root@fritz:/var/mod/root# sh -x /etc/init.d/rc.swap start
+ DAEMON=swap
+ CONF_NAME=mod
+ . /etc/init.d/modlibrc
+ export PATH=/mod/sbin:/mod/bin:/mod/usr/sbin:/mod/usr/bin:/sbin:/bin:/usr/sbin:/usr/bin
+ export LD_LIBRARY_PATH=/mod/lib:/mod/usr/lib
+ : swap
+ : mod
+ : swap_ENABLED
+ : /mod/etc/swap.conf
+ : swap
+ : /var/run/swap.pid
+ [ -n swap ]
+ modlib_loadconfig
+ local CONF_FILE=/mod/etc/conf/mod.cfg
+ [ ! -r /mod/etc/conf/mod.cfg ]
+ . /mod/etc/conf/mod.cfg
+ export MOD_CGI_WIDTH=600
+ export MOD_CROND=no
+ export MOD_EXTERNAL_DIRECTORY=/var/media/ftp/uStor01/external
+ export MOD_EXTERNAL_FREETZ_SERVICES=yes
+ export MOD_EXTERNAL_OWN_SERVICES=
+ export MOD_EXTERNAL_WAIT_INFINITE=no
+ export MOD_EXTERNAL_YEAR_MAX=2099
+ export MOD_EXTERNAL_YEAR_MIN=no
+ export MOD_GET_IP_METHOD=--all
+ export MOD_HTTPD=yes
+ export MOD_HTTPD_PASSWD=****************
+ export MOD_HTTPD_PORT=81
+ export MOD_HTTPD_USER=**********
+ export MOD_MOUNTED_MAIN=yes
+ export MOD_MOUNTED_SUB=yes
+ export MOD_MOUNTED_UMOUNT=yes
+ export MOD_SHOW_BOX_INFO=yes
+ export MOD_SHOW_FREETZ_INFO=yes
+ export MOD_SHOW_MEMORY_USAGE=yes
+ export MOD_SHUTDOWN_FIRST=inetd
+ export MOD_SHUTDOWN_IGNORE=syslogd
+ export MOD_SHUTDOWN_LAST=cifsmount davfs2 autofs
+ export MOD_STOR_AUTORUNEND=no
+ export MOD_STOR_KILLBLOCKER=no
+ export MOD_STOR_PREFIX=uStor
+ export MOD_STOR_USELABEL=no
+ export MOD_SWAP=yes
+ export MOD_SWAP_FILE=/*dev/*sda1/swapfile
+ export MOD_SWAP_SWAPPINESS=60
+ start
+ echo -n Starting swap ...
Starting swap ... + has_swap
+ sed 1d /proc/swaps
+ grep -v /dev/ramzswap0
+ grep -q
+ swapon /*dev/*sda1/swapfile
+ exitval=1
+ [ 1 -eq 0 ]
+ echo failed.
failed.
+ exit 1
+ DAEMON=swap
+ CONF_NAME=mod
+ : swap
+ : mod
+ : swap_ENABLED
+ : swap
+ [ -n swap ]
+ modlib_loadconfig
+ export MOD_HTTPD_PASSWD=****************************
+ export MOD_HTTPD_USER=***********************
+ export MOD_SWAP_FILE=/var/media/ftp/uStor01/swapfile
+ start
+ grep -q
+ swapon /var/media/ftp/uStor01/swapfile
+ exitval=1
+ [ 1 -eq 0 ]
+ echo failed.
failed.
+ exit 1
Das mit dem Reboot habe ich versucht, bringt aber nix. An der Hardwarehabe ich auch nichts verändert. Ist alle wie vor der 05.05.Da hilft nur reboot, wie oben richtig angedeutet wurde.
root@fritz:/var/mod/root# cat /proc/swaps
Filename Type Size Used Priority
/dev/sda4 partition 136544 1116 -2
/dev/ramzswap0 partition 16376 0 -1
