TC300 different meni languages
gonys
19 Jan 2008
Hi
Is a possibility of the change language in the TC300 phone to Polish?
Whether it is possible to build own with some program?
Please help. I need Polish, Russian and Czech language to this phone or tool to build by own.
There're only 2 gui languages per device possible. T9 database cannot be changed it seems.
For commercial project pls ask pirelli support at www.pirellibroadband.com or Your distributor.
Pls respect their terms and conditions.
For private use only You may decode the firmware image file with tc300ex and edit the strings in langstr.bin with a binaryfile editor but be careful not to change any system used bytes. good luck.
I already work over Polish software. If someone want then send me msg (PM).
hi i looking for polish or russian or danish language any help??
any help pls :> i realy badly need this lp - russian -polish -dunish any of them
jenniferjemma029
