- Mitglied seit
- 1 Aug 2022
- Beiträge
- 2,223
- Punkte für Reaktionen
- 483
- Punkte
- 83
Improvements
- Bintec-elmeg DECT 210 systems can be extended with Gigaset N870 devices
- Bintec-elmeg DECT 160 systems can be extended with Gigaset N670 devices
- Bintec-elmeg DECT 210 and DECT 160 system can be extended with Gigaset PRO handsets: R700H / S700H / SL800H / R700H Protect (Other PRO handsets will be GAP)
- Secure Firmware update with client certificates will use the existing SHA1 factory client certificate, this was disabled in software 2.57
- Codec g729 - Info about Annex B
- Registration lost after SBC maintenance
- Web-interface: Display diversion header option on/off
- Remove unsecure WEB-UI Cipher Suites
- LDAP Provisioning Parameter: remove "ObjectClass"
- Configure scheduled reboots via provisioning
- Automatic firmware update
- Disable Web UI by provisioning without need for reboot
- DECT manager restarts on 'Anonymous' call - sip-control terminated !!
- No audio during calls - "Could not find MediaIdx" error
- Not able to make calls
- No reverse lookup in handset phone-book when Diversion header present
- Virtual integrators send packets to the (Unknown) IP address: 192.168.143.1
- When 1 of the TrunkName parameter in oper is empty, no trunks are created at all
- MQTT bsStatus response, does not contain the name
N870(E)/N670/N610 - Release 2.59.0 - Gigaset PRO - Public Wiki - Confluence
teamwork.gigaset.com
