Skype 1.2.0.37 wurde veröffentlicht
* feature: Central Contacts List
* feature: Voicemail
* feature: SkypeIn
* feature: Getting Started Wizard
* feature: Promote Add To Contacts
* feature: toolbar added to call tab
* feature: File Transfer - ability to select multiple files to send
* feature: Import/Export contactlist from/to vCard
* feature: API: possible to initiate conference
* feature: added exitsurvey when Skype is uninstalled
* feature: chat /alertson * /alertsoff
* change: improved voice quality
* change: improved connectivity on XP SP2
* change: Options dialog - usability improvements
* change: new sounds
* change: file transfer: increased relayed transfer speed to 1500 bytes/sec
* change: Option to automatically close ft window when transfer is complete
* change: notification on entering SkypeMe mode changed to confirmation
* change: Send Contacts: possibility to send PSTN numbers
* change: Send Contacts form closed when all selected contacts added
* change: content of user profile phone fields is displayed in Contact List as links only if it's valid Skype contact identity
* change: prank call warning re-designed
* change: the number of simultaneous File Transfers limited to 50
* change: user selectable font size and type in Chat
* change: reversed pending authorization requests order on start-tab
* change: Import Contacts - bundled MSN, Microsoft Outlook, Outlook Express and Opera Contact Importers
* bugfix: improved 'Automatically check for updates'
* bugfix: My Skype Picture — files with jpeg extentions were not shown
* bugfix: 'accept authorization' buttons were not translatable
* bugfix: in some cases API did not deny access properly
* bugfix: API: commands BTN_RELEASED UP and BTN_RELEASED DOWN
* bugfix: API: "AUDIO IN" and "AUDIO OUT" commands did not read double byte driver names correctly
* bugfix: API: command BTN_PRESSED E failed with error 71 invalid key
* bugfix: API: command IMHISTORYCHANGED didn't work
* bugfix: API: mute from UI is communicated to API
* bugfix: API: No notification were shown when the user changed audio device
* bugfix: handling URL links in chat improved
* bugfix: Send Contacts: Add Selected button disabled, if contacts are unchecked
* bugfix: Send Contacts: username was displayed twice, if fullname was not chosen
* bugfix: Send Contacts: username and fullame were placed differently on sender's and receiver's side
* bugfix: unchecking Show Emoticons hided emoticons toolbar in IM windows
* bugfix: resource leak and potential crash condition fixed, related to traynotifications
* bugfix: addressbar quickfilter did not show all matches on some cases
* bugfix: avatar browser: select added image by default
* bugfix: doubleclicking on last (partially visible item in contactlist) acted on wrong contact
* bugfix: when conference call host runs out of skypeOut credits during call correct error messages are displayed
* bugfix: SkypeIn/SkypeOut error codes are displayed during conference calls
* bugfix: improved SkypeOut links handling in Chat window
* bugfix: installer now tries to shut down skype 10 times instead of 1 during install and uninstall
* bugfix: possible to add conference participant from addressbar with conference button
* bugfix: going automatically to 'Not Available' status was not working if AutoAway was set to 0
* bugfix: uninstaller behaviour improved
* bugfix: timestamps added to 'click here to see previous messages' link
* bugfix: installer reuses language selection
* bugfix: avatar browser did not work with multiple accounts
* bugfix: unicode character sorting was inconsistent
* bugfix: sometimes after a person had left Multi Chat, the person was still shown in participants list
* bugfix: default style emoticons have timestamps
* bugfix: sometimes number of copied chars were calculated wrong in chat
* bugfix: file transfer notification had missing content in some cases
* bugfix: text highlighting in chat improved
* bugfix: if file was renamed before saving, old filename was shown in dialog
* bugfix: Startup splash text was broken in German
* bugfix: edit profile: rare 'scan line index' out of range bug fixed
* bugfix: '&' was escaped in recent- and bookmarked chat menus
* bugfix: invalid handling of SkypeOut number when redialing from failed call tab
* bugfix: too long avatar file names did not fit to avatar browser
* bugfix: search results: ordering by birth date did not work on rare cases
* bugfix: conference holding issues
* bugfix: tooltips were missing in search results
download unter http://www.skype.com/products/skype/windows/
* feature: SkypeIn
