Samba: Direktes öffnen funktioniert nicht. Kopieren schon
So, endlich hab ich auch Zeit hierfür ;-)
SO sieht mein Syslog aus. Hab zusätzlich noch nach smb gegrept:
May 22 13:08:16 fritz daemon.err smbd[4040]: [2010/05/22 13:08:16, 0] lib/util_sock.c:get_peer_addr(1224)
May 22 13:08:16 fritz daemon.err smbd[4040]:   getpeername failed. Error was Transport endpoint is not connected
May 22 13:08:16 fritz daemon.err smbd[20785]: [2010/05/22 13:08:16, 0] lib/util_sock.c:get_peer_addr(1224)
May 22 13:08:16 fritz daemon.err smbd[20785]:   getpeername failed. Error was Transport endpoint is not connected
May 22 13:08:16 fritz daemon.err smbd[20785]: [2010/05/22 13:08:16, 0] lib/util_sock.c:write_data(562)
May 22 13:08:16 fritz daemon.err smbd[20785]:   write_data: write failure in writing to client 0.0.0.0. Error Connection reset by peer
May 22 13:08:16 fritz daemon.err smbd[20785]: [2010/05/22 13:08:16, 0] lib/util_sock.c:send_smb(761)
May 22 13:08:16 fritz daemon.err smbd[20785]:   Error writing 4 bytes to client. -1. (Connection reset by peer)
May 24 22:45:39 fritz daemon.err smbd[30524]: [2010/05/24 22:45:39, 0] lib/util_sock.c:get_peer_addr(1224)
May 24 22:45:39 fritz daemon.err smbd[30524]:   getpeername failed. Error was Transport endpoint is not connected
May 24 22:45:39 fritz daemon.err smbd[16236]: [2010/05/24 22:45:39, 0] lib/util_sock.c:get_peer_addr(1224)
May 24 22:45:39 fritz daemon.err smbd[16236]:   getpeername failed. Error was Transport endpoint is not connected
May 24 22:45:39 fritz daemon.err smbd[16236]: [2010/05/24 22:45:39, 0] lib/util_sock.c:write_data(562)
May 24 22:45:39 fritz daemon.err smbd[16236]:   write_data: write failure in writing to client 0.0.0.0. Error Connection reset by peer
May 24 22:45:39 fritz daemon.err smbd[16236]: [2010/05/24 22:45:39, 0] lib/util_sock.c:send_smb(761)
May 24 22:45:39 fritz daemon.err smbd[16236]:   Error writing 4 bytes to client. -1. (Connection reset by peer)
May 24 22:45:39 fritz daemon.err smbd[16235]: [2010/05/24 22:45:39, 0] smbd/service.c:make_connection(1202)
May 24 22:45:39 fritz daemon.err smbd[16235]:   192.168.178.20 (192.168.178.20) couldn't find service .
May 24 22:45:48 fritz daemon.err smbd[16237]: [2010/05/24 22:45:48, 0] smbd/service.c:make_connection_snum(1014)
May 24 22:45:48 fritz daemon.err smbd[16237]:   '/var/media/ftp/Onlinespeicher' does not exist or permission denied when connecting to [Onlinespeicher] Error was No such file or directory
May 24 22:45:49 fritz daemon.err smbd[16237]: [2010/05/24 22:45:49, 0] smbd/service.c:make_connection_snum(1014)
May 24 22:45:49 fritz daemon.err smbd[16237]:   '/var/media/ftp/Onlinespeicher' does not exist or permission denied when connecting to [Onlinespeicher] Error was No such file or directory
May 25 17:22:43 fritz daemon.err smbd[4874]: [2010/05/25 17:22:43, 0] smbd/service.c:make_connection(1202)
May 25 17:22:43 fritz daemon.err smbd[4874]:   mini-mee (192.168.178.20) couldn't find service .
May 25 18:56:14 fritz daemon.err smbd[4874]: [2010/05/25 18:56:14, 0] lib/util_sock.c:read_data(534)
May 25 18:56:14 fritz daemon.err smbd[4874]:   read_data: read failure for 4 bytes to client 192.168.178.20. Error = Connection reset by peer
May 25 18:56:14 fritz daemon.err smbd[4874]: [2010/05/25 18:56:14, 0] lib/util_sock.c:write_data(562)
May 25 18:56:14 fritz daemon.err smbd[4874]:   write_data: write failure in writing to client 192.168.178.20. Error Broken pipe
May 25 18:56:14 fritz daemon.err smbd[4874]: [2010/05/25 18:56:14, 0] lib/util_sock.c:send_smb(761)
May 25 18:56:14 fritz daemon.err smbd[4874]:   Error writing 75 bytes to client. -1. (Broken pipe)
May 25 19:45:32 fritz daemon.err smbd[32425]: [2010/05/25 19:45:32, 0] lib/util_sock.c:get_peer_addr(1224)
May 25 19:45:32 fritz daemon.err smbd[32425]:   getpeername failed. Error was Transport endpoint is not connected
May 25 19:45:32 fritz daemon.err smbd[32425]: [2010/05/25 19:45:32, 0] lib/util_sock.c:write_data(562)
May 25 19:45:32 fritz daemon.err smbd[32425]:   write_data: write failure in writing to client 192.168.178.20. Error Connection reset by peer
May 25 19:45:32 fritz daemon.err smbd[32425]: [2010/05/25 19:45:32, 0] lib/util_sock.c:send_smb(761)
May 25 19:45:32 fritz daemon.err smbd[32425]:   Error writing 4 bytes to client. -1. (Connection reset by peer)
May 25 20:17:36 fritz daemon.err smbd[11172]: [2010/05/25 20:17:36, 0] lib/util_sock.c:get_peer_addr(1224)
May 25 20:17:36 fritz daemon.err smbd[11172]:   getpeername failed. Error was Transport endpoint is not connected
May 25 20:17:36 fritz daemon.err smbd[11172]: [2010/05/25 20:17:36, 0] lib/util_sock.c:write_data(562)
May 25 20:17:36 fritz daemon.err smbd[11172]:   write_data: write failure in writing to client 192.168.178.20. Error Connection reset by peer
May 25 20:17:36 fritz daemon.err smbd[11172]: [2010/05/25 20:17:36, 0] lib/util_sock.c:send_smb(761)
May 25 20:17:36 fritz daemon.err smbd[11172]:   Error writing 4 bytes to client. -1. (Connection reset by peer)
May 25 20:36:47 fritz daemon.err smbd[9131]: [2010/05/25 20:36:47, 0] lib/util_sock.c:read_data(534)
May 25 20:36:47 fritz daemon.err smbd[9131]:   read_data: read failure for 4 bytes to client 192.168.178.20. Error = Connection timed out
May 26 17:10:50 fritz daemon.err smbd[20004]: [2010/05/26 17:10:50, 0] smbd/service.c:make_connection_snum(1014)
May 26 17:10:50 fritz daemon.err smbd[20004]:   '/var/media/ftp/Onlinespeicher' does not exist or permission denied when connecting to [Onlinespeicher] Error was No such file or directory
May 26 18:16:26 fritz daemon.err smbd[20004]: [2010/05/26 18:16:26, 0] lib/util_sock.c:read_data(534)
May 26 18:16:26 fritz daemon.err smbd[20004]:   read_data: read failure for 4 bytes to client 192.168.178.20. Error = No route to host
May 26 18:33:00 fritz daemon.err smbd[20209]: [2010/05/26 18:33:00, 0] lib/util_sock.c:get_peer_addr(1224)
May 26 18:33:00 fritz daemon.err smbd[20209]:   getpeername failed. Error was Transport endpoint is not connected
May 26 18:33:00 fritz daemon.err smbd[15703]: [2010/05/26 18:33:00, 0] lib/util_sock.c:get_peer_addr(1224)
May 26 18:33:00 fritz daemon.err smbd[15703]:   getpeername failed. Error was Transport endpoint is not connected
May 26 18:33:00 fritz daemon.err smbd[15703]: [2010/05/26 18:33:00, 0] lib/util_sock.c:write_data(562)
May 26 18:33:00 fritz daemon.err smbd[15703]:   write_data: write failure in writing to client 0.0.0.0. Error Connection reset by peer
May 26 18:33:00 fritz daemon.err smbd[15703]: [2010/05/26 18:33:00, 0] lib/util_sock.c:send_smb(761)
May 26 18:33:00 fritz daemon.err smbd[15703]:   Error writing 4 bytes to client. -1. (Connection reset by peer)
May 26 19:38:04 fritz daemon.err smbd[822]: [2010/05/26 19:38:04, 0] lib/util_sock.c:read_data(534)
May 26 19:38:04 fritz daemon.err smbd[822]:   read_data: read failure for 4 bytes to client 192.168.178.21. Error = Connection reset by peer
May 26 20:26:31 fritz daemon.err smbd[5529]: [2010/05/26 20:26:31, 0] lib/util_sock.c:read_data(534)
May 26 20:26:31 fritz daemon.err smbd[5529]:   read_data: read failure for 4 bytes to client 192.168.178.21. Error = Connection reset by peer
May 26 22:23:30 fritz daemon.err smbd[25187]: [2010/05/26 22:23:30, 0] lib/util_sock.c:read_data(534)
May 26 22:23:30 fritz daemon.err smbd[25187]:   read_data: read failure for 4 bytes to client 192.168.178.21. Error = Connection reset by peer
May 26 22:46:05 fritz daemon.err smbd[28193]: [2010/05/26 22:46:05, 0] lib/util_sock.c:read_data(534)
May 26 22:46:05 fritz daemon.err smbd[28193]:   read_data: read failure for 4 bytes to client 192.168.178.21. Error = Connection reset by peer
May 26 22:49:06 fritz daemon.err smbd[3652]: [2010/05/26 22:49:06, 0] lib/util_sock.c:read_data(534)
May 26 22:49:06 fritz daemon.err smbd[3652]:   read_data: read failure for 4 bytes to client 192.168.178.21. Error = Connection reset by peer
May 26 23:13:19 fritz daemon.err smbd[11892]: [2010/05/26 23:13:19, 0] lib/util_sock.c:read_data(534)
May 26 23:13:19 fritz daemon.err smbd[11892]:   read_data: read failure for 4 bytes to client 192.168.178.21. Error = Connection reset by peer
May 26 23:19:16 fritz daemon.err smbd[15819]: [2010/05/26 23:19:16, 0] lib/util_sock.c:read_data(534)
May 26 23:19:16 fritz daemon.err smbd[15819]:   read_data: read failure for 4 bytes to client 192.168.178.20. Error = Connection timed out
May 26 23:36:23 fritz daemon.err smbd[20209]: [2010/05/26 23:36:23, 0] lib/util_sock.c:get_peer_addr(1224)
May 26 23:36:23 fritz daemon.err smbd[20209]:   getpeername failed. Error was Transport endpoint is not connected
May 26 23:36:23 fritz daemon.err smbd[22118]: [2010/05/26 23:36:23, 0] lib/util_sock.c:get_peer_addr(1224)
May 26 23:36:23 fritz daemon.err smbd[22118]:   getpeername failed. Error was Transport endpoint is not connected
May 26 23:36:23 fritz daemon.err smbd[22118]: [2010/05/26 23:36:23, 0] lib/util_sock.c:write_data(562)
May 26 23:36:23 fritz daemon.err smbd[22118]:   write_data: write failure in writing to client 0.0.0.0. Error Connection reset by peer
May 26 23:36:23 fritz daemon.err smbd[22118]: [2010/05/26 23:36:23, 0] lib/util_sock.c:send_smb(761)
May 26 23:36:23 fritz daemon.err smbd[22118]:   Error writing 4 bytes to client. -1. (Connection reset by peer)
May 27 00:11:24 fritz daemon.err smbd[14111]: [2010/05/27 00:11:24, 0] lib/util_sock.c:read_data(534)
May 27 00:11:24 fritz daemon.err smbd[14111]:   read_data: read failure for 4 bytes to client 192.168.178.21. Error = No route to host
May 27 17:07:49 fritz daemon.err smbd[29826]: [2010/05/27 17:07:49, 0] lib/util_sock.c:get_peer_addr(1224)
May 27 17:07:49 fritz daemon.err smbd[29826]:   getpeername failed. Error was Transport endpoint is not connected
May 27 17:07:49 fritz daemon.err smbd[29733]: [2010/05/27 17:07:49, 0] lib/util_sock.c:get_peer_addr(1224)
May 27 17:07:49 fritz daemon.err smbd[29733]:   getpeername failed. Error was Transport endpoint is not connected
May 27 17:07:49 fritz daemon.err smbd[29733]: [2010/05/27 17:07:49, 0] lib/util_sock.c:write_data(562)
May 27 17:07:49 fritz daemon.err smbd[29733]:   write_data: write failure in writing to client 0.0.0.0. Error Connection reset by peer
May 27 17:07:49 fritz daemon.err smbd[29733]: [2010/05/27 17:07:49, 0] lib/util_sock.c:send_smb(761)
May 27 17:07:49 fritz daemon.err smbd[29733]:   Error writing 4 bytes to client. -1. (Connection reset by peer)
May 27 17:07:51 fritz daemon.err smbd[29735]: [2010/05/27 17:07:51, 0] lib/util_sock.c:get_peer_addr(1224)
May 27 17:07:51 fritz daemon.err smbd[29735]:   getpeername failed. Error was Transport endpoint is not connected
May 27 17:07:51 fritz daemon.err smbd[29735]: [2010/05/27 17:07:51, 0] lib/util_sock.c:write_data(562)
May 27 17:07:51 fritz daemon.err smbd[29735]:   write_data: write failure in writing to client 192.168.178.20. Error Connection reset by peer
May 27 17:07:51 fritz daemon.err smbd[29735]: [2010/05/27 17:07:51, 0] lib/util_sock.c:send_smb(761)
May 27 17:07:51 fritz daemon.err smbd[29735]:   Error writing 4 bytes to client. -1. (Connection reset by peer)
May 27 17:32:48 fritz daemon.err smbd[29736]: [2010/05/27 17:32:48, 0] lib/util_sock.c:read_data(534)
May 27 17:32:48 fritz daemon.err smbd[29736]:   read_data: read failure for 4 bytes to client 192.168.178.20. Error = Connection timed out
/var/mod/root #
Und her noch der nmb
May 22 12:28:54 fritz daemon.err nmbd[3456]: [2010/05/22 12:28:54, 0] nmbd/nmbd_become_lmb.c:become_local_master_stage2(396)
May 22 12:28:54 fritz daemon.err nmbd[3456]:   *****
May 22 12:28:54 fritz daemon.err nmbd[3456]:   Samba name server FRITZ.BOX is now a local master browser for workgroup ARBEITSGRUPPE on subnet 192.168.178.1
May 22 13:56:44 fritz daemon.err nmbd[3456]: [2010/05/22 13:56:44, 0] nmbd/nmbd_incomingrequests.c:process_name_release_request(118)
May 22 13:56:44 fritz daemon.err nmbd[3456]:   process_name_release_request: Attempt to release name ARBEITSGRUPPE<1d> from IP 192.168.178.20 on subnet 192.168.178.1 being rejected as it is one of our names.
May 22 13:56:45 fritz daemon.err nmbd[3456]: [2010/05/22 13:56:45, 0] nmbd/nmbd_incomingrequests.c:process_name_release_request(118)
May 22 13:56:45 fritz daemon.err nmbd[3456]:   process_name_release_request: Attempt to release name ARBEITSGRUPPE<1d> from IP 192.168.178.20 on subnet 192.168.178.1 being rejected as it is one of our names.
Thx
Es sind viele Meldungen vom smbd, daß die Gegenseite die Verbindung beendet hat. Vielleicht doch ein Problem im Zusammenhang mit dem Client?
Der nmbd hat mit dem Ganzen wenig zu tun.
Der Client ist der selbe wie immer. Vor dem Update ging es einwandfrei. Jetzt nicht mehr. Ich hab es gerade nochmal probiert. Zurzeit funktioniert es sporadisch, wenn es mal nicht funktioniert kommt.
/var/mod/root #  smbd -i -S -d3 -s /mod/etc/smb.conf
smbd version 3.0.37 started.
Copyright Andrew Tridgell and the Samba Team 1992-2009
uid=0 gid=0 euid=0 egid=0
creating default valid table
Processing section "[Onlinespeicher]"
WARNING: The "write cache size" option is deprecated
Processing section "[uStor01]"
added interface ip=192.168.178.1 bcast=192.168.178.255 nmask=255.255.255.0
Registered MSG_REQ_POOL_USAGE
Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED
waiting for a connection
setup_new_vc_session: New VC == 0, if NT4.x compatible we would close all old resources.
check_ntlm_password:  Authentication for user [ftpuser] -> [ftpuser] FAILED with error NT_STATUS_WRONG_PASSWORD
smbd (192.168.178.20) connect to service uStor01 initially as user ftpuser (uid=100, gid=1) (pid 20024)
ftpuser opened file beep.exe read=Yes write=No (numopen=2)
ftpuser closed file beep.exe (numopen=1) NT_STATUS_OK
ftpuser opened file vpn.log read=No write=No (numopen=2)
ftpuser closed file vpn.log (numopen=1) NT_STATUS_OK
INTERNAL ERROR: Signal 11 in pid 20024 (3.0.37)
Please read the Trouble-Shooting section of the Samba3-HOWTO
From: http://www.samba.org/samba/docs/Samba3-HOWTO.pdf
PANIC (pid 20024): internal error
unable to produce a stack trace on this platform
dumping core in /var/cores/smbd
Aborted
/var/mod/root #
Gleiches Problem bei mir hier, die 3.0.24 vom Samba hatte damit keine Probleme :)
Ich wollte eine Datei >200kb vom Netzlauferk kopieren.
Doch ich habe immer die Meldung von Windows XP bekommen xyz kann nicht kopiert werden: Es ist nicht genügend Arbeitsspeicher verfügbar.
Achtung jetzt Wird es Mysteriös! :confused:
Auf meinen Nokia N78 habe ich Symsmb (Samba Server+Client) drauf laufen, da konnte ich mir seltsamerweise eine Datei von um die 140 MB runterladen (ob der Transfer erfolgreich gewesen wäre weiß ich nicht da ich in etwa bei 25% abgebrochen habe)
Am PC kann es auch ne liegen, ich hab vom Handy 80 MB Daten über den Symbian Samba auf den PC kopiert und Nachdem ich mir ein neues Image gebaut habe mit dem AVM Samba, ging auch wieder der Dateitransfer von der Box an den PC. :confused:
Was sollen wir mit dem Samba machen?
Ich hab unter Linux probiert, da funktioniert alles bestens. Unter Windows 7 und Windows XP geht das direkte öffnen von Dateien nicht.
Ich denke, dass das an den Patches liegt die auf den Samba angewendet werden. Ich wüßte nicht wie ich da den Fehler finden soll. Den Patch hab ich von AVM abgeschaut und für die 3.0.37 angepasst bzw. versucht anzupassen. Ohne diesen Patch wird das Samba-Binary noch 1 MB größer.
Ein Möglichkeit wäre, dass wir die Freetz-Konfiguration des Samba für den AVM Samba anbieten, wenn man den nötigen Platz im Flash nicht hat. Und bei Bedarf und genug Platz im Flash den Freetz Samba als Option.
Leider tut sich beim Samba nichts in Richtung Modularität. Da gabs zwar öfter schon nachfragen und es wurde auch eine Wiki-Seite zum "embedded samba" erstellt, aber getan hat sich da seit fast 2 Jahren nix.
MfG Oliver
Ich denke, wir sollten den alten Samba weiter anbieten, und den neuen als Option unter unstable, bis sich da irgendwas mal erledigt. Wobei die Freetz-Seiten zum AVM-Samba auch noch was wären...
Ja, beides sind sehr gute Ideen :)
Am besten wir machen beides. zurück zur 3.0.24 und für Boxen mit noch weniger speicher eben nur das WebIf
Eine Box, bei der es sich lohnt, Samba mit ins Image zu nehmen, wird auch einen USB-Anschluß haben und somit die Möglichkeit, Samba auf dem USB-Speicher abzulegen.
Es bleibt natürlich die Problematik mit dem Hauptspeicher.
Ich wäre für die Option Samba alt (3.0.24) und den neuen (3.0.37) als Option.
Bis jetzt läuft der 3.0.24 Samba auf allen Boxen mit USB-Anschluß sehr stabil.
Getestet habe ich bis jetzt die 7141, 7170, 7240, 7270 V1 - V3
Wenn schon zwei Versionen wäre ich am ehesten für einmal die bisherige (3.0.24) und einmal eine aktuelle (da wären wir bei 3.5.3 bzw. 4alpha), die dann gerne auch ohne die ganzen AVM Hacks.
Der einzige Patch der vom Platz her laut den meisten Newsgrpups nennenswert was bringt ist MAX_DEBUG_LEVEL herunterzusetzen.
Ich hatte da ja auch so meine Probleme mit dem neuen Samba. Auch ich konnte Dateien zwar kopieren, aber nicht direkt öffnen, so wie es der TO beschrieben hatte.
Bei mir lag es an der Option "oplock", welche ich über die erweiterte Konfiguration auf der der Box deaktiviert habe.
Schaut mal hier:
http://www.ip-phone-forum.de/showthread.php?t=215491
währe, übrigens auch für die option den alten Sambe anzubieten und den aktuellen als unstable. Was mich jedoch etwas verwundert ist, dass bei fast allen direktes öffnen der Dateien nicht funktioniert, aber die Fehlermeldung dazu im Log immer ganz unterschiedlich aussieht. Irgendwie kann man das Phänomen nicht wirklich an etwas fest machen.
Danke an euch für eure Mühen
Bitte testen.
r4957
Und bitte vorher oplocks=no aus der Konfig nehmen, falls es drin steht.
MfG Oliver
Perfekt, Problem erledigt.
Sowohl direktes Öffnen als auch Kopieren funktionieren ohne Fehlermeldung(en).
Danke dafür !
so long,
_iwan.
[Edit frank_m24: Vollzitat vom Beitrag direkt darüber gelöscht, siehe Forumregeln.]
Habe grade r4957 getestet:
Beim Öffnen von Bildern über Samba wurde das erste Bild noch geöffnet, bei dem zweiten bekam ich jedoch dann die Meldung, das nicht genügend Festplattenspeicher vorhanden wäre (oder so ähnlich). MP3-Dateien hingegen liefen sofort an, habe da aber auch nur ganz kurz zwei Tracks angespielt. BSODs gab es keinen.
Ich bin jetzt ertmal zurück auf meine funktionierende Konfig, da meine Box momentan gebraucht wird (hab grad schon Mecker von Frau und Kindern bekommen :rolleyes:).
EDIT:
Bei Dir klappts _iwan?
Das wundert mich aber jetzt etwas. Naja, werde die Tage mal einen frischen "co" machen, eventuell is in meinem Build-System ja auch was krum. (Hatte dort jedenfalls die Tage mal ne Fehlermeldung: BUG:CPU-Lock oder so).
Hab gerade extra nochmal wüst hin- und hergeklickt.
Fazit: es klappt wirklich :)
Bilder, mp3s und Filme lassen sich ohne Fehlermeldungen öffnen. Alles Prima !
Sasch, ich glaube, der Fehler liegt bei Dir ... ;)
EDIT:
Also.
Neuer Checkout:
Das erste Bild, welches angeklickt wird, wird korrekt geöffnet, bei jedem weiteren Bild nach einem Klick auf "Weiter" (Windows Fax-Fotoanzeige) bekomme ich das hier zu sehen:
Mit "oplocks = no" in der Experten-Konfig kann ich wieder wie gewohnt durch die Bilder klickern.
ich kann ebenfalls bestätigen. Es funktioniert wieder alles wie gewohnt. Vielen Dank.
Von meiner Seite her kann der Thread geschlossen werden
Danke an oli
