Rufumleitung FB WLAN 7050 (Annex A) NEWBIE
martien
5 Sep 2006
See English below, first my best German:
Also, ich habe ein analoges Festnetz mit 1 Nummer, und die Rufumleitung soll mein VoIP Nummer klingeln. Aber, die Handleidung der FB7050Wlan zeigt: "Wird die FRITZ!Box Fon WLAN an einem analogen Telefonanschluss betrieben, dann können einkommende Rufe nur an eine an ere Nebenstelle oder an numerische Internetrufnummern umgeleitet werden." (pp 125, "12.3 Weitere Leistungsmerkmale")
Wie kann mann denn mein SIP VOIP nummer ([email protected]) klingeln?
I'm struggling with the Call Diversion (Rufumleitung) function. I'd like to divert inbound calls on my analog land-line to an internet number.
I subscribed to a couple of sip based VOIP services, and it would be great if calls to my landline would be diverted to one of these sip based VOIP services when Im away from home. One such sip based VOIP service can redirect SIP based phone calls to my mobile phone.
The user manual however mentions that calls can only be diverted to ''numerical internet numbers'' (section 10.3 Advanced features). Erm, does that mean that I cannot divert calls to a sip based VOIP service?
Any help would be great,
Martien
FON1 = connected to Festnetz analog phone.
FON2 = connected to Festnetz fax-modem in my PC.
FON3 = nothing connected, free.
Firmware: 14.03.91
Hey there,
unfortunately I don't know how it is handled with Draytel..
As I know from German providers such VoIP accounts are equiped with PSTN numbers - so reachable from offnet (land line)
In this case you just have to enter your phone number!
It is a difference if you forward a call to a phone number or a so-called SIP-URI (other networks involved)
I think the best would be to check this issue with your provider - they should tell you how to configure your fritzbox correctly!
By the way I would recommend to update your fb-firmware!
