[Gelöst] Telldus Tellstick für Freetz kompilieren (FritzBox 7390)
Kannst du mit dmesg oder cat /dev/debug Meldungen des Kernels zu deinem Problem sehen?Wie ist die Ausgabe von lsmod?
Oliver
Hi, danke für die Antwort.
Dmesg spuckt folgendes aus, was ich leider nicht komplett entziffern kann.
root@fritz:/var/mod/root# dmesg
Linux version 2.6.28.10 (hjortmann@EmbeddedVM) (gcc version 4.4.2 (GCC) ) #9 Wed Dec 22 16:19:11 CET 2010
phym = 04000000, mem = 04000000, max_pfn = 00004000
Reserving memory for CP1 @0xa4000000, size 0x00000000
CPU revision is: 0001954c (MIPS 34Kc)
Determined physical RAM map:
 memory: 04000000 @ 00000000 (usable)
nid=0 start=0 map=558 end=4000 mapsize=800 mode_bootmen_map=80558000
Initrd not found or empty - disabling initrd
Zone PFN ranges:
  Normal   0x00000000 -> 0x00004000
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
    0: 0x00000000 -> 0x00004000
On node 0 totalpages: 16384
free_area_init_node: node 0, pgdat 80404080, node_mem_map 81000000
  Normal zone: 128 pages used for memmap
  Normal zone: 0 pages reserved
  Normal zone: 16256 pages, LIFO batch:3
  Movable zone: 0 pages used for memmap
[c55] c55_mem_start = 0xfc0000
entering build_all_zonelists()
return from set_zonelist_order()
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
Kernel command line: console=ttyS1,115200n8r nor_size=16MB ethaddr=C0:25:06:12:5A:1D
[0:parse_mtd_size/712] '16MB'
[0:mtdnor_setup/914] nor_size = 0x1000000
[0:mtdnor_setup/921] mtd2 = 0x90000000,0x90020000
[0:mtdnor_setup/949] mtd1 = 0x90020000,0x90F80000
[0:mtdnor_setup/961] mtd3 = 0x90F80000,0x90FC0000
[0:mtdnor_setup/973] mtd4 = 0x90FC0000,0x91000000
mac address c0-25- 6-12-5a-1d
[trap_init] cpu_has_vint
[trap_init] cpu_has_ejtag
[trap_init] cpu_has_watch
[trap_init] cpu_has_divec
[trap_init] cpu_has_mcheck
[trap_init] cpu_has_mipsmt
[trap_init] cpu_has_4kex
Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
Primary data cache 16kB, 4-way, VIPT, no aliases, linesize 32 bytes
Writing ErrCtl register=00070b61
Readback ErrCtl register=00070b61
PID hash table entries: 256 (order: 8, 1024 bytes)
Console: colour dummy device 80x25
console [ttyS1] enabled
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 59260k/65536k available (3137k kernel code, 6208k reserved, 971k data, 184k init, 0k highmem)
Calibrating delay loop... 261.32 BogoMIPS (lpj=1306624)
Security Framework initialized
Mount-cache hash table entries: 512
kernel_init: started
kernel_init: kernel locked
net_namespace: 636 bytes
NET: Registered protocol family 16
Lantiq PCI host controller driver, version 1.1.7, (c) 2001-2010 Lantiq Deutschland GmbH
pci 0000:00:00.0: supports D1 D2
pci 0000:00:00.0: PME# supported from D1 D2
pci 0000:00:00.0: PME# disabled
pci 0000:00:0e.0: reg 10 32bit mmio: [0x000000-0x00ffff]
NET: Registered protocol family 8
NET: Registered protocol family 20
Switched to high resolution mode on CPU 0
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
gptu: totally 6 16-bit timers/counters
gptu: misc_register on minor 63
gptu: succeeded to request irq 120
gptu: succeeded to request irq 121
gptu: succeeded to request irq 122
gptu: succeeded to request irq 123
gptu: succeeded to request irq 124
gptu: succeeded to request irq 125
I[avm_register_busmaster:125]: Registered busmaster device: AVM_DMA_BUSMASTER
[bcu_control_interrupt] 'FPI Slave BCU0' Error Interrupt
Slave BCU[sBCU_EADD]: Error Address Register: 0x17000004
Slave BCU[sBCU_EDAT]: Error Data Capture Register: 0x0290030f
Slave BCU[sBCU_CON] : Control Register: 0x4009ffff
Slave BCU[sBCU_ECON]: Error Register (0x21be004d):
        FPI Bus Operation Code 0x2
        FPI Bus Tag Number 0x1
        FPI Bus Read Signal: passive
        FPI Bus Write Signal: active
        FPI Bus Supervisor Mode: active
        FPI Bus Acknowladge Signal: 0x3
        FPI Bus Abort: passive
        FPI Bus Ready: active
        FPI Bus Timeout: not pressed
        FPI Bus Error Counter: 77
[bcu_control_init] interrupts for BCU installed
Lantiq CGU driver, version 1.0.9, (c) 2001-2010 Lantiq Deutschland GmbH
config3 0x424 MT 1
MVPControl 0x2, STLB 0 VPC 1 EVP 0
mvpconf0 0xb8008403, PVPE 1 PTC 3 M 1
smvp_tc_init: tc 0 tcbind 00020000 tcstatus 18102000
smvp_tc_init: tc 1 tcbind 00200001 tcstatus 00000400
smvp_tc_init: tc 2 tcbind 00400001 tcstatus 00000400
smvp_tc_init: tc 3 tcbind 00600001 tcstatus 00000400
config3 0x424 MT 1
initcall vpe_module_init+0x0/0x544 returned with disabled interrupts
audit: initializing netlink socket (disabled)
type=2000 audit(0.590:1): initialized
[simple_profiling] 0 entries 50 min
squashfs: version 3.4 (2008/08/26) Phillip Lougher
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.10)
yaffs Dec 22 2010 16:18:39 Installing.
msgmni has been set to 115
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
io scheduler noop registered (default)
avm_net_trace: Up and running.
[avm] configured: watchdog event debug
AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0, build: Dec 22 2010 16:18:06)
[simple-profiling]: 4 performance counters implemented
Enable Performance Counter 0 for Data cache accesses (User-Mode enabled Supervisor-Mode enabled Kernel-Mode enabled Exeption-Mode disable)
Enable Performance Counter 1 for Data cache misses (User-Mode enabled Supervisor-Mode enabled Kernel-Mode enabled Exeption-Mode disable)
[avm]: AVM Simple Profiling enabled.
ifx_pmu_init: Major 244
Lantiq PMU driver, version 1.1.4, (c) 2001-2010 Lantiq Deutschland GmbH
Lantiq GPIO driver, version 1.2.12, (c) 2001-2010 Lantiq Deutschland GmbH
Infineon Technologies RCU driver version 1.0.6
Serial: SERIAL_AVM_ASC driver
ttyS0 at MMIO 0xbe100400 (irq = 100) is a IFX_ASC
ttyS1 at MMIO 0xbe100c00 (irq = 107) is a IFX_ASC
loop: module loaded
nbd: registered device at major 43
[cpmac] Version: 1.108.1.32.1.7 - Revision 811:1181 - Mi 22.12.2010 16:18:53
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
IFX SWITCH API, Version 0.9.8.1
SWAPI: Registered character device [switch_api] with major no [242]
cpmac0 up
IFX 3 Port Switch Eth driver, version ifxmips_3port_sw.c:v1.0.5
,(c)2009 Infineon Technologies AG
Lantiq ATM driver, version 1.0.19, (c) 2001-2010 Lantiq Deutschland GmbH
    ATM (A1) firmware version 0.16
ifxmips_atm: ATM init succeed
Generic platform RAM MTD, (c) 2004 Simtec Electronics
Platform NOR MTD, (c) AVM 2010
[plat_nor_probe]start probe
mtd-nor: Found 1 x16 devices at 0x0 in 16-bit bank
 Amd/Fujitsu Extended Query Table at 0x0040
mtd-nor: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
[parse_mtd_partitions] types=find_jffs2
[ifx_jffs2_parser_function] mtd_info->name mtd-nor mtd_info->index 0 param=0 p_mtd_pat=0x839f0a50
[ifx_jffs2_parser_function] try partition kernel (offset 0x20000 len 16121856)
[ifx_jffs2_parser_function] magic 19850003 found @pos 0xe80000, size 1048576
[parse_mtd_partitions] types=find_squashfs
[ifx_squashfs_parser_function] mtd_info->name mtd-nor mtd_info->index 0 param=0 p_mtd_pat=0x839f0a50
[ifx_squashfs_parser_function:315] pos: 0x183100 | offs[0]: 0x183100 | size[0]: 14667520 | offs[1]: 0x20000 | size[1]: 1454336
[ifx_squashfs_parser_function] magic found @pos 0x183100
6 find_squashfs partitions found on MTD device mtd-nor
Creating 6 MTD partitions on "mtd-nor":
0x00183100-0x00f80000 : "rootfs" (master-size:16777216)
mtd: partition "rootfs" doesn't start on an erase block boundary -- force read-only
[0:ifx_mtd_add_notifier/635] name rootfs
[0:ifx_mtd_add_notifier/639] found rootfs
[0:ifx_mtd_add_notifier/646] use rootfs
[0:ifx_mtd_add_notifier/650] root device: /dev/mtdblock0 (rootfs)
0x00020000-0x00183100 : "kernel" (master-size:16777216)
mtd: partition "kernel" doesn't end on an erase block -- force read-only
[0:ifx_mtd_add_notifier/635] name kernel
[0:ifx_mtd_add_notifier/679] skip kernel
0x00000000-0x00020000 : "urlader" (master-size:16777216)
[0:ifx_mtd_add_notifier/635] name urlader
[0:ifx_mtd_add_notifier/660] set ifx_urlader_mtd
0x00f80000-0x00fc0000 : "tffs (1)" (master-size:16777216)
[0:ifx_mtd_add_notifier/635] name tffs (1)
[0:ifx_mtd_add_notifier/668] tffs (1) on Index 3
0x00fc0000-0x01000000 : "tffs (2)" (master-size:16777216)
[0:ifx_mtd_add_notifier/635] name tffs (2)
[0:ifx_mtd_add_notifier/675] tffs (2) on Index 4
0x00e80000-0x00f80000 : "jffs2" (master-size:16777216)
[0:ifx_mtd_add_notifier/635] name jffs2
[0:ifx_mtd_add_notifier/679] skip jffs2
[0:ifx_mtd_add_notifier/635] name mtd-nor
[0:ifx_mtd_add_notifier/679] skip mtd-nor
mtd-nor mtd-nor: registered mtd device
Lantiq SSC driver, version 2.1.8, (c) 2001-2010 Lantiq Deutschland GmbH
Unknown SPI device: 0xFF 0xFF 0xFF
ifx_spi_flash_init: Found no serial flash device
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
CAPI Subsystem Rev 1.1.2.8
cpuidle: using governor ladder
cpuidle: using governor menu
IFX MEI Version 5.00.04<6>oprofile: using mips/34K performance monitoring.
IPv4 over IPv4 tunneling driver
TCP cubic registered
mcfw: IGMPv3 fast forwarding
NET: Registered protocol family 10
IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
Bridge firewalling registered
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
Initializing koam module
TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
      mount on mtd3 and mtd4 (double buffering)
Adam2 environment variables API installed.
kernel_init: basic setup done
[squashfs] use lzma compression
VFS: Mounted root (squashfs filesystem) readonly.
Freeing unused kernel memory: 406000: 184k freed
[uart_avm_set_termios] baudrate=115200, quot=107, fdv=24, reload=4, b=114840
trying /sbin/init
TFFS Name Table H
led_modul_Fritz_Box_7320: module license '
(C) Copyright 2008 by AVM
' taints kernel.
[led_gpio_bit_driver_init] gpio 44 name power
[led_gpio_bit_driver_init] gpio 47 name internet
[led_gpio_bit_driver_init] gpio 38 name dect
[led_gpio_bit_driver_init] gpio 37 name wlan
[led_gpio_bit_driver_init] gpio 35 name dual1
[led_gpio_bit_driver_init] gpio 45 name dual2
[button_init] name button_wlan, gpio 1 active_low
[button_init] name button_dect, gpio 2 active_low
AVM_WATCHDOG: System Init UEberwachung 240 Sekunden
rtc-avm rtc-avm.0: rtc core: registered avm as rtc0
[avm-rtc]: avm_rtc_probe: register: ret=0x83008c00
[avm-rtc]: avm_rtc_probe: success
[piglet]use gpio-settings for 172
patch_dectfw: c0b73000, totallen = 42926(a7ae)
patch_dectfw: patch_adress: 3dac max_len: 26 with Version 2 Len: 17
dect_loader: slow-bootmode
<FE>*
dect144xx_file_process: upload of '/lib/modules/dectfw_secondlevel_441.hex' successfull
[piglet]TDM: FS: 8035 Hz CLK: 1027950 Hz
[pcmlink]svn: 1272
[VPELink_PreInit] vpe-base 0xfc0000, maxsize: 131072
driver params overwritten io_addr=0x0 irq_num=0
[pcmlink]chrony-support
VPE loader: loading to 84000000 (fix at start-addr) len = 2097152
 elf loaded
vpe_run: tc 1 start-addr 80fc0000
vpe_run: tc 1 tcstatus 18000400 tcbind 00200001
 MVPCONTROL 00000002 vpeopt 00000000
[avm_debug]standard kernel-messages
capicodec_init()
[capi_codec] support fax
[capi_codec] support Codecs
dect_uicp_from_dect, ignore 15 bytes, dect_manager not up: 10000B00000F2F7B
ramzswap: /dev/ramzswap0 initialized: disksize_kb=16384<6>Adding 16376k swap on /dev/ramzswap0.  Priority:-1 extents:1 across:16376k
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
IFXUSB: ifxusb_hcd: version 3.0alpha B100312
IFXUSB: USB core #0 soft-reset
ifxusb_hcd ifxusb_hcd: IFX USB Controller
ifxusb_hcd ifxusb_hcd: new USB bus registered, assigned bus number 1
ifxusb_hcd ifxusb_hcd: irq 56, io mem 0xbe101000
IFXUSB: Init: Power Port (0)
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
IFXUSB: USB core #1 soft-reset
ifxusb_hcd ifxusb_hcd: new USB bus registered, assigned bus number 2
ifxusb_hcd ifxusb_hcd: irq 85, io mem 0xbe106000
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
IFXHCD#1: AVM Powermeter changed to 0 mA
dect_uicp_from_dect, ignore 23 bytes, dect_manager not up: 10001300000FF614
IFXHCD#2: AVM Powermeter changed to 0 mA
usb 2-1: new full speed USB device using ifxusb_hcd and address 2
HC_XFER_STALLCh 3 CTRL-IN S0 urb=8336e280 epqh=83bec180 urbd=8336a100
  Device address: 2
  Endpoint: 0, IN
  Endpoint type: CTRL
  Speed: FS
  Max packet size: 8
  Data buffer length: 10
  Transfer buffer: 8336a200, Transfer DMA: 0336a200
  Setup buffer: 8336a180, Setup DMA: 0336a180
  Interval: 0
  STATUS:KNOWN
HC_XFER_STALLCh 4 CTRL-IN S0 urb=8336e280 epqh=83bec180 urbd=8336a100
  Device address: 2
  Endpoint: 0, IN
  Endpoint type: CTRL
  Speed: FS
  Max packet size: 8
  Interval: 0
  STATUS:KNOWN
HC_XFER_STALLCh 5 CTRL-IN S0 urb=8336e280 epqh=83bec180 urbd=8336a100
  Device address: 2
  Endpoint: 0, IN
  Endpoint type: CTRL
  Speed: FS
  Max packet size: 8
  Interval: 0
  STATUS:KNOWN
Bus#2: AVM Powermeter changed to 90 mA
usb 2-1: configuration #1 chosen from 1 choice
IFXHCD#2: AVM Powermeter changed to 90 mA
Infineon CPE API Driver version: DSL CPE API V3.20.5.1
dynamically registered major number 236 for dsl_ar9
DSL_DRV: using proc fs
IFXHCD#2: AVM Powermeter changed to 100 mA
usb 2-1: reset full speed USB device using ifxusb_hcd and address 2
Modem is not ready!power mode 0 already set
DSL[00]: Line state has changed: 00000000 -> 000000FF
kdsldmod: init start (Nov 25 2010 12:56:39) sizeof(struct sk_buff)=192
kdsldmod: init done
DSL[00]: Line state has changed: 000000FF -> 00000100
DSL[00]: Line state has changed: 00000100 -> 00000100
eth: port 0 status 2 throttle 0
eth: port 1 status 1 throttle 1
eth: port 2 status 1 throttle 1
[cpmac] [adm_power_config] tried to set mode for port 2
[avm_power] : ethernet switch failed
eth: port 3 status 1 throttle 1
[cpmac] [adm_power_config] tried to set mode for port 3
DSL[00]: Line state has changed: 00000100 -> 00000200
DSL[00]: Line state has changed: 00000200 -> 00000300
[wlan_eeprom] calibration data blocks found = 1
[wlan_eeprom] Got calibration data version 255 for instance #1
[wlan_eeprom] Using complete eeprom from flash
wlanfw: Init.
ath_hal: 0.9.14.25 (AR5416, DEBUG, REGOPS_FUNC)
ath_dfs: Version 2.0.0
Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
wlan: 0.8.4.2 (Atheros/multi-bss)
Registered for AVM event source.
ADDRCONF(NETDEV_UP): eth0: link is not ready
device eth0 entered promiscuous mode
device cpmac0 entered promiscuous mode
DSL[00]: Line state has changed: 00000300 -> 00000380
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
lan: topology change detected, propagating
lan: port 1(eth0) entering forwarding state
ath_rate_atheros: Version 2.0.1
Copyright (c) 2001-2004 Atheros Communications, Inc, All Rights Reserved
ath_spectral: Version 2.0.0
ath_pci: 0.9.4.5 (Atheros/multi-bss)
ath_pci: CR-LSDK-1.3.1.146
cache line size: 8
Chan  Freq  RegPwr  HT   CTL CTL_U CTL_L DFS
   1  2412n     20  HT20  1    0    1     N
   2  2417n     20  HT20  1    0    1     N
   3  2422n     20  HT40  1    0    1     N
   4  2427n     20  HT40  1    0    1     N
   5  2432n     20  HT40  1    1    1     N
   6  2437n     20  HT40  1    1    1     N
   7  2442n     20  HT40  1    1    1     N
   8  2447n     20  HT40  1    1    1     N
   9  2452n     20  HT40  1    1    1     N
  10  2457n     20  HT40  1    1    0     N
  11  2462n     20  HT40  1    1    0     N
  12  2467n     20  HT20  1    1    0     N
  13  2472n     20  HT20  1    1    0     N
ath_descdma_setup: rx DMA map: a26e0000 (38160) -> physical 026e0000 (38160)
ath_descdma_setup: tx DMA map: a2700000 (149184) -> physical 02700000 (149184)
ath_descdma_setup: beacon DMA map: a2695000 (1152) -> physical 02695000 (1152)
dfs_init_radar_filters: dfs->dfs_rinfo.rn_numradars: 0
DFS min filter rssiThresh = 21
DFS max pulse dur = 131 ticks
ic_chainmask=3x3
wifi0: 11ng rates: 1Mbps 2Mbps 5.5Mbps 11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbps
wifi0: 11ng MCS:  0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15
wifi0: mac 384.2 phy 15.15 radio 12.0
wifi0: Use hw queue 1 for WME_AC_BE traffic
wifi0: Use hw queue 0 for WME_AC_BK traffic
wifi0: Use hw queue 2 for WME_AC_VI traffic
wifi0: Use hw queue 3 for WME_AC_VO traffic
wifi0: Use hw queue 8 for CAB traffic
wifi0: Use hw queue 9 for beacons
wifi0: Use hw queue 7 for UAPSD
avm_net_trace: New net trace device 'HW (2.4 + 5 GHz, wifi0)' registered with minor 128.
wifi0: Atheros 9287: mem=0x18000000, irq=24 hw_base=0xb8000000
wlan: mac acl policy registered
avm_net_trace: New net trace device 'AP (2.4 + 5 GHz, ath0)' registered with minor 130.
avm_net_trace: New net trace device 'AP (2.4 + 5 GHz, ath0)' registered with minor 131.
DSL[00]: Line state has changed: 00000380 -> 00000001
device ath0 entered promiscuous mode
lan: port 2(ath0) entering forwarding state
DSL[00]: Line state has changed: 00000001 -> 00000000
[capi_oslib] capi_installed
AVM_WATCHDOG: System Init UEberwachung abgeschlossen (172170 ms noch verfuegbar)
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_cpuclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=0 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dspclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=974 NormP=974 mW -> SumNormP=974 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_systemclock: norm_power_rate=100 act_rate=100 mul=65 div=10 offset=1793 NormP=2443 mW -> SumNormP=3417 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_wlan: norm_power_rate=100 act_rate=28 mul=84 div=10 offset=100 NormP=940 mW -> SumNormP=4357 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_analog: norm_power_rate=100 act_rate=0 mul=141 div=10 offset=100 NormP=1510 mW -> SumNormP=5867 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dect: norm_power_rate=100 act_rate=0 mul=200 div=78 offset=150 NormP=406 mW -> SumNormP=6273 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_ethernet: norm_power_rate=467 act_rate=16777436 mul=1 div=1 offset=50 NormP=517 mW -> SumNormP=6790 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dsl: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=6790 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_host: norm_power_rate=500 act_rate=0 mul=55 div=10 offset=0 NormP=2750 mW -> SumNormP=9540 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_client: norm_power_rate=0 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=9540 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_charge: norm_power_rate=446 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=9540 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_loadrate: norm_power_rate=100 act_rate=100 mul=15 div=1 offset=0 NormP=1500 mW -> SumNormP=11040 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_host2: norm_power_rate=100 act_rate=100 mul=55 div=10 offset=0 NormP=550 mW -> SumNormP=11590 mW
SysRq : Changing Loglevel
Loglevel set to 4
DSL[00]: Line state has changed: 00000380 -> 00000800
DSL[00]: Line state has changed: 00000800 -> 00000801
kdsld_token_thread: start
sch_llq: Dec 22 2010 16:18:37
userman: LAN Client Internet-Accounting and Blocking
userman: device registerd with major=228
userman: init ok
/proc/tffs: info request: success
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver ftdi_sio
ftdi_sio: v1.4.3:USB FTDI Serial Converters Driver
lan: port 2(ath0) entering disabled state
lan: port 1(eth0) entering disabled state
usb 2-1: USB disconnect, address 2
usb 1-1: new full speed USB device using ifxusb_hcd and address 2
HC_XFER_STALLCh 3 CTRL-IN S0 urb=81ad1200 epqh=83bec480 urbd=82cef800
  Device address: 2
  Endpoint: 0, IN
  Endpoint type: CTRL
  Speed: FS
  Max packet size: 8
  Transfer buffer: 82cefe80, Transfer DMA: 02cefe80
  Setup buffer: 818a8b00, Setup DMA: 018a8b00
  Interval: 0
  STATUS:KNOWN
HC_XFER_STALLCh 4 CTRL-IN S0 urb=81ad1200 epqh=83bec480 urbd=82cef800
  Device address: 2
  Endpoint: 0, IN
  Endpoint type: CTRL
  Speed: FS
  Max packet size: 8
  Interval: 0
  STATUS:KNOWN
HC_XFER_STALLCh 5 CTRL-IN S0 urb=81ad1200 epqh=83bec480 urbd=82cef800
  Device address: 2
  Endpoint: 0, IN
  Endpoint type: CTRL
  Speed: FS
  Max packet size: 8
  Interval: 0
  STATUS:KNOWN
Bus#1: AVM Powermeter changed to 90 mA
usb 1-1: configuration #1 chosen from 1 choice
ftdi_sio 1-1:1.0: FTDI USB Serial Device converter detected
usb 1-1: Detected FT232RL
usb 1-1: FTDI USB Serial Device converter now attached to ttyUSB0
IFXHCD#1: AVM Powermeter changed to 90 mA
usb 1-1: usbfs: interface 0 claimed by ftdi_sio while 'aurad' sets config #0
ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
ftdi_sio 1-1:1.0: device disconnected
usb 1-1: reset full speed USB device using ifxusb_hcd and address 2
usb 1-1: USB disconnect, address 2
usb 2-1: new full speed USB device using ifxusb_hcd and address 3
HC_XFER_STALLCh 7 CTRL-IN S0 urb=81ad1200 epqh=82e8d280 urbd=818a8b00
  Device address: 3
  Endpoint: 0, IN
  Endpoint type: CTRL
  Speed: FS
  Max packet size: 8
  Transfer buffer: 827b5480, Transfer DMA: 027b5480
  Setup buffer: 82e8cd80, Setup DMA: 02e8cd80
  Interval: 0
  STATUS:KNOWN
HC_XFER_STALLCh 8 CTRL-IN S0 urb=81ad1200 epqh=82e8d280 urbd=818a8b00
  Device address: 3
  Endpoint: 0, IN
  Endpoint type: CTRL
  Speed: FS
  Max packet size: 8
  Interval: 0
  STATUS:KNOWN
HC_XFER_STALLCh 9 CTRL-IN S0 urb=81ad1200 epqh=82e8d280 urbd=818a8b00
  Device address: 3
  Endpoint: 0, IN
  Endpoint type: CTRL
  Speed: FS
  Max packet size: 8
  Interval: 0
  STATUS:KNOWN
ftdi_sio 2-1:1.0: FTDI USB Serial Device converter detected
usb 2-1: Detected FT232RL
usb 2-1: FTDI USB Serial Device converter now attached to ttyUSB0
usb 2-1: usbfs: interface 0 claimed by ftdi_sio while 'aurad' sets config #0
ftdi_sio 2-1:1.0: device disconnected
usb 2-1: reset full speed USB device using ifxusb_hcd and address 3
usb 2-1: usbfs: interface 0 claimed by ftdi_sio while 'aurad' sets config #1
usb 2-1: FTDI USB Serial Device converter now attached to ttyUSB1
ifxusb_hcd ifxusb_hcd: remove, state 1
usb usb1: USB disconnect, address 1
IFXUSB: PortPower off
ifxusb_hcd ifxusb_hcd: USB bus 1 deregistered
usb usb2: USB disconnect, address 1
usb 2-1: USB disconnect, address 3
ftdi_sio ttyUSB1: FTDI USB Serial Device converter now disconnected from ttyUSB1
ifxusb_hcd ifxusb_hcd: USB bus 2 deregistered
IFXUSB: IFX USB platform_dev release
IFXUSB: ifxusb_hcd module removed
ftdi_sio ttyUSB0: ftdi_set_termios FAILED to set databits/stopbits/parity
ftdi_sio ttyUSB0: ftdi_set_termios urb failed to set baudrate
ftdi_sio ttyUSB0: urb failed to set to rts/cts flow control
HC_XFER_STALLCh 3 CTRL-IN S0 urb=81ad1380 epqh=83bec280 urbd=81a68f00
  Device address: 2
  Endpoint: 0, IN
  Endpoint type: CTRL
  Speed: FS
  Max packet size: 8
  Transfer buffer: 8335d980, Transfer DMA: 0335d980
  Setup buffer: 8335da00, Setup DMA: 0335da00
  Interval: 0
  STATUS:KNOWN
HC_XFER_STALLCh 4 CTRL-IN S0 urb=81ad1380 epqh=83bec280 urbd=81a68f00
  Device address: 2
  Endpoint: 0, IN
  Endpoint type: CTRL
  Speed: FS
  Max packet size: 8
  Interval: 0
  STATUS:KNOWN
HC_XFER_STALLCh 5 CTRL-IN S0 urb=81ad1380 epqh=83bec280 urbd=81a68f00
  Device address: 2
  Endpoint: 0, IN
  Endpoint type: CTRL
  Speed: FS
  Max packet size: 8
  Interval: 0
  STATUS:KNOWN
HC_XFER_STALLCh 10 CTRL-IN S0 urb=81ad1380 epqh=83bec380 urbd=83aee100
  Device address: 3
  Endpoint: 0, IN
  Endpoint type: CTRL
  Speed: FS
  Max packet size: 8
  Transfer buffer: 82793500, Transfer DMA: 02793500
  Setup buffer: 81a68400, Setup DMA: 01a68400
  Interval: 0
  STATUS:KNOWN
HC_XFER_STALLCh 5 CTRL-IN S0 urb=81ad1380 epqh=83bec380 urbd=83aee100
  Device address: 3
  Endpoint: 0, IN
  Endpoint type: CTRL
  Speed: FS
  Max packet size: 8
  Interval: 0
  STATUS:KNOWN
HC_XFER_STALLCh 3 CTRL-IN S0 urb=81ad1380 epqh=83bec380 urbd=83aee100
  Device address: 3
  Endpoint: 0, IN
  Endpoint type: CTRL
  Speed: FS
  Max packet size: 8
  Interval: 0
  STATUS:KNOWN
Die Eingabe von cat /dev/debug bringt folgende Meldungen des Kernels
root@fritz:/var/mod/root# cat /dev/debug
?[4294938494][isdn]svn:2747
[4294938601]PCMLINK: Version 7.356 Slots=5 BChan=5(Analog=1) DChan=0 Fifo=128 no HwCross DSP-EC: 1
[4294938690][DECTDRV_ERR] avm_dect driver init
[4294938690][DECTDRV_ERR] [avm_dect]avm_dect_thread: start
[4294939539][pcmlink]error: trigger to late 29503 usec (20151001 206D4CC5 206D8A80)
[4294939539]avm_DebugSignal: 0 kernel info: 0
[4294939539][avmdebug] push supportdata
[4294939539][avmdebug]push_mail: failed with ret=-2
[4294939542][pcmlink]error: trigger to late 28390 usec (206D4CC5 20C2354D 20C26A07)
[4294939542]avm_DebugSignal: 0 kernel info: 0
[4294939545][pcmlink]error: trigger to late 28385 usec (20C2354D 211719A7 2117569C)
[4294939545]avm_DebugSignal: 0 kernel info: 0
[4294939606]DSP: XDU=8( D1 ) OVR=7 MIPS_OVR=7
[00002244][avmdebug] push supportdata
[04837465]DSP: XDU=1( S1 ) OVR=0 MIPS_OVR=0
[04838465]DSP: XDU=2( S1 ) OVR=0 MIPS_OVR=0
[05409402]DSP: XDU=1( S1 ) OVR=0 MIPS_OVR=0
[05410402]DSP: XDU=1( S1 ) OVR=0 MIPS_OVR=0
[05411402]DSP: XDU=2( S1 ) OVR=0 MIPS_OVR=0
[05412402]DSP: XDU=2( S1 ) OVR=0 MIPS_OVR=0
Und lsmod gibt Folgendes aus:
root@fritz:/var/mod/root# lsmod
Module                  Size  Used by    Tainted: P
ifxusb_host            89792  0
ftdi_sio               52272  1
usbserial              32496  3 ftdi_sio
userman_mod            46992  2
sch_sfq                 6656  4
sch_llq                 9376  1
sch_tbf                 5632  1
wlan_scan_ap           13152  1
wlan_acl                5664  1
wlan_wep                5920  0
wlan_tkip              11840  2
wlan_ccmp               8160  4
wlan_xauth              1216  0
ath_pci               179200  0
ath_spectral           96320  1 ath_pci
ath_rate_atheros       60976  1 ath_pci
wlan                  269648  9 wlan_scan_ap,wlan_acl,wlan_wep,wlan_tkip,wlan_ccmp,wlan_xauth,ath_pci,ath_rate_atheros
ath_dfs                39008  3 wlan_scan_ap,ath_pci,wlan
ath_hal               327488  5 ath_pci,ath_spectral,ath_rate_atheros,ath_dfs
avm_ath_extensions     41392  6 wlan_scan_ap,ath_pci,ath_rate_atheros,wlan,ath_dfs,ath_hal
kdsldmod             1075904  7 userman_mod
dsl_ar9               300672  0
usbcore               125552  4 ifxusb_host,ftdi_sio,usbserial
ramzswap               16448  1
lzo_compress            2080  1 ramzswap
lzo_decompress          2272  1 ramzswap
dect_io                15232  0
avm_dect              232784  1 dect_io
capi_codec            322432  0
isdn_fbox_fon5        752048  5
pcmlink               241168  3 avm_dect,capi_codec,isdn_fbox_fon5
Piglet_noemif          23264  0
rtc_avm                 5520  2 pcmlink
led_modul_Fritz_Box_7320    68368  4
Irgendwie finde ich nirgends einen Hinweis auf den Telldus-Tellstick. Kann mich jemand korrigieren?
Danke vorab schonmal wieder! ;)
Ich lese da was von aurad. Hast du den AVM Fernanschluss an?
Oliver
Oliver
nein, der Fernanschluss ist nicht aktiviert. Sollte er denn aktiviert sein?
Außerdem würde mich interessieren, ob /dev/ttyUSB0 der richtige Link zum Tellstick in der conf ist. Kann ich das irgendwie checken?
Liebe Grüsse
Liebe Grüsse
Hallo nochmal ich.
Ich habe nun den USB-Fernanschluss einmal aktiviert.
UND SIEHE DA! ES FUNKTIONIERT! Aber leider nur alle 4 bis 5 mal (siehe Code). Woran kann das denn liegen?
root@fritz:/var/mod/root# tdtool --off 1
^C
^C
root@fritz:/var/mod/root# tdtool --on 1
[B][COLOR="#FF0000"]Turning on device 1, Funksteckdose 1 - Success[/COLOR][/B]
^C
^[[A
^C
^C
^C
Kann sich das jemand erklären? Meistens muss ich den tdtool-Befehl abbrechen, da keine Rückmeldung kommt. Doch dann auf einmal funktioniert es, dann wieder x-mal nicht.
Sowas kann natürlich immer an der USB-Implementierung liegen. Wir hatten da mit AVM Geräten schon öfter seltsame Verhaltensweisen...
Du hast eine 7320? Dann besteht vielleicht die Hoffnung, dass es sich mit der nächsten Firmware und neuem Kernel von selbst löst. :)
Oliver
Oliver
Ok, danke für die Info. Ärgerlich trotzdem. Da ich gerne auch von unterwegs den Strom steuern möchte (z.B. Dreambox einschalten um Timer zu programmieren), ist es natürlich eher unschön, nicht zu wissen, ob der Befehl nun ankam oder nicht :(
Vielleicht werde ich ein Skript schreiben, welches den Befehl dann einfach mehrere Male sendet. Ok, soweit danke für alle Hilfestellungen hier im Forum. Ich bleibe dran, und melde mich gegebenenfalls wieder, wenn es Neuigkeiten bzgl. des Problems gibt.
Da ja eine neue Firmware in Aussicht ist gibt es Hoffnung auf Besserung in naher Zukunft... :)
Oliver
[Edit frank_m24: Vollzitat vom Beitrag direkt darüber gelöscht, siehe Forumregeln.]
Na das klingt ja super;) Hat jemand eine Idee, wie man eine Smartphone-Steuerung für den Tellstick an der FritzBox hinbekommen kann? Am liebsten wäre mir eine Lösung von außen, die keine weiteren Basteleien an der Fritzbox voraussetzen.
Im Endeffekt würde ja ein simples Skript, welches den "tdtool --on/off 1, 2, 3 usw"-Befehl ausführt völlig ausreichen.
Bin aktuell noch am Suchen einer Lösung, die extrem simpel ist. Danke vorab
Wir haben in Freetz einen Ersatz für das dtrace on/off. Damit könnte das gehen!?
Oliver
Das verstehe ich nicht ganz. Ich dachte dtrace ist ein Systemwerkzeug zur Kernel-Analyse. Kannst du das eventuell verifizieren/falsifizieren, bzw. erklären was du damit meinst. Vielen Dank.
Achso, danke! Und in wiefern kann das zur Ansteuerung des tdtools verwendet werden? Ich stehe leider noch ein bisschen auf der Leitung..
Über einen Telefon-Code kann man das Programm aufrufen. Und wenn man das Programm durch ein eigenes Programm ersetzt, kann man dieses eigene Programm über den Telefon-Code aufrufen.
OK, ich glaube, ich verstehe. Z.b. besitzt die FritzBox ja auch die Möglichkeit, den Telnetd per Telefon zu aktivieren, was im Endeffekt ja auch einen terminal-ähnlichen Befehl darstellt oder?
Dann werde ich mir das tatsächlich nocheinmal anschauen. Wie heißt die Freetz-Alternative von dtrace?
BTW: danke an alle bisherigen Helfer. Klasse Forum mit kompetenter Hilfe und ohne rumgebeefe ;) Dank euch konnte selbst ich, ohne fundiertes Linux-Wissen gute Fortschritte in meinem Projekt erzielen. Top!
Jo sehe ich auch so. Das Tool "Home Automation" habe ich gestern gefunden. Es ist ein webbasierter Tellstick-Server. Überlege mir, das auf der Fritzbox zu installieren. Benötigt wird jedoch ein Webserver, PHP und MySql. Stressig! Da muss ich mich etz erst mal einlesen. ;)
MySql könnte schwierig werden. Da dürfte es einfacher sein, wenn du dir eine Webinterface schreibst auf der du per Knopfdruck die benötigten Aktionen ausführen kannst. Das geht dann nicht per Telefon, aber per Smartphone...
Oliver
Da sprichst du etwas an, das mich sehr neugierig macht. Diese Idee hatte ich auch schon. Das php Skript mit fsocketopen ist ja schnell geschrieben, nur ist die Frage ob mein Hoster (Strato) die ssh2-Geschichte unterstützt. Oder muss ich das Php-Skript direkt auf der Fritzbox hosten?
Man muss nicht PHP für ein einfaches Skript verwenden
Ok?! Ich wüsste spontan nichts anderes. Reiner Html-Markup kann sowas nicht. Und Java Script ist doch hier deutlich aufwendiger zu realisieren als PHP. Oder liege ich falsch?
EDIT: Oder meinst du CGI?
