so toolchain gebaut, die zlib und openssl als libs mit dem mod auch gebaut,
leider hab ich beim compeliren vom mac.c nen problem, hat einer ne idee?
openssh_fb_port/openssh-4.7p1$./configure --build=i386-linux-gnu --target=mipsel-linux --host=mipsel-linux --with-zlib=../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 --with-ssl-dir=../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e
OpenSSH has been configured with the following options:
User binaries: /usr/local/bin
System binaries: /usr/local/sbin
Configuration files: /usr/local/etc
Askpass program: /usr/local/libexec/ssh-askpass
Manual pages: /usr/local/share/man/manX
PID file: /var/run
Privilege separation chroot path: /var/empty
sshd default user PATH: /usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin
Manpage format: doc
PAM support: no
OSF SIA support: no
KerberosV support: no
SELinux support: no
Smartcard support: no
S/KEY support: no
TCP Wrappers support: no
MD5 password support: no
libedit support: no
Solaris process contract support: no
IP address in $DISPLAY hack: no
Translate v4 in v6 hack: yes
BSD Auth support: no
Random number source: OpenSSL internal ONLY
Host: mipsel-unknown-linux-gnu
Compiler: mipsel-linux-gcc
Compiler flags: -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99
Preprocessor flags: -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3
Linker flags: -L../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e -L../ds26-15.2_toolchain_tmp/source/zlib-1.2.3
Libraries: -lcrypto -lutil -lz -lcrypt -lresolv -lresolv
openssh-4.7p1$ make
conffile=`echo sshd_config.out | sed 's/.out$//'`; \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ./${conffile} > sshd_config.out
conffile=`echo ssh_config.out | sed 's/.out$//'`; \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ./${conffile} > ssh_config.out
conffile=`echo moduli.out | sed 's/.out$//'`; \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ./${conffile} > moduli.out
if test ! -z ""; then \
/usr/bin/perl ./fixprogs ssh_prng_cmds ; \
fi
if test "doc" = "cat"; then \
manpage=./`echo scp.1.out | sed 's/\.[1-9]\.out$/\.0/'`; \
else \
manpage=./`echo scp.1.out | sed 's/\.out$//'`; \
fi; \
if test "doc" = "man"; then \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} | gawk -f ./mdoc2man.awk > scp.1.out; \
else \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} > scp.1.out; \
fi
manpage=./`echo ssh-add.1.out | sed 's/\.[1-9]\.out$/\.0/'`; \
else \
manpage=./`echo ssh-add.1.out | sed 's/\.out$//'`; \
fi; \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} | gawk -f ./mdoc2man.awk > ssh-add.1.out; \
else \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} > ssh-add.1.out; \
fi
manpage=./`echo ssh-agent.1.out | sed 's/\.[1-9]\.out$/\.0/'`; \
else \
manpage=./`echo ssh-agent.1.out | sed 's/\.out$//'`; \
fi; \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} | gawk -f ./mdoc2man.awk > ssh-agent.1.out; \
else \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} > ssh-agent.1.out; \
fi
manpage=./`echo ssh-keygen.1.out | sed 's/\.[1-9]\.out$/\.0/'`; \
else \
manpage=./`echo ssh-keygen.1.out | sed 's/\.out$//'`; \
fi; \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} | gawk -f ./mdoc2man.awk > ssh-keygen.1.out; \
else \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} > ssh-keygen.1.out; \
fi
manpage=./`echo ssh-keyscan.1.out | sed 's/\.[1-9]\.out$/\.0/'`; \
else \
manpage=./`echo ssh-keyscan.1.out | sed 's/\.out$//'`; \
fi; \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} | gawk -f ./mdoc2man.awk > ssh-keyscan.1.out; \
else \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} > ssh-keyscan.1.out; \
fi
manpage=./`echo ssh.1.out | sed 's/\.[1-9]\.out$/\.0/'`; \
else \
manpage=./`echo ssh.1.out | sed 's/\.out$//'`; \
fi; \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} | gawk -f ./mdoc2man.awk > ssh.1.out; \
else \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} > ssh.1.out; \
fi
manpage=./`echo sshd.8.out | sed 's/\.[1-9]\.out$/\.0/'`; \
else \
manpage=./`echo sshd.8.out | sed 's/\.out$//'`; \
fi; \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} | gawk -f ./mdoc2man.awk > sshd.8.out; \
else \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} > sshd.8.out; \
fi
manpage=./`echo sftp-server.8.out | sed 's/\.[1-9]\.out$/\.0/'`; \
else \
manpage=./`echo sftp-server.8.out | sed 's/\.out$//'`; \
fi; \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} | gawk -f ./mdoc2man.awk > sftp-server.8.out; \
else \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} > sftp-server.8.out; \
fi
manpage=./`echo sftp.1.out | sed 's/\.[1-9]\.out$/\.0/'`; \
else \
manpage=./`echo sftp.1.out | sed 's/\.out$//'`; \
fi; \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} | gawk -f ./mdoc2man.awk > sftp.1.out; \
else \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} > sftp.1.out; \
fi
manpage=./`echo ssh-rand-helper.8.out | sed 's/\.[1-9]\.out$/\.0/'`; \
else \
manpage=./`echo ssh-rand-helper.8.out | sed 's/\.out$//'`; \
fi; \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} | gawk -f ./mdoc2man.awk > ssh-rand-helper.8.out; \
else \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} > ssh-rand-helper.8.out; \
fi
manpage=./`echo ssh-keysign.8.out | sed 's/\.[1-9]\.out$/\.0/'`; \
else \
manpage=./`echo ssh-keysign.8.out | sed 's/\.out$//'`; \
fi; \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} | gawk -f ./mdoc2man.awk > ssh-keysign.8.out; \
else \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} > ssh-keysign.8.out; \
fi
manpage=./`echo sshd_config.5.out | sed 's/\.[1-9]\.out$/\.0/'`; \
else \
manpage=./`echo sshd_config.5.out | sed 's/\.out$//'`; \
fi; \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} | gawk -f ./mdoc2man.awk > sshd_config.5.out; \
else \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} > sshd_config.5.out; \
fi
manpage=./`echo ssh_config.5.out | sed 's/\.[1-9]\.out$/\.0/'`; \
else \
manpage=./`echo ssh_config.5.out | sed 's/\.out$//'`; \
fi; \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} | gawk -f ./mdoc2man.awk > ssh_config.5.out; \
else \
/bin/sed -e 's|/etc/ssh/ssh_prng_cmds|/usr/local/etc/ssh_prng_cmds|g' -e 's|/etc/ssh/ssh_config|/usr/local/etc/ssh_config|g' -e 's|/etc/ssh/ssh_known_hosts|/usr/local/etc/ssh_known_hosts|g' -e 's|/etc/ssh/sshd_config|/usr/local/etc/sshd_config|g' -e 's|/usr/libexec|/usr/local/libexec|g' -e 's|/etc/shosts.equiv|/usr/local/etc/shosts.equiv|g' -e 's|/etc/ssh/ssh_host_key|/usr/local/etc/ssh_host_key|g' -e 's|/etc/ssh/ssh_host_dsa_key|/usr/local/etc/ssh_host_dsa_key|g' -e 's|/etc/ssh/ssh_host_rsa_key|/usr/local/etc/ssh_host_rsa_key|g' -e 's|/var/run/sshd.pid|/var/run/sshd.pid|g' -e 's|/etc/ssh/moduli|/usr/local/etc/moduli|g' -e 's|/etc/ssh/sshrc|/usr/local/etc/sshrc|g' -e 's|/usr/X11R6/bin/xauth|/usr/bin/xauth|g' -e 's|/var/empty|/var/empty|g' -e 's|/usr/bin:/bin:/usr/sbin:/sbin|/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin|g' ${manpage} > ssh_config.5.out; \
fi
(cd openbsd-compat && make)
make[1]: Betrete Verzeichnis '../openssh_fb_port/openssh-4.7p1/openbsd-compat'
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c bsd-arc4random.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c bsd-asprintf.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c bsd-closefrom.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c bsd-cray.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c bsd-cygwin_util.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c bsd-getpeereid.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c bsd-misc.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c bsd-nextstep.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c bsd-openpty.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c bsd-poll.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c bsd-snprintf.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c bsd-waitpid.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c fake-rfc2553.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c openssl-compat.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c xmmap.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c xcrypt.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c base64.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c basename.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c bindresvport.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c daemon.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c dirname.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c getcwd.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c getgrouplist.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c getopt.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c getrrsetbyname.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c glob.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c inet_aton.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c inet_ntoa.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c inet_ntop.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c mktemp.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c readpassphrase.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c realpath.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c rresvport.c
rresvport.c: In function 'rresvport_af':
rresvport.c:92: warning: implicit declaration of function 'close'
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c setenv.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c setproctitle.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c sha2.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c sigact.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c strlcat.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c strlcpy.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c strmode.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c strsep.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c strtonum.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c strtoll.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c strtoul.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c vis.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c port-aix.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c port-irix.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c port-linux.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c port-solaris.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c port-tun.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I.. -I. -I./.. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DHAVE_CONFIG_H -c port-uw.c
/usr/bin/ar rv libopenbsd-compat.a bsd-arc4random.o bsd-asprintf.o bsd-closefrom.o bsd-cray.o bsd-cygwin_util.o bsd-getpeereid.o bsd-misc.o bsd-nextstep.o bsd-openpty.o bsd-poll.o bsd-snprintf.o bsd-waitpid.o fake-rfc2553.o openssl-compat.o xmmap.o xcrypt.o base64.o basename.o bindresvport.o daemon.o dirname.o getcwd.o getgrouplist.o getopt.o getrrsetbyname.o glob.o inet_aton.o inet_ntoa.o inet_ntop.o mktemp.o readpassphrase.o realpath.o rresvport.o setenv.o setproctitle.o sha2.o sigact.o strlcat.o strlcpy.o strmode.o strsep.o strtonum.o strtoll.o strtoul.o vis.o port-aix.o port-irix.o port-linux.o port-solaris.o port-tun.o port-uw.o
/usr/bin/ar: creating libopenbsd-compat.a
a - bsd-arc4random.o
a - bsd-asprintf.o
a - bsd-closefrom.o
a - bsd-cray.o
a - bsd-cygwin_util.o
a - bsd-getpeereid.o
a - bsd-misc.o
a - bsd-nextstep.o
a - bsd-openpty.o
a - bsd-poll.o
a - bsd-snprintf.o
a - bsd-waitpid.o
a - fake-rfc2553.o
a - openssl-compat.o
a - xmmap.o
a - xcrypt.o
a - base64.o
a - basename.o
a - bindresvport.o
a - daemon.o
a - dirname.o
a - getcwd.o
a - getgrouplist.o
a - getopt.o
a - getrrsetbyname.o
a - glob.o
a - inet_aton.o
a - inet_ntoa.o
a - inet_ntop.o
a - mktemp.o
a - readpassphrase.o
a - realpath.o
a - rresvport.o
a - setenv.o
a - setproctitle.o
a - sha2.o
a - sigact.o
a - strlcat.o
a - strlcpy.o
a - strmode.o
a - strsep.o
a - strtonum.o
a - strtoll.o
a - strtoul.o
a - vis.o
a - port-aix.o
a - port-irix.o
a - port-linux.o
a - port-solaris.o
a - port-tun.o
a - port-uw.o
mipsel-linux-ranlib libopenbsd-compat.a
make[1]: Verlasse Verzeichnis '../openssh_fb_port/openssh-4.7p1/openbsd-compat'
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c acss.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c authfd.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c authfile.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c bufaux.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c bufbn.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c buffer.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c canohost.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c channels.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c cipher.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c cipher-acss.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c cipher-aes.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c cipher-bf1.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c cipher-ctr.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c cipher-3des1.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c cleanup.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c compat.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c compress.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c crc32.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c deattack.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c fatal.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c hostfile.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c log.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c match.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c md-sha256.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c moduli.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c nchan.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c packet.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c readpass.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c rsa.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c ttymodes.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c xmalloc.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c atomicio.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c key.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c dispatch.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c kex.c
mipsel-linux-gcc -g -O2 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -std=gnu99 -I. -I. -I../ds26-15.2_toolchain_tmp/source/openssl-0.9.8e/include -I../ds26-15.2_toolchain_tmp/source/zlib-1.2.3 -DSSHDIR=\"/usr/local/etc\" -D_PATH_SSH_PROGRAM=\"/usr/local/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/local/libexec/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/local/libexec/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/local/libexec/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/local/libexec/ssh-rand-helper\" -DHAVE_CONFIG_H -c mac.c
mac.c:62: error: 'EVP_ripemd160' undeclared here (not in a function)
mac.c: In function 'mac_compute':
mac.c:131: warning: format '%lu' expects type 'long unsigned int', but argument 3 has type 'unsigned int'
make: *** [mac.o] Fehler 1
openssh_fb_port/openssh-4.7p1$
