When I compile against a 2.6.20 kernel i get '!' and '}' chars in my aod and dad fields. This is probably the reason why asterisk does not work.
With the 2.6.18.6 kernel i had no problems.
Does anyone know how to get rid of this. Is this a problem when compiling under utf-8?
Thanks,
phonenumbers are replaced by: 234567890
P[ 0] MGMT: Short status dinfo 1000001
P[ 0] MGMT: SSTATUS: L1_ACTIVATED
P[ 1] handle_frm: frm->addr:42000103 frm->prim:3f082
P[ 1] --> lib: NEW_CR Ind with l3id:20001 on this port.
P[ 1] --> new_process: New L3Id: 20001
P[ 1] handle_frm: frm->addr:42000103 frm->prim:30582
P[ 1] set_channel: bc->channel:0 channel:0
P[ 1] lib Got Prim: Addr 42000103 prim 30582 dinfo 20001
P[ 1] $$$ find_chan: No channel found for oad:!234567890p¡234567890} dad:¡203458804}
P[ 1] I IND :SETUP oad:!234567890p¡234567890} dad:¡234567890} pid:2 state:none
P[ 1] --> channel:0 mode:TE cause:16 ocause:16 rad: cad:
P[ 1] --> info_dad: onumplan:6 dnumplan:7 rnumplan: cpnnumplan:0
P[ 1] --> caps:Unknown Bearer pi:0 keypad: sending_complete:0
P[ 1] --> screen:0 --> pres:0
P[ 1] --> addr:0 l3id:20001 b_stid:0 layer_id:0
P[ 1] --> facility:Fac_None out_facility:Fac_None
P[ 1] --> urate:0 rate:16 mode:0 user1:0
P[ 1] --> bc:81967d8 h:0 sh:0
P[ 1] --> bc_state:BCHAN_CLEANED
Thanks,
