mISDN hängt sich auf nach ca. einem Tag
nprzybilla
20 Mai 2006
nach einem Tag hängt sich mein misdn auf.
IM dmesg steht das:
mISDN_rdata: rport queue overflow (after 500ms!) 256/256 [addr:52010201 prim:120282 dinfo:ffffffff]
Wennich dann probiere misdn neu zu starte passiert eine Kernel exception und ich muß "hart" resetten
Was könnte das sein ?
Hier meine configs:
/etc/misdn-init
HTML:
# Configuration file for your misdn hardware
# Usage: /usr/sbin/misdn-init start|stop|restart|config|scan|help
# Card Settings
# Syntax: card=<number>,<type>[,<option>...]
#    <number>   count your cards beginning with 1
#    <type>     either 0x1,0x4 or 0x8 for your hfcmulti hardware,
#               or the name of your card driver module.
#    <option>   ulaw       - uLaw (instead of aLaw)
#               dtmf       - enable DTMF detection on all B-channels
#               pcm_slave  - set PCM bus into slave mode
#                            If you have a set of cards, all wired via PCM. Set
#                            all cards into pcm_slave mode and leave one out.
#                            The left card will automatically be Master.
#               ignore_pcm_frameclock   - this can be set in conjunction with
#                                       pcm_slave. If this card has a
#                                       PCI Bus Position before the Position
#                                       of the Master, then this port cannot
#                                       yet receive a frameclock, so it must
#                                       ignore the pcm frameclock.
#               rxclock    - use clocking for pcm from ST Port
#               crystalclock - use clocking for pcm from PLL (genrated on board)
#               watchdog   - This dual E1 Board has a Watchdog for
#                            transparent mode
card=1,hfcpci
card=2,hfcpci
# Port settings
# Syntax: <port_type>=<port_number>[,<port_number>...]
#    <port_type>    te_ptp              - TE-Mode, PTP
#                   te_ptmp             - TE-Mode, PTMP
#                   te_capi_ptp         - TE-Mode (capi), PTP
#                   te_capi_ptmp        - TE-Mode (capi), PTMP
#                   nt_ptp              - NT-Mode, PTP
#                   nt_ptmp             - NT-Mode, PTMP
#    <port_number>  port that should be considered
te_ptmp=2
te_ptp=1
# Port Options
# Syntax: option=<port_number>,<option>[,<option>...]
#    <option>  master_clock  - use master clock for this S/T interface
#                              (only once per chip, only for HFC 8/4)
#              optical       - optical (only HFC-E1)
#              los           - report LOS (only HFC-E1)
#              ais           - report AIS (only HFC-E1)
#              slip          - report SLIP (only HFC-E1)
#              nocrc4        - turn off crc4 mode use double frame instead
#                               (only HFC-E1)
# The master_clock option is essential for retrieving and transmitting
# faxes to avoid failures during transmission. It tells the driver to
# synchronize the Card with the given Port which should be a TE Port and
# connected to the PSTN in general.
#option=1,master_clock
#option=2,ais,nocrc4
#option=3,optical,los,ais,slip
# General Options for your hfcmulti hardware
# poll=<number>
#        Only one poll value must be given for all cards.
#        Give the number of samples for each fifo process.
#        By default 128 is used. Decrease to reduce delay, increase to
#        reduce cpu load. If unsure, don't mess with it!!!
#        Valid is 32, 64, 128, 256.
# dsp_poll=<number>
#       This is the poll option which is used by mISDN_dsp, this might
#       differ from the one given by poll= for the hfc based cards, since
#       they can only use multiples of 32, the dsp_poll is dependant on
#       the kernel timer setting which can be found in the CPU section
#       in the kernel config. Defaults are there either 100Hz, 250Hz
#       or 1000Hz. If your setting is either 1000 or 250 it is compatible
#       with the poll option for the hfc chips, if you have 100 it is
#       different and you need here a multiple of 80.
#       The default is to have no dsp_poll option, then the dsp itself
#       finds out which option is the best to use by itself
# pcm=<number>
#        Give the id of the PCM bus. All PCM busses with the same ID
#        are expected to be connected and have equal slots.
#        Only one chip of the PCM bus must be master, the others slave.
# debug=<number>
#        Enable debugging (see hfc_multi.h for debug options).
# dsp_options=<number>
#       set this to 2 and you'll have software bridging instead of
#       hardware bridging.
# dtmfthreshold=<milliseconds>
#       Here you can tune the sensitivity of the dtmf tone recognizer.
# timer=<1|0>
#       set this to 1 if you want hfcmulti to register at ztdummy (zaptel)
#       and provide a 1khz timing source for it. This makes it possible
#       to have an accurate timing source for asterisk through zaptel from
#       hfcmulti to make applications like Meetme and faxing between wctdm
#       and hfcmulti work properly.
poll=128
dsp_poll=128
dsp_options=0
dtmfthreshold=100
debug=1
[root@ticket ~]# vi /etc/asterisk/misdn.conf
HTML:
; chan_misdn sample config
; general section:
; for debugging and general setup, things that are not bound to port groups
[general]
; Sets the Path to the misdn-init.conf (for nt_ptp mode checking)
misdn_init=/etc/misdn-init.conf
; set debugging flag:
;   0 - No Debug
;   1 - mISDN Messages and * - Messages, and * - State changes
;   2 - Messages + Message specific Informations (e.g. bearer capability)
;   3 - very Verbose, the above + lots of Driver specific infos
;   4 - even more Verbose than 3
; default value: 0
debug=3
; set debugging file and flags for mISDNuser (NT-Stack)
; flags can be or'ed with the following values:
; DBGM_NET        0x00000001
; DBGM_MSG        0x00000002
; DBGM_FSM        0x00000004
; DBGM_TEI        0x00000010
; DBGM_L2         0x00000020
; DBGM_L3         0x00000040
; DBGM_L3DATA     0x00000080
; DBGM_BC         0x00000100
; DBGM_TONE       0x00000200
; DBGM_BCDATA     0x00000400
; DBGM_MAN        0x00001000
; DBGM_APPL       0x00002000
; DBGM_ISDN       0x00004000
; DBGM_SOCK       0x00010000
; DBGM_CONN       0x00020000
; DBGM_CDATA      0x00040000
; DBGM_DDATA      0x00080000
; DBGM_SOUND      0x00100000
; DBGM_SDATA      0x00200000
; DBGM_TOPLEVEL   0x40000000
; DBGM_ALL        0xffffffff
ntdebugflags=0
ntdebugfile=/var/log/misdn-nt.log
; the big trace
; default value: [not set]
tracefile=/var/log/asterisk/misdn.log
; set to yes if you want mISDN_dsp to bridge the calls in HW
; default value: yes
bridging=no
; stops dialtone after getting first digit on nt Port
stop_tone_after_first_digit=yes
; whether to append overlapdialed Digits to Extension or not
append_digits2exten=yes
;;; CRYPTION STUFF
; Whether to look for dynamic crypting attempt
; default value: no
dynamic_crypt=no
; crypt_prefix, what is used for crypting Protocol
crypt_prefix=**
; Keys for cryption, you reference them in the dialplan
; later also in dynamic encr.
crypt_keys=test,muh
; users sections:
; name your sections as you which but not "general" !
; the sections are Groups, you can dial out in extensions.conf
; with Dial(mISDN/g:extern/101) where extern is a section name,
; chan_misdn tries every port in this section to find a
; new free channel
; The default section is not a group section, it just contains config elements
; which are inherited by group sections.
[default]
; define your default context here
; default value: default
context=from-pstn
; language
; default value: en
language=de
; sets the musiconhold class
musicclass=default
; Either if we should produce DTMF Tones ourselves
senddtmf=yes
; If we should generate Ringing for chan_sip and others
far_alerting=yes
; here you can define which bearers should be allowed
allowed_bearers=all
; Prefixes for national and international, those are put before the
; oad if an according dialplan is set by the other end.
; default values: nationalprefix      : 0
;                 internationalprefix : 00
nationalprefix=0
internationalprefix=00
; set rx/tx gains between -8 and 8 to change the RX/TX Gain
; default values: rxgain: 0
;                 txgain: 0
rxgain=0
txgain=2
; some telcos especially in NL seem to need this set to yes, also in
; switzerland this seems to be important
; default value: no
te_choose_channel=no
; This option defines, if chan_misdn should check the L1 on  a PMP
; before making a group call on it. The L1 may go down for PMP Ports
; so we might need this.
; But be aware! a broken or plugged off cable might be used for a group call
; as well, since chan_misdn has no chance to distinguish if the L1 is down
; because of a lost Link or because the Provider shut it down...
; default: no
pmp_l1_check=no
; in PMP this option defines which cause should be sent out to
; the 3. caller. chan_misdn does not support callwaiting on TE
; PMP side. This allows to modify the RELEASE_COMPLETE cause
; at least.
reject_cause=16
; Send Setup_Acknowledge on incoming calls anyway (instead of PROCEEDING),
; this requests additional Infos, so we can waitfordigits
; without much issues. This works only for PTP Ports
; default value: no
need_more_infos=no
; set this to yes if you want to disconnect calls when a timeout occurs
; for example during the overlapdial phase
nttimeout=no
; set the method to use for channel selection:
;   standard    - always choose the first free channel with the lowest number
;   round_robin - use the round robin algorithm to select a channel. use this
;                 if you want to balance your load.
; default value: standard
method=standard
; dialplan means Type Of Number in ISDN Terms (for outgoing calls)
; there are different types of the dialplan:
; dialplan -> outgoing Number
; localdialplan -> callerid
; cpndialplan -> connected party number
; dialplan options:
; 0 - unknown
; 1 - International
; 2 - National
; 4 - Subscriber
; This setting is used for outgoing calls
; default value: 0
dialplan=0
localdialplan=0
cpndialplan=0
; turn this to no if you don't mind correct handling of Progress Indicators
early_bconnect=yes
; turn this on if you like to send Tone Indications to a Incoming
; isdn channel on a TE Port. Rarely used, only if the Telco allows
; you to send indications by yourself, normally the Telco sends the
; indications to the remote party.
; default: no
incoming_early_audio=no
; uncomment the following to get into s extension at extension conf
; there you can use DigitTimeout if you can't or don't want to use
; isdn overlap dial.
; note: This will jump into the s exten for every exten!
; default value: no
;always_immediate=no
; set this to yes if you want to generate your own dialtone
; with always_immediate=yes, else chan_misdn generates the dialtone
; default value: no
nodialtone=no
; uncomment the following if you want callers which called exactly the
; base number (so no extension is set) jump to the s extension.
; if the user dials something more it jumps to the correct extension
; instead
; default value: no
;immediate=no
; uncomment the following to have hold and retrieve support
; default value: no
;hold_allowed=yes
; Pickup and Callgroup
; default values: not set = 0
;callgroup=1
;pickupgroup=1
; these are the exact isdn screening and presentation indicators
; if -1 is given for both values the presentation indicators are used
; from asterisks SetCallerPres application.
; s=0, p=0 -> callerid presented not screened
; s=1, p=1 -> callerid presented but screened (the remote end does not see it!)
; default values s=-1, p=-1
presentation=-1
screen=-1
; this enables echocancellation, with the given number of taps
; be aware, move this setting only to outgoing portgroups!
; A value of zero turns echocancellation off.
; possible values are: 0,32,64,128,256,yes(=128),no(=0)
; default value: no
;echocancel=no
; chan_misdns jitterbuffer, default 4000
jitterbuffer=4000
; change this threshold to enable dejitter functionality
jitterbuffer_upper_threshold=0
; change this to yes, if you want to bridge a mISDN data channel to
; another channel type or to an application.
hdlc=no
[intern]
; define your ports, e.g. 1,2 (depends on mISDN-driver loading order)
;ports=1,2
; context where to go to when incoming Call on one of the above ports
;context=Intern
[internPP]
; adding the postfix 'ptp' to a port number is obsolete now, chan_misdn
; parses /etc/misdn-init.conf and sets the ptp mode to the corresponding
; configs. For backwards compatibility you can still set ptp here.
;ports=3
[first_extern]
; again port defs
ports=1,2
; again a context for incoming calls
context=from-pstn
; msns for te ports, listen on those numbers on the above ports, and
; indicate the incoming calls to asterisk
; here you can give a comma separated list or simply an '*' for
; any msn.
msns=*
; here an example with given msns
;[second_extern]
;ports=5
;context=Extern2
;callerid=15
;msns=102,144,101,104
Beste Grüße
Niels
Welche Version von mISDN bzw. chan_misdn verwendest du denn?
Ich kann mich daran erinnern, dass es mal solch ein Problem in der mISDN Version 1.1.2 mit dem chan_misdn 0.3.1-rc30 gab.
Wuerde dir vorschlagen, das aktuelles mISDN von der Bernet Seite zu ziehen (misdn 1.1.5). Dort ist so viel ich weiss definitiv dieser bugfix von crich drinnen.
habe folgendes:
mISDN-1_1_5
chan: 0.3.1-rc34
jitterbuffer ist auf 4000 wie in der Anleitung angegeben.
Beste Grüße
Niels
Hallo nprzybilla,
das Problem kann ich bestätigen.
Ich verwende auch Asterisk 1.4, ISDN-1_1_5, chan 0.3.1-rc34 und habe bei einem Neustart des Servers hin und wieder den queue overflow Fehler.
Auch hatte ich schon mehrmals das Problem, das Asterisk keine Anrufe über iISDN angenommen hatte.
Die ISDN Kanaäe waren aber laut "misdn show stacks" verfügbar.
Bist Du mit dem Problem weitergekommen?
Sven
ja bin ich. Ich habe von Beronet eine neue Version bekommen.
Liegt wohl an FreePBX.
habe Die Version mal angehängt!
beste Grüße
Niels
  • chan_misdn-0.3.1-rc34d.tar.gz
Danke für den Tipp,
habe die Treiber aktuallisiert.
Sven
Hallo konabi,
hatte sich nach dem Treiber update dein Problem erledigt ?
Ich verwende die mISDN Channeltreiber die mit Asterisk 1.4 mit ausgeliefert werden und habe keine Probleme mehr mit mISDN.
mfG Sven
