Mac-Adresse der FRITZ!Box
xsapling
30 Jan 2005
wenn ich im ATA-Betrieb der Box im Punkt Zuganngsdaten die Mac unter dem Unterpunkt "Mac-Adresse der FRITZ!Box" ändere, dann passiert folgendes in der Kosole:
/var/mod/root # Sep  8 23:18:31 igdd[242]: check_noip_devices: new iface eth0 found or changed
Sep  8 23:18:31 igdd[242]: check_noip_devices: old iface eth0 discard or changed
Sep  8 23:18:31 multid[269]: setsockopt for 0.0.0.0 failed - No such file or directory (2)
Sep  8 23:18:31 multid[269]: mcroute_del: lan: del route: 172.30.1.1 -> 239.255.255.250 failed - No such file or directory (2)
Sep  8 23:18:31 multid[269]: setsockopt for 0.0.0.0 failed - Cannot assign requested address (126)
Sep  8 23:18:31 multid[269]: mrouter: dsl: can't del interface - Cannot assign requested address (126)
Sep  8 23:18:32 igdd[242]: stop_statistic_poll: no application!!!
Sep  8 23:18:32 dsld[1177]: stopped.
Sep  8 23:18:39 dsld[1197]: csock: using poll
Sep  8 23:18:40 dsld[1197]: avmssl_init: done
Sep  8 23:18:41 dsld[1197]: startup (Jul  6 2006 15:02:21)
Sep  8 23:18:41 multid[269]: eth0: SIOCGIFADDR - Cannot assign requested address (126)
Sep  8 23:18:41 dsld[1199]: DSL Mac 00:15:0c:c3:7a:77
Sep  8 23:18:41 dsld[1199]: VOIP Mac 00:15:0c:c3:6a:1a
Sep  8 23:18:41 dsld[1199]: speed 1184/160 (LAN)
Sep  8 23:18:41 dsld[1199]: showtime
Sep  8 23:18:41 dsld[1199]: verbose: DISABLED
Sep  8 23:18:42 multid[269]: br_del_if: del bridge eth0 failed - Invalid argument (22)
Sep  8 23:18:42 igdd[242]: check_noip_devices: new iface eth0 found or changed
Sep  8 23:18:42 igdd[242]: check_noip_devices: new iface eth1 found or changed
Sep  8 23:18:47 igdd[242]: check_noip_devices: new iface eth0 found or changed
Sep  8 23:18:47 igdd[242]: check_noip_devices: old iface eth0 discard or changed
Sep  8 23:18:52 igdd[242]: leave mcast group 239.255.255.250 at interface 172.30.1.1 for 0.0.0.0:1900 failed - Cannot assign requested address (126)
Sep  8 23:21:01 cltmgr[236]: 0.0.0.0:2101: POLLHUP
Meine Frage ist die: wie kann ich vorgenannte Funktion(Mac-Adresse der FRITZ!Box) nutzen, ohne das Webinterface dafür zu nutzen? D.h. ich möchte diese Funktion aus der Konsole heraus anstoßen können.
Weiß jemand, wie das geht?
Xsap
Wie Du hier sehen kannst, gibt es eine Option bei ifconfig, um die MAC-Adresse (HW Ether) zu setzen.
--gandalf.
