RedBoot> fis load zImage
RedBoot> exec
Using base address 0x00070000 and length 0x000f3a90
Uncompressing Linux................................................................. done, booting the kernel.
Linux version 2.6.31.6-pae (pette@PETTE64) (gcc version 4.4.2 (GCC) ) #1 Fri Nov 27 20:59:32 CET 2009
CPU: XScale-IXP42x Family [690541c1] revision 1 (ARMv5TE), cr=000039ff
CPU: VIVT data cache, VIVT instruction cache
Machine: Intel IXDPG425
Memory policy: ECC disabled, Data cache writeback
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: console=ttyS0,115200n8 console=ttyS0 rootfstype=squashfs root=/dev/mtdblock3
PID hash table entries: 256 (order: 8, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 62852KB available (1820K code, 123K data, 76K init, 0K highmem)
NR_IRQS:32
Console: colour dummy device 80x30
Calibrating delay loop... 527.56 BogoMIPS (lpj=2637824)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
IXP4xx: Using 16MiB expansion bus window size
PCI: IXP4xx is host
PCI: IXP4xx Using direct access for memory space
pci 0000:00:0c.0: PME# supported from D0 D1 D2 D3hot
pci 0000:00:0c.0: PME# disabled
pci 0000:00:0d.0: PME# supported from D0 D1 D2 D3hot
pci 0000:00:0d.0: PME# disabled
pci 0000:00:0e.0: PME# supported from D0 D1 D2 D3hot
pci 0000:00:0e.0: PME# disabled
pci 0000:00:0e.1: PME# supported from D0 D1 D2 D3hot
pci 0000:00:0e.1: PME# disabled
pci 0000:00:0e.2: PME# supported from D0 D1 D2 D3hot
pci 0000:00:0e.2: PME# disabled
PCI: bus0: Fast back to back transfers disabled
pci 0000:00:0c.0: dmabounce: registered device
pci 0000:00:0d.0: dmabounce: registered device
pci 0000:00:0e.0: dmabounce: registered device
pci 0000:00:0e.1: dmabounce: registered device
pci 0000:00:0e.2: dmabounce: registered device
bio: create slab <bio-0> at 0
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
IXP4xx Queue Manager initialized.
squashfs: version 4.0 (2009/01/31) Phillip Lougher
JFFS2 version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat, Inc.
msgmni has been set to 122
io scheduler noop registered
io scheduler deadline registered (default)
Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0xc8000000 (irq = 15) is a XScale
console [ttyS0] enabled
IXP4xx MII Bus: probed
eth0: MII PHY 1 on NPE-B
PHY 0:00 not found
ixp4xx_eth: probe of ixp4xx_eth.32 failed with error 1
IXP4XX-Flash.0: Found 1 x16 devices at 0x0 in 16-bit bank
IXP4XX-Flash.0: Found 1 x16 devices at 0x1000000 in 16-bit bank
Intel/Sharp Extended Query Table at 0x0031
Using buffer write method
cfi_cmdset_0001: Erase suspend on write enabled
Searching for RedBoot partition table in IXP4XX-Flash.0 at offset 0xfe0000
7 RedBoot partitions found on MTD device IXP4XX-Flash.0
Creating 7 MTD partitions on "IXP4XX-Flash.0":
0x000000000000-0x000000080000 : "RedBoot"
0x000000080000-0x0000000c0000 : "nvram"
0x0000000c0000-0x0000001c0000 : "zImage"
0x0000001c0000-0x000000ec0000 : "main-fs"
0x000000ec0000-0x000000fc0000 : "update-fs"
0x000000fc0000-0x000000fc1000 : "RedBoot config"
0x000000fe0000-0x000001000000 : "FIS directory"
Creating 2 MTD partitions on "IXP4XX-Flash.0":
0x000001000000-0x000001400000 : "spare1"
0x000001400000-0x000002000000 : "spare2"
TCP cubic registered
NET: Registered protocol family 17
XScale DSP coprocessor detected.
VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
Freeing init memory: 76K
init started: BusyBox v1.15.2 (2009-11-27 20:26:18 CET)
starting pid 217, tty '': '/bin/sh /etc/rc.S'
Mounting /proc /tmp /run /etc /dev/pts /proc/bus/usb
/etc/rc.S: line 5: can't create /proc/sys/kernel/panic: nonexistent directory
Copying files to readable /etc directory
starting pid 226, tty '': '/bin/run-parts -a start /etc/rc.d'
Loading LED Manager
Creating temporary directories ...
Mounting /opt
Mounting /mnt
root: Starting nvramd ...
Starting syslogd ...
Setting system variables...
Loading modules ...
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
PCI: enabling device 0000:00:0e.2 (0140 -> 0142)
ehci_hcd 0000:00:0e.2: EHCI Host Controller
ehci_hcd 0000:00:0e.2: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:0e.2: controller configured manually
ehci_hcd 0000:00:0e.2: Enabling legacy PCI PM
ehci_hcd 0000:00:0e.2: irq 23, io mem 0x48002200
ehci_hcd 0000:00:0e.2: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.31.6-pae ehci_hcd
usb usb1: SerialNumber: 0000:00:0e.2
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 5 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
PCI: enabling device 0000:00:0e.0 (0140 -> 0142)
ohci_hcd 0000:00:0e.0: OHCI Host Controller
ohci_hcd 0000:00:0e.0: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:0e.0: irq 23, io mem 0x48000000
usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: OHCI Host Controller
usb usb2: Manufacturer: Linux 2.6.31.6-pae ohci_hcd
usb usb2: SerialNumber: 0000:00:0e.0
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 3 ports detected
PCI: enabling device 0000:00:0e.1 (0140 -> 0142)
ohci_hcd 0000:00:0e.1: OHCI Host Controller
ohci_hcd 0000:00:0e.1: new USB bus registered, assigned bus number 3
ohci_hcd 0000:00:0e.1: irq 23, io mem 0x48001000
usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb3: Product: OHCI Host Controller
usb usb3: Manufacturer: Linux 2.6.31.6-pae ohci_hcd
usb usb3: SerialNumber: 0000:00:0e.1
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
usbcore: registered new interface driver usbserial
USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
USB Serial support registered for pl2303
usbcore: registered new interface driver pl2303
pl2303: Prolific PL2303 USB to serial adaptor driver
Board reset manager loaded
IXP4xx Watchdog Timer: heartbeat 10 sec
ip_tables: (C) 2000-2006 Netfilter Core Team
u32 classifier
Performance counters on
Actions configured
dahdi: Telephony Interface Registered on major 196
dahdi: Version: 2.2.0.2
dahdi_dummy: High Resolution Timer started, good to go
Modular ISDN core version 1.1.20
NET: Registered protocol family 34
DSP modul 2.0
mISDN_dsp: DSP clocks every 80 samples. This equals 1 jiffies.
PCI: enabling device 0000:00:0c.0 (0140 -> 0143)
mISDN_hfcpci: found adapter CCD/Billion/Asuscom 2BD0 at 0000:00:0c.0
mISDN: HFC-PCI driver 2.0
HFC-PCI: defined at mem 0xc498c000 fifo 0xffc08000(0x3408000) IRQ 24 HZ 100
HFC 1 cards installed
PCI: enabling device 0000:00:0d.0 (0140 -> 0143)
mISDN_hfcpci: found adapter CCD/Billion/Asuscom 2BD0 at 0000:00:0d.0
HFC-PCI: defined at mem 0xc4990100 fifo 0xffc10000(0x3410000) IRQ 24 HZ 100
HFC 2 cards installed
USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
PPP generic driver version 2.4.2
root: Starting watchdog ...
root: Starting board reset daemon
root: Configure network ...
net eth0: firmware: requesting NPE-B
NPE-B: firmware functionality 0x2, revision 0x2:1
eth0: link up, speed 100 Mb/s, full duplex
BusyBox v1.15.2 (2009-11-27 20:26:18 CET) multi-call binary
Usage: ip [OPTIONS] {address | route | link | } {COMMAND}
root: Starting firewall...
iptables: No chain/target/match by that name.
Setting time ...
1970-01-01 01:00:21.956712 Cannot send command via /var/run/rcmd/server: No such file or directory
root: Starting Linux Call Router ...
** LCR Version 1.6
ERROR (in main() line 265) Cannot open /etc/asterisk/chanlcr/options.conf
root: Creating asterisk directories ...
ln: /mnt/var/spool/asterisk/moh: File exists
chown: /mnt/var/spool/asterisk/moh: No such file or directory
chown: /etc/asterisk: No such file or directory
chmod: /etc/asterisk: No such file or directory
chown: /proc/hfc/alarm: No such file or directory
cat: can't open '/sys/devices/platform/hbx_dsp.0/initialized': No such file or directory
root: Starting asterisk ...
root: Starting httpd ...
root: Setting keys ...
nv-upload: set NVRAM variable http.ssl.cert (mhttpd-cert.der).
nv-upload: set NVRAM variable http.ssl.key (mhttpd-key.der).
nv-upload: set NVRAM variable http.ssl.dhparam (mhttpd-dhparam.der).
nv-upload: set NVRAM variable http.ssl.ctx_sid.1 (SSL session [0] context).
nv-upload: set NVRAM variable http.ssl.ctx_sid.2 (SSL session [1] context).
root: Starting mhttpd ...
Reading RSA Key...
Reading DSS Key...
Started Asterisk Event Logger
No 'modules.conf' found, no modules will be loaded.
Unable to open AMI configuration manager.conf. Asterisk management interface (AMI) disabled.
CDR simple logging enabled.
Starting dropbear ...
Could not load features.conf
root: Waiting for the master board to come up ...
root: Master board is not ready yet, waiting ...
root: Waining too long for the master board, resuming
Starting rcmdd in normal mode ...
Hotplug-Script: Clean up ...
Starting system test ...
/etc/rc.d/80_systest: line 21: /bin/test_app: not found
/etc/rc.d/80_systest: line 21: /usr/sbin/dsp_test: not found
nvram: no such variable: service.telnetd.active
nvram: no such variable: service.ftpd.active
root: Starting inetd server ...
System is ready ...
root: Starting crond ...
root: Starting dnsmasq server ...
root: Starting addons ...
Starting maintenance shell ...
BusyBox v1.15.2 (2009-11-27 20:26:18 CET) built-in shell (ash)
Enter 'help' for a list of built-in commands.
sh: can't access tty; job control turned off
