UC520 mit internen S0
VSSteiner
4 Mrz 2010
ich habe ein Problem mit unserer UC520.
Wir haben einen Faxserver, der über eine ISDN Karte versendet.
Vor einer Woche haben wir eine UC520 bekommen.
Jetzt möchte ich den Faxserver weiter über die UC betreiben.
Ich habe folgendes in der CLI konfiguriert:
voice translation-rule 3
rule 1 /\(^.+\)/ /00\1/ type national national
rule 2 /\(^.+\)/ /000\1/ type international international
rule 3 /\(^.+\)/ /0\1/ type any subscriber
voice translation-rule 4
rule 15 // //
voice translation-rule 5
rule 1 /26/ /2521226/
voice translation-rule 6
rule 1 /^0/ /\1/
voice translation-rule 20
rule 1 /^252120/ /13/
rule 2 /^2521210/ /10/
rule 3 /^2521211/ /11/
rule 4 /^2521212/ /12/
rule 5 /^2521213/ /13/
rule 6 /^2521215/ /15/
rule 7 /^2521220/ /20/
rule 8 /^2521221/ /21/
rule 9 /^2521222/ /22/
rule 10 /^2521223/ /23/
rule 11 /^2521224/ /24/
rule 12 /^2521225/ /25/
rule 13 /^2521226/ /26/
rule 14 /^2521228/ /28/
rule 15 /^2521229/ /29/
voice translation-rule 1111
voice translation-rule 2000
rule 1 /2521227/ /27/
voice translation-profile OUTGOING_TRANSLATION_PROFILE
voice translation-profile PRI-AMT-OUT
translate calling 5
translate called 6
voice translation-profile PROFILE_ALL_BRI
translate calling 3
translate called 20
voice translation-profile VM_Profile
translate called 2000
interface BRI0/3/0 <--- Anschluss für Telefonie
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
isdn outgoing display-ie
isdn static-tei 0
trunk-group ALL_BRI 64
interface BRI0/3/1 <-- S0 Faxserver
no ip address
shutdown
isdn protocol-emulate network
isdn layer1-emulate network
isdn skipsend-idverify
line-power
voice-port 0/3/0
compand-type a-law
cptone DE
bearer-cap Speech
voice-port 0/3/1
compand-type a-law
cptone DE
bearer-cap Speech
dial-peer voice 2 pots
service stcapp
port 0/0/1
dial-peer voice 3 pots
service stcapp
port 0/0/2
dial-peer voice 4 pots
description ** CCA Analog Fax **
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 50 pots
description ** incoming dial peer **
translation-profile incoming PROFILE_ALL_BRI
incoming called-number .%
direct-inward-dial
port 0/1/0
dial-peer voice 51 pots
direct-inward-dial
port 0/1/1
dial-peer voice 150 pots
direct-inward-dial
port 0/3/0
dial-peer voice 151 pots
direct-inward-dial
port 0/3/1
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
destination-pattern 27
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2002 voip
description ** cue voicemail PSTN number **
translation-profile outgoing VM_Profile
destination-pattern 2521227$
b2bua
codec g711ulaw
no vad
dial-peer voice 53 pots
description ** outgoing dial peer **
translation-profile outgoing PRI-AMT-OUT
preference 1
destination-pattern 0T
progress_ind alert enable 8
port 0/1/0
forward-digits all
no sip-register
dial-peer voice 52 pots
preference 2
port 0/1/1
forward-digits all
no sip-register
dial-peer voice 153 pots
preference 3
port 0/3/0
forward-digits all
no sip-register
dial-peer voice 152 pots
preference 4
port 0/3/1
forward-digits all
no sip-register
dial-peer voice 1 pots
destination-pattern 28
port 0/0/0
no sip-register
dial-peer voice 5029 pots
description S0 Fax
destination-pattern 29
port 0/3/1
no sip-register
Habe dann die ISDN Karte an den Bri Port 0/3/1 angeschlossen.
Leider kann ich weder Faxe empfangen noch senden. Habe mal ein ISDN Telefon an die Bri 0/3/1 angeschlossen und kam weder rein noch raus.
Die ISDN Karte ist als MSN Anschluss konfiguriert.
Hoffe es kann mir einer helfen.
Hier mal ein Dabug isdn q931
000557: Mar 4 16:11:47.107: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Calling Party Number i = 0x2183, '5468568'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '2521229'
Plan:ISDN, Type:Subscriber(local)
High Layer Compat i = 0x9181
000558: Mar 4 16:11:47.119: ISDN BR0/3/1 Q931: Applying typeplan for sw-type 0x1 is 0x2 0x1, Calling num 5468568
000559: Mar 4 16:11:47.123: ISDN BR0/3/1 Q931: Sending SETUP callref = 0x0076 callID = 0x8080 switch = basic-net3 interface = Network
000560: Mar 4 16:11:47.123: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x81
Channel ID i = 0x89
Exclusive, B1
000561: Mar 4 16:11:47.123: ISDN BR0/3/1 **ERROR**: handle_l2d_srq_mail: Layer 1 inactive
000562: Mar 4 16:11:51.123: ISDN BR0/3/1 **ERROR**: handle_l2d_srq_mail: Layer 1 inactive
000563: Mar 4 16:11:51.123: ISDN BR0/3/1 **ERROR**: CCBRI_Go: NO CCB Src->L3 call id 0x8080, event 0x95 ces 0
000564: Mar 4 16:11:51.123: ISDN **ERROR**: Module-CCBRI Function-_Go Error-Event received for an unrecognized call. Data- 95, 0
000565: Mar 4 16:11:55.123: ISDN BR0/3/1 **ERROR**: CCBRI_Go: NO CCB Src->L3 call id 0x8080, event 0xC4 ces 0
000566: Mar 4 16:11:55.123: ISDN **ERROR**: Module-CCBRI Function-_Go Error-Event received for an unrecognized call. Data- C4, 0
000567: Mar 4 16:11:55.123: ISDN BR0/3/1 Q931: L3_ShutDown: Shutting down ISDN Layer 3
000568: Mar 4 16:11:55.127: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x81
Cause i = 0x80A9 - Temporary failure
000569: Mar 4 16:11:55.175: %LINK-3-UPDOWN: Interface BRI0/3/1, changed state to down
000570: Mar 4 16:11:55.195: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x01
000571: Mar 4 16:11:55.195: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x81
Bevor du das Kabel versuchst würde ich erst mal den Bri Port aktivieren ;-)
interface BRI0/3/1
no shutdown
Das Kabel wird er trotzdem brauchen.
Hab schon einige uc520 mit einer isdn PBX dahinter in betrieb genommen.
lg
Arnulf
erstmal danke für die Hilfe.
Den BRI Port habe ich, wenn ich teste auf no shut. Der Auszug aus der Konfig ist nachdem ich getestet hab und den Port wieder ausgeschaltet habe.
Habe mal anstatt das Fax ein ISDN Telefon angeschlossen und das Kabel gebaut.
Alles funktioniert prima!!!
DANKE!!!
wir verzweifeln gerade leider auch an der Config eines internen S0 Telefon's / Faxkarte an einer BRI Karte. Wir können die Karte, bzw. den Port mit line power aktivieren, aber wie vergeben wir auf dem Port eine interne MSN ?! Wir wollen mit einem Faxserver eigentlich nur Faxe nach extern verschicken, der Empfang auf diesem Interface ist nicht relevant.
Müssen wir an den Dial Peers "drehen" oder welches "Schräubchen" muss verstellt werden ?! Vielleicht hat auch jmd. ein entsprechendes Howto vorlieben, welches wir netterweise verwenden dürfen ?!
Wir freuen uns auf jegliche Antworten.
Danke und Gruß
Daniel
