Hello,
I've just updated my fritz.box_fon_wlan to version 08.04.15 and since then, I cannot switch back from annex B(to which I swithced to make the upgrade) to annex A. with the file : fritz_als_avme_annex_A_new.tar, I receive a message that the firmware upgrade is not avm and if I still want to upgrade, and if I click yes, nothing happens. Did anyone had the problem, and if yes how did it was solved. :noidea:
Thanks.
W@x.
Thanks.
W@x.
