Probleme beim Einrichten ein 8-fach ISDN Karte
letacla
23 Sep 2004
Ich versuche gerade eine OpenVox B800p (8 Port ISDN Karte) zu installieren.
Ich gehe folgendermasen vor :
root@siduxbox:/# [b]misdn-init scan[/b]
[OK] found the following devices:
card=1,0x8
[ii] run "/usr/sbin/misdn-init config" to store this information to /etc/misdn-init.conf
root@siduxbox:/# [b]misdn-init config[/b]
[OK] /etc/misdn-init.conf already present. backing it up to /etc/misdn-init.conf.save
[OK] /etc/misdn-init.conf created. It's now safe to run "/usr/sbin/misdn-init start"
[ii] make your ports (1-8) available in asterisk by editing "/etc/asterisk/misdn.conf"
root@siduxbox:/# [b]misdn-init start[/b]
 Loading module(s) for your misdn-cards:
/sbin/modprobe --ignore-install hfcmulti type=0x8 protocol=0x2,0x2,0x2,0x2,0x2,0x2,0x2,0x2 layermask=0xf,0xf,0xf,0xf,0xf,0xf,0xf,0xf poll=128 debug=0
/sbin/modprobe mISDN_dsp debug=0x0 options=0 poll=128 dtmfthreshold=100
root@siduxbox:/#
... als Ergebniss bekomme ich dann nur ...
root@siduxbox:/# [b]misdnportinfo[/b]
Found no card. Please be sure to load card drivers.
mISDN_close: fid(3) isize(131072) inbuf(0x804c060) irp(0x804c060) iend(0x804c060)
root@siduxbox:[b]lspci[/b]
05:09.0 ISDN controller: Cologne Chip Designs GmbH ISDN network Controller [HFC-8S] (rev 01)
root@siduxbox:/# [b]lsmod[/b]
Module                  Size  Used by
mISDN_dsp             200424  0
hfcmulti               79436  0
mISDN_capi            110764  0
l3udss1                45556  0
mISDN_l2               42988  0
mISDN_l1               13524  0
mISDN_core             86752  6 mISDN_dsp,hfcmulti,mISDN_capi,l3udss1,mISDN_l2,mISDN_l1
capi                   19136  0
capifs                  7048  2 capi
kernelcapi             41556  2 mISDN_capi,capi
root@siduxbox:/# [b]dmesg[/b]
CAPI Subsystem Rev 1.1.2.8
capifs: Rev 1.1.2.3
capi20: Rev 1.1.2.7: started up with major 68 (middleware+capifs)
Modular ISDN Stack core version (1_1_7_2) revision ($Revision: 1.40 $)
mISDNd: kernel daemon started (current:f6d9b020)
mISDNd: test event done
ISDN L1 driver version 1.20
ISDN L2 driver version 1.32
mISDN: DSS1 Rev. 1.47
mISDN Capi 2.0 driver file version 1.21
mISDN: HFC-multi driver Rev. 1.68
0 devices registered
mISDN_dsp: Audio DSP  Rev. 1.29 (debug=0x0) EchoCancellor MG2 dtmfthreshold(100)
mISDN_dsp: DSP clocks every 128 samples. This equals 16 jiffies.
Kernel 2.6.23
mISDN 1.1.7.2
Das sind mal die Infos die ich habe ...
... hat jemand eine Vorschlag was ich tun kann ???
Warum verwendest du mISDN 1.1.7? 1.1.8 ist aktuell...
1.1.8 macht keinen Unterschied, gleiches Problem !!!!
Funktioniert !!!!!
In der 'hfc_multi.c' war die OpenVox B800 noch nicht eingetragen. Diese dort integrieren und mISDN neu kompilieren, schon funktioniert alles.
