Rudi-Shell weg .... (?)
JohnDoe42
Aktives Mitglied
17 Mrz 2009
bei einem aktuellen Trunk-Image (r9132) für meine 7270v3 scheint im Freetz-WebIF unter "System" die Rudi-Shell verschwunden zu sein ...
Hier mal die .config:
FREETZ_HAVE_DOT_CONFIG=y
FREETZ_AVM_VERSION_7270_05_21=y
FREETZ_AVM_VERSION_05_2X=y
FREETZ_TYPE_FON_WLAN_7270_16=y
FREETZ_TYPE_FON_WLAN_7270_V3=y
FREETZ_TYPE_FON_WLAN_7270=y
FREETZ_TYPE_LANG_DE=y
FREETZ_TYPE_LANGUAGE="de"
FREETZ_AVM_VERSION_STRING="7270_05.21"
FREETZ_FILESYSTEM_MTD_SIZE=0
FREETZ_TYPE_PREFIX="7270_v3"
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_SHOW_ADVANCED=y
FREETZ_REPLACE_KERNEL_AVAILABLE=y
FREETZ_REPLACE_KERNEL=y
FREETZ_TARGET_IPV6_SUPPORT=y
FREETZ_TARGET_REF_16MB=y
FREETZ_TARGET_REF="16mb"
FREETZ_KERNEL_REF_16MB=y
FREETZ_KERNEL_REF="16mb"
FREETZ_KERNEL_MTD_SIZE=246
FREETZ_HAS_AVM_AURA_USB=y
FREETZ_HAS_AVM_NTFS=y
FREETZ_HAS_AVM_IPV6=y
FREETZ_HAS_AVM_WEBDAV=y
FREETZ_HAS_AVM_INETD=y
FREETZ_HAS_AVM_EXT3=y
FREETZ_HAS_AVM_TR069=y
FREETZ_HAS_AVM_CHRONYD=y
FREETZ_HAS_AVM_DECT=y
FREETZ_HAS_AVM_OPENSSL_LIBS=y
FREETZ_HAS_AVM_LSOF=y
FREETZ_HAS_AVM_NAS=y
FREETZ_HAS_AVM_MYFRITZ=y
FREETZ_HAS_AVM_PHONE=y
FREETZ_HAS_AVM_TAM=y
FREETZ_HAS_AVM_UDEV=y
FREETZ_HAS_AVM_USB_HOST=y
FREETZ_HAS_AVM_E2FSPROGS=y
FREETZ_HAS_AVM_WLAN=y
FREETZ_HAS_AVM_UMTS=y
FREETZ_HAS_AVM_JFFS2=y
FREETZ_HAS_AVM_MULTI_ANNEX=y
FREETZ_HAS_AVM_CTLMGR_STRUCT_V3=y
FREETZ_LANG_DE=y
FREETZ_LANG_STRING="de"
FREETZ_PATCH_FREETZMOUNT=y
FREETZ_USBSTORAGE_AUTOMOUNT=y
FREETZ_AUTOMOUNT_EXT3=y
FREETZ_AUTOMOUNT_FAT=y
FREETZ_AUTOMOUNT_NTFS=y
FREETZ_REMOVE_ASSISTANT=y
FREETZ_REMOVE_ASSISTANT_SIP=y
FREETZ_REMOVE_AVM_VPN=y
FREETZ_REMOVE_BRANDING_1und1=y
FREETZ_REMOVE_BRANDING_otwo=y
FREETZ_REMOVE_CAPIOVERTCP=y
FREETZ_REMOVE_CHRONYD=y
FREETZ_REMOVE_DECT=y
FREETZ_REMOVE_DTRACE=y
FREETZ_REMOVE_HELP=y
FREETZ_REMOVE_TR069=y
FREETZ_REMOVE_TR069_FWUPDATE=y
FREETZ_REMOVE_UMTSD=y
FREETZ_AVMDAEMON_DISABLE_TR069=y
FREETZ_PACKAGE_BRIDGE_UTILS=y
FREETZ_PACKAGE_DROPBEAR=y
FREETZ_PACKAGE_DROPBEAR_SFTP_SERVER=y
FREETZ_PACKAGE_DROPBEAR_WITH_ZLIB=y
FREETZ_PACKAGE_DROPBEAR_DISABLE_HOST_LOOKUP=y
FREETZ_PACKAGE_ESPEAK=y
FREETZ_PACKAGE_ESPEAK_ALL_LANGUAGES=y
FREETZ_PACKAGE_HASERL=y
FREETZ_PACKAGE_INETD=y
FREETZ_PACKAGE_OPENVPN=y
FREETZ_PACKAGE_OPENVPN_WITH_LZO=y
FREETZ_PACKAGE_OPENVPN_WITH_MGMNT=y
FREETZ_PACKAGE_OPENVPN_ENABLE_SMALL=y
FREETZ_PACKAGE_SAMBA=y
FREETZ_PACKAGE_NMBD=y
FREETZ_SAMBA_VERSION_3_0=y
FREETZ_PACKAGE_SAMBA_MAX_DEBUG_LEVEL=-1
FREETZ_PACKAGE_VSFTPD=y
FREETZ_PACKAGE_VSFTPD_WITH_SSL=y
FREETZ_PACKAGE_OPENSSH=y
FREETZ_PACKAGE_OPENSSH_sftp_server=y
FREETZ_PACKAGE_AUTHORIZED_KEYS=y
FREETZ_PACKAGE_AVM_FIREWALL=y
FREETZ_PACKAGE_SYSLOGD_CGI=y
FREETZ_SHOW_UNSTABLE_PACKAGES=y
FREETZ_PACKAGE_DTMFBOX=y
FREETZ_PACKAGE_DTMFBOX_WITH_CAPI=y
FREETZ_PACKAGE_DTMFBOX_WITH_VOIP=y
FREETZ_PACKAGE_DTMFBOX_WITH_ICE=y
FREETZ_PACKAGE_DTMFBOX_WITH_G711_CODEC=y
FREETZ_PACKAGE_DTMFBOX_WITH_ESPEAK=y
FREETZ_PACKAGE_IPTABLES=y
FREETZ_PACKAGE_IPTABLES_IS_SELECTABLE=y
FREETZ_PACKAGE_IPTABLES_SAVE_RESTORE=y
FREETZ_PACKAGE_IPTABLES_XML=y
FREETZ_PACKAGE_IPTABLES_CGI=y
FREETZ_PACKAGE_IPTABLES_STANDARD_MODULES=y
FREETZ_PACKAGE_IPTABLES_KERNEL_MODULES=y
FREETZ_MODULE_nf_conntrack=y
FREETZ_MODULE_nf_conntrack_ftp=y
FREETZ_MODULE_nf_conntrack_h323=y
FREETZ_MODULE_nf_conntrack_irc=y
FREETZ_MODULE_nf_conntrack_ipv4=y
FREETZ_MODULE_nf_conntrack_pptp=y
FREETZ_MODULE_nf_conntrack_proto_gre=y
FREETZ_MODULE_nf_conntrack_tftp=y
FREETZ_MODULE_nf_defrag_ipv4=y
FREETZ_MODULE_nf_nat=y
FREETZ_MODULE_nf_nat_ftp=y
FREETZ_MODULE_nf_nat_tftp=y
FREETZ_MODULE_iptable_filter=y
FREETZ_MODULE_iptable_mangle=y
FREETZ_MODULE_iptable_nat=y
FREETZ_MODULE_iptable_raw=y
FREETZ_MODULE_ip_tables=y
FREETZ_MODULE_ipt_LOG=y
FREETZ_MODULE_ipt_REJECT=y
FREETZ_MODULE_ipt_ttl=y
FREETZ_MODULE_ipt_TTL=y
FREETZ_MODULE_x_tables=y
FREETZ_MODULE_xt_CLASSIFY=y
FREETZ_MODULE_xt_comment=y
FREETZ_MODULE_xt_esp=y
FREETZ_MODULE_xt_length=y
FREETZ_MODULE_xt_limit=y
FREETZ_MODULE_xt_mac=y
FREETZ_MODULE_xt_multiport=y
FREETZ_MODULE_xt_mark=y
FREETZ_MODULE_xt_MARK=y
FREETZ_MODULE_xt_NFQUEUE=y
FREETZ_MODULE_xt_iprange=y
FREETZ_MODULE_xt_pkttype=y
FREETZ_MODULE_xt_physdev=y
FREETZ_MODULE_xt_quota=y
FREETZ_MODULE_xt_realm=y
FREETZ_MODULE_xt_state=y
FREETZ_MODULE_xt_statistic=y
FREETZ_MODULE_xt_string=y
FREETZ_MODULE_xt_tcpudp=y
FREETZ_MODULE_xt_tcpmss=y
FREETZ_PACKAGE_IPTABLES_SHARED_LIBS=y
FREETZ_LIB_libipt_addrtype=y
FREETZ_LIB_libipt_ah=y
FREETZ_LIB_libipt_CLUSTERIP=y
FREETZ_LIB_libipt_DNAT=y
FREETZ_LIB_libipt_ecn=y
FREETZ_LIB_libipt_ECN=y
FREETZ_LIB_libipt_icmp=y
FREETZ_LIB_libipt_LOG=y
FREETZ_LIB_libipt_MASQUERADE=y
FREETZ_LIB_libipt_MIRROR=y
FREETZ_LIB_libipt_NETMAP=y
FREETZ_LIB_libipt_realm=y
FREETZ_LIB_libipt_REDIRECT=y
FREETZ_LIB_libipt_REJECT=y
FREETZ_LIB_libipt_SAME=y
FREETZ_LIB_libipt_SNAT=y
FREETZ_LIB_libipt_ttl=y
FREETZ_LIB_libipt_TTL=y
FREETZ_LIB_libipt_ULOG=y
FREETZ_LIB_libipt_unclean=y
FREETZ_LIB_libxt_CLASSIFY=y
FREETZ_LIB_libxt_comment=y
FREETZ_LIB_libxt_connbytes=y
FREETZ_LIB_libxt_connmark=y
FREETZ_LIB_libxt_CONNMARK=y
FREETZ_LIB_libxt_CONNSECMARK=y
FREETZ_LIB_libxt_conntrack=y
FREETZ_LIB_libxt_dscp=y
FREETZ_LIB_libxt_DSCP=y
FREETZ_LIB_libxt_esp=y
FREETZ_LIB_libxt_hashlimit=y
FREETZ_LIB_libxt_helper=y
FREETZ_LIB_libxt_iprange=y
FREETZ_LIB_libxt_length=y
FREETZ_LIB_libxt_limit=y
FREETZ_LIB_libxt_mac=y
FREETZ_LIB_libxt_mark=y
FREETZ_LIB_libxt_MARK=y
FREETZ_LIB_libxt_multiport=y
FREETZ_LIB_libxt_NFLOG=y
FREETZ_LIB_libxt_NFQUEUE=y
FREETZ_LIB_libxt_NOTRACK=y
FREETZ_LIB_libxt_owner=y
FREETZ_LIB_libxt_physdev=y
FREETZ_LIB_libxt_pkttype=y
FREETZ_LIB_libxt_quota=y
FREETZ_LIB_libxt_rateest=y
FREETZ_LIB_libxt_RATEEST=y
FREETZ_LIB_libxt_sctp=y
FREETZ_LIB_libxt_SECMARK=y
FREETZ_LIB_libxt_standard=y
FREETZ_LIB_libxt_state=y
FREETZ_LIB_libxt_statistic=y
FREETZ_LIB_libxt_string=y
FREETZ_LIB_libxt_tcpmss=y
FREETZ_LIB_libxt_TCPMSS=y
FREETZ_LIB_libxt_tcp=y
FREETZ_LIB_libxt_time=y
FREETZ_LIB_libxt_tos=y
FREETZ_LIB_libxt_TOS=y
FREETZ_LIB_libxt_TRACE=y
FREETZ_LIB_libxt_u32=y
FREETZ_LIB_libxt_udp=y
FREETZ_LIB_libip6t_icmp6=y
FREETZ_PACKAGE_MOD=y
FREETZ_PACKAGE_MOD_ETCSERVICES=y
FREETZ_PACKAGE_MODCGI=y
FREETZ_DL_KERNEL_SITE="@AVM/fritzbox.fon_wlan_7270_v3/x_misc/opensrc"
FREETZ_DL_KERNEL_SOURCE="fritzbox7270-source-files-05.21.tar.gz"
FREETZ_DL_KERNEL_SOURCE_MD5="6975d65be957cd12f5df3633e3848495"
FREETZ_DL_SITE="@AVM/fritzbox.fon_wlan_7270_v3/firmware/deutsch"
FREETZ_DL_SOURCE="FRITZ.Box_Fon_WLAN_7270_v3.74.05.21.image"
FREETZ_DL_SOURCE_MD5="b53ac853ae3dc9ec5a9f1fccdd776c79"
FREETZ_VERBOSITY_LEVEL=2
FREETZ_SIZEINFO_COMPRESSED=y
FREETZ_JLEVEL=2
FREETZ_CHECK_CHANGED=y
FREETZ_DL_SITE_USER=""
FREETZ_OPTIONS_ETCSERVICES=y
FREETZ_SECURITY_LEVEL=1
FREETZ_STYLE_COLORED=y
FREETZ_STYLE="colored"
FREETZ_SKIN_legacy=y
FREETZ_FAVICON_NONE=y
FREETZ_FAVICON_STRING="none"
FREETZ_TAGGING_NONE=y
FREETZ_TAGGING_STRING="none"
FREETZ_DEVELOPER_VERSION_STRING=y
FREETZ_USER_DEFINED_COMMENT=""
FREETZ_CREATE_SEPARATE_OPTIONS_CFG=y
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
FREETZ_SQUASHFS_BLOCKSIZE=65536
FREETZ_KERNEL_VERSION_2_6_32=y
FREETZ_KERNEL_VERSION="2.6.32"
FREETZ_KERNEL_VERSION_2_6_13_MIN=y
FREETZ_KERNEL_VERSION_2_6_19_MIN=y
FREETZ_KERNEL_VERSION_2_6_28_MIN=y
FREETZ_KERNEL_VERSION_2_6_32_MIN=y
FREETZ_KERNEL_VERSION_2_6_32_MAX=y
FREETZ_KERNEL_LAYOUT_UR8=y
FREETZ_KERNEL_LAYOUT="ur8"
FREETZ_MODULES_KVER="2.6.32.41"
FREETZ_MODULE_fat=y
FREETZ_MODULE_fuse=y
FREETZ_MODULE_vfat=y
FREETZ_MODULE_msdos=y
FREETZ_BUSYBOX_ETHER_WAKE=y
FREETZ_BUSYBOX_INETD=y
FREETZ_BUSYBOX_IP=y
FREETZ_BUSYBOX_FEATURE_IP_ADDRESS=y
FREETZ_BUSYBOX_FEATURE_IP_LINK=y
FREETZ_BUSYBOX_FEATURE_IP_ROUTE=y
FREETZ_BUSYBOX_FEATURE_IP_TUNNEL=y
FREETZ_BUSYBOX_MD5SUM=y
FREETZ_BUSYBOX_REALPATH=y
FREETZ_BUSYBOX_STUN_IP=y
FREETZ_BUSYBOX_TAR_OLDGNU_COMPATIBILITY=y
FREETZ_BUSYBOX_VOLUMEID=y
FREETZ_BUSYBOX_VOLUMEID_EXT=y
FREETZ_BUSYBOX_VOLUMEID_FAT=y
FREETZ_BUSYBOX_VOLUMEID_NTFS=y
FREETZ_BUSYBOX_WGET=y
FREETZ_BUSYBOX_FEATURE_PREFER_IPV4_ADDRESS=y
FREETZ_LIB_STDCXXLIB=y
FREETZ_LIB_libuClibc__=y
FREETZ_LIB_libcrypto=y
FREETZ_LIB_libssl=y
FREETZ_LIB_liblzo2=y
FREETZ_LIB_libz=y
FREETZ_LIB_libcapi20=y
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libnsl=y
FREETZ_LIB_libpthread=y
FREETZ_LIB_libresolv=y
FREETZ_LIB_librt=y
FREETZ_LIB_libuClibc=y
FREETZ_LIB_libutil=y
FREETZ_LIB_libgcc_s=y
FREETZ_LIB_libctlmgr=y
FREETZ_LIB_libctlmgr_WITH_STRUCT_V3=y
FREETZ_LIB_libpopt=y
FREETZ_STRIP_BINARIES=y
FREETZ_STRIP_MODULES_FREETZ=y
FREETZ_TARGET_ARCH_LE=y
FREETZ_TARGET_ARCH="mipsel"
FREETZ_TARGET_CROSS="mipsel-linux-uclibc-"
FREETZ_KERNEL_CROSS="mipsel-unknown-linux-gnu-"
FREETZ_DOWNLOAD_TOOLCHAIN=y
FREETZ_GCC_4_6_COMPILED_KERNEL=y
FREETZ_UCLIBC_0_9_32_BASED_BOX=y
FREETZ_KERNEL_COMPILER_GCC_4_6=y
FREETZ_KERNEL_GCC_VERSION="4.6.3"
FREETZ_KERNEL_BINUTILS_VERSION="2.22"
FREETZ_TARGET_UCLIBC_VERSION_0_9_32=y
FREETZ_TARGET_COMPILER_GCC_4_6=y
FREETZ_STDCXXLIB_USE_UCLIBCXX=y
FREETZ_TARGET_UCLIBC_VERSION="0.9.32.1"
FREETZ_TARGET_GCC_VERSION="4.6.3"
FREETZ_GNULIBSTDCXX_VERSION="6.0.16"
FREETZ_STDCXXLIB="uclibcxx"
FREETZ_TARGET_BINUTILS_VERSION="2.22"
FREETZ_TARGET_UCLIBC_REF="mod"
FREETZ_TARGET_CFLAGS="-Os -pipe -Wa,--trap"
FREETZ_TARGET_LFS=y
FREETZ_TOOLCHAIN_MINIMIZE_REQUIRED_GLIBC_VERSION=y
Weiß damit jemand Rat ?
Grüße,
JD.
Mir ist nichts bekannt. Im Trac hat jedoch ein Nutzer die Tage berichtet, dass bei ihm der Menüpunkt System fehlt. Evtl. besteht hier ein Zusammenhang.
Oliver
Okay, was schlägst Du also vor, was ich tun könnte?
Außer ein paar Revisions zurück zu gehen und zu gucken, ab wann es wieder funktioniert ?
Grüße,
JD.
Edit: Mea maxima culpa, pardon. Ich war zu blöde zum Gucken.
'tschuldigung. Kann (schnell) zu.
Gerne. ;-)
