asterisk*CLI>
<--- SIP read from UDP:192.168.25.35:5060 --->
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.25.35:5060;rport;branch=z9hG4bK1448924419
To: <sip:[email protected]:5060>
Call-ID: [email protected]
CSeq: 20 INVITE
Contact: <sip:[email protected]:5060>
Max-Forwards: 70
User-Agent: Dahua UAC/3.0 VTO2000A V4.300.0.1
Expires: 120
Content-Type: application/sdp
Content-Length: 308
v=0
o=0 0 0 IN IP4 192.168.25.35
s=Dahua VT 1.5
c=IN IP4 192.168.25.35
t=0 0
m=video 20001 RTP/AVP 96
a=framerate:25.000000
a=rtpmap:96 H264/90000
a=sendrecv
m=audio 20000 RTP/AVP 101 97 0
a=rtpmap:97 PCM/16000
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
--- (12 headers 15 lines) ---
Sending to 192.168.25.35:5060 (NAT)
Using INVITE request as basis request - [email protected]
Found peer '8001' for '8001' from 192.168.25.35:5060
<--- Reliably Transmitting (NAT) to 192.168.25.35:5060 --->
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 192.168.25.35:5060;branch=z9hG4bK1448924419;received=192.168.25.35;rport=5060
To: <sip:[email protected]:5060>;tag=as5238b688
CSeq: 20 INVITE
Server: Asterisk PBX 16.2.1~dfsg-1+deb10u1
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
Supported: replaces, timer
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="4fe1fbd5"
Content-Length: 0
Scheduling destruction of SIP dialog '[email protected]' in 6400 ms (Method: INVITE)
ACK sip:[email protected]:5060 SIP/2.0
Route: <sip:192.168.25.95:5060;lr>
CSeq: 20 ACK
Content-Length: 0
--- (8 headers 0 lines) ---
Via: SIP/2.0/UDP 192.168.25.35:5060;rport;branch=z9hG4bK338187561
CSeq: 21 INVITE
Authorization: Digest username="8001", realm="asterisk", nonce="4fe1fbd5", uri="sip:[email protected]:5060", response="16722f32f19975b85a698e53e25d4dc8", algorithm=MD5
Max-Forwards: 70
Expires: 120
Content-Length: 308
v=0
s=Dahua VT 1.5
t=0 0
a=sendrecv
a=fmtp:101 0-15
a=sendrecv
--- (13 headers 15 lines) ---
== Using SIP VIDEO CoS mark 6
== Using SIP RTP CoS mark 5
Found RTP video format 96
Found video description format H264 for ID 96
Found RTP audio format 101
Found RTP audio format 97
Found RTP audio format 0
Found unknown media description format PCM for ID 97
Found audio description format PCMU for ID 0
Found audio description format telephone-event for ID 101
Capabilities: us - (ulaw|h264), peer - audio=(ulaw)/video=(h264)/text=(nothing), combined - (ulaw|h264)
Non-codec capabilities (dtmf): us - 0x0 (nothing), peer - 0x1 (telephone-event|), combined - 0x0 (nothing)
Peer audio RTP is at port 192.168.25.35:20000
Peer video RTP is at port 192.168.25.35:20001
Looking for 9901 in sip-out (domain 192.168.25.95)
sip_route_dump: route/path hop: <sip:[email protected]:5060>
<--- Transmitting (NAT) to 192.168.25.35:5060 --->
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.25.35:5060;branch=z9hG4bK338187561;received=192.168.25.35;rport=5060
CSeq: 21 INVITE
Content-Length: 0
-- Executing [9901@sip-out:1] Set("SIP/8001-0000001a", "CALLERID(num)=9901") in new stack
-- Executing [9901@sip-out:2] Ringing("SIP/8001-0000001a", "") in new stack
SIP/2.0 180 Ringing
To: <sip:[email protected]:5060>;tag=as41c39e5c
CSeq: 21 INVITE
Content-Length: 0
-- Executing [9901@sip-out:3] Answer("SIP/8001-0000001a", "") in new stack
Audio is at 19064
Video is at 192.168.25.95:18414
Adding codec ulaw to SDP
Adding video codec h264 to SDP
SIP/2.0 200 OK
CSeq: 21 INVITE
Content-Length: 270
v=0
o=root 393116226 393116226 IN IP4 192.168.25.95
s=Asterisk PBX 16.2.1~dfsg-1+deb10u1
c=IN IP4 192.168.25.95
b=CT:384
t=0 0
m=video 18414 RTP/AVP 96
a=sendrecv
m=audio 19064 RTP/AVP 0
a=maxptime:150
a=sendrecv
Via: SIP/2.0/UDP 192.168.25.35:5060;rport;branch=z9hG4bK1390926228
CSeq: 21 ACK
Max-Forwards: 70
Content-Length: 0
--- (10 headers 0 lines) ---
-- Executing [9901@sip-out:4] Dial("SIP/8001-0000001a", "SIP/11032,30,m") in new stack
Audio is at 15154
Video is at 192.168.25.95:11878
Reliably Transmitting (NAT) to 192.168.25.32:5060:
Via: SIP/2.0/UDP 192.168.25.95:5060;branch=z9hG4bK4bb2b4cc;rport
Max-Forwards: 70
Call-ID: [email protected]:5060
CSeq: 102 INVITE
User-Agent: Asterisk PBX 16.2.1~dfsg-1+deb10u1
Date: Mon, 10 Feb 2020 12:19:04 GMT
Content-Length: 272
v=0
o=root 1521505064 1521505064 IN IP4 192.168.25.95
b=CT:384
t=0 0
m=audio 15154 RTP/AVP 0
a=maxptime:150
a=sendrecv
m=video 11878 RTP/AVP 96
a=sendrecv
-- Called SIP/11032
-- Started music on hold, class 'default', on channel 'SIP/8001-0000001a'
<--- SIP read from UDP:192.168.25.32:5060 --->
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.25.95:5060;branch=z9hG4bK4bb2b4cc;rport=5060
CSeq: 102 INVITE
User-Agent: Dahua UAC/3.0 VTH1510CH V4.300.0.8
Content-Length: 0
SIP/2.0 101 Dialog Establishement
To: <sip:[email protected]:5060>;tag=1521107684
CSeq: 102 INVITE
Content-Length: 0
--- (9 headers 0 lines) ---
SIP/2.0 180 Ringing
CSeq: 102 INVITE
MaxRingingTime: 30
MaxConnectingTime: 600
MaxLeaveWordTime: 30
LeaveType: FTP
ShortNumber: 11032
DependentInfo: 192.168.25.35
Content-Length: 0
--- (15 headers 0 lines) ---
-- SIP/11032-0000001b is ringing
SIP/2.0 200 OK
CSeq: 102 INVITE
Content-Length: 308
v=0
o=0 0 0 IN IP4 192.168.25.32
s=Dahua VT 1.5
c=IN IP4 192.168.25.32
t=0 0
a=recvonly
a=fmtp:101 0-15
a=sendrecv
--- (10 headers 15 lines) ---
Peer audio RTP is at port 192.168.25.32:20000
Peer video RTP is at port 192.168.25.32:20001
Via: SIP/2.0/UDP 192.168.25.95:5060;branch=z9hG4bK1317f05e;rport
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
-- SIP/11032-0000001b answered SIP/8001-0000001a
-- Stopped music on hold on SIP/8001-0000001a
-- Channel SIP/11032-0000001b joined 'simple_bridge' basic-bridge <463f38a6-cf4e-416c-8243-be800dfdb01a>
-- Channel SIP/8001-0000001a joined 'simple_bridge' basic-bridge <463f38a6-cf4e-416c-8243-be800dfdb01a>
Audio is at 19064
Video is at 192.168.25.32:20001
Reliably Transmitting (NAT) to 192.168.25.35:5060:
Via: SIP/2.0/UDP 192.168.25.95:5060;branch=z9hG4bK7614e02d;rport
Max-Forwards: 70
To: <sip:[email protected]>;tag=2107754867
CSeq: 102 INVITE
X-asterisk-Info: SIP re-invite (External RTP bridge)
Content-Length: 270
v=0
o=root 393116226 393116227 IN IP4 192.168.25.95
b=CT:384
t=0 0
m=audio 20000 RTP/AVP 0
a=maxptime:150
a=sendrecv
a=sendrecv
Audio is at 15154
Video is at 192.168.25.35:20001
Via: SIP/2.0/UDP 192.168.25.95:5060;branch=z9hG4bK7782bedf;rport
Max-Forwards: 70
CSeq: 103 INVITE
Content-Length: 272
v=0
o=root 1521505064 1521505065 IN IP4 192.168.25.95
b=CT:384
t=0 0
a=maxptime:150
a=sendrecv
a=sendrecv
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.25.95:5060;branch=z9hG4bK7782bedf;rport=5060
CSeq: 103 INVITE
Content-Length: 0
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.25.95:5060;branch=z9hG4bK7614e02d;rport=5060
CSeq: 102 INVITE
Content-Length: 0
SIP/2.0 200 OK
CSeq: 103 INVITE
Content-Length: 206
v=0
s=Dahua VT 1.5
t=0 0
--- (10 headers 11 lines) ---
Via: SIP/2.0/UDP 192.168.25.95:5060;branch=z9hG4bK61379f56;rport
Max-Forwards: 70
CSeq: 103 ACK
Content-Length: 0
SIP/2.0 200 OK
CSeq: 102 INVITE
Content-Length: 206
v=0
s=Dahua VT 1.5
t=0 0
Via: SIP/2.0/UDP 192.168.25.95:5060;branch=z9hG4bK53848e55;rport
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
BYE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.25.32:5060;rport;branch=z9hG4bK467087132
To: <sip:[email protected]>;tag=as4a5940ae
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
Sending to 192.168.25.32:5060 (NAT)
Scheduling destruction of SIP dialog '[email protected]:5060' in 6400 ms (Method: BYE)
<--- Transmitting (NAT) to 192.168.25.32:5060 --->
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.25.32:5060;branch=z9hG4bK467087132;received=192.168.25.32;rport=5060
CSeq: 103 BYE
Content-Length: 0
-- Channel SIP/11032-0000001b left 'native_rtp' basic-bridge <463f38a6-cf4e-416c-8243-be800dfdb01a>
Audio is at 19064
Via: SIP/2.0/UDP 192.168.25.95:5060;branch=z9hG4bK575b2369;rport
Max-Forwards: 70
CSeq: 103 INVITE
Content-Length: 270
v=0
o=root 393116226 393116228 IN IP4 192.168.25.95
b=CT:384
t=0 0
a=maxptime:150
a=sendrecv
a=sendrecv
-- Channel SIP/8001-0000001a left 'native_rtp' basic-bridge <463f38a6-cf4e-416c-8243-be800dfdb01a>
== Spawn extension (sip-out, 9901, 4) exited non-zero on 'SIP/8001-0000001a'
Scheduling destruction of SIP dialog '[email protected]' in 6400 ms (Method: ACK)
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.25.95:5060;branch=z9hG4bK575b2369;rport=5060
CSeq: 103 INVITE
Content-Length: 0
SIP/2.0 200 OK
CSeq: 103 INVITE
Content-Length: 206
v=0
s=Dahua VT 1.5
t=0 0
Via: SIP/2.0/UDP 192.168.25.95:5060;branch=z9hG4bK0259fbd0;rport
Max-Forwards: 70
CSeq: 103 ACK
Content-Length: 0
Via: SIP/2.0/UDP 192.168.25.95:5060;branch=z9hG4bK07bd4e2d;rport
Max-Forwards: 70
CSeq: 104 BYE
Proxy-Authorization: Digest username="VTO2000A", realm="asterisk", algorithm=MD5, uri="sip:192.168.25.95", nonce="4fe1fbd5", response="27b8b2dff956847d1a1cae5c6d8f65b7"
X-Asterisk-HangupCause: Normal Clearing
X-Asterisk-HangupCauseCode: 16
Content-Length: 0
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.25.95:5060;branch=z9hG4bK07bd4e2d;rport=5060
CSeq: 104 BYE
Content-Length: 0
Really destroying SIP dialog '[email protected]' Method: ACK
Really destroying SIP dialog '[email protected]:5060' Method: BYE
OPTIONS sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.25.95:5060;branch=z9hG4bK28454e59;rport
Max-Forwards: 70
From: "asterisk" <sip:[email protected]>;tag=as08e43010
CSeq: 102 OPTIONS
Date: Mon, 10 Feb 2020 12:19:18 GMT
Content-Length: 0
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.25.95:5060;branch=z9hG4bK28454e59;rport=5060
To: <sip:[email protected]:5060>;tag=35975738
CSeq: 102 OPTIONS
Content-Length: 0
Really destroying SIP dialog '[email protected]:5060' Method: OPTIONS
Really destroying SIP dialog '[email protected]' Method: REGISTER
REGISTER sip:192.168.25.95 SIP/2.0
Via: SIP/2.0/UDP 192.168.25.35:5060;rport;branch=z9hG4bK1103768501
CSeq: 1 REGISTER
Max-Forwards: 70
Expires: 60
PhoneState: 0
Content-Length: 0
--- (12 headers 0 lines) ---
Via: SIP/2.0/UDP 192.168.25.35:5060;branch=z9hG4bK1103768501;received=192.168.25.35;rport=5060
To: <sip:[email protected]:5060>;tag=as6eb0e1c2
CSeq: 1 REGISTER
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="6d911bf8"
Content-Length: 0
Scheduling destruction of SIP dialog '[email protected]' in 32000 ms (Method: REGISTER)
Via: SIP/2.0/UDP 192.168.25.35:5060;rport;branch=z9hG4bK20317153
CSeq: 2 REGISTER
Authorization: Digest username="8001", realm="asterisk", nonce="6d911bf8", uri="sip:192.168.25.95", response="a00d25475f547ce58984d2e43376e628", algorithm=MD5
Max-Forwards: 70
Expires: 60
PhoneState: 0
Content-Length: 0
--- (13 headers 0 lines) ---
Via: SIP/2.0/UDP 192.168.25.95:5060;branch=z9hG4bK0f3e55f1;rport
Max-Forwards: 70
From: "asterisk" <sip:[email protected]>;tag=as398c1300
CSeq: 102 OPTIONS
Date: Mon, 10 Feb 2020 12:19:50 GMT
Content-Length: 0
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.25.35:5060;branch=z9hG4bK20317153;received=192.168.25.35;rport=5060
CSeq: 2 REGISTER
Expires: 60
Contact: <sip:[email protected]:5060>;expires=60
Content-Length: 0
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.25.95:5060;branch=z9hG4bK0f3e55f1;rport=5060
To: <sip:[email protected]:5060>;tag=1439453811
CSeq: 102 OPTIONS
Content-Length: 0
[Feb 10 13:20:01] NOTICE[705]: chan_sip.c:15828 sip_reregister: -- Re-registration for [email protected]
REGISTER 12 headers, 0 lines
Reliably Transmitting (NAT) to 192.168.25.1:5060:
REGISTER sip:192.168.25.1 SIP/2.0
Via: SIP/2.0/UDP 192.168.25.95:5060;branch=z9hG4bK2f1b01f1;rport
Max-Forwards: 70
CSeq: 112 REGISTER
Authorization: Digest username="vto2000a35", realm="fritz.box", algorithm=MD5, uri="sip:192.168.25.1", nonce="5B1C0FDB8DF77965", response="b62ca8c2255bb2aa5f524cc5b78116ae"
Expires: 120
Content-Length: 0
<--- SIP read from UDP:192.168.25.1:5060 --->
Via: SIP/2.0/UDP 192.168.25.95:5060;branch=z9hG4bK2f1b01f1;rport=5060
To: <sip:[email protected]>;tag=3B69FA783EF0E8BA
CSeq: 112 REGISTER
WWW-Authenticate: Digest realm="fritz.box", nonce="9F34695D90E3BDB6"
User-Agent: FRITZ!OS
Content-Length: 0
Responding to challenge, registration to domain/host name 192.168.25.1
Via: SIP/2.0/UDP 192.168.25.95:5060;branch=z9hG4bK7f8337db;rport
Max-Forwards: 70
CSeq: 113 REGISTER
Authorization: Digest username="vto2000a35", realm="fritz.box", algorithm=MD5, uri="sip:192.168.25.1", nonce="9F34695D90E3BDB6", response="f8ef27d729a348244aac4b28dfccae92"
Expires: 120
Content-Length: 0
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.25.95:5060;branch=z9hG4bK7f8337db;rport=5060
To: <sip:[email protected]>;tag=E45EC693063199DA
CSeq: 113 REGISTER
Contact: <sip:[email protected]:5060>;expires=300
User-Agent: AVM FRITZ!Box 7590 (UI) 154.07.12 (Jul 3 2019)
Supported: 100rel,replaces,timer
Allow-Events: telephone-event,refer,reg
Allow: INVITE,ACK,OPTIONS,CANCEL,BYE,UPDATE,PRACK,INFO,SUBSCRIBE,NOTIFY,REFER,MESSAGE,PUBLISH
Accept: application/sdp, multipart/mixed
Accept-Encoding: identity
Content-Length: 0
--- (14 headers 0 lines) ---
[Feb 10 13:20:01] NOTICE[705]: chan_sip.c:24836 handle_response_register: Outbound Registration: Expiry for 192.168.25.1 is 300 sec (Scheduling reregistration in 285 s)
asterisk*CLI>
