/var/mod/root $ openvpn /var/tmp/ovpn.conf
Sun Dec 16 18:05:38 2007 OpenVPN 2.1_rc4 mipsel-linux [SSL] [LZO2] [EPOLL] built on Oct 21 2007
Sun Dec 16 18:05:38 2007 Diffie-Hellman initialized with 1024 bit key
Sun Dec 16 18:05:38 2007 WARNING: file '/tmp/flash/box.key' is group or others accessible
Sun Dec 16 18:05:38 2007 TLS-Auth MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
Sun Dec 16 18:05:39 2007 TUN/TAP device tun0 opened
Sun Dec 16 18:05:39 2007 TUN/TAP TX queue length set to 100
Sun Dec 16 18:05:39 2007 /sbin/ifconfig tun0 10.0.8.1 pointopoint 10.0.8.2 mtu 1500
Sun Dec 16 18:05:39 2007 /sbin/route add -net 10.0.8.0 netmask 255.255.255.0 gw 10.0.8.2
Sun Dec 16 18:05:39 2007 /sbin/route add -net 192.168.178.0 netmask 255.255.255.0 gw 10.0.8.2
Sun Dec 16 18:05:39 2007 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
Sun Dec 16 18:05:39 2007 Socket Buffers: R=[110592->131072] S=[110592->131072]
Sun Dec 16 18:05:39 2007 UDPv4 link local (bound): [undef]:1194
Sun Dec 16 18:05:39 2007 UDPv4 link remote: [undef]
Sun Dec 16 18:05:39 2007 MULTI: multi_init called, r=256 v=256
Sun Dec 16 18:05:39 2007 Initialization Sequence Completed
Sun Dec 16 18:06:12 2007 MULTI: multi_create_instance called
Sun Dec 16 18:06:12 2007 89.62.32.222:1194 Re-using SSL/TLS context
Sun Dec 16 18:06:12 2007 89.62.32.222:1194 LZO compression initialized
Sun Dec 16 18:06:12 2007 89.62.32.222:1194 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
Sun Dec 16 18:06:12 2007 89.62.32.222:1194 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
Sun Dec 16 18:06:12 2007 89.62.32.222:1194 TLS: Initial packet from 89.62.32.222:1194, sid=1a032daa bd085779
Sun Dec 16 18:06:14 2007 89.62.32.222:1194 VERIFY OK: depth=1, /C=US/ST=CA/L=SanFrancisco/O=FortFunston/CN=ca/[email protected]
Sun Dec 16 18:06:14 2007 89.62.32.222:1194 VERIFY OK: depth=0, /C=US/ST=CA/O=FortFunston/CN=client/[email protected]
Sun Dec 16 18:06:15 2007 89.62.32.222:1194 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Sun Dec 16 18:06:15 2007 89.62.32.222:1194 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sun Dec 16 18:06:15 2007 89.62.32.222:1194 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Sun Dec 16 18:06:15 2007 89.62.32.222:1194 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sun Dec 16 18:06:15 2007 89.62.32.222:1194 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Sun Dec 16 18:06:15 2007 89.62.32.222:1194 [client] Peer Connection Initiated with 89.62.32.222:1194
Sun Dec 16 18:06:15 2007 client/89.62.32.222:1194 MULTI: no dynamic or static remote --ifconfig address is available for client/89.62.32.222:1194
Sun Dec 16 18:06:26 2007 client/89.62.32.222:1194 MULTI: bad source address from client [10.0.8.2], packet dropped
Sun Dec 16 18:06:29 2007 client/89.62.32.222:1194 MULTI: bad source address from client [10.0.8.2], packet dropped
Sun Dec 16 18:06:30 2007 client/89.62.32.222:1194 MULTI: bad source address from client [10.0.8.2], packet dropped
Sun Dec 16 18:06:35 2007 client/89.62.32.222:1194 MULTI: bad source address from client [10.0.8.2], packet dropped
Sun Dec 16 18:06:42 2007 client/89.62.32.222:1194 MULTI: bad source address from client [192.168.178.20], packet dropped
Sun Dec 16 18:06:43 2007 client/89.62.32.222:1194 MULTI: bad source address from client [192.168.178.20], packet dropped
Sun Dec 16 18:06:45 2007 client/89.62.32.222:1194 MULTI: bad source address from client [192.168.178.20], packet dropped
Sun Dec 16 18:06:47 2007 client/89.62.32.222:1194 MULTI: bad source address from client [10.0.8.2], packet dropped
Sun Dec 16 18:06:48 2007 client/89.62.32.222:1194 MULTI: bad source address from client [192.168.178.20], packet dropped
Sun Dec 16 18:06:49 2007 client/89.62.32.222:1194 MULTI: bad source address from client [10.0.8.2], packet dropped
Sun Dec 16 18:06:52 2007 client/89.62.32.222:1194 MULTI: bad source address from client [10.0.8.2], packet dropped
Sun Dec 16 18:06:53 2007 client/89.62.32.222:1194 MULTI: bad source address from client [10.0.8.2], packet dropped
Sun Dec 16 18:06:54 2007 client/89.62.32.222:1194 MULTI: bad source address from client [192.168.178.20], packet dropped
Sun Dec 16 18:06:57 2007 client/89.62.32.222:1194 MULTI: bad source address from client [10.0.8.2], packet dropped
Sun Dec 16 18:06:58 2007 client/89.62.32.222:1194 MULTI: bad source address from client [10.0.8.2], packet dropped
Sun Dec 16 18:06:59 2007 client/89.62.32.222:1194 MULTI: bad source address from client [10.0.8.2], packet dropped
