port 6(wdsdw2) entering learning state
lan: port 6(wdsdw2) entering forwarding state
device wdsdw3 entered promiscuous mode
lan: port 7(wdsdw3) entering learning state
lan: port 7(wdsdw3) entering forwarding state
kdsld: lan:
kdsld: 0: eth.proto 0x0800 ip.proto 17 udp.dport 5060 (act 1)
kdsld: 0: eth.proto 0x0800 ip.proto 17 udp.dport 53 (act 11)
kdsld: 0: eth.proto 0x0800 ip.proto 6 ip.len <= 800 tcp.dport 80 (act 12)
kdsld: 0: eth.proto 0x0800 ip.proto 6 ip.len <= 800 tcp.dport 8080 (act 12)
kdsld: 0: eth.proto 0x0800 ip.proto 6 ip.len <= 800 tcp.dport 3128 (act 12)
kdsld: 0: eth.proto 0x0800 ip.proto 6 ip.len <= 64 (act 10)
kdsld: 0: eth.proto 0x0800 ip.proto 1 (act 13)
kdsld: lan-optim:
kdsld: 0: eth.proto 0x0800 (act 1)
kdsld: 1: ip.proto 17 (act 1)
kdsld: 2: udp.dport 5060 (act 1)
kdsld: 2: udp.dport 53 (act 11)
kdsld: 1: ip.proto 6 (act 12)
kdsld: 2: ip.len <= 800 (act 12)
kdsld: 3: tcp.dport 80 (act 12)
kdsld: 3: tcp.dport 8080 (act 12)
kdsld: 3: tcp.dport 3128 (act 12)
kdsld: 2: ip.len <= 64 (act 10)
kdsld: 1: ip.proto 1 (act 13)
kdsld: showtime
kdsld: unsetup done.
kdsld: VCC 0: registered (1/32)
kdsld: 0: VPI/VCI 1/32 PPPoE internet 00:15:0c:c8:f2:74 (32,0) mc upstream
kdsld: internet: set_rcv_ipaddr: 169.254.2.1
kdsld: dsl: registered
kdsld: VCC 0: iface internet dslencap PPPoE pcapencap ETHER llctype ether
kdsld: VCC 0: pcapencap RFC1843
kdsld: no vpnconnections configured
kdsld: setup done.
kdsld_token_thread: start
kdsld: Channel 0 up (physical outgoing)
kdsld: internet: set_snd_ipaddr: 87.188.163.5
kdsld: internet: set_snd_mtu: 1492
kdsld: internet: connected
mcfw: forward enabled (vcc0: 00:15:0c:c8:f2:74, vlan 0, pppoe 8457)
kdsld: PPP led: on (value=1)
AR7WDT: System Init UEberwachung abgeschlossen (194300 ms noch verfuegbar)
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_cpuclock: norm_power_rate=100 act_rate=99 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=0 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dspclock: norm_power_rate=100 act_rate=84 mul=154 div=10 offset=974 NormP=2514 mW -> SumNormP=2514 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_systemclock: norm_power_rate=100 act_rate=83 mul=65 div=10 offset=1793 NormP=2443 mW -> SumNormP=4957 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_wlan: norm_power_rate=100 act_rate=-2147483548 mul=84 div=10 offset=100 NormP=940 mW -> SumNormP=5897 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_isdnnt: norm_power_rate=100 act_rate=0 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=5997 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_isdnte: norm_power_rate=100 act_rate=0 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=6097 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_analog: norm_power_rate=300 act_rate=0 mul=141 div=10 offset=100 NormP=4330 mW -> SumNormP=10427 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dect: norm_power_rate=100 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=10427 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_ethernet: norm_power_rate=467 act_rate=201326856 mul=1 div=1 offset=50 NormP=517 mW -> SumNormP=10944 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dsl: norm_power_rate=100 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=10944 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_host: norm_power_rate=500 act_rate=100 mul=55 div=10 offset=50 NormP=2800 mW -> SumNormP=13744 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_client: norm_power_rate=0 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=13744 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_charge: norm_power_rate=446 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=13744 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_loadrate: norm_power_rate=100 act_rate=19 mul=29 div=10 offset=-17 NormP=273 mW -> SumNormP=14017 mW
SysRq : Changing Loglevel
Loglevel set to 4
[ubik2_debug] eof_sync =1
ip_tables: (C) 2000-2002 Netfilter core team
ip_conntrack version 2.1 (256 buckets, 2048 max) - 248 bytes per conntrack
