This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by GNU Classpath configure 0.97.2, which was
generated by GNU Autoconf 2.61. Invocation command line was
$ ./configure --cache-file=/home/701/freetz-trunk/make/config.cache --target=mipsel-linux --host=mipsel-linux --build=i386-pc-linux-gnu --program-prefix= --program-suffix= --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --datadir=/usr/share --includedir=/usr/include --infodir=/usr/share/info --libdir=/usr/lib --libexecdir=/usr/lib --localstatedir=/var --mandir=/usr/share/man --sbindir=/usr/sbin --sysconfdir=/etc --with-gnu-ld --disable-nls --disable-gtk-peer --disable-qt-peer --disable-gconf-peer --without-libiconv-prefix --disable-plugin --with-ecj --disable-Werror
## Platform. ##
hostname = linux
uname -m = i686
uname -r = 2.6.28-17-generic
uname -s = Linux
uname -v = #58-Ubuntu SMP Tue Dec 1 18:57:07 UTC 2009
/usr/bin/uname -p = unknown
/bin/uname -X = unknown
/bin/arch = unknown
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: /home/701/freetz-trunk/toolchain/target/bin
PATH: /usr/local/sbin
PATH: /usr/local/bin
PATH: /usr/sbin
PATH: /usr/bin
PATH: /sbin
PATH: /bin
PATH: /usr/games
## Core tests. ##
configure:2047: loading cache /home/701/freetz-trunk/make/config.cache
configure:2179: checking build system type
configure:2197: result: i386-pc-linux-gnu
configure:2219: checking host system type
configure:2234: result: mipsel-unknown-linux-gnu
configure:2256: checking target system type
configure:2271: result: mipsel-unknown-linux-gnu
configure:2335: checking for a BSD-compatible install
configure:2391: result: /usr/bin/install -c
configure:2402: checking whether build environment is sane
configure:2445: result: yes
configure:2473: checking for a thread-safe mkdir -p
configure:2512: result: /bin/mkdir -p
configure:2525: checking for gawk
configure:2552: result: gawk
configure:2563: checking whether make sets $(MAKE)
configure:2584: result: yes
configure:2664: checking for mipsel-linux-strip
configure:2691: result: mipsel-linux-strip
configure:2767: checking how to create a ustar tar archive
configure:2780: tar --version
tar (GNU tar) 1.20
Copyright (C) 2008 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Written by John Gilmore and Jay Fenlason.
configure:2783: $? = 0
configure:2823: tardir=conftest.dir && eval tar --format=ustar -chf - "$tardir" >conftest.tar
configure:2826: $? = 0
configure:2830: tar -xf - <conftest.tar
configure:2833: $? = 0
configure:2846: result: gnutar
configure:3045: checking for style of include used by make
configure:3073: result: GNU
configure:3103: checking for mipsel-linux-gcc
configure:3130: result: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc
configure:3408: checking for C compiler version
configure:3415: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc --version >&5
mipsel-linux-uclibc-gcc (GCC) 4.2.4
Copyright (C) 2007 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:3418: $? = 0
configure:3425: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -v >&5
Using built-in specs.
Target: mipsel-linux-uclibc
Configured with: /home/oliver/fritzbox/freetz/trunk_i386/source/toolchain/target/gcc-4.2.4/configure --prefix=/home/oliver/fritzbox/freetz/trunk_i386/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/usr --build=i386-pc-linux-gnu --host=i386-pc-linux-gnu --target=mipsel-linux-uclibc --enable-languages=c,c++ --disable-__cxa_atexit --enable-target-optspace --with-gnu-ld --disable-libgomp --disable-multilib --disable-libmudflap --enable-shared --disable-nls --enable-sjlj-exceptions --with-float=soft --enable-cxx-flags=-msoft-float --disable-libssp : (reconfigured) /home/oliver/fritzbox/freetz/trunk_i386/source/toolchain/target/gcc-4.2.4/configure --prefix=/home/oliver/fritzbox/freetz/trunk_i386/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/usr --build=i386-pc-linux-gnu --host=i386-pc-linux-gnu --target=mipsel-linux-uclibc --enable-languages=c,c++ --disable-__cxa_atexit --enable-target-optspace --with-gnu-ld --disable-libgomp --disable-multilib --disable-libmudflap --enable-shared --disable-nls --enable-sjlj-exceptions --with-float=soft --enable-cxx-flags=-msoft-float --disable-libssp
Thread model: posix
gcc version 4.2.4
configure:3428: $? = 0
configure:3435: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -V >&5
mipsel-linux-uclibc-gcc: '-V' option must have argument
configure:3438: $? = 1
configure:3461: checking for C compiler default output file name
configure:3488: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c >&5
configure:3491: $? = 0
configure:3529: result: a.out
configure:3546: checking whether the C compiler works
configure:3576: result: yes
configure:3583: checking whether we are cross compiling
configure:3585: result: yes
configure:3588: checking for suffix of executables
configure:3595: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -o conftest -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c >&5
configure:3598: $? = 0
configure:3622: result:
configure:3628: checking for suffix of object files
configure:3680: result: o
configure:3684: checking whether we are using the GNU C compiler
configure:3736: result: yes
configure:3741: checking whether /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc accepts -g
configure:3876: result: yes
configure:3893: checking for /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc option to accept ISO C89
configure:3996: result: none needed
configure:4016: checking dependency style of /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc
configure:4107: result: gcc3
configure:4128: checking how to run the C preprocessor
configure:4244: result: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -E
configure:4273: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -E conftest.c
configure:4279: $? = 0
configure:4310: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -E conftest.c
conftest.c:10:28: error: ac_nonexistent.h: No such file or directory
configure:4316: $? = 1
configure: failed program was:
| /* confdefs.h. */
| #define PACKAGE_NAME "GNU Classpath"
| #define PACKAGE_TARNAME "classpath"
| #define PACKAGE_VERSION "0.97.2"
| #define PACKAGE_STRING "GNU Classpath 0.97.2"
| #define PACKAGE_BUGREPORT "[email protected]"
| #define PACKAGE "classpath"
| #define VERSION "0.97.2"
| /* end confdefs.h. */
| #include <ac_nonexistent.h>
configure:4354: checking for grep that handles long lines and -e
configure:4428: result: /bin/grep
configure:4433: checking for egrep
configure:4511: result: /bin/grep -E
configure:4516: checking for ANSI C header files
configure:4680: result: yes
configure:4704: checking for sys/types.h
configure:4747: result: yes
configure:4704: checking for sys/stat.h
configure:4704: checking for stdlib.h
configure:4704: checking for string.h
configure:4704: checking for memory.h
configure:4704: checking for strings.h
configure:4704: checking for inttypes.h
configure:4704: checking for stdint.h
configure:4704: checking for unistd.h
configure:4782: checking alsa/asoundlib.h usability
configure:4799: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c >&5
conftest.c:53:28: error: alsa/asoundlib.h: No such file or directory
configure:4805: $? = 1
| /* confdefs.h. */
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #include <stdio.h>
| #ifdef HAVE_SYS_TYPES_H
| # include <sys/types.h>
| #endif
| #ifdef HAVE_SYS_STAT_H
| # include <sys/stat.h>
| #endif
| #ifdef STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| #else
| # ifdef HAVE_STDLIB_H
| # endif
| #endif
| #ifdef HAVE_STRING_H
| # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
| # include <memory.h>
| # endif
| # include <string.h>
| #endif
| #ifdef HAVE_STRINGS_H
| # include <strings.h>
| #endif
| #ifdef HAVE_INTTYPES_H
| # include <inttypes.h>
| #endif
| #ifdef HAVE_STDINT_H
| # include <stdint.h>
| #endif
| #ifdef HAVE_UNISTD_H
| # include <unistd.h>
| #endif
| #include <alsa/asoundlib.h>
configure:4819: result: no
configure:4823: checking alsa/asoundlib.h presence
configure:4838: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -E conftest.c
conftest.c:20:28: error: alsa/asoundlib.h: No such file or directory
configure:4844: $? = 1
| /* confdefs.h. */
configure:4858: result: no
configure:4891: checking for alsa/asoundlib.h
configure:4899: result: no
configure:5015: checking dssi.h usability
configure:5032: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c >&5
conftest.c:53:18: error: dssi.h: No such file or directory
configure:5038: $? = 1
| /* confdefs.h. */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <dssi.h>
configure:5052: result: no
configure:5056: checking dssi.h presence
configure:5071: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -E conftest.c
conftest.c:20:18: error: dssi.h: No such file or directory
configure:5077: $? = 1
| /* confdefs.h. */
| #include <dssi.h>
configure:5091: result: no
configure:5124: checking for dssi.h
configure:5132: result: no
configure:5685: checking whether ln -s works
configure:5689: result: yes
configure:5709: checking for a BSD-compatible install
configure:5765: result: /usr/bin/install -c
configure:5893: checking for C++ compiler version
configure:5900: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc --version >&5
mipsel-linux-uclibc-g++ (GCC) 4.2.4
configure:5903: $? = 0
configure:5910: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -v >&5
Thread model: posix
gcc version 4.2.4
/home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/bin-ccache/../libexec/gcc/mipsel-linux-uclibc/4.2.4/collect2 --eh-frame-hdr -EL -dynamic-linker /lib/ld-uClibc.so.0 /home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/bin-ccache/../lib/gcc/mipsel-linux-uclibc/4.2.4/../../../../mipsel-linux-uclibc/lib/crt1.o /home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/bin-ccache/../lib/gcc/mipsel-linux-uclibc/4.2.4/../../../../mipsel-linux-uclibc/lib/crti.o /home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/bin-ccache/../lib/gcc/mipsel-linux-uclibc/4.2.4/crtbegin.o -L/home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/usr/lib/ -L/home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/bin-ccache/../lib/gcc/mipsel-linux-uclibc/4.2.4/ -L/home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/bin-ccache/../lib/gcc/mipsel-linux-uclibc/4.2.4 -L/home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/bin-ccache/../lib/gcc -L/home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/bin-ccache/../lib/gcc/mipsel-linux-uclibc/4.2.4/../../../../mipsel-linux-uclibc/lib -luClibc++ -lc -lgcc --as-needed -lgcc_s --no-as-needed /home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/bin-ccache/../lib/gcc/mipsel-linux-uclibc/4.2.4/crtend.o /home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/bin-ccache/../lib/gcc/mipsel-linux-uclibc/4.2.4/../../../../mipsel-linux-uclibc/lib/crtn.o
/home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/bin-ccache/../lib/gcc/mipsel-linux-uclibc/4.2.4/../../../../mipsel-linux-uclibc/lib/crt1.o: In function `__start':
(.text+0x1c): undefined reference to `main'
collect2: ld returned 1 exit status
configure:5913: $? = 1
configure:5920: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -V >&5
mipsel-linux-uclibc-g++: '-V' must come at the start of the command line
configure:5923: $? = 1
configure:5926: checking whether we are using the GNU C++ compiler
configure:5978: result: yes
configure:5983: checking whether /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc accepts -g
configure:6118: result: yes
configure:6143: checking dependency style of /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc
configure:6234: result: gcc3
configure:6322: checking for a sed that does not truncate output
configure:6378: result: /bin/sed
configure:6392: checking for ld used by /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc
configure:6459: result: /home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld
configure:6468: checking if the linker (/home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld) is GNU ld
configure:6483: result: yes
configure:6488: checking for /home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld option to reload object files
configure:6495: result: -r
configure:6513: checking for BSD-compatible nm
configure:6562: result: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-nm -B
configure:6566: checking how to recognize dependent libraries
configure:6752: result: pass_all
configure:6996: checking for dlfcn.h
configure:7002: result: yes
configure:7146: checking how to run the C++ preprocessor
configure:7258: result: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -E
configure:7287: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -E conftest.cpp
configure:7293: $? = 0
configure:7324: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -E conftest.cpp
conftest.cpp:21:28: error: ac_nonexistent.h: No such file or directory
configure:7330: $? = 1
| /* confdefs.h. */
| #define HAVE_DLFCN_H 1
configure:7379: checking for mipsel-linux-g77
configure:7409: result: no
configure:7379: checking for mipsel-linux-xlf
configure:7379: checking for mipsel-linux-f77
configure:7379: checking for mipsel-linux-frt
configure:7379: checking for mipsel-linux-pgf77
configure:7379: checking for mipsel-linux-cf77
configure:7379: checking for mipsel-linux-fort77
configure:7379: checking for mipsel-linux-fl32
configure:7379: checking for mipsel-linux-af77
configure:7379: checking for mipsel-linux-xlf90
configure:7379: checking for mipsel-linux-f90
configure:7379: checking for mipsel-linux-pgf90
configure:7379: checking for mipsel-linux-pghpf
configure:7379: checking for mipsel-linux-epcf90
configure:7379: checking for mipsel-linux-gfortran
configure:7379: checking for mipsel-linux-g95
configure:7379: checking for mipsel-linux-xlf95
configure:7379: checking for mipsel-linux-f95
configure:7379: checking for mipsel-linux-ifort
configure:7379: checking for mipsel-linux-ifc
configure:7379: checking for mipsel-linux-efc
configure:7379: checking for mipsel-linux-pgf95
configure:7379: checking for mipsel-linux-lf95
configure:7379: checking for mipsel-linux-ftn
configure:7423: checking for g77
configure:7453: result: no
configure:7423: checking for xlf
configure:7423: checking for f77
configure:7423: checking for frt
configure:7423: checking for pgf77
configure:7423: checking for cf77
configure:7423: checking for fort77
configure:7423: checking for fl32
configure:7423: checking for af77
configure:7423: checking for xlf90
configure:7423: checking for f90
configure:7423: checking for pgf90
configure:7423: checking for pghpf
configure:7423: checking for epcf90
configure:7423: checking for gfortran
configure:7423: checking for g95
configure:7423: checking for xlf95
configure:7423: checking for f95
configure:7423: checking for ifort
configure:7423: checking for ifc
configure:7423: checking for efc
configure:7423: checking for pgf95
configure:7423: checking for lf95
configure:7423: checking for ftn
configure:7480: checking for Fortran 77 compiler version
configure:7487: --version >&5
./configure: line 7488: --version: command not found
configure:7490: $? = 127
configure:7497: -v >&5
./configure: line 7498: -v: command not found
configure:7500: $? = 127
configure:7507: -V >&5
./configure: line 7508: -V: command not found
configure:7510: $? = 127
configure:7518: checking whether we are using the GNU Fortran 77 compiler
configure:7560: result: no
configure:7566: checking whether accepts -g
configure:7605: result: no
configure:7634: checking the maximum length of command line arguments
configure:7746: result: 32768
configure:7758: checking command to parse /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-nm -B output from /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc object
configure:7966: result: ok
configure:7970: checking for objdir
configure:7985: result: .libs
configure:8037: checking for mipsel-linux-ar
configure:8064: result: mipsel-linux-ar
configure:8133: checking for mipsel-linux-ranlib
configure:8160: result: mipsel-linux-ranlib
configure:8229: checking for mipsel-linux-strip
configure:8256: result: mipsel-linux-strip
configure:8845: checking for correct ltmain.sh version
configure:8895: result: yes
configure:8955: checking if /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc supports -fno-rtti -fno-exceptions
configure:8990: result: no
configure:9005: checking for /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc option to produce PIC
configure:9237: result: -fPIC
configure:9245: checking if /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc PIC flag -fPIC works
configure:9280: result: yes
configure:9308: checking if /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc static flag -static works
configure:9336: result: yes
configure:9346: checking if /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc supports -c -o file.o
configure:9393: result: yes
configure:9419: checking whether the /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc linker (/home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld) supports shared libraries
configure:10399: result: yes
configure:10420: checking whether -lc should be explicitly linked in
configure:10425: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c >&5
configure:10428: $? = 0
configure:10443: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -shared conftest.o -v -Wl,-soname -Wl,conftest -o conftest 2\>\&1 \| grep -lc \>/dev/null 2\>\&1
configure:10446: $? = 0
configure:10458: result: no
configure:10466: checking dynamic linker characteristics
configure:11081: result: GNU/Linux ld.so
configure:11105: checking how to hardcode library paths into programs
configure:11130: result: immediate
configure:11144: checking whether stripping libraries is possible
configure:11149: result: yes
configure:11951: checking if libtool supports shared libraries
configure:11953: result: yes
configure:11956: checking whether to build shared libraries
configure:11977: result: yes
configure:11980: checking whether to build static libraries
configure:11984: result: no
configure:12078: creating libtool
configure:12671: checking for ld used by /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc
configure:12738: result: /home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld
configure:12747: checking if the linker (/home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld) is GNU ld
configure:12762: result: yes
configure:12813: checking whether the /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc linker (/home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld) supports shared libraries
configure:13759: result: yes
configure:13776: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -c -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.cpp >&5
configure:13779: $? = 0
configure:13935: checking for /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc option to produce PIC
configure:14219: result: -fPIC
configure:14227: checking if /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc PIC flag -fPIC works
configure:14245: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -c -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fPIC -DPIC conftest.cpp >&5
configure:14249: $? = 0
configure:14262: result: yes
configure:14290: checking if /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc static flag -static works
configure:14318: result: yes
configure:14328: checking if /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc supports -c -o file.o
configure:14375: result: yes
configure:14401: checking whether the /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc linker (/home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld) supports shared libraries
configure:14427: result: yes
configure:14494: checking dynamic linker characteristics
configure:15057: result: GNU/Linux ld.so
configure:15081: checking how to hardcode library paths into programs
configure:15106: result: immediate
configure:21357: checking for gawk
configure:21384: result: gawk
configure:21403: checking for mipsel-linux-gcc
configure:21430: result: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc
configure:21708: checking for C compiler version
configure:21715: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc --version >&5
configure:21718: $? = 0
configure:21725: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -v >&5
Thread model: posix
gcc version 4.2.4
configure:21728: $? = 0
configure:21735: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -V >&5
configure:21738: $? = 1
configure:21741: checking whether we are using the GNU C compiler
configure:21793: result: yes
configure:21798: checking whether /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc accepts -g
configure:21933: result: yes
configure:21950: checking for /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc option to accept ISO C89
configure:22053: result: none needed
configure:22073: checking dependency style of /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc
configure:22164: result: gcc3
configure:22180: checking whether /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc and cc understand -c and -o together
configure:22279: result: yes
configure:22310: checking how to run the C preprocessor
configure:22426: result: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -E
configure:22455: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -E conftest.c
configure:22461: $? = 0
configure:22492: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -E conftest.c
conftest.c:21:28: error: ac_nonexistent.h: No such file or directory
configure:22498: $? = 1
| /* confdefs.h. */
configure:22600: checking __attribute__((,,))
configure:22627: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c >&5
configure:22633: $? = 0
configure:22652: result: yes
configure:22676: checking __attribute__((unused))
configure:22703: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c >&5
configure:22709: $? = 0
configure:22728: result: yes
configure:22748: checking for ANSI C header files
configure:22912: result: yes
configure:22923: checking size of void *
configure:22983: result: 4
configure:22992: checking whether byte ordering is bigendian
configure:23145: result: no
configure:23246: checking for unistd.h
configure:23252: result: yes
configure:23246: checking for sys/types.h
configure:23256: checking sys/config.h usability
configure:23273: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c >&5
conftest.c:61:24: error: sys/config.h: No such file or directory
configure:23279: $? = 1
| /* confdefs.h. */
| #define HAVE_GNUC25_ATTRIB
| #define HAVE_GNUC25_UNUSED
| #define SIZEOF_VOID_P 4
| #define BYTEORDER 1234
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <sys/config.h>
configure:23293: result: no
configure:23297: checking sys/config.h presence
configure:23312: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -E conftest.c
conftest.c:28:24: error: sys/config.h: No such file or directory
configure:23318: $? = 1
| /* confdefs.h. */
configure:23332: result: no
configure:23365: checking for sys/config.h
configure:23373: result: no
configure:23246: checking for sys/ioctl.h
configure:23256: checking asm/ioctls.h usability
configure:23279: $? = 0
configure:23293: result: yes
configure:23297: checking asm/ioctls.h presence
configure:23318: $? = 0
configure:23332: result: yes
configure:23365: checking for asm/ioctls.h
configure:23373: result: yes
configure:23246: checking for inttypes.h
configure:23246: checking for stdint.h
configure:23246: checking for utime.h
configure:23256: checking sys/utime.h usability
conftest.c:66:23: error: sys/utime.h: No such file or directory
| /* confdefs.h. */
| #define HAVE_SYS_IOCTL_H 1
| #define HAVE_ASM_IOCTLS_H 1
| #define HAVE_UTIME_H 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <sys/utime.h>
configure:23297: checking sys/utime.h presence
conftest.c:33:23: error: sys/utime.h: No such file or directory
| /* confdefs.h. */
configure:23365: checking for sys/utime.h
configure:23256: checking sys/filio.h usability
conftest.c:66:23: error: sys/filio.h: No such file or directory
| /* confdefs.h. */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <sys/filio.h>
configure:23297: checking sys/filio.h presence
conftest.c:33:23: error: sys/filio.h: No such file or directory
| /* confdefs.h. */
configure:23365: checking for sys/filio.h
configure:23246: checking for sys/time.h
configure:23246: checking for sys/select.h
configure:23256: checking crt_externs.h usability
conftest.c:68:25: error: crt_externs.h: No such file or directory
| /* confdefs.h. */
| #define HAVE_SYS_TIME_H 1
| #define HAVE_SYS_SELECT_H 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <crt_externs.h>
configure:23297: checking crt_externs.h presence
conftest.c:35:25: error: crt_externs.h: No such file or directory
| /* confdefs.h. */
configure:23365: checking for crt_externs.h
configure:23246: checking for fcntl.h
configure:23246: checking for sys/mman.h
configure:23256: checking magic.h usability
conftest.c:70:19: error: magic.h: No such file or directory
| /* confdefs.h. */
| #define HAVE_FCNTL_H 1
| #define HAVE_SYS_MMAN_H 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <magic.h>
configure:23297: checking magic.h presence
conftest.c:37:19: error: magic.h: No such file or directory
| /* confdefs.h. */
| #include <magic.h>
configure:23365: checking for magic.h
configure:23256: checking sys/event.h usability
conftest.c:70:23: error: sys/event.h: No such file or directory
| /* confdefs.h. */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <sys/event.h>
configure:23297: checking sys/event.h presence
conftest.c:37:23: error: sys/event.h: No such file or directory
| /* confdefs.h. */
configure:23365: checking for sys/event.h
configure:23256: checking sys/epoll.h usability
configure:23297: checking sys/epoll.h presence
configure:23365: checking for sys/epoll.h
configure:23256: checking ifaddrs.h usability
conftest.c:71:21: error: ifaddrs.h: No such file or directory
| /* confdefs.h. */
| #define HAVE_SYS_EPOLL_H 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <ifaddrs.h>
configure:23297: checking ifaddrs.h presence
conftest.c:38:21: error: ifaddrs.h: No such file or directory
| /* confdefs.h. */
configure:23365: checking for ifaddrs.h
configure:23246: checking for netinet/in_systm.h
configure:23256: checking netinet/ip.h usability
configure:23297: checking netinet/ip.h presence
configure:23365: checking for netinet/ip.h
configure:23256: checking net/if.h usability
configure:23297: checking net/if.h presence
configure:23365: checking for net/if.h
configure:23256: checking sys/loadavg.h usability
conftest.c:74:25: error: sys/loadavg.h: No such file or directory
| /* confdefs.h. */
| #define HAVE_NETINET_IN_SYSTM_H 1
| #define HAVE_NETINET_IP_H 1
| #define HAVE_NET_IF_H 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <sys/loadavg.h>
configure:23297: checking sys/loadavg.h presence
conftest.c:41:25: error: sys/loadavg.h: No such file or directory
| /* confdefs.h. */
configure:23365: checking for sys/loadavg.h
conftest.c:44:24: error: sys/config.h: No such file or directory
configure:23464: checking for library containing inet_pton
configure:23505: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -o conftest -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c >&5
configure:23511: $? = 0
configure:23539: result: none required
configure:23619: checking for ftruncate
configure:23699: result: yes
configure:23619: checking for fsync
configure:23675: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -o conftest -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c >&5
configure:23681: $? = 0
configure:23619: checking for select
configure:23619: checking for gethostname
configure:23619: checking for socket
configure:23619: checking for strerror
configure:23619: checking for fork
configure:23619: checking for pipe
configure:23619: checking for execve
conftest.c:75: warning: conflicting types for built-in function 'execve'
configure:23619: checking for open
configure:23619: checking for close
configure:23619: checking for lseek
configure:23619: checking for fstat
configure:23619: checking for read
configure:23619: checking for readv
configure:23619: checking for write
configure:23619: checking for writev
configure:23619: checking for htonl
configure:23619: checking for memset
configure:23619: checking for htons
configure:23619: checking for connect
configure:23619: checking for getsockname
configure:23619: checking for getpeername
configure:23619: checking for bind
configure:23619: checking for listen
configure:23619: checking for accept
configure:23619: checking for recvfrom
configure:23619: checking for send
configure:23619: checking for sendto
configure:23619: checking for setsockopt
configure:23619: checking for getsockopt
configure:23619: checking for time
configure:23619: checking for mktime
configure:23619: checking for gethostbyname_r
configure:23619: checking for localtime_r
configure:23619: checking for strerror_r
configure:23699: result: no
configure:23619: checking for fcntl
configure:23619: checking for statvfs
configure:23619: checking for mmap
configure:23619: checking for munmap
configure:23619: checking for mincore
configure:23619: checking for msync
configure:23619: checking for madvise
configure:23619: checking for getpagesize
configure:23619: checking for sysconf
configure:23619: checking for lstat
configure:23619: checking for readlink
configure:23619: checking for inet_aton
configure:23619: checking for inet_addr
configure:23619: checking for inet_pton
configure:23619: checking for getifaddrs
/tmp/ccA5yH3A.o: In function `main':
conftest.c:(.text+0x18): undefined reference to `getifaddrs'
configure:23681: $? = 1
| /* confdefs.h. */
| #define HAVE_INT32_DEFINED 1
| #define HAVE_BSD_INT32_DEFINED 1
| #define HAVE_FTRUNCATE 1
| #define HAVE_FSYNC 1
| #define HAVE_SELECT 1
| #define HAVE_GETHOSTNAME 1
| #define HAVE_SOCKET 1
| #define HAVE_STRERROR 1
| #define HAVE_FORK 1
| #define HAVE_PIPE 1
| #define HAVE_EXECVE 1
| #define HAVE_OPEN 1
| #define HAVE_CLOSE 1
| #define HAVE_LSEEK 1
| #define HAVE_FSTAT 1
| #define HAVE_READ 1
| #define HAVE_READV 1
| #define HAVE_WRITE 1
| #define HAVE_WRITEV 1
| #define HAVE_HTONL 1
| #define HAVE_MEMSET 1
| #define HAVE_HTONS 1
| #define HAVE_CONNECT 1
| #define HAVE_GETSOCKNAME 1
| #define HAVE_GETPEERNAME 1
| #define HAVE_BIND 1
| #define HAVE_LISTEN 1
| #define HAVE_ACCEPT 1
| #define HAVE_RECVFROM 1
| #define HAVE_SEND 1
| #define HAVE_SENDTO 1
| #define HAVE_SETSOCKOPT 1
| #define HAVE_GETSOCKOPT 1
| #define HAVE_TIME 1
| #define HAVE_MKTIME 1
| #define HAVE_GETHOSTBYNAME_R 1
| #define HAVE_LOCALTIME_R 1
| #define HAVE_FCNTL 1
| #define HAVE_STATVFS 1
| #define HAVE_MMAP 1
| #define HAVE_MUNMAP 1
| #define HAVE_MINCORE 1
| #define HAVE_MSYNC 1
| #define HAVE_MADVISE 1
| #define HAVE_GETPAGESIZE 1
| #define HAVE_SYSCONF 1
| #define HAVE_LSTAT 1
| #define HAVE_READLINK 1
| #define HAVE_INET_ATON 1
| #define HAVE_INET_ADDR 1
| #define HAVE_INET_PTON 1
| /* Define getifaddrs to an innocuous variant, in case <limits.h> declares getifaddrs.
| For example, HP-UX 11i <limits.h> declares gettimeofday. */
| #define getifaddrs innocuous_getifaddrs
| /* System header to define __stub macros and hopefully few prototypes,
| which can conflict with char getifaddrs (); below.
| Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
| <limits.h> exists even on freestanding compilers. */
| #ifdef __STDC__
| # include <limits.h>
| #else
| # include <assert.h>
| #endif
| #undef getifaddrs
| /* Override any GCC internal prototype to avoid an error.
| Use char because int might match the return type of a GCC
| builtin and then its argument prototype would still apply. */
| #ifdef __cplusplus
| extern "C"
| #endif
| char getifaddrs ();
| /* The GNU C library defines this for functions which it implements
| to always fail with ENOSYS. Some functions are actually named
| something starting with __ and the normal name is an alias. */
| #if defined __stub_getifaddrs || defined __stub___getifaddrs
| choke me
| #endif
| int
| main ()
| return getifaddrs ();
| return 0;
configure:23619: checking for kqueue
/tmp/ccRA1srJ.o: In function `main':
conftest.c:(.text+0x18): undefined reference to `kqueue'
| /* confdefs.h. */
| #define HAVE_FORK 1
| #define HAVE_PIPE 1
| #define HAVE_OPEN 1
| #define HAVE_READ 1
| #define HAVE_BIND 1
| #define HAVE_SEND 1
| #define HAVE_TIME 1
| #define HAVE_MMAP 1
| /* Define kqueue to an innocuous variant, in case <limits.h> declares kqueue.
| #define kqueue innocuous_kqueue
| which can conflict with char kqueue (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef kqueue
| #ifdef __cplusplus
| extern "C"
| #endif
| char kqueue ();
| #if defined __stub_kqueue || defined __stub___kqueue
| choke me
| #endif
| int
| main ()
| return kqueue ();
| return 0;
configure:23619: checking for kevent
/tmp/cco0LDpU.o: In function `main':
conftest.c:(.text+0x18): undefined reference to `kevent'
| /* confdefs.h. */
| #define HAVE_FORK 1
| #define HAVE_PIPE 1
| #define HAVE_OPEN 1
| #define HAVE_READ 1
| #define HAVE_BIND 1
| #define HAVE_SEND 1
| #define HAVE_TIME 1
| #define HAVE_MMAP 1
| /* Define kevent to an innocuous variant, in case <limits.h> declares kevent.
| #define kevent innocuous_kevent
| which can conflict with char kevent (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef kevent
| #ifdef __cplusplus
| extern "C"
| #endif
| char kevent ();
| #if defined __stub_kevent || defined __stub___kevent
| choke me
| #endif
| int
| main ()
| return kevent ();
| return 0;
configure:23619: checking for epoll_create
configure:23619: checking for getloadavg
/tmp/ccwxAsba.o: In function `main':
conftest.c:(.text+0x18): undefined reference to `getloadavg'
| /* confdefs.h. */
| #define HAVE_FORK 1
| #define HAVE_PIPE 1
| #define HAVE_OPEN 1
| #define HAVE_READ 1
| #define HAVE_BIND 1
| #define HAVE_SEND 1
| #define HAVE_TIME 1
| #define HAVE_MMAP 1
| #define HAVE_EPOLL_CREATE 1
| /* Define getloadavg to an innocuous variant, in case <limits.h> declares getloadavg.
| #define getloadavg innocuous_getloadavg
| which can conflict with char getloadavg (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef getloadavg
| #ifdef __cplusplus
| extern "C"
| #endif
| char getloadavg ();
| #if defined __stub_getloadavg || defined __stub___getloadavg
| choke me
| #endif
| int
| main ()
| return getloadavg ();
| return 0;
configure:23711: checking for magic_open in -lmagic
configure:23746: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -o conftest -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c -lmagic >&5
/home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/bin-ccache/../lib/gcc/mipsel-linux-uclibc/4.2.4/../../../../mipsel-linux-uclibc/bin/ld: cannot find -lmagic
configure:23752: $? = 1
| /* confdefs.h. */
| #define HAVE_FORK 1
| #define HAVE_PIPE 1
| #define HAVE_OPEN 1
| #define HAVE_READ 1
| #define HAVE_BIND 1
| #define HAVE_SEND 1
| #define HAVE_TIME 1
| #define HAVE_MMAP 1
| #ifdef __cplusplus
| extern "C"
| #endif
| char magic_open ();
| int
| main ()
| return magic_open ();
| return 0;
configure:23770: result: no
configure:23778: checking whether struct sockaddr_in6 is in netinet/in.h
configure:23801: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c >&5
configure:23807: $? = 0
configure:23817: result: yes
configure:23829: checking whether time.h and sys/time.h may both be included
configure:23880: result: yes
configure:23890: checking whether struct tm is in sys/time.h or time.h
configure:23941: result: time.h
configure:23951: checking for struct tm.tm_zone
configure:23982: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c >&5
configure:23988: $? = 0
configure:24048: result: yes
configure:24200: checking for tm_gmtoff in struct tm
configure:24223: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c >&5
configure:24229: $? = 0
configure:24239: result: yes
configure:24351: checking for an ANSI C-conforming const
configure:24447: result: yes
configure:24457: checking for inline
configure:24507: result: inline
configure:24526: checking for __attribute__
configure:24547: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c >&5
configure:24553: $? = 0
configure:24570: result: yes
configure:24591: checking how many arguments gethostbyname_r() takes
configure:24636: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c >&5
conftest.c: In function 'main':
conftest.c:105: error: too few arguments to function 'gethostbyname_r'
configure:24642: $? = 1
| /* confdefs.h. */
| #define HAVE_FORK 1
| #define HAVE_PIPE 1
| #define HAVE_OPEN 1
| #define HAVE_READ 1
| #define HAVE_BIND 1
| #define HAVE_SEND 1
| #define HAVE_TIME 1
| #define HAVE_MMAP 1
| #define HAVE_INET6 1
| #define TIME_WITH_SYS_TIME 1
| #define HAVE_STRUCT_TM_TM_ZONE 1
| #define HAVE_TM_ZONE 1
| #define STRUCT_TM_HAS_GMTOFF 1
| #include <netdb.h>
| int
| main ()
| char *name = "www.gnu.org";
| (void)gethostbyname_r(name) /* ; */
| return 0;
configure:24692: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c >&5
configure:24698: $? = 0
configure:24856: result: six
configure:24931: checking for ld used by GCC
configure:24994: result: /home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld
configure:25003: checking if the linker (/home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld) is GNU ld
configure:25015: result: yes
configure:25021: checking for shared library run path origin
configure:25034: result: done
configure:25464: checking for iconv
configure:25496: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -o conftest -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c >&5
configure:25502: $? = 0
configure:25572: result: yes
configure:25595: checking for iconv declaration
configure:25634: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c >&5
configure:25640: $? = 0
configure:25659: result:
extern size_t iconv (iconv_t cd, char * *inbuf, size_t *inbytesleft, char * *outbuf, size_t *outbytesleft);
configure:28769: checking for MSG_NOSIGNAL
configure:28792: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c >&5
configure:28798: $? = 0
configure:28803: result: yes
configure:28820: checking for SO_NOSIGPIPE
configure:28843: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c >&5
conftest.c:107: error: 'SO_NOSIGPIPE' undeclared (first use in this function)
conftest.c:107: error: (Each undeclared identifier is reported only once
conftest.c:107: error: for each function it appears in.)
configure:28849: $? = 1
| /* confdefs.h. */
| #define HAVE_FORK 1
| #define HAVE_PIPE 1
| #define HAVE_OPEN 1
| #define HAVE_READ 1
| #define HAVE_BIND 1
| #define HAVE_SEND 1
| #define HAVE_TIME 1
| #define HAVE_MMAP 1
| #define HAVE_FUNC_GETHOSTBYNAME_R_6 1
| #define HAVE_ICONV 1
| #define ICONV_CONST
| #define HAVE_MSG_NOSIGNAL 1
| #include <sys/socket.h>
| int
| main ()
| int f = SO_NOSIGPIPE;
| return 0;
configure:28865: result: no
configure:28871: checking for MSG_WAITALL
configure:28894: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c >&5
configure:28900: $? = 0
configure:28905: result: yes
configure:30056: checking jni_md.h support
configure:30064: WARNING: no
configure:30090: checking whether to enable maintainer-specific portions of Makefiles
configure:30099: result: no
configure:30181: checking for mkdir
configure:30199: found /bin/mkdir
configure:30211: result: /bin/mkdir
configure:30221: checking for cp
configure:30239: found /bin/cp
configure:30251: result: /bin/cp
configure:30261: checking for date
configure:30279: found /bin/date
configure:30291: result: /bin/date
configure:30302: checking for find
configure:30320: found /usr/bin/find
configure:30332: result: /usr/bin/find
configure:30344: checking for zip
configure:30362: found /usr/bin/zip
configure:30374: result: /usr/bin/zip
configure:30397: checking for fastjar
configure:30415: found /usr/bin/fastjar
configure:30427: result: /usr/bin/fastjar
configure:30755: checking whether to regenerate parsers with jay
configure:30757: result: no
configure:30794: checking for stdint types
configure:30827: /home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -c conftest.c >&5
configure:30833: $? = 0
configure:30866: result: stdint.h (shortcircuit)
configure:33570: result: make use of stdint.h in include/config-int.h (assuming C99 compatible system)
configure:33625: checking for ecj
configure:33655: result: no
configure:33625: checking for ecj-3.3
configure:33625: checking for ecj-3.2
configure:33625: checking for javac
configure:33641: found /usr/bin/javac
configure:33652: result: javac -Xlint:unchecked
configure:33712: checking if javac -Xlint:unchecked works
configure:33732: javac -Xlint:unchecked -source 1.5 -target 1.5 Object.java
Error: The option "-Xlint:unchecked" is unsupported in this build.
configure:33735: $? = 2
configure:33739: error: The Java compiler javac -Xlint:unchecked failed (see config.log, check the CLASSPATH?)
## Cache variables. ##
ac_cv_CAN_USE_SYSCTL=no
ac_cv_build=i386-pc-linux-gnu
ac_cv_build_alias=i386-pc-linux-gnu
ac_cv_c_attribute=yes
ac_cv_c_bigendian=no
ac_cv_c_compiler_gnu=yes
ac_cv_c_const=yes
ac_cv_c_inline=inline
ac_cv_c_int16_t=yes
ac_cv_c_int32_t=yes
ac_cv_c_int8_t=yes
ac_cv_c_uint32_t=yes
ac_cv_c_uint64_t=yes
ac_cv_c_volatile=yes
ac_cv_cpp_func=yes
ac_cv_cxx_compiler_gnu=yes
ac_cv_decl_map_anon=yes
ac_cv_env_CCASFLAGS_set=
ac_cv_env_CCASFLAGS_value=
ac_cv_env_CCAS_set=
ac_cv_env_CCAS_value=
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=set
ac_cv_env_CC_value=/home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc
ac_cv_env_CFLAGS_set=set
ac_cv_env_CFLAGS_value='-Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64'
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=set
ac_cv_env_CXXFLAGS_value='-Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64'
ac_cv_env_CXX_set=set
ac_cv_env_CXX_value=/home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc
ac_cv_env_F77_set=
ac_cv_env_F77_value=
ac_cv_env_FFLAGS_set=
ac_cv_env_FFLAGS_value=
ac_cv_env_LDFLAGS_set=set
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_LINGUAS_set=
ac_cv_env_LINGUAS_value=
ac_cv_env_XMKMF_set=
ac_cv_env_XMKMF_value=
ac_cv_env_build_alias_set=set
ac_cv_env_build_alias_value=i386-pc-linux-gnu
ac_cv_env_dav_group_set=
ac_cv_env_dav_group_value=
ac_cv_env_dav_localstatedir_set=
ac_cv_env_dav_localstatedir_value=
ac_cv_env_dav_syscachedir_set=
ac_cv_env_dav_syscachedir_value=
ac_cv_env_dav_user_set=
ac_cv_env_dav_user_value=
ac_cv_env_host_alias_set=set
ac_cv_env_host_alias_value=mipsel-linux
ac_cv_env_ssbindir_set=
ac_cv_env_ssbindir_value=
ac_cv_env_target_alias_set=set
ac_cv_env_target_alias_value=mipsel-linux
ac_cv_exeext=
ac_cv_f77_compiler_gnu=no
ac_cv_file__usr_X11R6_lib64=no
ac_cv_file__usr_X11R6_lib=no
ac_cv_func_CRYPTO_set_idptr_callback=no
ac_cv_func_SSL_SESSION_cmp=yes
ac_cv_func__doprnt=no
ac_cv_func__exit=yes
ac_cv_func__getpty=no
ac_cv_func_accept=yes
ac_cv_func_alloca_works=yes
ac_cv_func_basename=yes
ac_cv_func_bcopy=yes
ac_cv_func_bind=yes
ac_cv_func_bzero=yes
ac_cv_func_calloc_0_nonnull=yes
ac_cv_func_chown_works=no
ac_cv_func_clearenv=yes
ac_cv_func_close=yes
ac_cv_func_closedir_void=yes
ac_cv_func_connect=yes
ac_cv_func_daemon=yes
ac_cv_func_dlopen=yes
ac_cv_func_dup2=yes
ac_cv_func_endpwent=yes
ac_cv_func_endutent=yes
ac_cv_func_endutxent=no
ac_cv_func_epoll_create=yes
ac_cv_func_epoll_ctl=no
ac_cv_func_execve=yes
ac_cv_func_fchmod=yes
ac_cv_func_fchown=yes
ac_cv_func_fcntl=yes
ac_cv_func_finite=yes
ac_cv_func_fork=yes
ac_cv_func_fork_works=yes
ac_cv_func_freeaddrinfo=yes
ac_cv_func_fseeko=yes
ac_cv_func_fstat=yes
ac_cv_func_fsync=yes
ac_cv_func_ftruncate=yes
ac_cv_func_gai_strerror=yes
ac_cv_func_getaddrinfo=yes
ac_cv_func_getcwd=yes
ac_cv_func_getdelim=yes
ac_cv_func_getegid=yes
ac_cv_func_geteuid=yes
ac_cv_func_gethostbyname_r=yes
ac_cv_func_gethostname=yes
ac_cv_func_getifaddrs=no
ac_cv_func_getline=yes
ac_cv_func_getloadavg=no
ac_cv_func_getmntent=yes
ac_cv_func_getnameinfo=yes
ac_cv_func_getopt_long=yes
ac_cv_func_getpagesize=yes
ac_cv_func_getpeername=yes
ac_cv_func_getsockname=yes
ac_cv_func_getsockopt=yes
ac_cv_func_getspnam=yes
ac_cv_func_gettimeofday=yes
ac_cv_func_getttynam=yes
ac_cv_func_getusershell=yes
ac_cv_func_getutent=yes
ac_cv_func_getutid=yes
ac_cv_func_getutline=yes
ac_cv_func_getutxent=no
ac_cv_func_getutxid=no
ac_cv_func_getutxline=no
ac_cv_func_htonl=yes
ac_cv_func_htons=yes
ac_cv_func_index=yes
ac_cv_func_inet_addr=yes
ac_cv_func_inet_aton=yes
ac_cv_func_inet_ntop=yes
ac_cv_func_inet_pton=yes
ac_cv_func_isatty=yes
ac_cv_func_isblank=yes
ac_cv_func_isinf=yes
ac_cv_func_isnan=yes
ac_cv_func_issetugid=no
ac_cv_func_kevent=no
ac_cv_func_kqueue=no
ac_cv_func_link=yes
ac_cv_func_listen=yes
ac_cv_func_localtime_r=yes
ac_cv_func_logout=yes
ac_cv_func_logwtmp=yes
ac_cv_func_lseek=yes
ac_cv_func_lstat=yes
ac_cv_func_lstat_dereferences_slashed_symlink=no
ac_cv_func_madvise=yes
ac_cv_func_malloc_0_nonnull=yes
ac_cv_func_memcmp_working=yes
ac_cv_func_memcpy=yes
ac_cv_func_memmove=yes
ac_cv_func_memset=yes
ac_cv_func_mincore=yes
ac_cv_func_mkdir=yes
ac_cv_func_mkstemp=yes
ac_cv_func_mktime=yes
ac_cv_func_mmap=yes
ac_cv_func_mmap_anon=yes
ac_cv_func_mmap_dev_zero=yes
ac_cv_func_mmap_file=yes
ac_cv_func_mmap_fixed_mapped=no
ac_cv_func_msync=yes
ac_cv_func_munmap=yes
ac_cv_func_nl_langinfo=yes
ac_cv_func_open=yes
ac_cv_func_pipe=yes
ac_cv_func_poll=yes
ac_cv_func_posix_getgrgid_r=yes
ac_cv_func_posix_getpwuid_r=yes
ac_cv_func_putenv=yes
ac_cv_func_pututline=yes
ac_cv_func_pututxline=no
ac_cv_func_read=yes
ac_cv_func_readlink=yes
ac_cv_func_readv=yes
ac_cv_func_realloc_0_nonnull=yes
ac_cv_func_recvfrom=yes
ac_cv_func_remove=yes
ac_cv_func_rename=yes
ac_cv_func_rindex=yes
ac_cv_func_rpmatch=no
ac_cv_func_select=yes
ac_cv_func_select_args='int,fd_set *,struct timeval *'
ac_cv_func_send=yes
ac_cv_func_sendto=yes
ac_cv_func_setbuf=yes
ac_cv_func_setbuffer=yes
ac_cv_func_setlocale=yes
ac_cv_func_setpgrp_void=yes
ac_cv_func_setsockopt=yes
ac_cv_func_setutent=yes
ac_cv_func_setutxent=no
ac_cv_func_setvbuf=yes
ac_cv_func_shutdown=yes
ac_cv_func_sigaction=yes
ac_cv_func_signal=yes
ac_cv_func_sigvec=no
ac_cv_func_snprintf=yes
ac_cv_func_socket=yes
ac_cv_func_stat_empty_string_bug=yes
ac_cv_func_statvfs=yes
ac_cv_func_stpcpy=yes
ac_cv_func_strcasecmp=yes
ac_cv_func_strcasestr=yes
ac_cv_func_strchr=yes
ac_cv_func_strdup=yes
ac_cv_func_strerror=yes
ac_cv_func_strerror_r=no
ac_cv_func_strerror_r_char_p=yes
ac_cv_func_strftime=yes
ac_cv_func_strlcat=yes
ac_cv_func_strlcpy=yes
ac_cv_func_strncasecmp=yes
ac_cv_func_strnlen=yes
ac_cv_func_strpbrk=yes
ac_cv_func_strrchr=yes
ac_cv_func_strstr=yes
ac_cv_func_strtol=yes
ac_cv_func_strtoll=yes
ac_cv_func_symlink=yes
ac_cv_func_sysconf=yes
ac_cv_func_tcgetpgrp=yes
ac_cv_func_time=yes
ac_cv_func_times=yes
ac_cv_func_unlink=yes
ac_cv_func_updwtmp=yes
ac_cv_func_usleep=yes
ac_cv_func_utime=yes
ac_cv_func_utime_null=no
ac_cv_func_utimes=yes
ac_cv_func_utmpname=yes
ac_cv_func_utmpxname=no
ac_cv_func_vfork=yes
ac_cv_func_vfork_works=yes
ac_cv_func_vprintf=yes
ac_cv_func_vsnprintf=yes
ac_cv_func_which_gethostbyname_r=six
ac_cv_func_write=yes
ac_cv_func_writev=yes
ac_cv_have_decl___UCLIBC__=yes
ac_cv_have_decl_malloc=yes
ac_cv_have_decl_stpcpy=yes
ac_cv_have_decl_strerror_r=yes
ac_cv_have_struct_addrinfo=yes
ac_cv_have_struct_in6_addr=yes
ac_cv_have_struct_sockaddr_in6=yes
ac_cv_have_struct_sockaddr_storage=yes
ac_cv_header_alsa_asoundlib_h=no
ac_cv_header_argz_h=no
ac_cv_header_arpa_inet_h=yes
ac_cv_header_asm_ioctls_h=yes
ac_cv_header_crt_externs_h=no
ac_cv_header_crypt_h=yes
ac_cv_header_dirent_dirent_h=yes
ac_cv_header_dlfcn_h=yes
ac_cv_header_dssi_h=no
ac_cv_header_errno_h=yes
ac_cv_header_fcntl_h=yes
ac_cv_header_getopt_h=yes
ac_cv_header_gpm_h=no
ac_cv_header_gssapi_gssapi_h=no
ac_cv_header_gssapi_h=no
ac_cv_header_iconv_h=yes
ac_cv_header_ifaddrs_h=no
ac_cv_header_inttypes_h=yes
ac_cv_header_ioctl_h=no
ac_cv_header_langinfo_h=yes
ac_cv_header_lastlog_h=yes
ac_cv_header_libgen_h=yes
ac_cv_header_libintl_h=no
ac_cv_header_libutil_h=no
ac_cv_header_limits_h=yes
ac_cv_header_locale_h=yes
ac_cv_header_magic_h=no
ac_cv_header_memory_h=yes
ac_cv_header_minix_config_h=no
ac_cv_header_mntent_h=yes
ac_cv_header_ncurses_h=yes
ac_cv_header_net_if_h=yes
ac_cv_header_netdb_h=yes
ac_cv_header_netinet_in_h=yes
ac_cv_header_netinet_in_systm_h=yes
ac_cv_header_netinet_ip_h=yes
ac_cv_header_netinet_tcp_h=yes
ac_cv_header_openssl_opensslv_h=yes
ac_cv_header_openssl_ssl_h=yes
ac_cv_header_pam_pam_appl_h=no
ac_cv_header_paths_h=yes
ac_cv_header_poll_h=yes
ac_cv_header_pty_h=yes
ac_cv_header_regex_h=yes
ac_cv_header_security_pam_appl_h=no
ac_cv_header_shadow_h=yes
ac_cv_header_signal_h=yes
ac_cv_header_stdarg_h=yes
ac_cv_header_stdc=yes
ac_cv_header_stddef_h=yes
ac_cv_header_stdint=stdint.h
ac_cv_header_stdint_h=yes
ac_cv_header_stdint_t=stdint.h
ac_cv_header_stdlib_h=yes
ac_cv_header_string_h=yes
ac_cv_header_strings_h=yes
ac_cv_header_stropts_h=no
ac_cv_header_sys_bsdtypes_h=no
ac_cv_header_sys_config_h=no
ac_cv_header_sys_epoll_h=yes
ac_cv_header_sys_event_h=no
ac_cv_header_sys_filio_h=no
ac_cv_header_sys_ioctl_h=yes
ac_cv_header_sys_limits_h=no
ac_cv_header_sys_loadavg_h=no
ac_cv_header_sys_mman_h=yes
ac_cv_header_sys_mount_h=yes
ac_cv_header_sys_param_h=yes
ac_cv_header_sys_poll_h=yes
ac_cv_header_sys_select_h=yes
ac_cv_header_sys_socket_h=yes
ac_cv_header_sys_stat_h=yes
ac_cv_header_sys_time_h=yes
ac_cv_header_sys_times_h=yes
ac_cv_header_sys_types_h=yes
ac_cv_header_sys_types_h_makedev=yes
ac_cv_header_sys_utime_h=no
ac_cv_header_sys_wait_h=yes
ac_cv_header_syslog_h=yes
ac_cv_header_termio_h=yes
ac_cv_header_termios_h=yes
ac_cv_header_time=yes
ac_cv_header_ttyent_h=yes
ac_cv_header_unistd_h=yes
ac_cv_header_util_h=no
ac_cv_header_utime_h=yes
ac_cv_header_utmp_h=yes
ac_cv_header_utmpx_h=no
ac_cv_header_vfork_h=no
ac_cv_header_wchar_h=yes
ac_cv_header_wctype_h=yes
ac_cv_header_zlib_h=yes
ac_cv_host=mipsel-unknown-linux-gnu
ac_cv_host_alias=mipsel-linux
ac_cv_lib_cposix_strerror=no
ac_cv_lib_crypt_crypt=yes
ac_cv_lib_cups_httpConnect=no
ac_cv_lib_dir_opendir=no
ac_cv_lib_error_at_line=yes
ac_cv_lib_intl_tolower=no
ac_cv_lib_magic_magic_open=no
ac_cv_lib_ncurses___use_default_colors=yes
ac_cv_lib_ncurses_initscr=yes
ac_cv_lib_resolv_res_mkquery=yes
ac_cv_lib_tiff_TIFFOpen=yes
ac_cv_lib_util_openpty=yes
ac_cv_lib_z_deflate=yes
ac_cv_lib_z_inflate=yes
ac_cv_libevent_linker_option='(none)'
ac_cv_libevent_normal=yes
ac_cv_linux_vers=2.6.13.1
ac_cv_member_struct_sockaddr_storage_ss_family=yes
ac_cv_member_struct_stat_st_blksize=yes
ac_cv_member_struct_tm___tm_gmtoff=no
ac_cv_member_struct_tm_tm_gmtoff=yes
ac_cv_member_struct_tm_tm_zone=yes
ac_cv_member_struct_utmp_ut_addr=yes
ac_cv_member_struct_utmp_ut_addr_v6=yes
ac_cv_member_struct_utmp_ut_exit=yes
ac_cv_member_struct_utmp_ut_host=yes
ac_cv_member_struct_utmp_ut_id=yes
ac_cv_member_struct_utmp_ut_pid=yes
ac_cv_member_struct_utmp_ut_time=yes
ac_cv_member_struct_utmp_ut_tv=yes
ac_cv_member_struct_utmp_ut_type=yes
ac_cv_member_struct_utmpx_ut_addr=no
ac_cv_member_struct_utmpx_ut_addr_v6=no
ac_cv_member_struct_utmpx_ut_host=no
ac_cv_member_struct_utmpx_ut_id=no
ac_cv_member_struct_utmpx_ut_syslen=no
ac_cv_member_struct_utmpx_ut_time=no
ac_cv_member_struct_utmpx_ut_tv=no
ac_cv_member_struct_utmpx_ut_type=no
ac_cv_objext=o
ac_cv_openssl_linker_option='(none)'
ac_cv_path_AR=/home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-ar
ac_cv_path_CERTUTIL=notfound
ac_cv_path_CP=/bin/cp
ac_cv_path_DATE=/bin/date
ac_cv_path_EGREP='/bin/grep -E'
ac_cv_path_FASTJAR=/usr/bin/fastjar
ac_cv_path_FGREP='/bin/grep -F'
ac_cv_path_FIND=/usr/bin/find
ac_cv_path_GMSGFMT=/usr/bin/msgfmt
ac_cv_path_GREP=/bin/grep
ac_cv_path_KRB5_CONFIG=/usr/bin/krb5-config
ac_cv_path_MKDIR=/bin/mkdir
ac_cv_path_MSGFMT=/usr/bin/msgfmt
ac_cv_path_MSGMERGE=/usr/bin/msgmerge
ac_cv_path_NEON_CONFIG=/home/701/freetz-trunk/toolchain/target/bin/neon-config
ac_cv_path_OPENSSL=/home/701/freetz-trunk/toolchain/target/bin/openssl
ac_cv_path_PK12UTIL=notfound
ac_cv_path_PKG_CONFIG=/usr/bin/pkg-config
ac_cv_path_RANLIB=/home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-ranlib
ac_cv_path_SED=/bin/sed
ac_cv_path_XGETTEXT=/usr/bin/xgettext
ac_cv_path_ZIP=/usr/bin/zip
ac_cv_path_install='/usr/bin/install -c'
ac_cv_path_mkdir=/bin/mkdir
ac_cv_prog_AR=mipsel-linux-ar
ac_cv_prog_AWK=gawk
ac_cv_prog_BUILD_CC=gcc
ac_cv_prog_CC=/home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc
ac_cv_prog_CPP='/home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -E'
ac_cv_prog_CXX=/home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc
ac_cv_prog_CXXCPP='/home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -E'
ac_cv_prog_JAVAC='javac -Xlint:unchecked'
ac_cv_prog_LD=mipsel-linux-ld
ac_cv_prog_MAKE_LOWER_TAGS=no
ac_cv_prog_MAKE_UPPER_TAGS=no
ac_cv_prog_OBJDUMP=mipsel-linux-objdump
ac_cv_prog_RANLIB=mipsel-linux-ranlib
ac_cv_prog_STRIP=mipsel-linux-strip
ac_cv_prog_ac_ct_INSTALL=install
ac_cv_prog_cc__home_701_freetz_trunk_toolchain_target_bin_mipsel_linux_uclibc_gcc_c_o=yes
ac_cv_prog_cc_c89=
ac_cv_prog_cc_g=yes
ac_cv_prog_cc_stdc=
ac_cv_prog_cxx_g=yes
ac_cv_prog_egrep='grep -E'
ac_cv_prog_f77_g=no
ac_cv_prog_gcc_traditional=no
ac_cv_prog_make_make_set=yes
ac_cv_safe_to_define___extensions__=yes
ac_cv_search_basename='none required'
ac_cv_search_getmntent='none required'
ac_cv_search_inet_pton='none required'
ac_cv_search_opendir='none required'
ac_cv_search_openpty=-lutil
ac_cv_sizeof_char=1
ac_cv_sizeof_double=8
ac_cv_sizeof_fpos_t=24
ac_cv_sizeof_int=4
ac_cv_sizeof_long=4
ac_cv_sizeof_long_double=8
ac_cv_sizeof_long_long=8
ac_cv_sizeof_off_t=8
ac_cv_sizeof_pid_t=4
ac_cv_sizeof_ptrdiff_t=4
ac_cv_sizeof_short=2
ac_cv_sizeof_signed_char=1
ac_cv_sizeof_size_t=4
ac_cv_sizeof_socklen_t=4
ac_cv_sizeof_ssize_t=4
ac_cv_sizeof_stat_st_size=8
ac_cv_sizeof_time_t=4
ac_cv_sizeof_void_p=4
ac_cv_stdint_message='using gnu compiler mipsel-linux-uclibc-gcc (GCC) 4.2.4'
ac_cv_stdint_result='(assuming C99 compatible system)'
ac_cv_struct_tm=time.h
ac_cv_sys_file_offset_bits=no
ac_cv_sys_large_files=no
ac_cv_sys_largefile_CC=no
ac_cv_sys_largefile_source=no
ac_cv_sys_long_file_names=yes
ac_cv_target=mipsel-unknown-linux-gnu
ac_cv_target_alias=mipsel-linux
ac_cv_type_mode_t=yes
ac_cv_type_off_t=yes
ac_cv_type_pid_t=yes
ac_cv_type_signal=void
ac_cv_type_signed_char=yes
ac_cv_type_size_t=yes
ac_cv_type_socklen_t=yes
ac_cv_type_ssize_t=yes
ac_cv_type_struct_sockaddr_storage=yes
ac_cv_type_u_int16_t=yes
ac_cv_type_uid_t=yes
ac_cv_type_uint16_t=yes
ac_cv_type_void_p=yes
ac_cv_working_alloca_h=yes
acl_cv_path_LD=/home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld
acl_cv_prog_gnu_ld=yes
acl_cv_rpath=done
am_cv_CC_dependencies_compiler_type=gcc3
am_cv_CXX_dependencies_compiler_type=gcc3
am_cv_func_iconv=yes
am_cv_langinfo_codeset=yes
am_cv_lib_iconv=no
am_cv_prog_tar_ustar=gnutar
am_cv_proto_iconv='extern size_t iconv (iconv_t cd, char * *inbuf, size_t *inbytesleft, char * *outbuf, size_t *outbytesleft);'
am_cv_proto_iconv_arg1=
cf_cv_1UL=1UL
cf_cv_abi_version=5
cf_cv_ansi_cc=-DCC_HAS_PROTOS
cf_cv_builtin_bool=1
cf_cv_cc_bool_type=0
cf_cv_cc_u_d_options=yes
cf_cv_dcl_errno=yes
cf_cv_define_sigwinch=yes
cf_cv_do_relink=yes
cf_cv_do_symlinks=yes
cf_cv_enable_lp64=0
cf_cv_enable_opaque=NCURSES_OPAQUE
cf_cv_enable_reentrant=0
cf_cv_func_nanosleep=yes
cf_cv_func_openpty=pty.h
cf_cv_func_vsscanf=vsscanf
cf_cv_gcc_inline=yes
cf_cv_gnu_source=yes
cf_cv_have_errno=yes
cf_cv_have_isascii=yes
cf_cv_have_tcgetattr=yes
cf_cv_header_stdbool_h=1
cf_cv_ld_rpath=no
cf_cv_lib_util=yes
cf_cv_link_dataonly=yes
cf_cv_makeflags=
cf_cv_mixedcase=yes
cf_cv_need_libm=yes
cf_cv_prog_CC_c_o=yes
cf_cv_regex=regex.h
cf_cv_rel_version=5.7
cf_cv_rm_so_locs=no
cf_cv_shared_soname='`basename $@ .${REL_VERSION}`.${ABI_VERSION}'
cf_cv_shlib_version=rel
cf_cv_shlib_version_infix=no
cf_cv_sig_atomic_t='volatile sig_atomic_t'
cf_cv_sizechange=yes
cf_cv_src_modules='ncurses panel menu form'
cf_cv_struct_dirent64=no
cf_cv_subst_AR_OPTS=rv
cf_cv_sys_time_select=yes
cf_cv_system_name=linux-gnu
cf_cv_timestamp='Tue Dec 22 08:00:59 CET 2009'
cf_cv_type_of_bool='unsigned char'
cf_cv_type_sigaction=no
cf_cv_typeof_chtype=long
cf_cv_typeof_mmask_t=long
cf_cv_unsigned_literals=yes
cf_cv_weak_symbols=no
cf_cv_working_poll=no
gcc_cv_c_gcc_attribute_supported=yes
gcc_cv_c_gcc_attribute_unused=yes
gt_cv_func_CFLocaleCopyCurrent=no
gt_cv_func_CFPreferencesCopyAppValue=no
libffi_cv_ro_eh_frame=no
lt_cv_archive_cmds_need_lc=no
lt_cv_compiler_c_o=yes
lt_cv_compiler_o_lo=no
lt_cv_deplibs_check_method=pass_all
lt_cv_file_magic_cmd='$MAGIC_CMD'
lt_cv_file_magic_test_file=
lt_cv_ld_reload_flag=-r
lt_cv_nm_interface='BSD nm'
lt_cv_objdir=.libs
lt_cv_path_LD=/home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld
lt_cv_path_LDCXX=/home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld
lt_cv_path_NM='/home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-nm -B'
lt_cv_path_SED=/bin/sed
lt_cv_prog_cc_can_build_shared=yes
lt_cv_prog_cc_no_builtin=
lt_cv_prog_cc_pic=' -fPIC'
lt_cv_prog_cc_pic_works=yes
lt_cv_prog_cc_shlib=
lt_cv_prog_cc_static=-static
lt_cv_prog_cc_static_works=yes
lt_cv_prog_cc_wl=-Wl,
lt_cv_prog_compiler_c_o=yes
lt_cv_prog_compiler_c_o_CXX=yes
lt_cv_prog_compiler_pic_works=yes
lt_cv_prog_compiler_pic_works_CXX=yes
lt_cv_prog_compiler_rtti_exceptions=no
lt_cv_prog_compiler_static_works=yes
lt_cv_prog_compiler_static_works_CXX=yes
lt_cv_prog_gnu_ld=yes
lt_cv_prog_gnu_ldcxx=yes
lt_cv_sys_global_symbol_pipe='sed -n -e '\''s/^.*[ ]\([ABCDGIRSTW][ABCDGIRSTW]*\)[ ][ ]*\(\)\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2\3 \3/p'\'''
lt_cv_sys_global_symbol_to_c_name_address='sed -n -e '\''s/^: \([^ ]*\) $/ {\"\1\", (lt_ptr) 0},/p'\'' -e '\''s/^[BCDEGRST] \([^ ]*\) \([^ ]*\)$/ {"\2", (lt_ptr) \&\2},/p'\'''
lt_cv_sys_global_symbol_to_cdecl='sed -n -e '\''s/^. .* \(.*\)$/extern int \1;/p'\'''
lt_cv_sys_lib_dlsearch_path_spec='/lib /usr/lib /lib/i486-linux-gnu /usr/lib/i486-linux-gnu /usr/lib/alsa-lib /usr/local/lib '
lt_cv_sys_lib_search_path_spec='/home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/lib/gcc/mipsel-linux-uclibc/4.2.4 /home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/lib/gcc /home/701/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/mipsel-linux-uclibc/lib'
lt_cv_sys_max_cmd_len=32768
lt_lt_cv_prog_compiler_c_o='"yes"'
lt_lt_cv_prog_compiler_c_o_CXX='"yes"'
lt_lt_cv_sys_global_symbol_pipe='"sed -n -e '\''s/^.*[ ]\\([ABCDGIRSTW][ABCDGIRSTW]*\\)[ ][ ]*\\(\\)\\([_A-Za-z][_A-Za-z0-9]*\\)\$/\\1 \\2\\3 \\3/p'\''"'
lt_lt_cv_sys_global_symbol_to_c_name_address='"sed -n -e '\''s/^: \\([^ ]*\\) \$/ {\\\"\\1\\\", (lt_ptr) 0},/p'\'' -e '\''s/^[BCDEGRST] \\([^ ]*\\) \\([^ ]*\\)\$/ {\"\\2\", (lt_ptr) \\&\\2},/p'\''"'
lt_lt_cv_sys_global_symbol_to_cdecl='"sed -n -e '\''s/^. .* \\(.*\\)\$/extern int \\1;/p'\''"'
ne_cv_cc_timezone=yes
ne_cv_cc_werror=yes
ne_cv_fmt_off_t=lld
ne_cv_fmt_size_t=u
ne_cv_fmt_ssize_t=d
ne_cv_fmt_time_t=ld
ne_cv_gai_addrconfig=no
ne_cv_lib_neon=yes
ne_cv_lib_neonver=yes
ne_cv_lib_ssl097=yes
ne_cv_libsfor_getaddrinfo='none needed'
ne_cv_libsfor_socket='none needed'
ne_cv_os_uname=Linux
ne_cv_pkg_libproxy_1_0=no
ne_cv_pkg_openssl=yes
ne_cv_pkg_pakchois=no
## Output variables. ##
ACLOCAL='${SHELL} /home/701/freetz-trunk/source/classpath-0.97.2/missing --run aclocal-1.10'
AMDEPBACKSLASH='\'
AMDEP_FALSE='#'
AMDEP_TRUE=''
AMTAR='${SHELL} /home/701/freetz-trunk/source/classpath-0.97.2/missing --run tar'
AR='mipsel-linux-ar'
AUTOCONF='${SHELL} /home/701/freetz-trunk/source/classpath-0.97.2/missing --run autoconf'
AUTOHEADER='${SHELL} /home/701/freetz-trunk/source/classpath-0.97.2/missing --run autoheader'
AUTOMAKE='${SHELL} /home/701/freetz-trunk/source/classpath-0.97.2/missing --run automake-1.10'
AWK='gawk'
BUILD_CLASS_FILES_FALSE=''
BUILD_CLASS_FILES_TRUE='#'
CAIRO_CFLAGS=''
CAIRO_LIBS=''
CC='/home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc'
CCDEPMODE='depmode=gcc3'
CFLAGS='-Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64'
CLASSPATH_CONVENIENCE='-no-undefined'
CLASSPATH_INCLUDES='-I$(top_srcdir)/include -I$(top_srcdir)/native/jni/classpath -I$(top_srcdir)/native/jni/native-lib'
CLASSPATH_MODULE='-module -version-info 0:0:0 -no-undefined'
COLLECTIONS_PREFIX=''
CP='/bin/cp'
CPPFLAGS=''
CREATE_ALSA_LIBRARIES_FALSE=''
CREATE_ALSA_LIBRARIES_TRUE='#'
CREATE_API_DOCS_FALSE=''
CREATE_API_DOCS_TRUE='#'
CREATE_COLLECTIONS_FALSE=''
CREATE_COLLECTIONS_TRUE='#'
CREATE_CORE_JNI_LIBRARIES_FALSE='#'
CREATE_CORE_JNI_LIBRARIES_TRUE=''
CREATE_DSSI_LIBRARIES_FALSE=''
CREATE_DSSI_LIBRARIES_TRUE='#'
CREATE_GCONF_PEER_LIBRARIES_FALSE=''
CREATE_GCONF_PEER_LIBRARIES_TRUE='#'
CREATE_GSTREAMER_PEER_LIBRARIES_FALSE=''
CREATE_GSTREAMER_PEER_LIBRARIES_TRUE='#'
CREATE_GTK_PEER_LIBRARIES_FALSE=''
CREATE_GTK_PEER_LIBRARIES_TRUE='#'
CREATE_JNI_HEADERS_FALSE=''
CREATE_JNI_HEADERS_TRUE='#'
CREATE_JNI_LIBRARIES_FALSE='#'
CREATE_JNI_LIBRARIES_TRUE=''
CREATE_PLUGIN_FALSE=''
CREATE_PLUGIN_TRUE='#'
CREATE_QT_PEER_LIBRARIES_FALSE=''
CREATE_QT_PEER_LIBRARIES_TRUE='#'
CREATE_WRAPPERS_FALSE=''
CREATE_WRAPPERS_TRUE='#'
CREATE_XMLJ_LIBRARY_FALSE=''
CREATE_XMLJ_LIBRARY_TRUE='#'
CXX='/home/701/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc'
CXXDEPMODE='depmode=gcc3'
CXXFLAGS='-Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64'
CYGPATH_W='echo'
DATE='/bin/date'
DEFAULT_PREFS_PEER='gnu.java.util.prefs.GConfBasedFactory'
DEFS=''
DEPDIR='.deps'
DSYMUTIL=''
ECHO='echo'
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
ECJ_JAR=''
ENABLE_LOCAL_SOCKETS_FALSE=''
ENABLE_LOCAL_SOCKETS_TRUE=''
ERROR_CFLAGS=''
EXAMPLESDIR='examples'
EXEEXT=''
F77=''
FASTJAR='/usr/bin/fastjar'
FFLAGS=''
FIND='/usr/bin/find'
FREETYPE2_CFLAGS=''
FREETYPE2_LIBS=''
GCONF_CFLAGS=''
GCONF_LIBS=''
GDK_CFLAGS=''
GDK_LIBS=''
GJDOC=''
GLIB_CFLAGS=''
GLIB_LIBS=''
GREP='/bin/grep'
GSTREAMER_BASE_CFLAGS=''
GSTREAMER_BASE_LIBS=''
GSTREAMER_CFLAGS=''
GSTREAMER_FILE_READER=''
GSTREAMER_LIBS=''
GSTREAMER_MIXER_PROVIDER=''
GSTREAMER_PLUGINS_BASE_CFLAGS=''
GSTREAMER_PLUGINS_BASE_LIBS=''
GST_PLUGIN_LDFLAGS=''
GTK_CFLAGS=''
GTK_LIBS=''
INIT_LOAD_LIBRARY='true'
INSTALL_CLASS_FILES_FALSE=''
INSTALL_CLASS_FILES_TRUE='#'
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_GLIBJ_ZIP_FALSE='#'
INSTALL_GLIBJ_ZIP_TRUE=''
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
JAVAC_MEM_OPT=''
JAVA_LANG_SYSTEM_EXPLICIT_INITIALIZATION='false'
JAY=''
JAY_SKELETON=''
LDFLAGS=''
LIBDEBUG='false'
LIBICONV=''
LIBMAGIC=''
LIBOBJS=''
LIBS=''
LIBTOOL='$(SHELL) $(top_builddir)/libtool'
LIBVERSION='0:0:0'
LN_S='ln -s'
LTLIBICONV=''
LTLIBOBJS=''
MAINT='#'
MAINTAINER_MODE_FALSE=''
MAINTAINER_MODE_TRUE='#'
MAKEINFO='${SHELL} /home/701/freetz-trunk/source/classpath-0.97.2/missing --run makeinfo'
MKDIR='/bin/mkdir'
MOC=''
MOZILLA_CFLAGS=''
MOZILLA_LIBS=''
NMEDIT=''
OBJEXT='o'
PACKAGE='classpath'
PACKAGE_BUGREPORT='[email protected]'
PACKAGE_NAME='GNU Classpath'
PACKAGE_STRING='GNU Classpath 0.97.2'
PACKAGE_TARNAME='classpath'
PACKAGE_VERSION='0.97.2'
PANGOFT2_CFLAGS=''
PANGOFT2_LIBS=''
PATH_SEPARATOR=':'
PATH_TO_ESCHER=''
PATH_TO_GLIBJ_ZIP=''
PERL=''
PKG_CONFIG=''
PLUGIN_DIR=''
QT_CFLAGS=''
QT_LIBS=''
RANLIB='mipsel-linux-ranlib'
REGEN_PARSERS_FALSE=''
REGEN_PARSERS_TRUE='#'
REMOVE=''
SED='/bin/sed'
SET_MAKE=''
SHELL='/bin/bash'
STRICT_WARNING_CFLAGS='-Wstrict-prototypes -pedantic'
STRIP='mipsel-linux-strip'
TOOLSDIR='tools'
USER_JAVAH=''
USE_ESCHER_FALSE=''
USE_ESCHER_TRUE=''
USE_PREBUILT_GLIBJ_ZIP_FALSE=''
USE_PREBUILT_GLIBJ_ZIP_TRUE='#'
VERSION='0.97.2'
VM_BINARY='${prefix}/bin/jamvm'
WARNING_CFLAGS='-W -Wall -Wmissing-declarations -Wwrite-strings -Wmissing-prototypes -Wno-long-long'
XMKMF=''
XML_CFLAGS=''
XML_LIBS=''
XSLT_CFLAGS=''
XSLT_LIBS=''
XTEST_LIBS=''
X_CFLAGS=''
X_EXTRA_LIBS=''
X_LIBS=''
X_PRE_LIBS=''
ZIP=''
ac_ct_CC=''
ac_ct_CXX=''
ac_ct_F77=''
am__fastdepCC_FALSE='#'
am__fastdepCC_TRUE=''
am__fastdepCXX_FALSE='#'
am__fastdepCXX_TRUE=''
am__include='include'
am__isrc=''
am__leading_dot='.'
am__quote=''
am__tar='tar --format=ustar -chf - "$$tardir"'
am__untar='tar -xf -'
bindir='/usr/bin'
build='i386-pc-linux-gnu'
build_alias='i386-pc-linux-gnu'
build_cpu='i386'
build_os='linux-gnu'
build_vendor='pc'
datadir='/usr/share'
datarootdir='${prefix}/share'
default_toolkit='gnu.java.awt.peer.gtk.GtkToolkit'
docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
dvidir='${docdir}'
exec_prefix='/usr'
glibjdir='${datadir}/${PACKAGE}'
host='mipsel-unknown-linux-gnu'
host_alias='mipsel-linux'
host_cpu='mipsel'
host_os='linux-gnu'
host_vendor='unknown'
htmldir='${docdir}'
includedir='/usr/include'
infodir='/usr/share/info'
install_sh='$(SHELL) /home/701/freetz-trunk/source/classpath-0.97.2/install-sh'
libdir='/usr/lib'
libexecdir='/usr/lib'
localedir='${datarootdir}/locale'
localstatedir='/var'
mandir='/usr/share/man'
mkdir_p='/bin/mkdir -p'
nativeexeclibdir='${libdir}/${PACKAGE}'
oldincludedir='/usr/include'
pdfdir='${docdir}'
prefix='/usr'
program_transform_name='s&$$&&;s&^&&'
psdir='${docdir}'
sbindir='/usr/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='/etc'
target='mipsel-unknown-linux-gnu'
target_alias='mipsel-linux'
target_cpu='x86'
target_os='linux-gnu'
target_vendor='unknown'
vm_classes='${top_srcdir}/vm/reference'
## confdefs.h. ##
#define PACKAGE_NAME "GNU Classpath"
#define PACKAGE_TARNAME "classpath"
#define PACKAGE_VERSION "0.97.2"
#define PACKAGE_STRING "GNU Classpath 0.97.2"
#define PACKAGE_BUGREPORT "[email protected]"
#define PACKAGE "classpath"
#define VERSION "0.97.2"
#define STDC_HEADERS 1
#define HAVE_SYS_TYPES_H 1
#define HAVE_SYS_STAT_H 1
#define HAVE_STDLIB_H 1
#define HAVE_STRING_H 1
#define HAVE_MEMORY_H 1
#define HAVE_STRINGS_H 1
#define HAVE_INTTYPES_H 1
#define HAVE_STDINT_H 1
#define HAVE_UNISTD_H 1
#define HAVE_FORK 1
#define HAVE_PIPE 1
#define HAVE_OPEN 1
#define HAVE_READ 1
#define HAVE_BIND 1
#define HAVE_SEND 1
#define HAVE_TIME 1
#define HAVE_MMAP 1
#define ICONV_CONST
#define HAVE_MSG_WAITALL 1
configure: exit 1
