(10:50:12) DEBUG: logging to file "C:\Programme\JFritz\debug.txt" has been enabled
(10:50:12) DEBUG: Save Dir: C:\Programme\JFritz\
(10:50:13) DEBUG: Found file to backup: jfritz.calls.xml
(10:50:13) DEBUG: Found file to backup: jfritz.phonebook.xml
(10:50:13) DEBUG: Found file to backup: jfritz.properties.xml
(10:50:13) DEBUG: Found file to backup: jfritz.quickdials.xml
(10:50:13) DEBUG: Found file to backup: jfritz.sipprovider.xml
(10:50:13) DEBUG: Multiple instance lock: set lock.
(10:50:13) DEBUG: Operating System : Windows XP
(10:50:13) DEBUG: JFritz runs on Windows
(10:50:13) DEBUG: Urlstr: http://192.168.1.1:82/cgi-bin/webcm
(10:50:13) DEBUG: Postdata: getpage=../html/de/menus/menu2.html&var%3Alang=de&var%3Amenu=home&var%3Apagename=home&login%3Acommand%2Fpassword=
(10:50:19) DEBUG: Detected Firmware: 14.04.06ds-0.2.6 de
(10:50:20) DEBUG: Sorting unfiltered data
(10:50:20) DEBUG: updating the filter
(10:50:20) DEBUG: Sorting all filtered Rows
(10:50:20) DEBUG: Start commandline parsing
(10:50:20) DEBUG: New instance of JFrame
(10:50:20) DEBUG: Create JFritz-GUI
(10:50:21) DEBUG: Subdirectory: \lang
(10:50:21) DEBUG: full path: C:\Programme\JFritz\lang
(10:50:21) DEBUG: Hiding call-by-call column
(10:50:21) DEBUG: Hiding port column
(10:50:22) DEBUG: Check Systray-Support
(10:50:22) DEBUG: Searching for FritzBox per UPnP / SSDP
(10:50:23) DEBUG: Timeout for SSDP
(10:50:23) DEBUG: Box found at /192.168.1.1: jesus_christ_station UPnP/1.0 AVM FRITZ!Box Fon WLAN 7050 14.04.06
(10:50:23) DEBUG: Begin processing Version File
(10:50:23) DEBUG: CheckVersionThread exiting..
(10:50:23) DEBUG: Action fetchTask
(10:50:23) DEBUG: Timer enabled
(10:50:23) DEBUG: Action fetchList
(10:50:23) DEBUG: Watchdog enabled
(10:50:23) DEBUG: box.address: 192.168.1.1
(10:50:23) DEBUG: box.port: 82
(10:50:23) DEBUG: box.password:
(10:50:23) DEBUG: box.firmware: 14.04.06ds-0.2.6 de
(10:50:23) DEBUG: Opening HTML Callerlist page
(10:50:23) DEBUG: Urlstr: http://192.168.1.1:82/cgi-bin/webcm
(10:50:23) DEBUG: Postdata: getpage=../html/de/menus/menu2.html&var%3Alang=de&var%3Amenu=fon&var%3Apagename=foncalls&login%3Acommand%2Fpassword=
(10:50:25) DEBUG: Retrieving the CSV list from the box
(10:50:25) DEBUG: Received response, begin processing call list
(10:50:25) DEBUG: CSV-Header: Typ;Datum;Name;Rufnummer;Nebenstelle;Eigene Rufnummer;Dauer
(10:50:25) DEBUG: 2 Lines read from csv file
(10:50:25) DEBUG: 1 New entries processed
(10:50:25) DEBUG: Sorting unfiltered data
(10:50:25) DEBUG: updating the filter
(10:50:25) DEBUG: Sorting all filtered Rows
(10:50:25) DEBUG: Saving to file C:\Programme\JFritz\jfritz.calls.xml
(10:50:26) DEBUG: Finished processing response
(10:50:26) DEBUG: Clearing List
(10:50:26) DEBUG: Urlstr: http://192.168.1.1:82/cgi-bin/webcm
(10:50:26) DEBUG: Postdata: getpage=../html/de/menus/menu2.html&var%3Alang=de&var%3Apagename=foncalls&var%3Amenu=fon&telcfg%3Asettings/ClearJournal=1
(10:50:28) DEBUG: Running FetchListTask..
(10:50:29) DEBUG: Action reverselookup
(10:50:37) DEBUG: Action config
(10:50:37) DEBUG: Subdirectory: \lang
(10:50:37) DEBUG: full path: C:\Programme\JFritz\lang
(10:50:37) DEBUG: Found resources for locale 'de_DE', loading flag image 'C:\Programme\JFritz\lang\flags\de.gif'
(10:50:37) DEBUG: Found resources for locale 'en_US', loading flag image 'C:\Programme\JFritz\lang\flags\us.gif'
(10:50:37) DEBUG: Found resources for locale 'it_IT', loading flag image 'C:\Programme\JFritz\lang\flags\it.gif'
(10:50:37) DEBUG: Found resources for locale 'nl_NL', loading flag image 'C:\Programme\JFritz\lang\flags\nl.gif'
(10:50:37) DEBUG: Found resources for locale 'pl_PL', loading flag image 'C:\Programme\JFritz\lang\flags\pl.gif'
(10:50:37) DEBUG: Found resources for locale 'ru_RU', loading flag image 'C:\Programme\JFritz\lang\flags\ru.gif'
(10:50:37) DEBUG: FRITZ!Box call monitor chosen
(10:50:37) DEBUG: SSDP FW: 14.04.06
(10:50:37) DEBUG: Urlstr: http://192.168.1.1:80/cgi-bin/webcm
(10:50:37) DEBUG: Postdata: getpage=../html/de/menus/menu2.html&var%3Alang=de&var%3Amenu=home&var%3Apagename=home&login%3Acommand%2Fpassword=
