Mon Sep 13 23:49:01 2010 OpenVPN 2.1.3 i686-pc-mingw32 [SSL] [LZO2] [PKCS11] built on Aug 20 2010
Mon Sep 13 23:49:01 2010 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Mon Sep 13 23:49:01 2010 Control Channel Authentication: using 'C:\Program Files (x86)\OpenVPN\config\static.key' as a OpenVPN static key file
Mon Sep 13 23:49:01 2010 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Sep 13 23:49:01 2010 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Sep 13 23:49:01 2010 WARNING: normally if you use --mssfix and/or --fragment, you should also set --tun-mtu 1500 (currently it is 1492)
Mon Sep 13 23:49:01 2010 Control Channel MTU parms [ L:1565 D:166 EF:66 EB:0 ET:0 EL:0 ]
Mon Sep 13 23:49:01 2010 Socket Buffers: R=[8192->8192] S=[8192->8192]
Mon Sep 13 23:49:01 2010 Data Channel MTU parms [ L:1565 D:1450 EF:41 EB:4 ET:32 EL:0 ]
Mon Sep 13 23:49:01 2010 Local Options hash (VER=V4): '715aaf04'
Mon Sep 13 23:49:01 2010 Expected Remote Options hash (VER=V4): '8d7b1722'
Mon Sep 13 23:49:01 2010 UDPv4 link local: [undef]
Mon Sep 13 23:49:01 2010 UDPv4 link remote: xx.xxx.xxx.xxx:1194
Mon Sep 13 23:49:01 2010 TLS: Initial packet from xx.xxx.xxx.xxx:1194, sid=4469b2f5 e221a635
Mon Sep 13 23:49:02 2010 VERIFY OK: depth=1, /C=DE/ST=NR/L=Burgsteinfurt/O=OpenVPN/CN=ca/[email protected]
Mon Sep 13 23:49:02 2010 VERIFY OK: nsCertType=SERVER
Mon Sep 13 23:49:02 2010 VERIFY OK: depth=0, /C=DE/ST=NR/O=OpenVPN/CN=fritzbox/[email protected]
Mon Sep 13 23:49:03 2010 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Mon Sep 13 23:49:03 2010 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Sep 13 23:49:03 2010 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Mon Sep 13 23:49:03 2010 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Sep 13 23:49:03 2010 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Mon Sep 13 23:49:03 2010 [fritzbox] Peer Connection Initiated with xx.xxx.xxx.xxx:1194
Mon Sep 13 23:49:06 2010 SENT CONTROL [fritzbox]: 'PUSH_REQUEST' (status=1)
Mon Sep 13 23:49:06 2010 PUSH: Received control message: 'PUSH_REPLY,route 192.168.200.1 ,route-gateway 192.168.200.1,route 192.168.178.0 255.255.255.0,ping 10,ping-restart 120,ifconfig 192.168.100.110 255.255.255.0'
Mon Sep 13 23:49:06 2010 OPTIONS IMPORT: timers and/or timeouts modified
Mon Sep 13 23:49:06 2010 OPTIONS IMPORT: --ifconfig/up options modified
Mon Sep 13 23:49:06 2010 OPTIONS IMPORT: route options modified
Mon Sep 13 23:49:06 2010 OPTIONS IMPORT: route-related options modified
Mon Sep 13 23:49:06 2010 ROUTE default_gateway=192.168.178.1
Mon Sep 13 23:49:06 2010 TAP-WIN32 device [LAN-Verbindung 4] opened: \\.\Global\{DA6E1FB1-00D3-4D2F-9A27-8895C7863E19}.tap
Mon Sep 13 23:49:06 2010 TAP-Win32 Driver Version 9.7
Mon Sep 13 23:49:06 2010 TAP-Win32 MTU=1500
Mon Sep 13 23:49:07 2010 NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address LAN-Verbindung 4 dhcp
Mon Sep 13 23:49:07 2010 Notified TAP-Win32 driver to set a DHCP IP/netmask of 192.168.100.110/255.255.255.0 on interface {DA6E1FB1-00D3-4D2F-9A27-8895C7863E19} [DHCP-serv: 192.168.100.0, lease-time: 31536000]
Mon Sep 13 23:49:07 2010 Successful ARP Flush on interface [22] {DA6E1FB1-00D3-4D2F-9A27-8895C7863E19}
Mon Sep 13 23:49:12 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:12 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:17 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:17 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:18 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:18 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:19 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:19 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:20 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:20 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:21 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:21 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:22 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:22 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:23 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:23 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:24 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:24 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:25 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:25 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:26 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:26 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:27 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:27 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:28 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:28 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:29 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:29 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:30 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:30 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:31 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:31 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:32 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:32 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:33 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:33 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:34 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:34 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:35 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:35 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:36 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:36 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:37 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:37 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:38 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:38 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:39 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:39 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:40 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:40 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:41 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:41 2010 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 13 23:49:42 2010 TEST ROUTES: 0/2 succeeded len=2 ret=0 a=0 u/d=up
Mon Sep 13 23:49:42 2010 OpenVPN ROUTE: omitted no-op route: 192.168.200.1/255.255.255.255 -> 192.168.200.1
Mon Sep 13 23:49:42 2010 WARNING: potential route subnet conflict between local LAN [192.168.178.0/255.255.255.0] and remote VPN [192.168.178.0/255.255.255.0]
Mon Sep 13 23:49:42 2010 C:\WINDOWS\system32\route.exe ADD 192.168.178.0 MASK 255.255.255.0 192.168.200.1
Mon Sep 13 23:49:42 2010 Warning: route gateway is not reachable on any active network adapters: 192.168.200.1
Mon Sep 13 23:49:42 2010 Route addition via IPAPI failed [adaptive]
Mon Sep 13 23:49:42 2010 Route addition fallback to route.exe
OK!
SYSTEM ROUTING TABLE
0.0.0.0 0.0.0.0 192.168.178.1 p=0 i=13 t=4 pr=3 a=6541 h=0 m=1525/0/0/0/0
127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=3 a=6574 h=0 m=306/0/0/0/0
127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=6574 h=0 m=306/0/0/0/0
127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=6574 h=0 m=306/0/0/0/0
192.168.100.0 255.255.255.0 192.168.100.110 p=0 i=22 t=3 pr=3 a=34 h=0 m=286/0/0/0/0
192.168.100.110 255.255.255.255 192.168.100.110 p=0 i=22 t=3 pr=3 a=34 h=0 m=286/0/0/0/0
192.168.100.255 255.255.255.255 192.168.100.110 p=0 i=22 t=3 pr=3 a=34 h=0 m=286/0/0/0/0
192.168.152.0 255.255.255.0 192.168.152.1 p=0 i=17 t=3 pr=3 a=6552 h=0 m=276/0/0/0/0
192.168.152.1 255.255.255.255 192.168.152.1 p=0 i=17 t=3 pr=3 a=6552 h=0 m=276/0/0/0/0
192.168.152.255 255.255.255.255 192.168.152.1 p=0 i=17 t=3 pr=3 a=6552 h=0 m=276/0/0/0/0
192.168.172.0 255.255.255.0 192.168.172.1 p=0 i=19 t=3 pr=3 a=6552 h=0 m=276/0/0/0/0
192.168.172.1 255.255.255.255 192.168.172.1 p=0 i=19 t=3 pr=3 a=6552 h=0 m=276/0/0/0/0
192.168.172.255 255.255.255.255 192.168.172.1 p=0 i=19 t=3 pr=3 a=6552 h=0 m=276/0/0/0/0
192.168.178.0 255.255.255.0 192.168.178.22 p=0 i=13 t=3 pr=3 a=6541 h=0 m=281/0/0/0/0
192.168.178.0 255.255.255.0 192.168.200.1 p=0 i=13 t=4 pr=3 a=0 h=0 m=26/0/0/0/0
192.168.178.22 255.255.255.255 192.168.178.22 p=0 i=13 t=3 pr=3 a=6541 h=0 m=281/0/0/0/0
192.168.178.255 255.255.255.255 192.168.178.22 p=0 i=13 t=3 pr=3 a=6541 h=0 m=281/0/0/0/0
224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=3 a=6574 h=0 m=306/0/0/0/0
224.0.0.0 240.0.0.0 192.168.100.110 p=0 i=22 t=3 pr=3 a=6556 h=0 m=286/0/0/0/0
224.0.0.0 240.0.0.0 192.168.152.1 p=0 i=17 t=3 pr=3 a=6556 h=0 m=276/0/0/0/0
224.0.0.0 240.0.0.0 192.168.172.1 p=0 i=19 t=3 pr=3 a=6556 h=0 m=276/0/0/0/0
224.0.0.0 240.0.0.0 192.168.178.22 p=0 i=13 t=3 pr=3 a=6545 h=0 m=281/0/0/0/0
255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=6574 h=0 m=306/0/0/0/0
255.255.255.255 255.255.255.255 192.168.100.110 p=0 i=22 t=3 pr=3 a=6556 h=0 m=286/0/0/0/0
255.255.255.255 255.255.255.255 192.168.152.1 p=0 i=17 t=3 pr=3 a=6556 h=0 m=276/0/0/0/0
255.255.255.255 255.255.255.255 192.168.172.1 p=0 i=19 t=3 pr=3 a=6556 h=0 m=276/0/0/0/0
255.255.255.255 255.255.255.255 192.168.178.22 p=0 i=13 t=3 pr=3 a=6545 h=0 m=281/0/0/0/0
SYSTEM ADAPTER LIST
TAP-Win32 Adapter V9
Index = 22
GUID = {DA6E1FB1-00D3-4D2F-9A27-8895C7863E19}
IP = 192.168.100.110/255.255.255.0
MAC = 00:ff:da:6e:1f:b1
GATEWAY = 0.0.0.0/255.255.255.255
DHCP SERV = 192.168.100.0/255.255.255.255
DHCP LEASE OBTAINED = Mon Sep 13 23:49:07 2010
DHCP LEASE EXPIRES = Tue Sep 13 23:49:07 2011
DNS SERV =
TAP-Win32 Adapter OAS
Index = 21
GUID = {E371C67F-C0E7-448F-8DD4-A48D8AA177C7}
IP = 0.0.0.0/0.0.0.0
MAC = 00:ff:e3:71:c6:7f
DHCP SERV =
DHCP LEASE OBTAINED = Mon Sep 13 23:49:42 2010
DHCP LEASE EXPIRES = Mon Sep 13 23:49:42 2010
DNS SERV =
Intel(R) PRO/Wireless 3945ABG-Netzwerkverbindung
Index = 13
GUID = {6A33445A-01C2-4C27-82FF-D286FD0C96CB}
IP = 192.168.178.22/255.255.255.0
MAC = 00:1f:3c:83:a2:db
GATEWAY = 192.168.178.1/255.255.255.255
DHCP SERV = 192.168.178.1/255.255.255.255
DHCP LEASE OBTAINED = Mon Sep 13 22:10:05 2010
DHCP LEASE EXPIRES = Thu Sep 23 22:10:05 2010
DNS SERV = 192.168.178.1/255.255.255.255
Broadcom NetLink (TM)-Gigabit-Ethernet
Index = 11
GUID = {A8FCF9F1-DCF3-4CFA-8F5A-ED9200D544CA}
MAC = 00:1f:29:9a:aa:88
DHCP SERV =
DNS SERV =
VMware Virtual Ethernet Adapter for VMnet1
Index = 17
GUID = {E2FD5E39-F92A-4058-B9B7-861A608B4808}
IP = 192.168.152.1/255.255.255.0
MAC = 00:50:56:c0:00:01
DNS SERV =
VMware Virtual Ethernet Adapter for VMnet8
Index = 19
GUID = {3128272A-E922-447A-AD48-DCA256E90812}
IP = 192.168.172.1/255.255.255.0
MAC = 00:50:56:c0:00:08
DNS SERV =
Mon Sep 13 23:49:42 2010 Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
