Messagenet and pfeffer
kandy
19 Feb 2005
After installed the mod with iptables and thank you to pfeffer now you can use the FBF with messagenet.it.
This is the command.
iptables -t nat -A OUTPUT -p udp -d 212.97.59.76 --destination-port 5060 -j DNAT --to-destination 212.97.59.76:5061
Hi kandy,
did you try to configure the SIP server using a destination port? This has worked for me when trying it.
(like in 212.97.59.76:5061)
Enrik
Yes I tried to start voipd with the port 5061 without luck.
The fritz!Box used all the time the port 5060 to make the outgoing calls.
I am using in the same fritzbox others provider that they use the port 5060, probably this was the problem.
`voipd -P <port>' selects the source port, not destination port.
You have to enter "<ipaddress>:<destport>" in the "registrar" field of /var/flash/voip.conf. This works via the web interface, too.
Enrik
[/quote]
[/quote]
In this case use the port 5061 only for sip registration, doesn't work with a outgoing call.
Bye
the-duke
