ich möchte gern wenn ích von außen auf meinen asterisk anrufe, einfach nur eine feste interne Rufnummer haben und einfach bloß die extension hinten anhägen wenn ich ein bestimmtes Telefon erreichen will. z.B. vorwahl+rufnummer+extension
Das ganze soll auf trixbox 1.1.1 laufen, alles andere funzt soweit.
sip.conf
extensions.conf
sagt mir bitte was ihr noch benötigt, ich möchte nicht das ganze fForum zuspammen
thx im Voraus
MfG bEx
sip.conf
; Note: If your SIP devices are behind a NAT and your Asterisk
; server isn't, try adding "nat=1" to each peer definition to
; solve translation problems.
[general]
port = 5060 ; Port to bind to (SIP is 5060)
bindaddr = 0.0.0.0 ; Address to bind to (all addresses on machine)
disallow=all
allow=ulaw
allow=alaw
language=de
; If you need to answer unauthenticated calls, you should change this
; next line to 'from-trunk', rather than 'from-sip-external'.
; You'll know this is happening if when you call in you get a message
; saying "The number you have dialed is not in service. Please check the
; number and try again."
context = from-sip-external ; Send unknown SIP callers to this context
callerid = Unknown
tos=0x68
; #, in this configuration file, is NOT A COMMENT. This is exactly
; how it should be.
#include sip_nat.conf
#include sip_custom.conf
#include sip_additional.conf
extensions.conf
; Asterisk Management Portal (AMP)
; Copyright (C) 2004 Coalescent Systems Inc
; dialparties.agi (http://www.sprackett.com/asterisk/)
; Asterisk::AGI (http://asterisk.gnuinter.net/)
; gsm (http://www.ibiblio.org/pub/Linux/utils/compress/!INDEX.short.html)
; loligo sounds (http://www.loligo.com/asterisk/sounds/)
; mpg123 (http://voip-info.org/wiki-Asterisk+config+musiconhold.conf)
; include extension contexts generated from AMP
#include extensions_additional.conf
; Customizations to this dialplan should be made in extensions_custom.conf
; See extensions_custom.conf.sample for an example
#include extensions_custom.conf
[from-trunk] ; just an alias since VoIP shouldn't be called PSTN
include => from-pstn
[from-pstn]
include => from-pstn-custom ; create this context in extensions_custom.conf to include customizations
include => ext-findmefollow ; MODIFICATOIN (PL) for findmefollow if enabled, should be bofore ext-local
include => ext-did-direct ; MODIFICATOIN (PL) put before ext-did to take precedence
include => ext-did
exten => fax,1,Goto(ext-fax,in_fax,1)
; MODIFICATION (PL)
; Required to assure that direct dids go to personal ring group before local extension.
; This could be auto-generated however I it is prefered to be put here and hard coded
; so that it can be modified if ext-local should take precedence in certain situations.
; will have to decide what to do later.
[from-did-direct]
include => ext-local
; Macros [macro]
; Rings one or more extensions. Handles things like call forwarding and DND
; We don't call dial directly for anything internal anymore.
; ARGS: $TIMER, $OPTIONS, $EXT1, $EXT2, $EXT3, ...
; Use a Macro call such as the following:
; Macro(dial,$DIAL_TIMER,$DIAL_OPTIONS,$EXT1,$EXT2,$EXT3,...)
[macro-dial]
exten => s,1,AGI,dialparties.agi
exten => s,2,NoOp(Returned from dialparties with no extensions to call)
exten => s,3,NoOp(DIALSTATUS is '${DIALSTATUS}')
exten => s,10,Dial(${ds}) ; dialparties will set the priority to 10 if $ds is not null
exten => s,20,NoOp(Returned from dialparties with hunt groups to dial )
exten => s,21,Set(HuntLoop=0)
exten => s,22,GotoIf($[${HuntMembers} >= 1]?30 ) ; if this is from rg-group, don't strip prefix
exten => s,23,NoOp(Returning there are no members left in the hunt group to ring)
exten => s,30,Set(HuntMember=HuntMember${HuntLoop})
exten => s,31,GotoIf($[$["${CALLTRACE_HUNT}" != "" ] & $["${RingGroupMethod}" = "hunt" ]]?32:35 ) ; Set CAll Trace for Hunt member we are going to call
exten => s,32,Set(CT_EXTEN=${CUT(ARG3,,$[${HuntLoop} + 1])})
exten => s,33,Set(DB(CALLTRACE/${CT_EXTEN})=${CALLTRACE_HUNT})
exten => s,34,Goto(s,42)
exten => s,35,GotoIf($[$["${CALLTRACE_HUNT}" != "" ] & $["${RingGroupMethod}" = "memoryhunt" ]]?36:50 ) ;Set Call Trace for each hunt member we are going to call "Memory groups have multiple members to set CALL TRACE For hence the loop
exten => s,36,Set(CTLoop=0)
exten => s,37,GotoIf($[${CTLoop} > ${HuntLoop}]?42 ) ; if this is from rg-group, don't strip prefix
exten => s,38,Set(CT_EXTEN=${CUT(ARG3,,$[${CTLoop} + 1])})
exten => s,39,Set(DB(CALLTRACE/${CT_EXTEN})=${CALLTRACE_HUNT})
exten => s,40,Set(CTLoop=$[1 + ${CTLoop}])
exten => s,41,Goto(s,37)
exten => s,42,Dial(${${HuntMember}}${ds} ) ; dialparties will set the priority to 20 if $ds is not null and its a hunt group
exten => s,43,Set(HuntLoop=$[1 + ${HuntLoop}])
exten => s,44,Set(HuntMembers=$[${HuntMembers} - 1])
exten => s,45,Goto(s,22)
exten => s,50,DBdel(CALLTRACE/${CT_EXTEN})
exten => s,51,Goto(s,42)
; Ring an extension, if the extension is busy or there is no answer send it
; to voicemail
; ARGS: $VMBOX, $EXT
[macro-exten-vm]
exten => s,1,Macro(user-callerid)
exten => s,n,Set(FROMCONTEXT=exten-vm)
exten => s,n,Set(VMBOX=${ARG1})
exten => s,n,Set(EXTTOCALL=${ARG2})
exten => s,n,Set(CFUEXT=${DB(CFU/${EXTTOCALL})})
exten => s,n,Set(RT=${IF($[$["${VMBOX}"!="novm"] | $["foo${CFUEXT}"!="foo"]]?${RINGTIMER}:"")})
exten => s,n,Macro(record-enable,${EXTTOCALL},IN)
exten => s,n,GotoIf($["${CHANNEL:0:5}" = "Local"]?dolocaldial,1) ; if the channel is Local
exten => s,n,Macro(dial,${RT},${DIAL_OPTIONS},${EXTTOCALL})
exten => s,n,GosubIf($[$["${DIALSTATUS}"="NOANSWER"] & $["foo${CFUEXT}"!="foo"]]?docfu,1) ; check for CFU in use on no answer
exten => s,n,NoOp(Voicemail is '${VMBOX}')
exten => s,n,GotoIf($["${VMBOX}" = "novm"]?s-${DIALSTATUS},1) ; no voicemail in use for this extension
exten => s,n,NoOp(Sending to Voicemail box ${EXTTOCALL})
exten => s,n,Macro(vm,${VMBOX},${DIALSTATUS})
; Local channel should try to ring the phone only then come back out
; i.e. it's wrong for it to Answer the call in any way (including Congestion
; and stop the initiating dialplan from being returned to)
exten => dolocaldial,1,Macro(dial,,${DIAL_OPTIONS},${EXTTOCALL})
exten => dolocaldial,n,NoOp(Returned to dolocaldial with DIALSTATUS '${DIALSTATUS}')
; Try the Call Forward on No Answer / Unavailable number
exten => docfu,1,Set(RTCFU=${IF($["${VMBOX}"!="novm"]?${RINGTIMER}:"")})
exten => docfu,n,Dial(Local/${CFUEXT}@from-internal/n,${RTCFU},${DIAL_OPTIONS})
exten => docfu,n,Return
; Extensions with no Voicemail box reporting BUSY come here
exten => s-BUSY,1,NoOp(Extension is reporting BUSY and not passing to Voicemail)
exten => s-BUSY,n,Busy()
exten => s-BUSY,n,Wait(60)
exten => s-BUSY,n,Congestion()
; Anything but BUSY comes here
exten => _s-.,1,Congestion()
[macro-vm]
exten => s,n,Set(VMGAIN=${IF($["foo${VM_GAIN}"!="foo"]?"g(${VM_GAIN})":"")})
exten => s,n,Goto(s-${ARG2},1)
exten => s-BUSY,1,NoOp(BUSY voicemail)
exten => s-BUSY,n,Macro(get-vmcontext,${ARG1})
exten => s-BUSY,n,Voicemail(${ARG1}@${VMCONTEXT}|b${VMGAIN}) ; Voicemail Busy message
exten => s-BUSY,n,Goto(exit-${VMSTATUS},1)
exten => s-DIRECTDIAL,1,NoOp(DIRECTDIAL voicemail)
exten => s-DIRECTDIAL,n,Macro(get-vmcontext,${ARG1})
exten => s-DIRECTDIAL,n,Voicemail(${ARG1}@${VMCONTEXT}|${VM_DDTYPE}${VMGAIN})
exten => s-DIRECTDIAL,n,Goto(exit-${VMSTATUS},1)
exten => _s-.,1,Macro(get-vmcontext,${ARG1})
exten => _s-.,n,Voicemail(${ARG1}@${VMCONTEXT}|u${VMGAIN}) ; Voicemail Unavailable message
exten => _s-.,n,Goto(exit-${VMSTATUS},1)
exten => o,1,Background(one-moment-please) ; 0 during vm message will hangup
exten => o,n,GotoIf($["foo${FROM_DID}" = "foo"]?from-pstn,s,1:from-pstn,${FROM_DID},1)
exten => a,1,Macro(get-vmcontext,${ARG1})
exten => a,n,VoiceMailMain(${ARG1}@${VMCONTEXT})
exten => a,n,Hangup
exten => exit-FAILED,1,Playback(im-sorry&an-error-has-occured)
exten => exit-FAILED,n,Hangup()
exten => exit-SUCCESS,1,Playback(goodbye)
exten => exit-SUCCESS,n,Hangup()
exten => exit-USEREXIT,1,Playback(goodbye)
exten => exit-USEREXIT,n,Hangup()
exten => t,1,Hangup()
; get the voicemail context for the user in ARG1
[macro-get-vmcontext]
exten => s,1,Set(VMCONTEXT=${DB(AMPUSER/${ARG1}/voicemail)})
exten => s,2,GotoIf($["foo${VMCONTEXT}" = "foo"]?200:300)
exten => s,200,Set(VMCONTEXT=default)
exten => s,300,NoOp()
; For some reason, if I don't run setCIDname, CALLERID(name) will be blank in my AGI
; ARGS: none
[macro-fixcid]
exten => s,1,Set(CALLERID(name)=${CALLERID(name)})
; Ring groups of phones
; ARGS: comma separated extension list
; 1 - Ring Group Strategy
; 2 - ringtimer
; 3 - prefix
; 4 - extension list
[macro-rg-group]
exten => s,2,GotoIf($["${CALLERID(name):0:${LEN(${RGPREFIX})}}" != "${RGPREFIX}"]?4:3) ; check for old prefix
exten => s,3,Set(CALLERID(name)=${CALLERID(name):${LEN(${RGPREFIX})}}) ; strip off old prefix
exten => s,4,Set(RGPREFIX=${ARG3}) ; set new prefix
exten => s,5,Set(CALLERID(name)=${RGPREFIX}${CALLERID(name)}) ; add prefix to callerid name
exten => s,6,Set(RecordMethod=Group) ; set new prefix
exten => s,7,Macro(record-enable,${MACRO_EXTEN},${RecordMethod})
exten => s,8,Set(RingGroupMethod=${ARG1}) ;
exten => s,9,Macro(dial,${ARG2},${DIAL_OPTIONS},${ARG4})
exten => s,10,Set(RingGroupMethod='') ;
; Outgoing channel(s) are busy ... inform the client
[macro-outisbusy]
exten => s,1,Playback(all-circuits-busy-now)
exten => s,2,Playback(pls-try-call-later)
exten => s,3,Macro(hangupcall)
; What to do on hangup.
[macro-hangupcall]
exten => s,1,ResetCDR(w)
exten => s,2,NoCDR()
exten => s,3,Wait(5)
exten => s,4,Hangup
[macro-faxreceive]
exten => s,1,Set(FAXFILE=/var/spool/asterisk/fax/${UNIQUEID}.tif)
exten => s,2,Set(EMAILADDR=${FAX_RX_EMAIL})
exten => s,3,rxfax(${FAXFILE})
exten => s,103,Set(EMAILADDR=${FAX_RX_EMAIL})
exten => s,104,Goto(3)
; dialout and strip the prefix
[macro-dialout]
exten => s,2,GotoIf($["${ECID${CALLERID(number)}}" = ""]?5) ;check for CID override for exten
exten => s,3,Set(CALLERID(all)=${ECID${CALLERID(number)}})
exten => s,4,Goto(7)
exten => s,5,GotoIf($["${OUTCID_${ARG1}}" = ""]?7) ;check for CID override for trunk
exten => s,6,Set(CALLERID(all)=${OUTCID_${ARG1}})
exten => s,7,Set(length=${LEN(${DIAL_OUT_${ARG1}})})
exten => s,8,Dial(${OUT_${ARG1}}/${ARG2:${length}})
exten => s,9,Congestion
exten => s,109,Macro(outisbusy)
; dialout using default OUT trunk - no prefix
[macro-dialout-default]
exten => s,2,Macro(record-enable,${CALLERID(number)},OUT)
exten => s,3,Macro(outbound-callerid,${ARG1})
exten => s,4,Dial(${OUT}/${ARG1})
exten => s,5,Congestion
exten => s,105,Macro(outisbusy)
; dialout using a trunk, using pattern matching (don't strip any prefix)
; arg1 = trunk number, arg2 = number, arg3 = route password
; MODIFIED (PL)
; Modified both Dial() commands to include the new TRUNK_OPTIONS from the general
; screen of AMP
[macro-dialout-trunk]
exten => s,1,GotoIf($["${ARG3}" = ""]?3:2) ; arg3 is pattern password
exten => s,2,Authenticate(${ARG3})
exten => s,3,Macro(user-callerid)
exten => s,4,Macro(record-enable,${CALLERID(number)},OUT)
exten => s,5,Macro(outbound-callerid,${ARG1})
exten => s,6,Set(GROUP()=OUT_${ARG1})
exten => s,7,GotoIf($[ ${GROUP_COUNT()} > ${OUTMAXCHANS_${ARG1}} ]?108)
; if we've used up the max channels, continue at (n+101)
exten => s,8,Set(DIAL_NUMBER=${ARG2})
exten => s,9,Set(DIAL_TRUNK=${ARG1})
exten => s,10,AGI(fixlocalprefix) ; this sets DIAL_NUMBER to the proper dial string for this trunk
exten => s,11,Set(OUTNUM=${OUTPREFIX_${ARG1}}${DIAL_NUMBER}) ; OUTNUM is the final dial number
exten => s,12,Set(custom=${CUT(OUT_${ARG1},:,1)}) ; Custom trunks are prefixed with "AMP:"
exten => s,13,GotoIf($["${custom}" = "AMP"]?16)
exten => s,14,Dial(${OUT_${ARG1}}/${OUTNUM},120,${TRUNK_OPTIONS}) ; Regular Trunk Dial
exten => s,15,Goto(s-${DIALSTATUS},1)
; This is a custom trunk. Substitute $OUTNUM$ with the actual number and rebuild the dialstring
; example trunks: "AMP:CAPI/XXXXXXXX:b$OUTNUM$,30,r", "AMP:OH323/[email protected]:XXXX"
exten => s,16,Set(pre_num=${CUT(OUT_${ARG1},$,1)})
exten => s,17,Set(the_num=${CUT(OUT_${ARG1},$,2)}) ; this is where we expect to find string OUTNUM
exten => s,18,Set(post_num=${CUT(OUT_${ARG1},$,3)})
exten => s,19,GotoIf($["${the_num}" = "OUTNUM"]?20:21) ; if we didn't find "OUTNUM", then skip to Dial
exten => s,20,Set(the_num=${OUTNUM}) ; replace "OUTNUM" with the actual number to dial
exten => s,21,Dial(${pre_num:4}${the_num}${post_num},120,${TRUNK_OPTIONS})
exten => s,22,Goto(s-${DIALSTATUS},1)
exten => s,108,Noop(max channels used up)
exten => s-BUSY,1,NoOp(Trunk is reporting BUSY)
exten => s-BUSY,2,Busy()
exten => s-BUSY,3,Wait(60)
exten => s-BUSY,4,NoOp()
exten => _s-.,1,NoOp(Dial failed due to ${DIALSTATUS})
; Adds a dynamic agent/member to a Queue
; Prompts for call-back number - in not entered, uses CIDNum
[macro-agent-add]
exten => s,1,Wait(1)
exten => s,2,Macro(user-callerid)
exten => s,3,Read(CALLBACKNUM,agent-user) ; get callback number from user
exten => s,4,GotoIf($["${CALLBACKNUM}" = ""]?5:7)) ; if user just pressed # or timed out, use cidnum
exten => s,5,Set(CALLBACKNUM=${CALLERID(number)})
exten => s,6,GotoIf($["${CALLBACKNUM}" = ""]?2)) ; if still no number, start over
exten => s,7,GotoIf($["${ARG2}" = ""]?9:8)) ; arg2 is queue password
exten => s,8,Authenticate(${ARG2})
exten => s,9,AddQueueMember(${ARG1}|Local/${CALLBACKNUM}@from-internal/n) ; using chan_local allows us to have agents over trunks
exten => s,10,UserEvent(Agentlogin|Agent: ${CALLBACKNUM})
exten => s,11,Wait(1)
exten => s,12,Playback(agent-loginok)
exten => s,13,Hangup()
; Removes a dynamic agent/member from a Queue
[macro-agent-del]
exten => s,7,RemoveQueueMember(${ARG1}|Local/${CALLBACKNUM}@from-internal/n)
exten => s,8,UserEvent(RefreshQueue)
exten => s,9,Wait(1)
exten => s,10,Playback(agent-loggedoff)
exten => s,11,Hangup()
[macro-dialout-enum]
; This has been violently beaten upon by Rob Thomas, [email protected]
; to 1: Be compliant with all the depreciated bits in asterisk 1.2 and
; above, and 2: to give a good shot at attempting to be compliant with
; RFC3761 by honouring the order in which records are returned.
exten => s,1,GotoIf($["${ARG3}" = ""]PASSWD?NOPASSWD); arg3 is pattern password
exten => s,n(PASSWD),Authenticate(${ARG3})
exten => s,n(NOPASSWD),Macro(user-callerid)
exten => s,n,Macro(record-enable,${CALLERID(number)},OUT)
exten => s,n,Macro(outbound-callerid,${ARG1})
exten => s,n,Set(GROUP()=OUT_${ARG1})
exten => s,n,GotoIf($[ ${GROUP_COUNT()} > ${OUTMAXCHANS_${ARG1}} ]?nochans)
exten => s,n,Set(DIAL_NUMBER=${ARG2})
exten => s,n,Set(DIAL_TRUNK=${ARG1})
exten => s,n,AGI(fixlocalprefix) ; this sets DIAL_NUMBER to the proper dial string for this trunk
exten => s,n,Set(E164NETWORKS=e164.arpa-e164.info-e164.org) ; enum networks to check
exten => s,n,GotoIf($["${DIAL_NUMBER:0:1}" = "+"]?begin) ; Skip next line if it already is prefixed by a plus
exten => s,n,Set(DIAL_NUMBER=+${DIAL_NUMBER}) ; Add a plus to the start, becasue ENUMLOOKUP needs it.
; start of main network loop
exten => s,n(begin),NoOp(E164NETWORKS is ${E164NETWORKS})
exten => s,n,GotoIf($["${E164NETWORKS:1:2}"=""]?failedtotally)
exten => s,n,Set(ENUMNET=${CUT(E164NETWORKS,-,1)})
exten => s,n,Set(E164NETWORKS=${CUT(E164NETWORKS,-,2-)})
exten => s,n,NoOp(E164NETWORKS is now ${E164NETWORKS})
exten => s,n,NoOp(ENUMNET is ${ENUMNET})
exten => s,n,Set(ENUMCOUNT=${ENUMLOOKUP(${DIAL_NUMBER},all,c,${ENUMNET})})
exten => s,n,Set(ENUMPTR=0)
exten => s,n,Set(LOOKUPBUG=0)
; start of main lookup loop
exten => s,n(startloop),GotoIf($["${ENUMPTR}"<"${ENUMCOUNT}"]?continue:failed)
; Now, let's start through them.
exten => s,n(continue),Set(ENUMPTR=$[${ENUMPTR}+1])
exten => s,n,NoOp(Doing ENUMLOOKUP(${DIAL_NUMBER},all,${ENUMPTR},${ENUMNET}))
exten => s,n,Set(ENUM=${ENUMLOOKUP(${DIAL_NUMBER},all,${ENUMPTR},${ENUMNET})})
; Deal with reponse
exten => s,n,GotoIf($["${ENUM:0:3}" = "sip" ]?sipuri)
exten => s,n,GotoIf($["${ENUM:0:3}" = "iax" ]?iaxuri)
; It doesn't matter if you don't have h323 enabled, as when it tries to dial, it cares
; about dialstatus and retries if there are any enum results left.
exten => s,n,GotoIf($["${ENUM:0:3}" = "h32" ]?h323uri)
; e164.org can return 'ADDRESS' lines. Because of *'s poor handling of Enum
; lookups, we want to DECREMENT the enum pointer. Yes. That means we try more
; times than there actually exists entries.
exten => s,n,GotoIf($["${ENUM:0:3}" = "ADD" ]?enumbug)
; OK. If we're here, we've still got some enum entries to go through. Back to
; the start with you!
exten => s,n,Goto(startloop)
; We're here because of the poor implementation of ENUMLOOKUP in Asterisk. It
; is quite possible to do three ENUMLOOKUPS and get the same entry each time.
; The only workaround I can think of is when we hit an invalid entry, do a
; DECREMENT of the pointer, and keep trying.
exten => s,n(enumbug),Set(ENUMPTR=$[${ENUMPTR}-1])
exten => s,n,NoOp(If this is looping with the same ENUM value, The ENUMLOOKUP function is fixed!)
exten => s,n,Set(LOOKUPBUG=$[${LOOKUPBUG}+1])
; If we've done this more than, ooh, 5 times, then give up on this network. Sorry.
exten => s,n,GotoIf($["${LOOKUPBUG}" > 5 ]?failed)
exten => s,n,Goto(continue)
; If the prefix is 'sip:'...
exten => s,n(sipuri),Set(DIALSTR=SIP/${ENUM:4})
exten => s,n,Goto(dodial)
; If it's IAX2...
exten => s,n(iaxuri),Set(DIALSTR=IAX2/${ENUM:5})
; Or even if it's H323.
exten => s,n(h323uri),Set(DIALSTR=H323/${ENUM:5})
exten => s,n(dodial),Dial(${DIALSTR})
exten => s,n,NoOp(Dial exited in macro-enum-dialout with ${DIALSTATUS})
; Now, if we're still here, that means the Dial failed for some reason.
; If it's CONGESTION or CHANUNAVAIL we probably want to try again on a
; different channel. However, if it's the last one, we don't have any
; left, and I didn't keep any previous dialstatuses, so hopefully
; someone looking throught the logs would have seen the NoOp's
exten => s,n,GotoIf($["${ENUMPTR}"<"${ENUMCOUNT}"]?maybemore:dialfailed)
exten => s,n(maybemore),GotoIf($[ $[ "${DIALSTATUS}" = "CHANUNAVAIL" ] | $[ "${DIALSTATUS}" = "CONGESTION" ] ]?continue)
; If we're here, then it's BUSY or NOANSWER or something and well, deal with it.
exten => s,n(dialfailed),Goto(s-${DIALSTATUS},1)
; Here are the exit points for the macro.
exten => s,n(failed),NoOp(EnumLookup failed on network ${ENUMNET})
exten => s,n,Goto(begin)
exten => s,n(failedtotally),NoOp(EnumLookup failed -- no more networks to try)
exten => s,n,Goto(end)
exten => s,n(nochans),NoOp(max channels used up)
exten => s,n(end),NoOp(Exiting macro-dialout-enum)
[macro-record-enable]
exten => s,1,GotoIf(${LEN(${BLINDTRANSFER})} > 0?2:4)
exten => s,2,ResetCDR(w)
exten => s,3,StopMonitor()
exten => s,4,AGI(recordingcheck,${TIMESTAMP},${UNIQUEID})
exten => s,5,Noop(No recording needed)
exten => s,999,Monitor(wav49,${CALLFILENAME}, mb)
;exten => s,3,BackGround(for-quality-purposes)
;exten => s,4,BackGround(this-call-may-be)
;exten => s,5,BackGround(recorded)
; This macro is for dev purposes and just dumps channel/app variables. Useful when designing new contexts.
[macro-dumpvars]
exten => s,1,Noop(ACCOUNTCODE=${ACCOUNTCODE})
exten => s,2,Noop(ANSWEREDTIME=${ANSWEREDTIME})
exten => s,3,Noop(BLINDTRANSFER=${BLINDTRANSFER})
exten => s,4,Noop(CALLERID=${CALLERID(all)})
exten => s,5,Noop(CALLERID(name)=${CALLERID(name)})
exten => s,6,Noop(CALLERID(number)=${CALLERID(number)})
exten => s,7,Noop(CALLINGPRES=${CALLINGPRES})
exten => s,8,Noop(CHANNEL=${CHANNEL})
exten => s,9,Noop(CONTEXT=${CONTEXT})
exten => s,10,Noop(DATETIME=${DATETIME})
exten => s,11,Noop(DIALEDPEERNAME=${DIALEDPEERNAME})
exten => s,12,Noop(DIALEDPEERNUMBER=${DIALEDPEERNUMBER})
exten => s,13,Noop(DIALEDTIME=${DIALEDTIME})
exten => s,14,Noop(DIALSTATUS=${DIALSTATUS})
exten => s,15,Noop(DNID=${DNID})
exten => s,16,Noop(EPOCH=${EPOCH})
exten => s,17,Noop(EXTEN=${EXTEN})
exten => s,18,Noop(HANGUPCAUSE=${HANGUPCAUSE})
exten => s,19,Noop(INVALID_EXTEN=${INVALID_EXTEN})
exten => s,20,Noop(LANGUAGE=${LANGUAGE})
exten => s,21,Noop(MEETMESECS=${MEETMESECS})
exten => s,22,Noop(PRIORITY=${PRIORITY})
exten => s,23,Noop(RDNIS=${RDNIS})
exten => s,24,Noop(SIPDOMAIN=${SIPDOMAIN})
exten => s,25,Noop(SIP_CODEC=${SIP_CODEC})
exten => s,26,Noop(SIPCALLID=${SIPCALLID})
exten => s,27,Noop(SIPUSERAGENT=${SIPUSERAGENT})
exten => s,28,Noop(TIMESTAMP=${TIMESTAMP})
exten => s,29,Noop(TXTCIDNAME=${TXTCIDNAME})
exten => s,30,Noop(UNIQUEID=${UNIQUEID})
exten => s,31,Noop(TOUCH_MONITOR=${TOUCH_MONITOR})
exten => s,32,Noop(MACRO_CONTEXT=${MACRO_CONTEXT})
exten => s,33,Noop(MACRO_EXTEN=${MACRO_EXTEN})
exten => s,34,Noop(MACRO_PRIORITY=${MACRO_PRIORITY})
[macro-user-logon]
; check device type
exten => s,1,Set(DEVICETYPE=${DB(DEVICE/${CALLERID(number)}/type)})
exten => s,2,GotoIf($["${DEVICETYPE}" = "fixed"]?s-FIXED,1)
; get user's extension
exten => s,3,Set(AMPUSER=${ARG1})
exten => s,4,GotoIf($["${AMPUSER}" = ""]?5:9)
exten => s,5,BackGround(please-enter-your)
exten => s,6,Playback(extension)
exten => s,7,Read(AMPUSER,then-press-pound)
; get user's password and authenticate
exten => s,8,Wait(1)
exten => s,9,Set(AMPUSERPASS=${DB(AMPUSER/${AMPUSER}/password)})
exten => s,10,GotoIf($[${LEN(${AMPUSERPASS})} = 0]?s-NOPASSWORD,1)
; do not continue if the user has already logged onto this device
exten => s,11,Set(DEVICEUSER=${DB(DEVICE/${CALLERID(number)}/user)})
exten => s,12,GotoIf($["${DEVICEUSER}" = "${AMPUSER}"]?s-ALREADYLOGGEDON,1)
exten => s,13,Authenticate(${AMPUSERPASS})
; devices can only be mapped to one user - loggoff anyone else who is here
exten => s,14,Macro(user-logoff)
; map user to device
exten => s,15,Set(AMPUSERDEVICES=${DB(AMPUSER/${AMPUSER}/device)})
exten => s,16,GotoIf($[${LEN(${AMPUSERDEVICES})} = 0]?18)
exten => s,17,Set(AMPUSERDEVICES=${AMPUSERDEVICES}&)
exten => s,18,Set(AMPUSERDEVICES=${AMPUSERDEVICES}${CALLERID(number)})
exten => s,19,Set(DB(AMPUSER/${AMPUSER}/device)=${AMPUSERDEVICES})
; map device to user
exten => s,20,Set(DB(DEVICE/${CALLERID(number)}/user)=${AMPUSER})
; create symlink from dummy device mailbox to user's mailbox
exten => s,21,System(/bin/ln -s /var/spool/asterisk/voicemail/default/${AMPUSER}/ /var/spool/asterisk/voicemail/device/${CALLERID(number)})
exten => s-FIXED,1,NoOp(Device is FIXED and cannot be logged into)
exten => s-FIXED,2,Playback(ha/phone)
exten => s-FIXED,3,SayDigits(${CALLERID(number)})
exten => s-FIXED,4,Playback(is-curntly-unavail)
exten => s-FIXED,5,Playback(vm-goodbye)
exten => s-FIXED,6,Hangup ;TODO should play msg indicated device cannot be logged into
exten => s-ALREADYLOGGEDON,1,NoOp(This device has already been logged into by this user)
exten => s-ALREADYLOGGEDON,2,Playback(vm-goodbye)
exten => s-ALREADYLOGGEDON,3,Hangup ;TODO should play msg indicated device is already logged into
exten => s-NOPASSWORD,1,NoOp(This extension does not exist or no password is set)
exten => s-NOPASSWORD,2,Playback(an-error-has-occured)
exten => s-NOPASSWORD,3,Playback(vm-goodbye)
exten => s-NOPASSWORD,4,Hangup ;TODO should play msg indicated device is already logged into
[macro-user-logoff]
; check device type
; remove entry from user's DEVICE key
; delete the symlink to user's voicemail box
exten => s,3,System(rm -f /var/spool/asterisk/voicemail/device/${CALLERID(number)})
exten => s,4,Set(DEVAMPUSER=${DB(DEVICE/${CALLERID(number)}/user)})
exten => s,5,Set(AMPUSERDEVICES=${DB(AMPUSER/${DEVAMPUSER}/device)})
exten => s,6,AGI(list-item-remove.php,${AMPUSERDEVICES},${CALLERID(number)},AMPUSERDEVICES,&)
; reset user -> device mapping
; users can log onto multiple devices, need to just remove device from value
exten => s,7,Set(DB(AMPUSER/${DEVAMPUSER}/device)=${AMPUSERDEVICES})
; reset device -> user mapping
exten => s,8,Set(DB(DEVICE/${CALLERID(number)}/user)=none)
exten => s,9,Playback(vm-goodbye)
exten => s-FIXED,1,NoOp(Device is FIXED and cannot be logged out of)
exten => s-FIXED,2,Playback(an-error-has-occured)
exten => s-FIXED,3,Playback(vm-goodbye)
exten => s-FIXED,4,Hangup ;TODO should play msg indicated device cannot be logged into
[macro-systemrecording]
exten => s,1,Goto(${ARG1},1)
exten => dorecord,1,Record(/tmp/${CALLERID(number)}-ivrrecording:wav)
exten => dorecord,n,Wait(1)
exten => dorecord,n,Goto(confmenu,1)
exten => docheck,1,Playback(/tmp/${CALLERID(number)}-ivrrecording)
exten => docheck,n,Wait(1)
exten => docheck,n,Goto(confmenu,1)
exten => confmenu,1,Background(to-listen-to-it&press-1&to-rerecord-it&press-star|m||macro-systemrecording)
exten => confmenu,n,Read(RECRESULT||1|||4)
exten => confmenu,n,GotoIf($["x${RECRESULT}"="x*"]?dorecord,1)
exten => confmenu,n,GotoIf($["x${RECRESULT}"="x1"]?docheck,1)
exten => confmenu,n,Goto(1)
exten => 1,1,Goto(docheck,1)
exten => *,1,Goto(dorecord,1)
exten => t,1,Playback(goodbye)
exten => t,n,Hangup
exten => i,1,Playback(pm-invalid-option)
exten => i,n,Goto(confmenu,1)
exten => h,1,Hangup
; CallerID Handling
;sets the callerid of the device to that of the logged in user
[macro-user-callerid]
exten => s,1,GotoIf($["${CHANNEL:0:5}" = "Local"]?report)
exten => s,n,GotoIf($["${REALCALLERIDNUM:1:2}" != ""]?start)
exten => s,n,Set(REALCALLERIDNUM=${CALLERID(number)})
exten => s,n(start),NoOp(REALCALLERIDNUM is ${REALCALLERIDNUM})
exten => s,n,Set(AMPUSER=${DB(DEVICE/${REALCALLERIDNUM}/user)})
exten => s,n,Set(AMPUSERCIDNAME=${DB(AMPUSER/${AMPUSER}/cidname)})
exten => s,n,GotoIf($["x${AMPUSERCIDNAME:1:2}" = "x"]?report)
exten => s,n,Set(CALLERID(all)=${AMPUSERCIDNAME} <${AMPUSER}>)
exten => s,n(report),NoOp(Using CallerID ${CALLERID(all)})
; overrides callerid out trunks
; arg1 is trunk
; macro-user-callerid should be called _before_ using this macro
[macro-outbound-callerid]
exten => s,1,GotoIf($["${REALCALLERIDNUM:1:2}" != ""]?start)
exten => s,n,Set(USEROUTCID=${DB(AMPUSER/${REALCALLERIDNUM}/outboundcid)})
exten => s,n,Set(EMERGENCYCID=${DB(DEVICE/${REALCALLERIDNUM}/emergency_cid)})
exten => s,n,Set(TRUNKOUTCID=${OUTCID_${ARG1}})
exten => s,n,GotoIf($["${EMERGENCYROUTE:1:2}" = ""]?trunkcid) ; check EMERGENCY ROUTE
exten => s,n,GotoIf($["${EMERGENCYCID:1:2}" = ""]?trunkcid) ; empty EMERGENCY CID, so default back to trunk
exten => s,n,Set(CALLERID(all)=${EMERGENCYCID}) ; emergency cid for device
exten => s,n,Goto(report)
exten => s,n(trunkcid),GotoIf($["${TRUNKOUTCID:1:2}" = ""]?usercid) ;check for CID override for trunk (global var)
exten => s,n,Set(CALLERID(all)=${TRUNKOUTCID})
exten => s,n(usercid),GotoIf($["${USEROUTCID:1:2}" = ""]?report) ; check CID override for extension
exten => s,n,Set(CALLERID(all)=${USEROUTCID})
exten => s,n(report),NoOp(CallerID set to ${CALLERID(all)})
; Privacy Manager Macro makes sure that any calls that don't pass the privacy manager are presented
; with congestion since there have been observed cases of the call continuing if not stopped with a
; congestion, and this provides a slightly more friendly 'sorry' message in case the user is
; legitamately trying to be cooperative.
; Note: the following options are configurable in privacy.conf:
; maxretries = 3 ; default value, number of retries before failing
; minlength = 10 ; default value, number of digits to be accepted as valid CID
[macro-privacy-mgr]
exten => s,1,Set(KEEPCID=${CALLERID(num)})
exten => s,n,GotoIf($["foo${CALLERID(num):0:1}"="foo+"]?CIDTEST2:CIDTEST1)
exten => s,n(CIDTEST1),Set(TESTCID=${MATH(1+${CALLERID(num)})})
exten => s,n,Goto(TESTRESULT)
exten => s,n(CIDTEST2),Set(TESTCID=${MATH(1+${CALLERID(num):1})})
exten => s,n(TESTRESULT),GotoIf($["foo${TESTCID}"="foo"]?CLEARCID:PRIVMGR)
exten => s,n(CLEARCID),Set(CALLERID(num)=)
exten => s,n(PRIVMGR),PrivacyManager()
exten => s,n,SetCallerPres(allowed_passed_screen); stop gap until app_privacy.c clears unavailble bit
exten => s,PRIVMGR+101,Noop(STATUS: ${PRIVACYMGRSTATUS} CID: ${CALLERID(num)} ${CALLERID(name)} CALLPRES: ${CALLLINGPRES})
exten => s,n,Playback(sorry-youre-having-problems)
exten => s,n,Playback(goodbye)
exten => s,n,Congestion()
exten => s,n,Hangup
; Inbound Contexts [from]
[from-sip-external]
;give external sip users congestion and hangup
; Yes. This is _really_ meant to be _. - I know asterisk whinges about it, but
; I do know what I'm doing. This is correct.
exten => _.,1,NoOp(Received incoming SIP connection from unknown peer to ${EXTEN})
exten => _.,n,Set(DID=${IF($["${EXTEN:1:2}"=""]?s:${EXTEN})})
exten => _.,n,Goto(s,1)
exten => s,1,GotoIf($["${ALLOW_SIP_ANON}"="yes"]?from-trunk,${DID},1)
exten => s,n,Set(TIMEOUT(absolute)=15)
exten => s,n,Answer
exten => s,n,Wait(2)
exten => s,n,Playback(ss-noservice)
exten => s,n,Hangup
exten => h,1,NoOp(Hangup)
exten => i,1,NoOp(Invalid)
exten => t,1,NoOp(Timeout)
[from-internal]
; applications are now mostly all found in from-internal-additional in _custom.conf
include => parkedcalls
include => from-internal-custom
;allow phones to dial other extensions
include => ext-fax
;allow phones to access generated contexts
; MODIFIED (PL)
; Currently the include for findmefollow is being auto-generated before ext-local which is the desired behavior.
; However, I haven't been able to do anything that I know of to force this. We need to determine if it should
; be hardcoded into here to make sure it doesn't change with some configuration. For now I will leave it out
; until we can discuss this.
include => from-internal-additional
exten => s,1,Macro(hangupcall)
exten => h,1,Macro(hangupcall)
[from-zaptel]
exten => _X.,1,Set(DID=${EXTEN})
exten => _X.,n,Goto(s,1)
exten => s,1,NoOp(Entering from-zaptel with DID == ${DID})
; If ($did == "") { $did = "s"; }
exten => s,n,Set(DID=${IF($["${DID}"= ""]?s:${DID})})
exten => s,n,NoOp(DID is now ${DID})
exten => s,n,GotoIf($["${CHANNEL:0:3}"="Zap"]?zapok:notzap)
exten => s,n(notzap),Goto(ext-did,${DID},1)
; If there's no ext-did,s,1, that means there's not a no did/no cid route. Hangup.
exten => s,n,Macro(hangup)
exten => s,n(zapok),NoOp(Is a Zaptel Channel)
exten => s,n,Set(CHAN=${CHANNEL:4})
exten => s,n,Set(CHAN=${CUT(CHAN,-,1)})
exten => s,n,Macro(from-zaptel-${CHAN},${DID},1)
; If nothing there, then treat it as a DID
exten => s,n,NoOp(Returned from Macro from-zaptel-${CHAN})
exten => s,n,Goto(ext-did,${DID},1)
; Extension Contexts [ext]
[ext-fax]
exten => s,1,Answer
exten => s,2,Goto(in_fax,1)
exten => in_fax,1,StopPlayTones
exten => in_fax,2,GotoIf($["${FAX_RX}" = "system"]?3:analog_fax,1)
exten => in_fax,3,Macro(faxreceive)
exten => in_fax,4,system(/var/lib/asterisk/bin/fax-process.pl --to ${EMAILADDR} --from ${FAX_RX_FROM} --subject "Fax from ${CALLERID(number)} ${CALLERID(name)}" --attachment ${CALLERID(number)}.pdf --type application/pdf --file ${FAXFILE});
exten => in_fax,5,Hangup
exten => analog_fax,1,GotoIf($["${FAX_RX}" = "disabled"]?4:2) ;if fax is disabled, just hang up
exten => analog_fax,2,Set(DIAL=${DB(DEVICE/${FAX_RX}/dial)});
exten => analog_fax,3,Dial(${DIAL},20,d)
exten => analog_fax,4,Hangup
;exten => out_fax,1,wait(7)
exten => out_fax,1,txfax(${TXFAX_NAME}|caller)
exten => out_fax,2,Hangup
exten => h,1,Hangup()
;this is where parked calls go if they time-out. Should probably re-ring
[default]
exten => s,1,Playback(vm-goodbye)
exten => s,2,Macro(hangupcall)
thx im Voraus
MfG bEx
