root@Speedport:/var/tmp# strace ./nzbget_static -c nzbget.conf hallo
execve("./nzbget_static", ["./nzbget_static", "-c", "nzbget.conf", "hallo"], [/* 209 vars */]) = 0
ioctl(0, TIOCNXCL, {B38400 opost isig icanon echo ...}) = 0
ioctl(1, TIOCNXCL, {B38400 opost isig icanon echo ...}) = 0
close(3) = 0
stat("/var/tmp/download/dst", 0x7fdc6250) = -1 ENOENT (No such file or directory)
stat("/var/tmp/download", 0x7fdc6188) = -1 ENOENT (No such file or directory)
stat("/var/tmp", {st_mode=S_IFDIR|S_ISVTX|0777, st_size=0, ...}) = 0
mkdir("/var/tmp/download", 0777) = 0
stat("/var/tmp/download", {st_mode=S_IFDIR|0755, st_size=0, ...}) = 0
mkdir("/var/tmp/download/dst", 0777) = 0
stat("/var/tmp/download/dst", {st_mode=S_IFDIR|0755, st_size=0, ...}) = 0
stat("/var/tmp/download/tmp", 0x7fdc6250) = -1 ENOENT (No such file or directory)
mkdir("/var/tmp/download/tmp", 0777) = 0
stat("/var/tmp/download/tmp", {st_mode=S_IFDIR|0755, st_size=0, ...}) = 0
stat("/var/tmp/download/queue", 0x7fdc6250) = -1 ENOENT (No such file or directory)
mkdir("/var/tmp/download/queue", 0777) = 0
stat("/var/tmp/download/queue", {st_mode=S_IFDIR|0755, st_size=0, ...}) = 0
stat("/var/tmp/download/nzb", 0x7fdc6250) = -1 ENOENT (No such file or directory)
mkdir("/var/tmp/download/nzb", 0777) = 0
stat("/var/tmp/download/nzb", {st_mode=S_IFDIR|0755, st_size=0, ...}) = 0
getcwd("/var/tmp", 1024) = 9
brk(0x820000) = 0x820000
brk(0x823000) = 0x823000
brk(0x825000) = 0x825000
brk(0x826000) = 0x826000
brk(0x828000) = 0x828000
rt_sigaction(SIGINT, {0x10000000, [RT_69 RT_71 RT_72 RT_74 RT_75 RT_76 RT_78 RT_80 RT_83 RT_84 RT_85 RT_86 RT_87], 0x580704 /* SA_??? */}, {SIG_DFL, [], 0}, 16) = 0
rt_sigaction(SIGTERM, {0x10000000, [RT_69 RT_71 RT_72 RT_74 RT_75 RT_76 RT_78 RT_80 RT_83 RT_84 RT_85 RT_86 RT_87], 0x580704 /* SA_??? */}, {SIG_DFL, [], 0}, 16) = 0
rt_sigaction(SIGCHLD, {0x10000000, [RT_69 RT_71 RT_72 RT_74 RT_75 RT_76 RT_78 RT_80 RT_83 RT_84 RT_85 RT_86 RT_87], 0x580704 /* SA_??? */}, {SIG_DFL, [], 0}, 16) = 0
rt_sigaction(SIGPIPE, {0x10000000, [], SA_NOCLDSTOP}, {SIG_DFL, [RT_68 RT_75 RT_77 RT_79 RT_80 RT_81 RT_83 RT_84 RT_86 RT_87], 0}, 16) = 0
brk(0x829000) = 0x829000
time(NULL) = 946694413
brk(0x82a000) = 0x82a000
stat64("/mod/root/.terminfo", 0x7fdc55e8) = -1 ENOENT (No such file or directory)
stat64("/opt/share/terminfo", 0x7fdc55e8) = -1 ENOENT (No such file or directory)
write(2, "Error opening terminal: ", 24Error opening terminal: ) = 24
write(2, "xterm", 5xterm) = 5
write(2, ".\n", 2.
) = 2
exit(1) = ?
