Speed-to-Fritz version: 25.08.09-multi
Phase 1: Download or check firmware images.
Phase 2: Unpack and extract files from images.
-- Unpacking FRITZ.Box_Fon_WLAN_7170.29.04.76.image to:
/home/jars/Desktop/speed-to-fritz/FBDIR
HW Feature Fritz_Box_7170
DECT: not detected
ISDN NT: detected
ISDN TE: detected
USB Port: 1.0 detected
a/b Ports: 3 Port(s)
eth Ports: 4 Port(s)
Phase 3: Copy sources.
7170/////////////////////////////////////////////////////////////////////////////
Phase 4: Apply changes.
-- Matching Versions: 04.76-0 - -
Replacing hardware related files of AVM firmware images ...
-- Applying Button for sending fonbook ...
-- Bugfix for home.js
-- Adding 'Info' button and display of mod related data ...
-- Make links...
-- Applying 'check signature' patch ...
-- Removing 'Tab0' from updatepage ...
-- Patching install webpages ...
Phase 9: Patch install.
Path: /home/jars/Desktop/speed-to-fritz/FBDIR
Phase 10: Pack and deliver.
Settings:
Script version : 25.08.09-multi
Firmware for update via GUI : fw__WV_.-_Fritz_Box_7170_29.04.76-0-sp2fr-09.08.25-r-498M_OEM-avm_annexB_de.image
Firmware for update via FTP : kernel.image
Output directory : /home/jars/Desktop/speed-to-fritz/Firmware.new
Branding set to : avm
AVM source is : Fritz_Box_7170
AVM source firmware mod is : 7170
Creating filesystem image, be patient ...
Merging kernel image
Test kernel size is OK
kernel image size: 7265280 (max: 7798784, free: 533504)
-- Approximately free time for the answering machine: 148s (2min 28s)
Generation of new 'kernel.image' completed successfully!
Packing ...
You may now use it in regular firmware upgrade process.
Or:
Continue with upload of new kernel.image to speedport via ftp ...
1. Login to 192.168.178.1 as adam2 (pw adam2)
2. Issue commands: bin, passiv, quote MEDIA FLSH
3. Transfer file: put kernel.image mtd1
4. Change branding: quote SETENV firmware_version avm
5. Change kernel_args: quote SETENV kernel_args annex=B
6. Reboot speedport: quote REBOOT
7. Exit ftp: quit
Or:
Use ./ftpXXX 'ENTER' to do the above, if you have a functional netconnection
on this LINUX System to your Speedport, no additional settings are needed.
All done .... Press 'ENTER' to return to the calling shell.
