Hallo ihr da draussen,
wer kann mir mal helfen - ich kämpfe mit der UC520 - alles klappt soweit - nur bekomme ich keinen Ruf rein oder raus auf den Anlagenanschluss (2stellige Durchwahl) - denke es sind die Rules - aber ich denke da kann mal jemand drüber schauen....
Hier die Config
! Last configuration change at 07:45:49 GMT Tue Dec 11 2007
! NVRAM config last updated at 07:45:50 GMT Tue Dec 11 2007
version 12.4
parser config cache interface
parser config interface
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
service internal
service compress-config
hostname UC520
boot-start-marker
boot-end-marker
enable secret 5 $1$zIL6$pVU972lsDnWtthePVQj5G0
no aaa new-model
clock timezone GMT -8
clock summer-time GMT recurring
network-clock-participate wic 1
ip cef
ip dhcp relay information trust-all
ip dhcp use vrf connected
ip dhcp excluded-address 10.1.1.1 10.1.1.10
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp pool phone
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
option 150 ip 10.1.1.1
ip dhcp pool data
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 205.152.0.20
ip name-server 205.152.0.20
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp
ip inspect name SDM_LOW vdolive
stcapp ccm-group 1
stcapp
stcapp feature access-code
multilink bundle-name authenticated
isdn switch-type basic-net3
voice service voip
allow-connections h323 to h323
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice translation-rule 1
rule 1 /^$/ /30/
rule 2 /^0.*/ /30/
voice translation-rule 10
rule 1 /^\(.*\)/ /00\1/ type national national
rule 2 /^\(.*\)/ /000\1/ type international international
voice translation-profile changeCalling
translate calling 10
voice translation-profile changeNullCalled
translate called 1
voice-card 0
no dspfarm
crypto pki trustpoint TP-self-signed-2698669147
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2698669147
revocation-check none
rsakeypair TP-self-signed-2698669147
crypto pki certificate chain TP-self-signed-2698669147
certificate self-signed 01
3082023D 308201A6 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32363938 36363931 3437301E 170D3037 31323131 31343536
33305A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 36393836
36393134 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100D292 0AEB9C91 ABF32F20 B4D461FE 04F5DAAE 4C8643B4 CF7598C5 98F50BAB
E77A43EB 3F012FFE 2E9472F3 4A1CA1BA 47965AC8 D2D3E6BC 66D81B20 86C4BEF4
00812B56 3D138AE0 A832C8C0 86C65DAB 2780E701 BB07EAB8 6EB96829 9092DDFE
3AC31DBC 3AB414CB 8B2FD01B D11083B2 145923F1 57703307 17456CB8 BA1EC006
FF430203 010001A3 65306330 0F060355 1D130101 FF040530 030101FF 30100603
551D1104 09300782 05554335 3230301F 0603551D 23041830 1680140D D6C6F922
077B61AE 8A494E2B 215CDF1B 1CCEF630 1D060355 1D0E0416 04140DD6 C6F92207
7B61AE8A 494E2B21 5CDF1B1C CEF6300D 06092A86 4886F70D 01010405 00038181
007568D5 F59D0DCF 59C61E75 19B1D910 0F2D932B E9650B40 45580EC6 0473F8A8
803905F6 5559359E 62083D38 8CCE4BDC 0F765FD3 23CE2198 B487578E 4D5BE8EC
3889E845 0FF23A1A 7295820C 162B20D5 D13B63EA F7EC09CA B580199F D838CDA1
DD38A996 559B1005 D320F8A6 566EB18B CB1F82ED 7647BA82 347393B2 5FDCC9B7 D0
quit
username cisco privilege 15 secret 5 $1$iOvy$imfBPpGn1qq2HK/D.Nnk2/
archive
log config
process-max-time 50
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 101 in
ip nat inside
ip virtual-reassembly
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address 172.31.140.197 255.255.255.224
ip access-group 104 in
ip nat outside
ip inspect SDM_LOW out
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description $FW_INSIDE$cue is initialized with default IMAP group
ip unnumbered Loopback0
ip access-group 100 in
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
macro description cisco-phone
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
switchport mode trunk
macro description cisco-switch
interface BRI0/1/0
description PSTN (1)
no ip address
isdn overlap-receiving T302 3000
isdn point-to-point-setup
isdn incoming-voice voice
isdn send-alerting
isdn sending-complete
isdn static-tei 0
isdn skipsend-idverify
interface BRI0/1/1
description PSTN (2)
no ip address
shutdown
isdn send-alerting
isdn static-tei 0
interface Vlan1
ip address 192.168.10.1 255.255.255.0
ip access-group 102 in
ip nat inside
interface Vlan100
ip address 10.1.1.1 255.255.255.0
ip access-group 103 in
ip nat inside
ip route 0.0.0.0 0.0.0.0 172.31.140.193
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
ip http server
ip http authentication local
ip http secure-server
ip http path flash:
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip 192.168.10.0 0.0.0.255 any
access-list 100 deny ip 10.1.1.0 0.0.0.255 any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 deny ip 192.168.10.0 0.0.0.255 any
access-list 101 deny ip 10.1.1.0 0.0.0.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration
access-list 102 remark SDM_ACL Category=1
access-list 102 deny ip 10.1.10.0 0.0.0.3 any
access-list 102 deny ip 10.1.1.0 0.0.0.255 any
access-list 102 deny ip host 255.255.255.255 any
access-list 102 deny ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration
access-list 103 remark SDM_ACL Category=1
access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 deny ip 10.1.10.0 0.0.0.3 any
access-list 103 deny ip 192.168.10.0 0.0.0.255 any
access-list 103 deny ip host 255.255.255.255 any
access-list 103 deny ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration
access-list 104 remark SDM_ACL Category=1
access-list 104 deny ip 10.1.10.0 0.0.0.3 any
access-list 104 deny ip 192.168.10.0 0.0.0.255 any
access-list 104 deny ip 10.1.1.0 0.0.0.255 any
access-list 104 permit udp any eq bootps any eq bootpc
access-list 104 permit icmp any any echo-reply
access-list 104 permit icmp any any time-exceeded
access-list 104 permit icmp any any unreachable
access-list 104 deny ip 10.0.0.0 0.255.255.255 any
access-list 104 deny ip 172.16.0.0 0.15.255.255 any
access-list 104 deny ip 192.168.0.0 0.0.255.255 any
access-list 104 deny ip 127.0.0.0 0.255.255.255 any
access-list 104 deny ip host 255.255.255.255 any
access-list 104 deny ip any any log
snmp-server community public RO
tftp-server flash:CP7902080001SCCP051117A.sbin
tftp-server flash:apps11.1-1-2-26.sbn
tftp-server flash:cnu11.3-1-2-26.sbn
tftp-server flash:cvm11sccp.8-0-2-25.sbn
tftp-server flash:dsp11.1-1-2-26.sbn
tftp-server flash:jar11sccp.8-0-2-25.sbn
tftp-server flash:SCCP11.8-0-3S.loads
tftp-server flash:term06.default.loads
tftp-server flash:term11.default.loads
tftp-server flash:S00104000100.sbn
tftp-server flash:cmterm_7936.3-3-5-0.bin
tftp-server flash
0030702T023.loads
tftp-server flash
0030702T023.sbn
tftp-server flash
0030702T023.sb2
tftp-server flash
0030702T023.bin
tftp-server flash:cmterm-7941-7961-sccp.7.0.3.tar
tftp-server flash:cnu41.2-7-6-26.sbn
tftp-server flash:CVM41.2-0-2-26.sbn
tftp-server flash:Jar41.2-9-2-26.sbn
tftp-server flash:TERM41.7-0-3-0S.loads
tftp-server flash:term41.default.loads
tftp-server flash:term61.default.loads
tftp-server flash:cnu70.2-7-6-26.sbn
tftp-server flash:CVM70.2-0-2-26.sbn
tftp-server flash:Jar70.2-9-2-26.sbn
tftp-server flash:TERM70.7-0-3-0S.loads
tftp-server flash:term70.default.loads
tftp-server flash:term71.default.loads
tftp-server flash:apps31.8-1-0-89.sbn
tftp-server flash:cnu31.8-1-0-89.sbn
tftp-server flash:cvm31sccp.8-1-0-90.sbn
tftp-server flash:dsp31.8-1-0-89.sbn
tftp-server flash:jar31sccp.8-1-0-90.sbn
tftp-server flash:SCCP31.8-1-1SR2S.loads
tftp-server flash:term31.default.loads
tftp-server flash:APPS-1.0.1.SBN
tftp-server flash:CP7921G-1.0.1.LOADS
tftp-server flash:GUI-1.0.1.SBN
tftp-server flash:SYS-1.0.1.SBN
tftp-server flash:/de-tc-sccp.jar alias German_Germany/tc-sccp.jar
tftp-server flash:/de-mk-sccp.jar alias German_Germany/mk-sccp.jar
tftp-server flash:/de-td-sccp.jar alias German_Germany/td-sccp.jar
tftp-server flash:/its/germany_7960-tones.xml alias Germany/g3-tones.xml
tftp-server flash:/g3-tones.xml alias Germany/g3-tones.xml
control-plane
voice-port 0/0/0
timeouts ringing infinity
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
echo-cancel coverage 32
compand-type a-law
cptone AT
timeouts interdigit 5
timeouts wait-release infinity
bearer-cap Speech
voice-port 0/1/1
compand-type a-law
cptone AT
bearer-cap Speech
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer cor custom
name internal
name local
name domestic
name international
name 900
name 976
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-domestic
member domestic
dial-peer cor list call-international
member international
dial-peer cor list call-900
member 900
dial-peer cor list call-976
member 976
dial-peer cor list user-internal
member internal
dial-peer cor list user-local
member internal
member local
dial-peer cor list user-domestic
member internal
member local
member domestic
dial-peer cor list user-international
member internal
member local
member domestic
dial-peer cor list user900-internal
member internal
member 900
member 976
dial-peer cor list user900-local
member internal
member local
member 900
member 976
dial-peer cor list user900-domestic
member internal
member local
member domestic
member 900
member 976
dial-peer cor list user900-international
member internal
member local
member domestic
member 900
member 976
dial-peer voice 1 pots
service stcapp
port 0/0/0
dial-peer voice 2 pots
service stcapp
port 0/0/1
dial-peer voice 3 pots
service stcapp
port 0/0/2
dial-peer voice 4 pots
service stcapp
port 0/0/3
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
destination-pattern 99
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 80
codec g711ulaw
no vad
dial-peer voice 52 pots
corlist outgoing call-local
description ** BRI pots dial-peer **
preference 1
destination-pattern 0[2-9].....
port 0/1/0
forward-digits 6
no sip-register
dial-peer voice 53 pots
corlist outgoing call-domestic
preference 1
destination-pattern 01............
port 0/1/0
prefix 1
no sip-register
dial-peer voice 54 pots
corlist outgoing call-international
preference 1
destination-pattern 0011T
port 0/1/0
prefix 011
no sip-register
dial-peer voice 55 pots
corlist outgoing call-900
preference 1
destination-pattern 01900.......
port 0/1/0
prefix 1900
no sip-register
dial-peer voice 56 pots
corlist outgoing call-976
preference 1
destination-pattern 01976.......
port 0/1/0
prefix 1976
no sip-register
dial-peer voice 57 pots
incoming called-number .
direct-inward-dial
port 0/1/0
dial-peer voice 58 pots
preference 1
destination-pattern 0110
port 0/1/1
forward-digits 3
no sip-register
dial-peer voice 59 pots
description ** BRI pots dial-peer **-Emergency dial-peer
preference 1
destination-pattern 110
port 0/1/1
forward-digits 3
no sip-register
dial-peer voice 60 pots
preference 1
port 0/1/1
forward-digits 6
no sip-register
dial-peer voice 61 pots
preference 1
port 0/1/1
prefix 1
no sip-register
dial-peer voice 62 pots
preference 1
port 0/1/1
prefix 011
no sip-register
dial-peer voice 63 pots
preference 1
port 0/1/1
prefix 1900
no sip-register
dial-peer voice 64 pots
preference 1
port 0/1/1
prefix 1976
no sip-register
dial-peer voice 65 pots
direct-inward-dial
port 0/1/1
dial-peer voice 503 pots
description ISDN INCOMING call to Ephone DN
translation-profile incoming changeCalling
incoming called-number 00-99
direct-inward-dial
dial-peer voice 501 pots
destination-pattern 0T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
direct-inward-dial
port 0/1/0
dial-peer voice 502 pots
direct-inward-dial
port 0/1/1
dial-peer voice 504 pots
description ISDN EINGEHEND
translation-profile incoming changeNullCalled
destination-pattern .T
direct-inward-dial
port 0/1/0
dial-peer voice 505 pots
direct-inward-dial
port 0/1/1
telephony-service
video
load 7960-7940 P0030702T023
load 7914 S00104000100
load 7902 CP7902080001SCCP051117A
load 7921 CP7921G-1.0.1
load 7931 SCCP31.8-1-1SR2S
load 7941GE TERM41.7-0-3-0S
load 7941 TERM41.7-0-3-0S
load 7961GE TERM41.7-0-3-0S
load 7961 TERM41.7-0-3-0S
load 7971 TERM70.7-0-3-0S
load 7970 TERM70.7-0-3-0S
load 7936 cmterm_7936.3-3-5-0
load 7906 SCCP11.8-0-3S
load 7911 SCCP11.8-0-3S
max-ephones 22
max-dn 88
ip source-address 10.1.1.1 port 2000
auto assign 10 to 27
auto assign 5 to 8 type anl
calling-number initiator
timeouts busy 4
system message UC520
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
cnf-file location flash:
user-locale DE
network-locale DE
time-zone 5
time-format 24
date-format dd-mm-yy
voicemail 99
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$rDI0$t96A3Wm6bSE4R8OIXPHur/
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 0.T
secondary-dialtone 0
create cnf-files version-stamp 7960 Dec 11 2007 07:01:37
ephone-dn 5 dual-line
number 30 no-reg primary
label 30
description aa a
name aa a
call-forward busy 99
call-forward noan 99 timeout 10
corlist incoming user-domestic
translation-profile incoming CallBlocking
ephone-dn 6 dual-line
number 31 no-reg primary
label 31
description bb b
name bb b
ephone-dn 7 dual-line
number 32 no-reg primary
label 32
description cc c
name cc c
ephone-dn 8 dual-line
number 33 no-reg primary
label 33
description dd d
name dd d
ephone-dn 9
number BCD no-reg primary
description MoH
moh ip 239.10.16.8 port 2139 out-call ABC
ephone-dn 10 dual-line
number 34 secondary 34 no-reg primary
label 34
description ee e
name ee e
corlist incoming user-international
ephone-dn 11 dual-line
number 35 no-reg primary
label 35
description ff f
name ff f
ephone-dn 87
number A801.. no-reg primary
mwi off
ephone-dn 88
number A800.. no-reg primary
mwi on
ephone 1
device-security-mode none
mac-address C58D.EF18.0000
username "a1"
type anl
button 1:5
ephone 2
mac-address C58D.EF18.0001
username "b1"
type anl
button 1:6
ephone 3
mac-address C58D.EF18.0002
username "c1"
type anl
button 1:7
ephone 4
mac-address C58D.EF18.0003
username "d1"
type anl
button 1:8
ephone 5
mac-address 001E.136C.7C82
username "e1"
type 7911
button 1:10
ephone 6
mac-address 001B.D460.743B
username "f1"
type 7960
button 1:11
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
login local
line vty 5 100
login local
ntp master
webvpn cef
end
Hier die Config
version 12.4
no service pad
service internal
hostname UC520
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp pool phone
ip dhcp pool data
stcapp ccm-group 1
stcapp
voice service voip
voice class codec 1
rule 1 /^$/ /30/
rule 2 /^0.*/ /30/
translate called 1
voice-card 0
no dspfarm
quit
archive
log config
process-max-time 50
interface Loopback0
ip nat inside
ip nat outside
duplex auto
speed auto
ip nat inside
interface BRI0/1/0
no ip address
isdn send-alerting
isdn static-tei 0
interface BRI0/1/1
no ip address
shutdown
isdn send-alerting
isdn static-tei 0
interface Vlan1
ip nat inside
interface Vlan100
ip nat inside
ip http server
ip http path flash:
tftp-server flash
tftp-server flash
tftp-server flash
tftp-server flash
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
compand-type a-law
cptone AT
bearer-cap Speech
voice-port 0/1/1
compand-type a-law
cptone AT
bearer-cap Speech
voice-port 0/4/0
auto-cut-through
signal immediate
sccp
sccp ccm group 1
name internal
name local
name domestic
name international
name 900
name 976
member internal
member local
member domestic
member 900
member 976
member internal
member internal
member local
member internal
member local
member domestic
member internal
member local
member domestic
member internal
member 900
member 976
member internal
member local
member 900
member 976
member internal
member local
member domestic
member 900
member 976
member internal
member local
member domestic
member 900
member 976
service stcapp
port 0/0/0
service stcapp
port 0/0/1
service stcapp
port 0/0/2
service stcapp
port 0/0/3
port 0/4/0
no sip-register
codec g711ulaw
no vad
codec g711ulaw
no vad
preference 1
port 0/1/0
forward-digits 6
no sip-register
preference 1
port 0/1/0
prefix 1
no sip-register
preference 1
port 0/1/0
prefix 011
no sip-register
preference 1
port 0/1/0
prefix 1900
no sip-register
preference 1
port 0/1/0
prefix 1976
no sip-register
direct-inward-dial
port 0/1/0
preference 1
port 0/1/1
forward-digits 3
no sip-register
preference 1
port 0/1/1
forward-digits 3
no sip-register
preference 1
port 0/1/1
forward-digits 6
no sip-register
preference 1
port 0/1/1
prefix 1
no sip-register
preference 1
port 0/1/1
prefix 011
no sip-register
preference 1
port 0/1/1
prefix 1900
no sip-register
preference 1
port 0/1/1
prefix 1976
no sip-register
direct-inward-dial
port 0/1/1
direct-inward-dial
direct-inward-dial
port 0/1/0
direct-inward-dial
port 0/1/1
direct-inward-dial
port 0/1/0
direct-inward-dial
port 0/1/1
telephony-service
video
max-ephones 22
max-dn 88
timeouts busy 4
user-locale DE
network-locale DE
time-zone 5
time-format 24
voicemail 99
dn-webedit
time-webedit
transfer-pattern .T
label 30
description aa a
name aa a
label 31
description bb b
name bb b
label 32
description cc c
name cc c
label 33
description dd d
name dd d
ephone-dn 9
description MoH
label 34
description ee e
name ee e
label 35
description ff f
name ff f
ephone-dn 87
mwi off
ephone-dn 88
mwi on
ephone 1
username "a1"
type anl
button 1:5
ephone 2
username "b1"
type anl
button 1:6
ephone 3
username "c1"
type anl
button 1:7
ephone 4
username "d1"
type anl
button 1:8
ephone 5
username "e1"
type 7911
button 1:10
ephone 6
username "f1"
type 7960
button 1:11
line con 0
no modem enable
line aux 0
line 2
no exec
transport input all
line vty 0 4
login local
line vty 5 100
login local
ntp master
webvpn cef
end
