Gigaset C470 IP / C475 IP / S675 IP / S685 IP - Firmware update 12/2010 (version 02227)
Improvements:
* New URL for profile and firmware update:
http://profile.gigaset.net/chagall/…
* PSTN: correct behavior for calls using access code with 2 or 3 digits
* VoIP: account specific MWI notification
* VoIP: improved early media support for outgoing wideband calls (handling of ALERTING)
* Fix for internal call from a wideband handset to a narrowband handset
* Display correct date for the last three days of the year.
* Web Configurator (Settings/Telephony/Audio): the Codec list for Gigaset.net is also displayed if no other VoIP accounts are configured.
* Web Configurator (Status/Device): MAC identifier for auto-configuration is shown additionally to MAC address.
* PBX Interoperability: Trixbox Pro - fix for incoming calls
* Australia: correct Daylight Saving Time is used.
