OpenSSL Fehler beim kompilieren
ready
16 Jul 2007
Hallo Leute,
ich möchte aktuell eine Freetz firmware für die 7390 kompilieren. Das ganze geschieht aus einem frischen Trunk heraus. Revision 9759.
ready@one:~/Apps/Freetz2$ make
cmd() { PATH="/data/root/home/ready/Apps/Freetz2/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc/bin:/data/root/home/ready/Apps/Freetz2/toolchain/build/mips_gcc-4.6.3/mips-unknown-linux-gnu/bin:/data/root/home/ready/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/data/root/home/ready/bin:/system/scripts:/data/root/home/ready/bin:/system/scripts" LD_RUN_PATH="/usr/lib/freetz" make -j2  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } };     if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x MAKEDEPPROG="/data/root/home/ready/Apps/Freetz2/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc" CC="/data/root/home/ready/Apps/Freetz2/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc" AR="/data/root/home/ready/Apps/Freetz2/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-ar r" RANLIB="/data/root/home/ready/Apps/Freetz2/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-ranlib" NM="/data/root/home/ready/Apps/Freetz2/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-nm" FREETZ_MOD_OPTIMIZATION_FLAGS="-march=24kc -Os -W -Wall -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" SHARED_LDFLAGS="" INSTALL_PREFIX="/data/root/home/ready/Apps/Freetz2/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc" install
make[1]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x'
if [ -n "" ]; then \
                EXCL_OBJ='aes_core.o aes_cbc.o bn_asm.o des_enc.o fcrypt_b.o   ../crypto/aes/aes_cfb.o ../crypto/aes/aes_ecb.o ../crypto/aes/aes_ofb.o ../crypto/bn/bn_add.o ../crypto/bn/bn_blind.o ../crypto/bn/bn_ctx.o ../crypto/bn/bn_div.o ../crypto/bn/bn_exp2.o ../crypto/bn/bn_exp.o ../crypto/bn/bn_gcd.o ../crypto/bn/bn_lib.o ../crypto/bn/bn_mod.o ../crypto/bn/bn_mont.o ../crypto/bn/bn_mul.o ../crypto/bn/bn_prime.o ../crypto/bn/bn_rand.o ../crypto/bn/bn_recp.o ../crypto/bn/bn_shift.o ../crypto/bn/bn_sqr.o ../crypto/bn/bn_word.o ../crypto/bn/bn_x931p.o ../crypto/buffer/buf_str.o ../crypto/cryptlib.o ../crypto/des/cfb64ede.o ../crypto/des/cfb64enc.o ../crypto/des/cfb_enc.o ../crypto/des/ecb3_enc.o ../crypto/des/ecb_enc.o ../crypto/des/ofb64ede.o ../crypto/des/ofb64enc.o ../crypto/des/fcrypt.o ../crypto/des/set_key.o ../crypto/dsa/dsa_utl.o ../crypto/dsa/dsa_sign.o ../crypto/dsa/dsa_vrf.o ../crypto/err/err.o ../crypto/evp/digest.o ../crypto/evp/enc_min.o ../crypto/evp/e_aes.o ../crypto/evp/e_des3.o ../crypto/evp/p_sign.o ../crypto/evp/p_verify.o ../crypto/mem_clr.o ../crypto/mem.o ../crypto/rand/md_rand.o ../crypto/rand/rand_egd.o ../crypto/rand/randfile.o ../crypto/rand/rand_lib.o ../crypto/rand/rand_os2.o ../crypto/rand/rand_unix.o ../crypto/rand/rand_win.o ../crypto/rsa/rsa_lib.o ../crypto/rsa/rsa_none.o ../crypto/rsa/rsa_oaep.o ../crypto/rsa/rsa_pk1.o ../crypto/rsa/rsa_pss.o ../crypto/rsa/rsa_ssl.o ../crypto/rsa/rsa_x931.o ../crypto/sha/sha1dgst.o ../crypto/sha/sha256.o ../crypto/sha/sha512.o ../crypto/uid.o' ; export EXCL_OBJ ; \
                ARX='/usr/bin/perl ${TOP}/util/arx.pl /data/root/home/ready/Apps/Freetz2/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-ar r' ; \
        else \
                ARX='/data/root/home/ready/Apps/Freetz2/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-ar r' ; \
        fi ; export ARX ; \
                dir=crypto; target=all; if echo " crypto ssl         apps " | grep " $dir " >/dev/null 2>/dev/null; then if [ -d "$dir" ]; then (       [ $target != all -a -z "" ] && FIPSCANLIB=/dev/null; cd $dir && echo "making $target in $dir..." && TOP= && unset TOP ${LIB+LIB} ${LIBS+LIBS} ${INCLUDE+INCLUDE} ${INCLUDES+INCLUDES} ${DIR+DIR} ${DIRS+DIRS} ${SRC+SRC} ${LIBSRC+LIBSRC} ${LIBOBJ+LIBOBJ} ${ALL+ALL} ${EXHEADER+EXHEADER} ${HEADER+HEADER} ${GENERAL+GENERAL} ${CFLAGS+CFLAGS} ${ASFLAGS+ASFLAGS} ${AFLAGS+AFLAGS} ${LDCMD+LDCMD} ${LDFLAGS+LDFLAGS} ${SHAREDCMD+SHAREDCMD} ${SHAREDFLAGS+SHAREDFLAGS} ${SHARED_LIB+SHARED_LIB} ${LIBEXTRAS+LIBEXTRAS} && make -e PLATFORM='linux-freetz-be' PROCESSOR='' CC='/data/root/home/ready/Apps/Freetz2/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc' CFLAG='-fPIC -DOPENSSL_PIC -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -DOPENSSL_SMALL_FOOTPRINT -DOPENSSL_NO_ERR -DB_ENDIAN -DTERMIO -march=24kc -Os -W -Wall -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fomit-frame-pointer -Wall' AS='/data/root/home/ready/Apps/Freetz2/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc' ASFLAG='-fPIC -DOPENSSL_PIC -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -DOPENSSL_SMALL_FOOTPRINT -DOPENSSL_NO_ERR -DB_ENDIAN -DTERMIO -march=24kc -Os -W -Wall -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fomit-frame-pointer -Wall -c' AR='/data/root/home/ready/Apps/Freetz2/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-ar r' PERL='/usr/bin/perl' RANLIB='/data/root/home/ready/Apps/Freetz2/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-ranlib' SDIRS='objects md4 md5 sha hmac des aes rc4 bf cast bn rsa dsa dh dso engine buffer bio stack lhash rand err evp asn1 pem x509 x509v3 conf txt_db pkcs7 pkcs12 comp ocsp ui krb5 store pqueue' LIBRPATH='/usr/lib' INSTALL_PREFIX='/data/root/home/ready/Apps/Freetz2/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc' INSTALLTOP='/usr' OPENSSLDIR='/mod/etc/ssl' LIBDIR='lib' MAKEDEPEND='$${TOP}/util/domd $${TOP} -MD /data/root/home/ready/Apps/Freetz2/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc' DEPFLAG='-DOPENSSL_NO_DEPRECATED -DOPENSSL_NO_AES192 -DOPENSSL_NO_ANS1 -DOPENSSL_NO_CAMELLIA -DOPENSSL_NO_CAPIENG -DOPENSSL_NO_CMS -DOPENSSL_NO_EC -DOPENSSL_NO_ECDH -DOPENSSL_NO_ECDSA -DOPENSSL_NO_ENGINES -DOPENSSL_NO_FIPS -DOPENSSL_NO_GMP -DOPENSSL_NO_IDEA -DOPENSSL_NO_JPAKE -DOPENSSL_NO_MD2 -DOPENSSL_NO_MDC2 -DOPENSSL_NO_PERLASM -DOPENSSL_NO_RC2 -DOPENSSL_NO_RC5 -DOPENSSL_NO_RFC3779 -DOPENSSL_NO_RIPEMD -DOPENSSL_NO_RMD160 -DOPENSSL_NO_SEED -DOPENSSL_NO_SHA0 -DOPENSSL_NO_SMIME' MAKEDEPPROG='/data/root/home/ready/Apps/Freetz2/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc' SHARED_LDFLAGS='' KRB5_INCLUDES='' LIBKRB5='' EXE_EXT='' SHARED_LIBS=' libcrypto.so.0.9.8 libssl.so.0.9.8' SHLIB_EXT='.so.0.9.8' SHLIB_TARGET='linux-shared' PEX_LIBS='' EX_LIBS='-ldl' CPUID_OBJ='' BN_ASM='bn_asm.o' DES_ENC='des_enc.o fcrypt_b.o' AES_ASM_OBJ='aes_core.o aes_cbc.o' BF_ENC='bf_enc.o' CAST_ENC='c_enc.o' RC4_ENC='rc4_enc.o rc4_skey.o' RC5_ENC='rc5_enc.o' SHA1_ASM_OBJ='' MD5_ASM_OBJ='' RMD160_ASM_OBJ='' FIPSLIBDIR='/usr/local/ssl/fips-1.0/lib/' FIPSCANLIB="${FIPSCANLIB:-}" FIPSCANISTERINTERNAL='n' FIPS_EX_OBJ='../crypto/aes/aes_cfb.o ../crypto/aes/aes_ecb.o ../crypto/aes/aes_ofb.o ../crypto/bn/bn_add.o ../crypto/bn/bn_blind.o ../crypto/bn/bn_ctx.o ../crypto/bn/bn_div.o ../crypto/bn/bn_exp2.o ../crypto/bn/bn_exp.o ../crypto/bn/bn_gcd.o ../crypto/bn/bn_lib.o ../crypto/bn/bn_mod.o ../crypto/bn/bn_mont.o ../crypto/bn/bn_mul.o ../crypto/bn/bn_prime.o ../crypto/bn/bn_rand.o ../crypto/bn/bn_recp.o ../crypto/bn/bn_shift.o ../crypto/bn/bn_sqr.o ../crypto/bn/bn_word.o ../crypto/bn/bn_x931p.o ../crypto/buffer/buf_str.o ../crypto/cryptlib.o ../crypto/des/cfb64ede.o ../crypto/des/cfb64enc.o ../crypto/des/cfb_enc.o ../crypto/des/ecb3_enc.o ../crypto/des/ecb_enc.o ../crypto/des/ofb64ede.o ../crypto/des/ofb64enc.o ../crypto/des/fcrypt.o ../crypto/des/set_key.o ../crypto/dsa/dsa_utl.o ../crypto/dsa/dsa_sign.o ../crypto/dsa/dsa_vrf.o ../crypto/err/err.o ../crypto/evp/digest.o ../crypto/evp/enc_min.o ../crypto/evp/e_aes.o ../crypto/evp/e_des3.o ../crypto/evp/p_sign.o ../crypto/evp/p_verify.o ../crypto/mem_clr.o ../crypto/mem.o ../crypto/rand/md_rand.o ../crypto/rand/rand_egd.o ../crypto/rand/randfile.o ../crypto/rand/rand_lib.o ../crypto/rand/rand_os2.o ../crypto/rand/rand_unix.o ../crypto/rand/rand_win.o ../crypto/rsa/rsa_lib.o ../crypto/rsa/rsa_none.o ../crypto/rsa/rsa_oaep.o ../crypto/rsa/rsa_pk1.o ../crypto/rsa/rsa_pss.o ../crypto/rsa/rsa_ssl.o ../crypto/rsa/rsa_x931.o ../crypto/sha/sha1dgst.o ../crypto/sha/sha256.o ../crypto/sha/sha512.o ../crypto/uid.o' THIS=${THIS:-build_crypto} MAKEFILE=Makefile MAKEOVERRIDES= TOP=.. DIR=$dir $target ) || exit 1; fi; fi
making all in crypto...
make[2]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto'
making install in crypto...
making all in crypto/objects...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/objects'
make[3]: Für das Ziel »all« ist nichts zu tun.
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/objects'
making all in crypto/md4...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/md4'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/md4'
making all in crypto/md5...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/md5'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/md5'
making all in crypto/sha...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/sha'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/sha'
making all in crypto/hmac...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/hmac'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/hmac'
making all in crypto/des...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/des'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/des'
making all in crypto/aes...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/aes'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/aes'
making all in crypto/rc4...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/rc4'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/rc4'
making all in crypto/bf...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/bf'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/bf'
making all in crypto/cast...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/cast'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/cast'
making all in crypto/bn...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/bn'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/bn'
making all in crypto/rsa...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/rsa'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/rsa'
making all in crypto/dsa...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/dsa'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/dsa'
making all in crypto/dh...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/dh'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/dh'
making all in crypto/dso...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/dso'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/dso'
making all in crypto/engine...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/engine'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/engine'
making all in crypto/buffer...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/buffer'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/buffer'
making all in crypto/bio...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/bio'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/bio'
making all in crypto/stack...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/stack'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/stack'
making all in crypto/lhash...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/lhash'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/lhash'
making all in crypto/rand...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/rand'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/rand'
making all in crypto/err...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/err'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/err'
making all in crypto/evp...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/evp'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/evp'
making all in crypto/asn1...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/asn1'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/asn1'
making all in crypto/pem...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/pem'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/pem'
making all in crypto/x509...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/x509'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/x509'
making all in crypto/x509v3...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/x509v3'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/x509v3'
making all in crypto/conf...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/conf'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/conf'
making all in crypto/txt_db...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/txt_db'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/txt_db'
making all in crypto/pkcs7...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/pkcs7'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/pkcs7'
making all in crypto/pkcs12...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/pkcs12'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/pkcs12'
making all in crypto/comp...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/comp'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/comp'
making all in crypto/ocsp...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/ocsp'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/ocsp'
making all in crypto/ui...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/ui'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/ui'
making all in crypto/krb5...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/krb5'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/krb5'
making all in crypto/store...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/store'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/store'
making all in crypto/pqueue...
make[3]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/pqueue'
make[3]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto/pqueue'
make[2]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/crypto'
making all in ssl...
make[2]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/ssl'
make[2]: Für das Ziel »all« ist nichts zu tun.
make[2]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/ssl'
making all in apps...
make[2]: Betrete Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/apps'
make[2]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x/apps'
making install in crypto/objects...
making install in crypto/md4...
making install in crypto/md5...
making install in crypto/sha...
making install in crypto/hmac...
making install in crypto/des...
making install in crypto/aes...
making install in crypto/rc4...
making install in crypto/bf...
making install in crypto/cast...
making install in crypto/bn...
making install in crypto/rsa...
making install in crypto/dsa...
making install in crypto/dh...
making install in crypto/dso...
making install in crypto/engine...
making install in crypto/buffer...
making install in crypto/bio...
making install in crypto/stack...
making install in crypto/lhash...
making install in crypto/rand...
making install in crypto/err...
making install in crypto/evp...
making install in crypto/asn1...
making install in crypto/pem...
making install in crypto/x509...
making install in crypto/x509v3...
making install in crypto/conf...
making install in crypto/txt_db...
making install in crypto/pkcs7...
making install in crypto/pkcs12...
making install in crypto/comp...
making install in crypto/ocsp...
making install in crypto/ui...
making install in crypto/krb5...
making install in crypto/store...
making install in crypto/pqueue...
making install in ssl...
making install in apps...
installing openssl
installing /system/scripts
cp: Verzeichnis „/system/scripts“ ausgelassen
make[2]: *** [install] Fehler 1
make[1]: *** [install_sw] Fehler 1
make[1]: Verlasse Verzeichnis '/data/root/home/ready/Apps/Freetz2/source/target-mips_uClibc-0.9.32.1/openssl-0.9.8x'
make: *** [/data/root/home/ready/Apps/Freetz2/toolchain/build/mips_gcc-4.6.3_uClibc-0.9.32.1/mips-linux-uclibc/usr/lib/libssl.so.0.9.8] Fehler 1
Hier noch die config:
# Automatically generated file; DO NOT EDIT.
# Freetz Configuration
FREETZ_HAVE_DOT_CONFIG=y
# General --------------------------------
FREETZ_AVM_VERSION_7390_05_21=y
FREETZ_AVM_VERSION_05_2X_MIN=y
FREETZ_AVM_VERSION_05_2X=y
# FREETZ_TYPE_300IP_AS_FON is not set
# FREETZ_TYPE_2170 is not set
# FREETZ_TYPE_6810 is not set
# FREETZ_TYPE_6840 is not set
# FREETZ_TYPE_FON is not set
# FREETZ_TYPE_FON_5010 is not set
# FREETZ_TYPE_FON_5050 is not set
# FREETZ_TYPE_FON_5124 is not set
# FREETZ_TYPE_FON_5140 is not set
# FREETZ_TYPE_FON_WLAN is not set
# FREETZ_TYPE_FON_WLAN_7050 is not set
# FREETZ_TYPE_FON_WLAN_7112 is not set
# FREETZ_TYPE_FON_WLAN_7113 is not set
# FREETZ_TYPE_FON_WLAN_7140 is not set
# FREETZ_TYPE_FON_WLAN_7141 is not set
# FREETZ_TYPE_FON_7150 is not set
# FREETZ_TYPE_FON_WLAN_7170 is not set
# FREETZ_TYPE_FON_WLAN_7240 is not set
# FREETZ_TYPE_FON_WLAN_7270_V1 is not set
# FREETZ_TYPE_FON_WLAN_7270_V2 is not set
# FREETZ_TYPE_FON_WLAN_7270_V3 is not set
# FREETZ_TYPE_FON_WLAN_7312 is not set
# FREETZ_TYPE_FON_WLAN_7320 is not set
# FREETZ_TYPE_FON_WLAN_7330_XL is not set
# FREETZ_TYPE_FON_WLAN_7330_SL is not set
# FREETZ_TYPE_FON_WLAN_7340 is not set
# FREETZ_TYPE_FON_WLAN_7360_XL is not set
# FREETZ_TYPE_FON_WLAN_7360_SL is not set
FREETZ_TYPE_FON_WLAN_7390=y
# FREETZ_TYPE_FON_WLAN_7570 is not set
# FREETZ_TYPE_WLAN_3020 is not set
# FREETZ_TYPE_WLAN_3030 is not set
# FREETZ_TYPE_WLAN_3130 is not set
# FREETZ_TYPE_WLAN_3131 is not set
# FREETZ_TYPE_WLAN_3170 is not set
# FREETZ_TYPE_WLAN_3270 is not set
# FREETZ_TYPE_WLAN_3270_V3 is not set
# FREETZ_TYPE_WLAN_3370 is not set
# FREETZ_TYPE_SPEEDPORT_W501V is not set
# FREETZ_TYPE_CUSTOM is not set
FREETZ_TYPE_LANG_DE=y
# FREETZ_TYPE_LANG_EN is not set
FREETZ_TYPE_FIRMWARE_05_22=y
# FREETZ_TYPE_FIRMWARE_current is not set
FREETZ_TYPE_LANGUAGE="de"
FREETZ_AVM_VERSION_STRING="7390_05.21"
FREETZ_FILESYSTEM_MTD_SIZE=0
FREETZ_TYPE_PREFIX="7390_05_22"
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_SHOW_ADVANCED=y
FREETZ_REPLACE_KERNEL_AVAILABLE=y
# FREETZ_REPLACE_KERNEL is not set
FREETZ_TARGET_IPV6_SUPPORT=y
FREETZ_TARGET_REF_16MB=y
FREETZ_TARGET_REF="16mb"
FREETZ_KERNEL_REF_16MB=y
FREETZ_KERNEL_REF="16mb"
FREETZ_KERNEL_MTD_SIZE=238
FREETZ_HAS_AVM_PTY_SUPPORT=y
# FREETZ_HAS_AVM_CDROM_ISO is not set
FREETZ_HAS_AVM_AURA_USB=y
# FREETZ_HAS_AVM_MINID is not set
FREETZ_HAS_AVM_NTFS=y
FREETZ_HAS_AVM_IPV6=y
FREETZ_HAS_AVM_WEBDAV=y
FREETZ_HAS_AVM_INETD=y
FREETZ_HAS_AVM_EXT3=y
FREETZ_HAS_AVM_TR069=y
FREETZ_HAS_AVM_TR069_FWUPDATE=y
FREETZ_HAS_AVM_CHRONYD=y
FREETZ_HAS_AVM_DECT=y
FREETZ_HAS_AVM_OPENSSL_LIBS=y
FREETZ_HAS_AVM_LSOF=y
FREETZ_HAS_AVM_SOCAT=y
FREETZ_HAS_AVM_NAS=y
FREETZ_HAS_AVM_MYFRITZ=y
FREETZ_HAS_AVM_PHONE=y
# FREETZ_HAS_AVM_STRACE is not set
FREETZ_HAS_AVM_TAM=y
FREETZ_HAS_AVM_UDEV=y
# FREETZ_HAS_UPDATE_FILESYSTEM_IMAGE is not set
# FREETZ_HAS_USB_CLIENT is not set
FREETZ_HAS_AVM_USB_HOST=y
# FREETZ_HAS_AVM_USB_HOST_AHCI is not set
FREETZ_HAS_AVM_E2FSPROGS=y
FREETZ_HAS_AVM_WLAN=y
FREETZ_HAS_AVM_UMTS=y
# FREETZ_HAS_AVM_JFFS2 is not set
FREETZ_HAS_AVM_JUNK_BYTES=y
# FREETZ_HAS_AVM_MICROVOIP_DSL is not set
# FREETZ_HAS_AVM_ANNEX_A_AND_B is not set
FREETZ_HAS_AVM_MULTI_ANNEX=y
FREETZ_HAS_AVM_CTLMGR_STRUCT_V3=y
FREETZ_HAS_AVM_RAMZSWAP=y
# FREETZ_HAS_AVM_AHA is not set
# Mod ------------------------------------
FREETZ_LANG_DE=y
# FREETZ_LANG_EN is not set
FREETZ_LANG_STRING="de"
# Patches
# Web menu patches -----------------------
# FREETZ_PATCH_VCC is not set
# FREETZ_PATCH_ATA is not set
# FREETZ_ADD_REGEXT_GUI is not set
# FREETZ_PATCH_GSMVOICE is not set
FREETZ_PATCH_SIGNED=y
# USB patches --------------------
FREETZ_PATCH_FREETZMOUNT=y
FREETZ_USBSTORAGE_AUTOMOUNT=y
# FREETZ_AUTOMOUNT_EXT2 is not set
FREETZ_AUTOMOUNT_EXT3=y
# FREETZ_AUTOMOUNT_EXT4 is not set
FREETZ_AUTOMOUNT_FAT=y
# FREETZ_AUTOMOUNT_HFS is not set
# FREETZ_AUTOMOUNT_HFS_PLUS is not set
# FREETZ_AUTOMOUNT_LUKS is not set
FREETZ_AUTOMOUNT_NTFS=y
# FREETZ_AUTOMOUNT_REISER_FS is not set
# FREETZ_AUTOMOUNT_LINUXSWAP is not set
# FREETZ_PATCH_MAXDEVCOUNT is not set
# FREETZ_MODIFY_UMTSD is not set
# FREETZ_CUSTOM_UDEV_RULES is not set
# Removal patches ------------------------
# FREETZ_REMOVE_MULTI_ANNEX_FIRMWARE_DIFFS is not set
FREETZ_REMOVE_ASSISTANT=y
# FREETZ_REMOVE_ASSISTANT_SIP is not set
# FREETZ_REMOVE_AURA_USB is not set
# FREETZ_REMOVE_NAS is not set
# FREETZ_REMOVE_AVM_VPN is not set
# Remove brandings
FREETZ_REMOVE_BRANDING_1und1=y
# FREETZ_REMOVE_BRANDING_avm is not set
# FREETZ_REMOVE_CAPIOVERTCP is not set
# FREETZ_REMOVE_CHRONYD is not set
# FREETZ_REMOVE_DECT is not set
# FREETZ_REMOVE_DSLD is not set
# FREETZ_REMOVE_SHOWDSLDSTAT is not set
FREETZ_REMOVE_DTRACE=y
# FREETZ_REMOVE_FTPD is not set
FREETZ_REMOVE_HELP=y
# FREETZ_REMOVE_RAMZSWAP is not set
FREETZ_REMOVE_LSOF=y
FREETZ_REMOVE_SOCAT=y
# FREETZ_REMOVE_MEDIASRV is not set
# FREETZ_REMOVE_NTFS is not set
# FREETZ_REMOVE_PRINTSERV is not set
# FREETZ_REMOVE_RUNCLOCK is not set
# FREETZ_REMOVE_SAMBA is not set
# FREETZ_REMOVE_SUPPORT is not set
FREETZ_REMOVE_TR069=y
# FREETZ_REMOVE_TR069_FWUPDATE is not set
# FREETZ_REMOVE_UMTSD is not set
# FREETZ_REMOVE_UPNP is not set
FREETZ_REMOVE_USERMAN=y
# FREETZ_REMOVE_AVM_E2FSPROGS is not set
# FREETZ_REMOVE_VOIPD is not set
# FREETZ_REMOVE_VOIP_ISDN is not set
# FREETZ_REMOVE_WEBDAV is not set
# FREETZ_REMOVE_WLAN is not set
# Replacement patches --------------------
# Replace OpenSSL libraries (not available, requires openssl-0.9.8)
# FREETZ_REPLACE_DTRACE is not set
# FREETZ_REPLACE_ONLINECHANGED is not set
# Additional patches ---------------------
# FREETZ_ENFORCE_URLADER_SETTINGS is not set
# Misc patches ---------------------------
# FREETZ_DISABLE_SERIAL_CONSOLE is not set
# AVM daemons ----------------------------
# FREETZ_AVMDAEMON_DISABLE_IGD is not set
FREETZ_AVMDAEMON_DISABLE_NTP=y
# FREETZ_AVMDAEMON_DISABLE_IGM is not set
FREETZ_AVMDAEMON_DISABLE_TR069=y
# FREETZ_AVMDAEMON_DISABLE_MULTIDPORTS is not set
# Package selection
# Debug helpers
# FREETZ_PACKAGE_GDB is not set
# FREETZ_PACKAGE_INOTIFY_TOOLS is not set
FREETZ_PACKAGE_LDD=y
FREETZ_PACKAGE_LSOF=y
# FREETZ_PACKAGE_LTRACE is not set
# FREETZ_PACKAGE_NANO_SHELL is not set
# FREETZ_PACKAGE_PCIUTILS is not set
# FREETZ_PACKAGE_STRACE is not set
# FREETZ_PACKAGE_USBUTILS is not set
# Standard packages
# FREETZ_PACKAGE_AICCU is not set
# FREETZ_PACKAGE_BFTPD is not set
# FREETZ_PACKAGE_BIRD is not set
# FREETZ_PACKAGE_BRIDGE_UTILS is not set
# FREETZ_PACKAGE_CALLMONITOR is not set
# FREETZ_PACKAGE_CHECKMAILD is not set
# Cifsmount (not available, needs replace kernel)
# FREETZ_PACKAGE_CURL is not set
# FREETZ_PACKAGE_DECO is not set
# FREETZ_PACKAGE_DNS2TCP is not set
# FREETZ_PACKAGE_DNSMASQ is not set
# FREETZ_PACKAGE_DROPBEAR is not set
# FREETZ_PACKAGE_ESPEAK is not set
# FREETZ_PACKAGE_FORTUNE is not set
# FREETZ_PACKAGE_FUSE is not set
FREETZ_PACKAGE_HASERL=y
# FREETZ_PACKAGE_HASERL_WITH_LUA is not set
FREETZ_PACKAGE_INETD=y
# FREETZ_PACKAGE_KNOCK is not set
# FREETZ_PACKAGE_MC is not set
# FREETZ_PACKAGE_MTR is not set
# FREETZ_PACKAGE_NANO is not set
# FREETZ_PACKAGE_NETCAT is not set
# FREETZ_PACKAGE_NC6 is not set
# FREETZ_PACKAGE_NETSNMP is not set
# FREETZ_PACKAGE_NFS_UTILS is not set
# FREETZ_PACKAGE_NTFS is not set
# FREETZ_PACKAGE_OPENNTPD is not set
FREETZ_PACKAGE_OPENVPN=y
FREETZ_PACKAGE_OPENVPN_VERSION_2_2=y
# FREETZ_PACKAGE_OPENVPN_VERSION_2_3 is not set
FREETZ_PACKAGE_OPENVPN_OPENSSL=y
FREETZ_PACKAGE_OPENVPN_STATIC=y
FREETZ_PACKAGE_OPENVPN_WITH_LZO=y
# FREETZ_PACKAGE_OPENVPN_WITH_MGMNT is not set
FREETZ_PACKAGE_OPENVPN_ENABLE_SMALL=y
# FREETZ_PACKAGE_OPENVPN_USE_IPROUTE is not set
# FREETZ_PACKAGE_PHP is not set
# FREETZ_PACKAGE_PINGTUNNEL is not set
# FREETZ_PACKAGE_PORTMAP is not set
# Point-to-Point (not available, needs replace kernel)
# FREETZ_PACKAGE_PRIVOXY is not set
# FREETZ_PACKAGE_RADVD is not set
# FREETZ_PACKAGE_RCAPID is not set
# FREETZ_PACKAGE_SAMBA is not set
# FREETZ_PACKAGE_SCREEN is not set
# FREETZ_PACKAGE_STUNNEL is not set
# FREETZ_PACKAGE_TCPDUMP is not set
# FREETZ_PACKAGE_TINYPROXY is not set
# FREETZ_PACKAGE_TOR is not set
# FREETZ_PACKAGE_TRANSMISSION is not set
FREETZ_PACKAGE_VNSTAT=y
FREETZ_PACKAGE_VNSTAT_DAEMON=y
FREETZ_PACKAGE_VNSTAT_IMAGE=y
# FREETZ_PACKAGE_VPNC is not set
# FREETZ_PACKAGE_VSFTPD is not set
# FREETZ_PACKAGE_XMAIL is not set
# Testing
# FREETZ_PACKAGE_APACHE is not set
# FREETZ_PACKAGE_APACHE2 is not set
# autofs (not available, needs replace kernel)
# FREETZ_PACKAGE_AVAHI is not set
# FREETZ_PACKAGE_BASH is not set
# FREETZ_PACKAGE_BFUSB is not set
# FREETZ_PACKAGE_BIND is not set
# FREETZ_PACKAGE_BIP is not set
# FREETZ_PACKAGE_BITTWIST is not set
# FREETZ_PACKAGE_BLUEZ_UTILS is not set
# FREETZ_PACKAGE_BR2684CTL is not set
# FREETZ_PACKAGE_CCID is not set
# FREETZ_PACKAGE_CLASSPATH is not set
# FREETZ_PACKAGE_CRYPTSETUP is not set
# FREETZ_PACKAGE_CTORRENT is not set
# FREETZ_PACKAGE_DANTE is not set
# FREETZ_PACKAGE_DAVFS2 is not set
# FREETZ_PACKAGE_DBUS is not set
# FREETZ_PACKAGE_DEBOOTSTRAP is not set
# FREETZ_PACKAGE_DIGITEMP is not set
# FREETZ_PACKAGE_DOSFSTOOLS is not set
# FREETZ_PACKAGE_DTACH is not set
# FREETZ_PACKAGE_DVBSNOOP is not set
# FREETZ_PACKAGE_DVBSTREAM is not set
# FREETZ_PACKAGE_DVBTUNE is not set
# FREETZ_PACKAGE_E2FSPROGS is not set
# FREETZ_PACKAGE_EMPTY is not set
# FREETZ_PACKAGE_FFMPEG is not set
# FREETZ_PACKAGE_FOWSR is not set
# FREETZ_PACKAGE_FSTYP is not set
# FREETZ_PACKAGE_GIT is not set
# FREETZ_PACKAGE_GNU_MAKE is not set
# FREETZ_PACKAGE_GNUTLS is not set
# FREETZ_PACKAGE_GOCR is not set
# FREETZ_PACKAGE_HAPROXY is not set
# FREETZ_PACKAGE_HD_IDLE is not set
# FREETZ_PACKAGE_HOL is not set
# FREETZ_PACKAGE_HTOP is not set
# FREETZ_PACKAGE_HTPDATE is not set
# FREETZ_PACKAGE_HTTPRY is not set
# FREETZ_PACKAGE_HTTPTUNNEL is not set
# FREETZ_PACKAGE_IFSTAT is not set
# FREETZ_PACKAGE_IFTOP is not set
# FREETZ_PACKAGE_IGMPPROXY is not set
# FREETZ_PACKAGE_IMAGEMAGICK is not set
# FREETZ_PACKAGE_INADYN_MT is not set
# FREETZ_PACKAGE_INADYN_OPENDNS is not set
# FREETZ_PACKAGE_IODINE is not set
# FREETZ_PACKAGE_IPTRAF is not set
# FREETZ_PACKAGE_IPUTILS is not set
# FREETZ_PACKAGE_IRSSI is not set
# FREETZ_PACKAGE_JAMVM is not set
# FREETZ_PACKAGE_LFTP is not set
# FREETZ_PACKAGE_LIGHTTPD is not set
# FREETZ_PACKAGE_LYNX is not set
# FREETZ_PACKAGE_LUA is not set
# FREETZ_PACKAGE_MADPLAY is not set
# FREETZ_PACKAGE_MATRIXTUNNEL is not set
# FREETZ_PACKAGE_MCABBER is not set
# FREETZ_PACKAGE_MEDIATOMB is not set
# FREETZ_PACKAGE_MICROPERL is not set
# FREETZ_PACKAGE_MINI_SNMPD is not set
# FREETZ_PACKAGE_MINICOM is not set
# FREETZ_PACKAGE_MINIDLNA is not set
# FREETZ_PACKAGE_MODULE_INIT_TOOLS is not set
# FREETZ_PACKAGE_NAGIOS is not set
# FREETZ_PACKAGE_NCFTP is not set
# FREETZ_PACKAGE_NETATALK is not set
# FREETZ_PACKAGE_NETPBM is not set
# FREETZ_PACKAGE_NOIP is not set
# FREETZ_PACKAGE_NGIRCD is not set
# FREETZ_PACKAGE_NMAP is not set
# FREETZ_PACKAGE_OBEXFTP is not set
# FREETZ_PACKAGE_OIDENTD is not set
# FREETZ_PACKAGE_OPENCONNECT is not set
# FREETZ_PACKAGE_OPENDD is not set
# OpenSSH
# FREETZ_PACKAGE_OPENSSH_sshd is not set
# FREETZ_PACKAGE_OPENSSH_ssh is not set
# FREETZ_PACKAGE_OPENSSH_scp is not set
# FREETZ_PACKAGE_OPENSSH_CLIENTUTILS is not set
# FREETZ_PACKAGE_OPENSSH_KEYUTILS is not set
# FREETZ_PACKAGE_OPENSSH_sftp is not set
# FREETZ_PACKAGE_OPENSSH_sftp_server is not set
# FREETZ_PACKAGE_OWFS is not set
# FREETZ_PACKAGE_PCSC_LITE is not set
# FREETZ_PACKAGE_POLIPO is not set
# FREETZ_PACKAGE_PYTHON is not set
# FREETZ_PACKAGE_QUAGGA is not set
# FREETZ_PACKAGE_RIPMIME is not set
FREETZ_PACKAGE_RRDTOOL=y
# FREETZ_PACKAGE_RSYNC is not set
# FREETZ_PACKAGE_RUBY is not set
# FREETZ_PACKAGE_RUSH is not set
# FREETZ_PACKAGE_SABLEVM_SDK is not set
# FREETZ_PACKAGE_SER2NET is not set
# FREETZ_PACKAGE_SHELLINABOX is not set
# FREETZ_PACKAGE_SIPROXD is not set
# FREETZ_PACKAGE_SISPMCTL is not set
# FREETZ_PACKAGE_SLANG is not set
# FREETZ_PACKAGE_SLURM is not set
# FREETZ_PACKAGE_SMARTMONTOOLS is not set
# FREETZ_PACKAGE_SMSTOOLS3 is not set
# FREETZ_PACKAGE_SMUSBUTIL is not set
# FREETZ_PACKAGE_SOCAT is not set
# FREETZ_PACKAGE_SPAWN_FCGI is not set
# FREETZ_PACKAGE_SQLITE is not set
# FREETZ_PACKAGE_SSHFS_FUSE is not set
# FREETZ_PACKAGE_STREAMRIPPER is not set
# FREETZ_PACKAGE_SUBVERSION is not set
# FREETZ_PACKAGE_SUNDTEK is not set
# FREETZ_PACKAGE_SYNCE_DCCM is not set
# FREETZ_PACKAGE_TCP_WRAPPERS is not set
# FREETZ_PACKAGE_TCPPROXY is not set
# FREETZ_PACKAGE_TREE is not set
# FREETZ_PACKAGE_TRICKLE is not set
# FREETZ_PACKAGE_TMUX is not set
# FREETZ_PACKAGE_UDPXY is not set
# FREETZ_PACKAGE_UMURMUR is not set
# FREETZ_PACKAGE_UNFS3 is not set
# FREETZ_PACKAGE_UNRAR is not set
# FREETZ_PACKAGE_USBIP is not set
# FREETZ_PACKAGE_USBROOT is not set
# FREETZ_PACKAGE_UTIL_LINUX_NG is not set
FREETZ_PACKAGE_VIM=y
FREETZ_PACKAGE_VIM_TINY=y
# FREETZ_PACKAGE_VIM_NORMAL is not set
# FREETZ_PACKAGE_VIM_HUGE is not set
# FREETZ_PACKAGE_VTUN is not set
# FREETZ_PACKAGE_WGET is not set
# FREETZ_PACKAGE_WOL is not set
# FREETZ_PACKAGE_WPUT is not set
# FREETZ_PACKAGE_XPDF is not set
# FREETZ_PACKAGE_XRELAYD is not set
# FREETZ_PACKAGE_XSLTPROC is not set
# Web interfaces
# FREETZ_PACKAGE_AUTHORIZED_KEYS is not set
FREETZ_PACKAGE_AVM_FIREWALL=y
# FREETZ_PACKAGE_DNSD_CGI is not set
FREETZ_PACKAGE_DOWNLOADER=y
# FREETZ_PACKAGE_NFSD_CGI is not set
# FREETZ_PACKAGE_ONLINECHANGED_CGI is not set
# FREETZ_PACKAGE_PHPXMAIL is not set
# FREETZ_PACKAGE_PPP_CGI is not set
FREETZ_PACKAGE_RRDSTATS=y
# FREETZ_PACKAGE_RRDSTATS_CABLEMODEM is not set
# FREETZ_PACKAGE_RRDSTATS_SEGMENTLOAD is not set
FREETZ_PACKAGE_RRDSTATS_STORAGE=y
FREETZ_PACKAGE_RRDSTATS_NETWORK=y
# FREETZ_PACKAGE_RRDSTATS_DIGITEMP is not set
# FREETZ_PACKAGE_SPINDOWN_CGI is not set
FREETZ_PACKAGE_SYSLOGD_CGI=y
# FREETZ_PACKAGE_TRANSMISSION_CGI is not set
FREETZ_PACKAGE_VNSTAT_CGI=y
FREETZ_PACKAGE_WOL_CGI=y
# FREETZ_SHOW_UNSTABLE_PACKAGES is not set
FREETZ_PACKAGE_MOD=y
FREETZ_PACKAGE_MOD_ETCSERVICES=y
FREETZ_PACKAGE_MODCGI=y
# Advanced options
# FREETZ_DL_OVERRIDE is not set
FREETZ_DL_KERNEL_SITE=""
FREETZ_DL_KERNEL_SOURCE="${FREETZ_AVM_VERSION_STRING}-release_kernel.tar.xz"
FREETZ_DL_KERNEL_SOURCE_MD5="2e8b43c176c1cbe9f815078109d88e61"
FREETZ_DL_SITE="@AVM/Downgrade/FRITZ!Box Fon WLAN 7390/deutsch"
FREETZ_DL_SOURCE="FRITZ.Box_Fon_WLAN_7390.84.05.22.image"
FREETZ_DL_SOURCE_MD5="e7b50eec03e2fd23a2ff4b21caf7d692"
# Build system options
FREETZ_VERBOSITY_LEVEL=2
FREETZ_SIZEINFO_COMPRESSED=y
# FREETZ_SIZEINFO_UNCOMPRESSED is not set
# Firmware packaging (fwmod) special options
# FREETZ_FWMOD_SKIP_UNPACK is not set
# FREETZ_FWMOD_SKIP_MODIFY is not set
# FREETZ_FWMOD_SKIP_PACK is not set
# FREETZ_FWMOD_SDK is not set
# FREETZ_FWMOD_USBROOT is not set
# FREETZ_FWMOD_NFSROOT is not set
FREETZ_JLEVEL=2
FREETZ_CHECK_CHANGED=y
# FREETZ_BACKUP_CONFIG_CACHE is not set
FREETZ_DL_SITE_USER=""
# Freetz customisation
FREETZ_OPTIONS_ETCSERVICES=y
FREETZ_SECURITY_LEVEL=1
FREETZ_STYLE_COLORED=y
# FREETZ_STYLE_GREY is not set
FREETZ_STYLE="colored"
# Webinterface skins
FREETZ_SKIN_legacy=y
# FREETZ_SKIN_newfreetz is not set
# FREETZ_SKIN_phoenix is not set
# FREETZ_FAVICON_NONE is not set
# FREETZ_FAVICON_ATOMPHIL is not set
FREETZ_FAVICON_CUMA=y
# FREETZ_FAVICON_DSL123 is not set
# FREETZ_FAVICON_HANSOLO is not set
FREETZ_FAVICON_STRING="cuma"
FREETZ_TAGGING_NONE=y
# FREETZ_TAGGING_CUMA is not set
FREETZ_TAGGING_STRING="none"
# Additional image/box information
FREETZ_DEVELOPER_VERSION_STRING=y
# FREETZ_MODIFY_AVM_VERSION is not set
FREETZ_USER_DEFINED_COMMENT=""
# FREETZ_CUSTOM_IMAGE_NAME is not set
# FREETZ_REMOVE_BOX_INFO is not set
# FREETZ_REMOVE_FREETZ_INFO is not set
FREETZ_CREATE_SEPARATE_OPTIONS_CFG=y
# FREETZ_REMOVE_DOT_CONFIG is not set
FREETZ_SQUASHFS_BLOCKSIZE_ORIG=y
# FREETZ_SQUASHFS_BLOCKSIZE_65536 is not set
# FREETZ_KERNEL_VERSION_2_6_13 is not set
# FREETZ_KERNEL_VERSION_2_6_19 is not set
FREETZ_KERNEL_VERSION_2_6_28=y
# FREETZ_KERNEL_VERSION_2_6_32 is not set
FREETZ_KERNEL_VERSION="2.6.28"
FREETZ_KERNEL_VERSION_2_6_13_MIN=y
FREETZ_KERNEL_VERSION_2_6_19_MIN=y
FREETZ_KERNEL_VERSION_2_6_28_MIN=y
# FREETZ_KERNEL_VERSION_2_6_32_MIN is not set
# FREETZ_KERNEL_VERSION_2_6_13_MAX is not set
# FREETZ_KERNEL_VERSION_2_6_19_MAX is not set
FREETZ_KERNEL_VERSION_2_6_28_MAX=y
FREETZ_KERNEL_VERSION_2_6_32_MAX=y
FREETZ_KERNEL_LAYOUT_IKS=y
FREETZ_KERNEL_LAYOUT="iks"
FREETZ_MODULES_KVER="2.6.28.10"
# Kernel modules
# block
# FREETZ_MODULE_block2mtd is not set
# crypto
# FREETZ_MODULE_arc4 is not set
# FREETZ_MODULE_sha256_generic is not set
# drivers
# FREETZ_MODULE_loop is not set
# FREETZ_MODULE_nbd is not set
# FREETZ_MODULE_cdrom is not set
# FREETZ_MODULE_capiconn is not set
# FREETZ_MODULE_nand is not set
# FREETZ_MODULE_ohio_nand is not set
# FREETZ_MODULE_dummy is not set
# FREETZ_MODULE_ppp_deflate is not set
# FREETZ_MODULE_pppoe is not set
# FREETZ_MODULE_pppox is not set
# FREETZ_MODULE_ppp_mppe_mppc is not set
# FREETZ_MODULE_scsi_mod is not set
# FREETZ_MODULE_sd_mod is not set
# FREETZ_MODULE_sg is not set
# FREETZ_MODULE_sr_mod is not set
# FREETZ_MODULE_usblp is not set
# FREETZ_MODULE_usb_storage is not set
# FREETZ_MODULE_usbmon is not set
# FREETZ_MODULE_usbip is not set
# FREETZ_MODULE_usbip_common_mod is not set
# FREETZ_MODULE_usbserial is not set
# FREETZ_MODULE_ipaq is not set
# FREETZ_MODULE_cp2101 is not set
# FREETZ_MODULE_pl2303 is not set
# FREETZ_MODULE_ftdi_sio is not set
# FREETZ_MODULE_hci_usb is not set
# FREETZ_MODULE_bfusb is not set
# FREETZ_MODULE_firmware_class is not set
# FREETZ_MODULE_dm_mod is not set
# FREETZ_MODULE_dm_crypt is not set
# FREETZ_MODULE_option is not set
# fs
# FREETZ_MODULE_autofs4 is not set
# FREETZ_MODULE_cifs is not set
# FREETZ_MODULE_coda is not set
# FREETZ_MODULE_ext2 is not set
# FREETZ_MODULE_ext4 is not set
# FREETZ_MODULE_fat is not set
# FREETZ_MODULE_hfs is not set
# FREETZ_MODULE_hfsplus is not set
# FREETZ_MODULE_fuse is not set
# FREETZ_MODULE_iso9660 is not set
# FREETZ_MODULE_jbd2 is not set
# FREETZ_MODULE_lockd is not set
# FREETZ_MODULE_mini_fo is not set
# FREETZ_MODULE_minix is not set
# FREETZ_MODULE_nfsd is not set
# FREETZ_MODULE_exportfs is not set
# FREETZ_MODULE_nfs is not set
# FREETZ_MODULE_nls_cp437 is not set
# FREETZ_MODULE_nls_cp852 is not set
# FREETZ_MODULE_nls_iso8859_15 is not set
# FREETZ_MODULE_nls_iso8859_1 is not set
# FREETZ_MODULE_nls_utf8 is not set
# FREETZ_MODULE_reiserfs is not set
# FREETZ_MODULE_udf is not set
# FREETZ_MODULE_unionfs is not set
# FREETZ_MODULE_vfat is not set
# FREETZ_MODULE_msdos is not set
# FREETZ_MODULE_jffs2 is not set
# FREETZ_MODULE_mbcache is not set
# lib
# FREETZ_MODULE_crc16 is not set
# FREETZ_MODULE_crc_ccitt is not set
# FREETZ_MODULE_lzo_compress is not set
# FREETZ_MODULE_lzo_decompress is not set
# net
# FREETZ_MODULE_bluetooth is not set
# FREETZ_MODULE_bnep is not set
# FREETZ_MODULE_cls_u32 is not set
# FREETZ_MODULE_l2cap is not set
# network scheduler
# FREETZ_MODULE_sch_cbq is not set
# FREETZ_MODULE_sch_htb is not set
# FREETZ_MODULE_sch_llq is not set
# FREETZ_MODULE_sch_sfq is not set
# FREETZ_MODULE_sch_tbf is not set
# FREETZ_MODULE_rfcomm is not set
# FREETZ_MODULE_sunrpc is not set
# BusyBox options
# FREETZ_BUSYBOX_AR is not set
FREETZ_BUSYBOX_BRCTL=y
# FREETZ_BUSYBOX_BRCTL_FANCY is not set
# FREETZ_BUSYBOX_BLKID is not set
# FREETZ_BUSYBOX_BZIP2 is not set
# FREETZ_BUSYBOX_CHGRP is not set
# FREETZ_BUSYBOX_FEATURE_DD_IBS_OBS is not set
# FREETZ_BUSYBOX_FINDFS is not set
# FREETZ_BUSYBOX_DNSD is not set
# FREETZ_BUSYBOX_DIFF is not set
# FREETZ_BUSYBOX_BASE64 is not set
# FREETZ_BUSYBOX_DOS2UNIX is not set
FREETZ_BUSYBOX_ETHER_WAKE=y
# FREETZ_BUSYBOX_FAKEIDENTD is not set
# FREETZ_BUSYBOX_FANCY_KEYS is not set
# FREETZ_BUSYBOX_FUSER is not set
FREETZ_BUSYBOX_INETD=y
FREETZ_BUSYBOX_IP=y
FREETZ_BUSYBOX_FEATURE_IP_ADDRESS=y
FREETZ_BUSYBOX_FEATURE_IP_LINK=y
# FREETZ_BUSYBOX_FEATURE_IP_RULE is not set
FREETZ_BUSYBOX_FEATURE_IP_ROUTE=y
FREETZ_BUSYBOX_FEATURE_IP_TUNNEL=y
# FREETZ_BUSYBOX_LAST is not set
# FREETZ_BUSYBOX_LESS is not set
# FREETZ_BUSYBOX_LONG_OPTS is not set
# FREETZ_BUSYBOX_LS_COLOR is not set
FREETZ_BUSYBOX_MD5SUM=y
# FREETZ_BUSYBOX_MDEV is not set
# FREETZ_BUSYBOX_MODINFO is not set
# FREETZ_BUSYBOX_MOUNT_HELPERS is not set
# FREETZ_BUSYBOX_MOUNT_LABEL is not set
FREETZ_BUSYBOX_NICE=y
# FREETZ_BUSYBOX_PATCH is not set
# FREETZ_BUSYBOX_PSCAN is not set
FREETZ_BUSYBOX_REALPATH=y
# FREETZ_BUSYBOX_RENICE is not set
# FREETZ_BUSYBOX_SEQ is not set
# FREETZ_BUSYBOX_SHA1SUM is not set
# FREETZ_BUSYBOX_SPLIT is not set
FREETZ_BUSYBOX_START_STOP_DAEMON=y
FREETZ_BUSYBOX_STUN_IP=y
# FREETZ_BUSYBOX_TAC is not set
FREETZ_BUSYBOX_TAR_OLDGNU_COMPATIBILITY=y
# FREETZ_BUSYBOX_UDHCPC is not set
# FREETZ_BUSYBOX_UDHCPD is not set
# FREETZ_BUSYBOX_UNIX2DOS is not set
# FREETZ_BUSYBOX_UNZIP is not set
# FREETZ_BUSYBOX_FEATURE_USERNAME_COMPLETION is not set
# FREETZ_BUSYBOX_USLEEP is not set
FREETZ_BUSYBOX_VOLUMEID=y
FREETZ_BUSYBOX_VOLUMEID_EXT=y
FREETZ_BUSYBOX_VOLUMEID_FAT=y
# FREETZ_BUSYBOX_VOLUMEID_HFS is not set
# FREETZ_BUSYBOX_VOLUMEID_LINUXRAID is not set
# FREETZ_BUSYBOX_VOLUMEID_LINUXSWAP is not set
# FREETZ_BUSYBOX_VOLUMEID_LUKS is not set
FREETZ_BUSYBOX_VOLUMEID_NTFS=y
# FREETZ_BUSYBOX_VOLUMEID_REISERFS is not set
FREETZ_BUSYBOX_WGET=y
# FREETZ_BUSYBOX_FEATURE_WGET_STATUSBAR is not set
# FREETZ_BUSYBOX_FEATURE_WGET_AUTHENTICATION is not set
# FREETZ_BUSYBOX_FEATURE_WGET_TIMEOUT is not set
# FREETZ_BUSYBOX_WHO is not set
# FREETZ_BUSYBOX_WHOAMI is not set
# IPv6 Options
FREETZ_BUSYBOX_FEATURE_PREFER_IPV4_ADDRESS=y
# FREETZ_BUSYBOX_PING6 is not set
# FREETZ_BUSYBOX_TRACEROUTE6 is not set
# Locale & Unicode options
# FREETZ_BUSYBOX_LOCALE_SUPPORT is not set
# FREETZ_BUSYBOX_UNICODE_SUPPORT is not set
# Shared Libraries
# Apache Portable Runtime libs
# FREETZ_LIB_libapr is not set
# FREETZ_LIB_libapr_WITH_DSO is not set
# FREETZ_LIB_libaprutil is not set
# FREETZ_LIB_libaprutil_WITH_LIBDB is not set
# Avahi libraries
# FREETZ_LIB_libavahi_common is not set
# FREETZ_LIB_libavahi_core is not set
# FREETZ_LIB_libavahi_client is not set
# C++
# FREETZ_LIB_STDCXXLIB is not set
# FREETZ_LIB_STDCXXLIB_WITH_WCHAR is not set
# FREETZ_LIB_libstdc__ is not set
# FREETZ_LIB_libuClibc__ is not set
# FREETZ_LIB_libuClibc__WITH_WCHAR is not set
# Charsets & Internationalization
# FREETZ_LIB_libiconv is not set
# FREETZ_LIB_libintl is not set
# Crypto & SSL
# GnuPG ----------------------------------
# FREETZ_LIB_libgpg_error is not set
# FREETZ_LIB_libgcrypt is not set
# Digests ---
# Symmetric ciphers ---
# Asymmetric ciphers ---
# GnuTLS ---------------------------------
# FREETZ_LIB_libgnutls is not set
# FREETZ_LIB_libtasn1 is not set
# SSL ------------------------------------
# FREETZ_LIB_libcyassl is not set
# FREETZ_LIB_libmatrixssl is not set
# FREETZ_LIB_libpolarssl is not set
# FREETZ_LIB_libcrypto is not set
FREETZ_OPENSSL_VERSION_PROMPT=y
FREETZ_OPENSSL_VERSION_0=y
# FREETZ_OPENSSL_VERSION_1 is not set
FREETZ_OPENSSL_SHLIB_VERSION="0.9.8"
# Data compression
# FREETZ_LIB_liblzo2 is not set
FREETZ_LIB_libz=y
# Database
# FREETZ_LIB_libdb is not set
# FREETZ_LIB_libsqlite3 is not set
# File systems
# e2fsprogs libraries
# FREETZ_LIB_libblkid is not set
# FREETZ_LIB_libcom_err is not set
# FREETZ_LIB_libe2p is not set
# FREETZ_LIB_libext2fs is not set
# FREETZ_LIB_libss is not set
# FREETZ_LIB_libuuid is not set
# FREETZ_LIB_libfuse is not set
# FREETZ_LIB_libntfs is not set
# GLib
# FREETZ_LIB_libglib_2 is not set
# FREETZ_LIB_libgio_2 is not set
# FREETZ_LIB_libgobject_2 is not set
# FREETZ_LIB_libgmodule_2 is not set
# FREETZ_LIB_libgthread_2 is not set
# Graphics & fonts
FREETZ_LIB_libfreetype=y
FREETZ_LIB_libart_lgpl_2=y
# FREETZ_LIB_libexif is not set
FREETZ_LIB_libjpeg=y
FREETZ_LIB_libpng12=y
FREETZ_LIB_libgd=y
# FREETZ_LIB_libopenjpeg is not set
# FREETZ_LIB_libtiff is not set
# FREETZ_LIB_libnetpbm is not set
# Multi precision arithmetic libs
# FREETZ_LIB_libgmp is not set
# FREETZ_LIB_libmpfr is not set
# FREETZ_LIB_libmpc is not set
# Multimedia
# Audio and video codecs
# Audio codecs
# FREETZ_LIB_libFLAC is not set
# FREETZ_LIB_libmad is not set
# FREETZ_LIB_libogg is not set
# FFmpeg libraries
# FREETZ_LIB_libavcodec is not set
# FREETZ_LIB_libavdevice is not set
# FREETZ_LIB_libavfilter is not set
# FREETZ_LIB_libavformat is not set
# FREETZ_LIB_libavutil is not set
# FREETZ_LIB_libpostproc is not set
# FREETZ_LIB_libswresample is not set
# FREETZ_LIB_libswscale is not set
# Video codecs
# Vorbis video codec ---------------------
# FREETZ_LIB_libvorbis is not set
# FREETZ_LIB_libvorbisenc is not set
# FREETZ_LIB_libvorbisfile is not set
# ID3 tag reading libs
# FREETZ_LIB_libid3tag is not set
# FREETZ_LIB_libtag is not set
# ncurses
FREETZ_LIB_libncurses=y
# terminfo database
# Select terminfo database entries to install (see help of 'Show all items')
FREETZ_SHARE_terminfo=y
# FREETZ_SHARE_terminfo_showall is not set
FREETZ_SHARE_terminfo_ansi=y
FREETZ_SHARE_terminfo_gnome=y
FREETZ_SHARE_terminfo_konsole=y
FREETZ_SHARE_terminfo_linux=y
FREETZ_SHARE_terminfo_putty=y
FREETZ_SHARE_terminfo_rxvt=y
FREETZ_SHARE_terminfo_screen=y
FREETZ_SHARE_terminfo_screenMINUSw=y
FREETZ_SHARE_terminfo_sun=y
FREETZ_SHARE_terminfo_vt100=y
FREETZ_SHARE_terminfo_vt102=y
FREETZ_SHARE_terminfo_vt102MINUSnsgr=y
FREETZ_SHARE_terminfo_vt102MINUSw=y
FREETZ_SHARE_terminfo_vt200=y
FREETZ_SHARE_terminfo_vt220=y
FREETZ_SHARE_terminfo_vt52=y
FREETZ_SHARE_terminfo_xterm=y
FREETZ_SHARE_terminfo_xtermMINUScolor=y
FREETZ_SHARE_terminfo_xtermMINUSxfree86=y
# FREETZ_LIB_libform is not set
# FREETZ_LIB_libmenu is not set
# FREETZ_LIB_libpanel is not set
# Networking
# ATM ------------------------------------
# FREETZ_LIB_libatm is not set
# Bluetooth ------------------------------
# FREETZ_LIB_libbluetooth is not set
# FREETZ_LIB_libopenobex is not set
# ISDN & CAPI ----------------------------
# FREETZ_LIB_libcapi20 is not set
# Misc networking ------------------------
# FREETZ_LIB_libdnet is not set
# FREETZ_LIB_libpcap is not set
# FREETZ_LIB_libnet is not set
# FREETZ_LIB_liboping is not set
# FREETZ_LIB_libosip2 is not set
# FREETZ_LIB_libosipparser2 is not set
# Readline
# FREETZ_LIB_libreadline is not set
# FREETZ_LIB_libhistory is not set
# Regular expressions
# FREETZ_LIB_libpcre is not set
# FREETZ_LIB_libpcreposix is not set
# uClibc
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libpthread=y
FREETZ_LIB_librt=y
# FREETZ_LIB_libthread_db is not set
FREETZ_LIB_libuClibc=y
# FREETZ_LIB_libutil is not set
# USB & FTDI
# FREETZ_LIB_libusb is not set
# FREETZ_LIB_libusb_1 is not set
# FREETZ_LIB_libftdi is not set
# Web and WebDAV
# FREETZ_LIB_libcurl is not set
# FREETZ_LIB_libcurl_WITH_ZLIB is not set
# FREETZ_LIB_libjs is not set
# FREETZ_LIB_libneon is not set
# FREETZ_LIB_libneon_WITH_SSL is not set
# FREETZ_LIB_libneon_WITH_ZLIB is not set
# XML & XSLT
# FREETZ_LIB_libexpat is not set
# FREETZ_LIB_libxml2 is not set
# FREETZ_LIB_libxml2_WITH_HTML is not set
# FREETZ_LIB_libxslt is not set
# FREETZ_LIB_libexslt is not set
# FREETZ_LIB_libattr is not set
# FREETZ_LIB_libdbus is not set
FREETZ_LIB_libgcc_s=y
# FREETZ_LIB_libconfig is not set
# FREETZ_LIB_libdaemon is not set
# FREETZ_LIB_libdevmapper is not set
# FREETZ_LIB_libelf is not set
# FREETZ_LIB_libevent is not set
# FREETZ_LIB_libffi is not set
FREETZ_LIB_libctlmgr=y
FREETZ_LIB_libctlmgr_WITH_STRUCT_V3=y
# FREETZ_LIB_libmultid is not set
# FREETZ_LIB_libltdl is not set
# FREETZ_LIB_liblua is not set
# FREETZ_LIB_libpopt is not set
# FREETZ_LIB_libprotobuf_c is not set
FREETZ_LIB_librrd=y
# FREETZ_LIB_librrd_th is not set
# FREETZ_LIB_libslang is not set
# FREETZ_LIB_libsynce is not set
# FREETZ_LIB_libsysfs is not set
# FREETZ_LIB_libwx_baseu is not set
# FREETZ_LIB_libyaml is not set
# Strip binaries, libs, modules and scripts
FREETZ_STRIP_BINARIES=y
# FREETZ_STRIP_LIBRARIES is not set
# FREETZ_STRIP_MODULES_NONE is not set
FREETZ_STRIP_MODULES_FREETZ=y
# FREETZ_STRIP_MODULES_ALL is not set
# FREETZ_STRIP_SCRIPTS is not set
# External
# EXTERNAL_ENABLED is not set
FREETZ_TARGET_ARCH_BE=y
FREETZ_TARGET_ARCH="mips"
FREETZ_TARGET_CROSS="mips-linux-uclibc-"
FREETZ_KERNEL_CROSS="mips-unknown-linux-gnu-"
# Toolchain options
FREETZ_DOWNLOAD_TOOLCHAIN=y
# FREETZ_BUILD_TOOLCHAIN is not set
# FREETZ_GCC_3_4_COMPILED_KERNEL is not set
FREETZ_GCC_4_6_COMPILED_KERNEL=y
# FREETZ_UCLIBC_0_9_28_BASED_BOX is not set
# FREETZ_UCLIBC_0_9_29_BASED_BOX is not set
FREETZ_UCLIBC_0_9_32_BASED_BOX=y
# Kernel toolchain options ----------------------------------
FREETZ_KERNEL_COMPILER_GCC_4_6=y
FREETZ_KERNEL_GCC_VERSION="4.6.3"
FREETZ_KERNEL_BINUTILS_VERSION="2.22"
# Target toolchain options ----------------------------------
FREETZ_TARGET_UCLIBC_VERSION_0_9_32=y
FREETZ_TARGET_COMPILER_GCC_4_6=y
FREETZ_STDCXXLIB_USE_UCLIBCXX=y
# FREETZ_STDCXXLIB_USE_GNULIBSTDCXX is not set
FREETZ_TARGET_UCLIBC_VERSION="0.9.32.1"
FREETZ_TARGET_GCC_VERSION="4.6.3"
FREETZ_GNULIBSTDCXX_VERSION="6.0.16"
FREETZ_STDCXXLIB="uclibcxx"
FREETZ_TARGET_BINUTILS_VERSION="2.22"
FREETZ_TARGET_UCLIBC_REF="mod"
FREETZ_TARGET_CFLAGS="-Os -W -Wall -pipe -Wa,--trap"
# FREETZ_TARGET_UCLIBC_REDUCED_LOCALE_SET is not set
# FREETZ_TARGET_NLS is not set
FREETZ_TARGET_LFS=y
# FREETZ_TARGET_TOOLCHAIN is not set
# Both kernel and target toolchain related options ----------
FREETZ_TOOLCHAIN_MINIMIZE_REQUIRED_GLIBC_VERSION=y
# FREETZ_TOOLCHAIN_32BIT is not set
# FREETZ_TOOLCHAIN_CCACHE is not set
Kann mir hier jemand helfen?
Über der Abbruchmeldung ist von /system/scripts die Rede. Das ist ein Ort auf meiner HDD wo ich selbst geschriebene Scripte sammel. Ist in der PATH Variable. Ich hab keine Ahnung warum das hier bei OpenSSL auftaucht.
Über der Abbruchmeldung ist von /system/scripts die Rede. ... Ist in der PATH Variable.
Kommt die Abbruchmeldung auch dann, wenn " /system/scripts" nicht in der PATH-Variable ist?
Hab folgendes gemacht:
ready@one:/home/ready/Apps/Freetz2$ export PATH=/data/root/home/ready/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
ready@one:/home/ready/Apps/Freetz2$ make openssl-precompiled
kommt zum selben Fehler. Kann aber jetzt nicht sicher sagen ob eine Subshell die PATH Variable nicht neu einliest.
Schau mal in der Datei "Makefile" aus dem source-Ordner für openssl in Freetz, nach ob dort etwas von "/system/scripts" eingetragen ist.
Nicht mehr nötig, ich habe das Problem gelöst.
Ich hatte in meiner bashrc die Variable SCRIPTS exportiert, mit dem Inhalt /system/scripts. Daran scheint sich Freetz irgendwie gestört zu haben.
Hab den export überschrieben mit "", schon gings. (Jedenfalls das OpenSSL kompilieren)
