Feb 1 14:31:57 fritz kern.warn kernel: [106895.370000] [0]system-load 2 loadavg 2.91 2.73 2.43 - 148 tasks:0 % curr:ctlmgr(0 %) max:ntfs-3g(0 %, pid:4391), readytorun: 4, pgfault 89/s (max 2 avg 1.0)
Feb 1 14:32:15 fritz daemon.info hostapd: ath0: STA WPA: group key handshake completed (RSN)
Feb 1 14:32:16 fritz daemon.info hostapd: ath0: STA WPA: group key handshake completed (RSN)
Feb 1 14:32:43 fritz kern.err kernel: [106941.400000] [nand_command_lp] read block is critical (status: 0xe8, column: 0x0 page: 0x825f)
Feb 1 14:34:35 fritz kern.warn kernel: [107053.990000] [0]system-load 2 loadavg 3.46 3.4 2.59 - 151 tasks:129 % curr:version(0 %) max:ntfs-3g(61 %, pid:4391), readytorun: 4, pgfault 57/s (max 2 avg 1.0)
Feb 1 14:34:37 fritz kern.info kernel: [107055.480000] /proc/tffs: info request: success
Feb 1 14:34:40 fritz kern.warn kernel: [107059.040000] [1]system-load 2 loadavg 3.66 3.8 2.61 - 153 tasks:5 % curr:python2.7.bin(0 %) max:ntfs-3g(1 %, pid:4391), readytorun: 6, pgfault 76/s (max 2 avg 1.0)
Feb 1 14:35:05 fritz kern.warn kernel: [107083.490000] [0]system-load 3 loadavg 3.39 3.6 2.61 - 147 tasks:119 % curr:ntfs-3g(49 %) max:ntfs-3g(49 %, pid:4391), readytorun: 2, pgfault 247/s (max 2 avg 1.0)
Feb 1 14:35:48 fritz kern.err kernel: [107126.760000] [nand_command_lp] read block is critical (status: 0xe8, column: 0x0 page: 0x825f)
Feb 1 14:37:46 fritz kern.err kernel: [107245.110000] SQUASHFS error: sb_bread failed reading block 0x98e7
Feb 1 14:37:47 fritz kern.err kernel: [107245.130000] SQUASHFS error: Unable to read page, block 263248c, size 774b
Feb 1 14:37:47 fritz kern.err kernel: [107245.180000] SQUASHFS error: sb_bread failed reading block 0x98e7
Feb 1 14:37:47 fritz kern.err kernel: [107245.200000] SQUASHFS error: Unable to read page, block 263248c, size 774b
Feb 1 14:37:47 fritz kern.err kernel: [107245.220000] SQUASHFS error: sb_bread failed reading block 0x98e7
Feb 1 14:37:47 fritz kern.err kernel: [107245.230000] SQUASHFS error: Unable to read page, block 263248c, size 774b
Feb 1 14:37:47 fritz kern.err kernel: [107245.250000] SQUASHFS error: sb_bread failed reading block 0x98e7
Feb 1 14:37:47 fritz kern.err kernel: [107245.260000] SQUASHFS error: Unable to read page, block 263248c, size 774b
Feb 1 14:37:47 fritz kern.err kernel: [107245.280000] SQUASHFS error: sb_bread failed reading block 0x98e7
Feb 1 14:37:47 fritz kern.err kernel: [107245.290000] SQUASHFS error: Unable to read page, block 263248c, size 774b
Feb 1 14:37:47 fritz kern.err kernel: [107245.310000] SQUASHFS error: sb_bread failed reading block 0x98e7
Feb 1 14:37:47 fritz kern.err kernel: [107245.320000] SQUASHFS error: Unable to read page, block 263248c, size 774b
Feb 1 14:37:47 fritz kern.err kernel: [107245.340000] SQUASHFS error: sb_bread failed reading block 0x98e7
Feb 1 14:37:47 fritz kern.err kernel: [107245.350000] SQUASHFS error: Unable to read page, block 263248c, size 774b
Feb 1 14:37:47 fritz kern.err kernel: [107245.370000] SQUASHFS error: sb_bread failed reading block 0x98e7
Feb 1 14:37:47 fritz kern.err kernel: [107245.370000] SQUASHFS error: Unable to read page, block 263248c, size 774b
Feb 1 14:37:47 fritz kern.err kernel: [107245.390000] SQUASHFS error: sb_bread failed reading block 0x98e7
Feb 1 14:37:47 fritz kern.err kernel: [107245.400000] SQUASHFS error: Unable to read page, block 263248c, size 774b
Feb 1 14:37:47 fritz kern.err kernel: [107245.420000] SQUASHFS error: sb_bread failed reading block 0x98e7
Feb 1 14:37:47 fritz kern.err kernel: [107245.430000] SQUASHFS error: Unable to read page, block 263248c, size 774b
Feb 1 14:38:49 fritz kern.err kernel: [107307.640000] [nand_command_lp] read block is critical (status: 0xe8, column: 0x0 page: 0x825f)
Feb 1 14:39:29 fritz kern.err kernel: [107347.650000] [nand_command_lp] read block is critical (status: 0xe8, column: 0x0 page: 0x825f)
Feb 1 14:40:58 fritz kern.err kernel: [107437.000000] [nand_command_lp] read block is critical (status: 0xe8, column: 0x0 page: 0x825f)
Feb 1 14:42:15 fritz daemon.info hostapd: ath0: STA WPA: group key handshake completed (RSN)
Feb 1 14:42:16 fritz daemon.info hostapd: ath0: STA WPA: group key handshake completed (RSN)
Feb 1 14:47:44 fritz kern.info kernel: [107841.860000] /proc/tffs: info request: success
Feb 1 14:47:55 fritz kern.warn kernel: [107852.850000] [1]system-load 3 loadavg 2.79 2.68 2.62 - 160 tasks:151 % curr:openvpn_2(3 %) max:python2.7.bin(34 %, pid:16294), readytorun: 6, pgfault 790/s (max 1 avg 1.0)
