Hi
while building 7390_10767, I noticed what seems to be the output of a syntax error in a patch files somewhere near the removal patch of print server or storage. The build succeeded anyway. So it is probably not critical.
Mind you, I never use the print server or storage part of Fritz, so if it is important, I would not discover it. The error may simply be in the removal of the Print server and USB storage, which I typically do:
removing AVM's printserver
rm -rf build/modified/filesystem/sbin/printserv
rm -rf build/modified/filesystem/etc/hotplug/udev-printer-lp
rm -rf build/modified/filesystem/lib/modules/2.6.28.10/kernel/drivers/usb/class/usblp.ko
patching rc.conf
patching build/modified/filesystem/etc/init.d/rc.conf
applying patch file ./patches/scripts/460-MAXDEVCOUNT.sh
patching create_handle.sh: MAXDEVCOUNT
patching build/modified/filesystem/etc/hotplug/create_handle.sh
applying patch file ./patches/scripts/480-alarmclock.sh
applying patch file ./patches/scripts/490-remove-ramzswap.sh
applying patch file ./patches/scripts/500-remove-mediasrv.sh
patching rc.conf
patching settings.lua
patching build/modified/filesystem/usr/www/all/storage/settings.lua
[B][COLOR="#800000"][B]sed: -e expression #1, char 1: unknown command: `-'[/B][/COLOR][/B]
remove mediasrv files
