[Frage] Länge Voicemail
Ich hab mir jetzt mal die Datei vs-2021-08-06.7.log gezogen
Um 12:55 hab ich das mit der Voicemail getestet. Nach 13 Sekunden Aufnahme war wieder Schluß.
Das sind die Einträge dazu (7777 ist die allgemeine Nummer zur Voicemailbox und 331 meine Durchwahl):
riginalCalledNumber: 331 divertingNumber: 331 redirectingName: Kirschner, S.
[ 12:55:04.516232][DB][CMediaProcessingManager::OnIncomingCall ][3980385136]             -------------------------------------------------------------
[ 12:55:04.516239][DB][CMediaProcessingManager::OnIncomingCall ][3980385136]             calling:  called: 7777 Alerting: 331
[ 12:55:04.516282][DB][CMediaProcessingInterface::Reserved     ][3980385136]             Channel channel_01 is now Reserved: true
[ 12:55:04.516292][DB][CMPMEB::CreateApplication               ][3980385136]             Requested to create Application Voicemail
[ 12:55:04.516307][DB][CMediaProcessingManager::DumpCalls      ][3980385136]             ------------------------------------------------------------------------------------------
[ 12:55:04.516316][DB][CMediaProcessingManager::DumpCalls      ][3980385136]             Channel: channel_00 Application: None State: Idle MEB CallID: 1, CSTA CallID: -2147483647
[ 12:55:04.516326][DB][CMediaProcessingManager::DumpCalls      ][3980385136]             Channel: channel_01 Application: Voicemail State: Initialized MEB CallID: 80000051, CSTA CallID: 0
[ 12:55:04.516336][DB][CMediaProcessingManager::DumpCalls      ][3980385136]             ------------------------------------------------------------------------------------------
[ 12:55:04.516358][DB][CMediaProcessingManager::OnIncomingCall ][3980385136]             MEB channel 'channel_01' on (meb) callid '80000051'
[ 12:55:04.516396][DB][CMPMEB::OnIncomingCall                  ][3980385136]             MEB reports CSTA callid is: 35293
[ 12:55:04.516406][DB][CMediaProcessingInterface::SetChannelState][3980385136]             Channel channel_01 is now Ringing
[ 12:55:04.516416][DB][CMediaProcessingManager::DumpCalls      ][3980385136]             ------------------------------------------------------------------------------------------
[ 12:55:04.516425][DB][CMediaProcessingManager::DumpCalls      ][3980385136]             Channel: channel_00 Application: None State: Idle MEB CallID: 1, CSTA CallID: -2147483647
[ 12:55:04.516434][DB][CMediaProcessingManager::DumpCalls      ][3980385136]             Channel: channel_01 Application: Voicemail State: Ringing MEB CallID: 80000051, CSTA CallID: 35293
[ 12:55:04.516443][DB][CMediaProcessingManager::DumpCalls      ][3980385136]             ------------------------------------------------------------------------------------------
[ 12:55:04.516451][DB][CMPMEB::OnIncomingCall                  ][3980385136]             calling:  called: 7777
[ 12:55:04.516461][DB][CMPMEB::OnIncomingCall                  ][3980385136]             -------------------------------------------------------------
[ 12:55:04.516473][DB][CMPMEB::OnIncomingCall                  ][3980385136]             Diversion Information
[ 12:55:04.516483][DB][CMPMEB::OnIncomingCall                  ][3980385136]             Diversion Counter: 1
[ 12:55:04.516495][DB][CMPMEB::OnIncomingCall                  ][3980385136]             Diversion Reason: eDiversionReasonCFNR
[ 12:55:04.516521][DB][CMPMEB::OnIncomingCall                  ][3980385136]
originalCalledNumber: 331 divertingNumber: 331 redirectingName: Kirschner, S.
[ 12:55:04.516533][DB][CMPMEB::OnIncomingCall                  ][3980385136]             -------------------------------------------------------------
[ 12:55:04.516635][DB][CMPMEB::OnIncomingCall                  ][3980385136]             Creating VM call on MP channel channel_01
[ 12:55:04.516709][DB][CCall::LocalCallID                      ][3980385136]             csta call id from 0 -> 35293!
[ 12:55:04.516722][DB][CCall::Extension                        ][3980385136]             Call 35293 is now on extension '7777'
[ 12:55:04.516746][IN][CMPMEB::OnIncomingCall                  ][3980385136]             Creating new VoiceMail call (35293)
[ 12:55:04.516772][DB][CCallManager::RegisterNewCall           ][3980385136]             RegisterNewCall callid:33589725
[ 12:55:04.516787][DB][CCallManager::RegisterNewCall           ][3980385136]             current inbound fax call:0, outbound fax call:0
[ 12:55:04.516935][DB][CHVoiceMail::LoadVoicemailStructure     ][3980385136]                 Loaded VM Structure from file: '/var/system/vsl/conf/voicemail_structure.xml'
[ 12:55:04.516996][DB][CHVoiceMail::Initialize                 ][3980385136]                 this->activate() returned 0
[ 12:55:04.517024][DB][Siemens::MEBSend                        ][3980385136]                     Type: 358d
Interessant wäre der Zeitraum 12:55:15 bis 12:55:19. Also der Zeitpunkt des Gesprächsabbruchs. Im zitierten Log sieht man nur wie der Anruf (erfolgreich) auf die Voicemail geleitet wurde.
[ 12:55:14.750802][ER][CVSConnectionClient::process            ][4078885744]             dc (0xe6f4e330)
[ 12:55:15.005222][DB][CVSConnectionClient::Notify             ][4076784496]             Notify on Client (0xe650e0b0)
[ 12:55:15.005459][DB][CVSConnectionClient::handle_output      ][4068379504]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:15.007757][ER][CVSConnectionClient::process            ][4047502192]             dc (0xe650e0b0)
[ 12:55:15.020108][DB][CVSConnectionClient::Notify             ][4114606960]             Notify on Client (0xe6e7ecb8)
[ 12:55:15.020329][DB][CVSConnectionClient::handle_output      ][4057979760]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:15.028895][DB][CVSConnectionClient::Notify             ][4074683248]             Notify on Client (0xed9c6cd8)
[ 12:55:15.029082][DB][CVSConnectionClient::handle_output      ][4039097200]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:15.041463][ER][CVSConnectionClient::process            ][4091493232]             dc (0xe6e7ecb8)
[ 12:55:15.043676][ER][CVSConnectionClient::process            ][4015983472]             dc (0xed9c6cd8)
[ 12:55:15.110377][DB][CVSConnectionClient::Notify             ][4062182256]             Notify on Client (0xe7065918)
[ 12:55:15.110641][DB][CVSConnectionClient::handle_output      ][4070480752]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:15.173927][DB][CVSConnectionClient::Heartbeat          ][4112505712]             Heartbeat report for Client (0xe7065918) min: 007 ms max: 396 ms avg: 55.778104 ms std_dev: 65.512765 ms
[ 12:55:15.174005][ER][CVSConnectionClient::process            ][4112505712]             dc (0xe7065918)
[ 12:55:15.235358][DB][CVSConnectionClient::Notify             ][4104100720]             Notify on Client (0xe6a11c90)
[ 12:55:15.235679][DB][CVSConnectionClient::handle_output      ][4007578480]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:15.239407][ER][CVSConnectionClient::process            ][4024388464]             dc (0xe6a11c90)
[ 12:55:15.241824][DB][CVSConnectionClient::Notify             ][4020185968]             Notify on Client (0xf2233558)
[ 12:55:15.241995][DB][CVSConnectionClient::handle_output      ][4034894704]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:15.283166][ER][CVSConnectionClient::process            ][4106201968]             dc (0xf2233558)
[ 12:55:15.283685][DB][CVSConnectionClient::Notify             ][4007578480]             Notify on Client (0xe6513788)
[ 12:55:15.283874][DB][CVSConnectionClient::handle_output      ][4024388464]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:15.302898][ER][CVSConnectionClient::process            ][4078885744]             dc (0xe6513788)
[ 12:55:15.303776][DB][CVSConnectionClient::Notify             ][4072582000]             Notify on Client (0xe6a415f0)
[ 12:55:15.304002][DB][CVSConnectionClient::handle_output      ][4114606960]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:15.345085][DB][CVSConnectionClient::Heartbeat          ][4057979760]             Heartbeat report for Client (0xe6a415f0) min: 021 ms max: 398 ms avg: 25.991202 ms std_dev: 19.828762 ms
[ 12:55:15.345157][ER][CVSConnectionClient::process            ][4057979760]             dc (0xe6a415f0)
[ 12:55:15.418033][DB][CVSConnectionClient::Notify             ][4028590960]             Notify on Client (0xed995500)
[ 12:55:15.418253][DB][CVSConnectionClient::handle_output      ][4066278256]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:15.431028][DB][CVSConnectionClient::Heartbeat          ][4085189488]             Heartbeat report for Client (0xed995500) min: 008 ms max: 101 ms avg: 11.691105 ms std_dev: 7.298843 ms
[ 12:55:15.431091][ER][CVSConnectionClient::process            ][4085189488]             dc (0xed995500)
[ 12:55:15.604915][DB][CVSConnectionClient::Notify             ][4106201968]             Notify on Client (0x09ae3cf0)
[ 12:55:15.605170][DB][CVSConnectionClient::handle_output      ][4110404464]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:15.618116][DB][CVSConnectionClient::Heartbeat          ][4095695728]             Heartbeat report for Client (0x09ae3cf0) min: 011 ms max: 082 ms avg: 16.022483 ms std_dev: 4.591045 ms
[ 12:55:15.618211][ER][CVSConnectionClient::process            ][4095695728]             dc (0x09ae3cf0)
[ 12:55:15.760176][DB][CVSConnectionClient::Notify             ][4018084720]             Notify on Client (0xf568be88)
[ 12:55:15.760462][DB][CVSConnectionClient::handle_output      ][4011780976]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:15.761355][ER][CVSConnectionClient::process            ][4080986992]             dc (0xf568be88)
[ 12:55:15.874563][DB][CVSConnectionClient::Notify             ][4051676016]             Notify on Client (0xe705b580)
[ 12:55:15.874839][DB][CVSConnectionClient::handle_output      ][4099898224]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:15.893406][ER][CVSConnectionClient::process            ][4097796976]             dc (0xe705b580)
[ 12:55:16.187265][DB][CVSConnectionClient::Notify             ][4114606960]             Notify on Client (0xe6db9060)
[ 12:55:16.187522][DB][CVSConnectionClient::handle_output      ][4057979760]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:16.205167][DB][CVSConnectionClient::Heartbeat          ][4028590960]             Heartbeat report for Client (0xe6db9060) min: 015 ms max: 075 ms avg: 17.984360 ms std_dev: 4.442502 ms
[ 12:55:16.205232][ER][CVSConnectionClient::process            ][4028590960]             dc (0xe6db9060)
[ 12:55:16.322597][DB][CVSConnectionClient::Notify             ][4041198448]             Notify on Client (0x09a4fc30)
[ 12:55:16.322729][DB][CVSConnectionClient::handle_output      ][4022287216]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:16.324831][ER][CVSConnectionClient::process            ][4051676016]             dc (0x09a4fc30)
[ 12:55:16.345024][DB][CVSConnectionClient::Notify             ][4097796976]             Notify on Client (0xed98dce0)
[ 12:55:16.345167][DB][CVSConnectionClient::handle_output      ][4036995952]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:16.346190][ER][CVSConnectionClient::process            ][4013882224]             dc (0xed98dce0)
[ 12:55:16.362287][DB][CVSConnectionClient::Notify             ][4108303216]             Notify on Client (0xe6f86f18)
[ 12:55:16.362468][DB][CVSConnectionClient::handle_output      ][4062182256]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:16.364236][ER][CVSConnectionClient::process            ][4070480752]             dc (0xe6f86f18)
[ 12:55:16.399561][DB][CVSConnectionClient::Notify             ][4024388464]             Notify on Client (0xe6420340)
[ 12:55:16.399803][DB][CVSConnectionClient::handle_output      ][4089391984]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:16.401030][ER][CVSConnectionClient::process            ][4026489712]             dc (0xe6420340)
[ 12:55:16.425471][DB][CVSConnectionClient::Notify             ][4022287216]             Notify on Client (0xe6c9f3c0)
[ 12:55:16.425620][DB][CVSConnectionClient::handle_output      ][4051676016]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:16.454271][ER][CVSConnectionClient::process            ][4099898224]             dc (0xe6c9f3c0)
[ 12:55:16.484976][DB][CVSConnectionClient::Notify             ][4041198448]             Notify on Client (0x09a500b0)
[ 12:55:16.485374][DB][CVSConnectionClient::handle_output      ][4022287216]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:16.486095][ER][CVSConnectionClient::process            ][4051676016]             dc (0x09a500b0)
[ 12:55:16.546666][DB][CMediaProcessingInterface::SetChannelState][3971980144]         Channel channel_01 is now Idle
[ 12:55:16.546742][DB][CMediaProcessingManager::DumpCalls      ][3971980144]         ------------------------------------------------------------------------------------------
[ 12:55:16.546771][DB][CMediaProcessingManager::DumpCalls      ][3971980144]         Channel: channel_00 Application: None State: Idle MEB CallID: 1, CSTA CallID: -2147483647
[ 12:55:16.546807][DB][CMediaProcessingManager::DumpCalls      ][3971980144]         Channel: channel_01 Application: Voicemail State: Idle MEB CallID: 80000051, CSTA CallID: 35293
[ 12:55:16.546826][DB][CMediaProcessingManager::DumpCalls      ][3971980144]         ------------------------------------------------------------------------------------------
[ 12:55:16.547984][DB][CMPMEB::svc                             ][3971980144]         Received a 'Result' notification, current state = 5
[ 12:55:16.548020][DB][CMPMEB::svc                             ][3971980144]         Received a 5 result
[ 12:55:16.548035][DB][CMPMEB::svc                             ][3971980144]         GetDigits finished: Digits:
[ 12:55:16.549552][DB][CMPMEB::GetDigitsEx                     ][3831475056]                         Getting digits. fileName='/var/system/vsl/lang/de-de/prompts/caller-main-instructions-no-oper.wav, ', digitsMask='0123456789#', maxDigits='1', digitsTimeout='3', poundStops='false', starStops='false'
[ 12:55:16.549629][DB][CHVoicemail::MainMenu                   ][3831475056]                     Switching to MainMenu 2
[ 12:55:16.549658][DB][CHVoicemail::SubMenu                    ][3831475056]                     Switching to SubMenu 0
[ 12:55:16.549724][DB][CMPMEB::svc                             ][3971980144]         Received a 'GetDigits' notification, current state = 5
[ 12:55:16.549770][DB][CMediaProcessingInterface::SetChannelState][3971980144]         Channel channel_01 is now GettingDigits
[ 12:55:16.549806][DB][CMediaProcessingManager::DumpCalls      ][3971980144]         ------------------------------------------------------------------------------------------
[ 12:55:16.549838][DB][CMediaProcessingManager::DumpCalls      ][3971980144]         Channel: channel_00 Application: None State: Idle MEB CallID: 1, CSTA CallID: -2147483647
[ 12:55:16.549871][DB][CMediaProcessingManager::DumpCalls      ][3971980144]         Channel: channel_01 Application: Voicemail State: GettingDigits MEB CallID: 80000051, CSTA CallID: 35293
[ 12:55:16.549901][DB][CMediaProcessingManager::DumpCalls      ][3971980144]         ------------------------------------------------------------------------------------------
[ 12:55:16.719786][DB][CVSConnectionClient::Notify             ][4089391984]             Notify on Client (0x09a4ac50)
[ 12:55:16.720091][DB][CVSConnectionClient::handle_output      ][4026489712]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:16.720953][DB][CVSConnectionClient::Notify             ][4080986992]             Notify on Client (0x09b3e728)
[ 12:55:16.721124][DB][CVSConnectionClient::handle_output      ][4041198448]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:16.721662][DB][CVSConnectionClient::Heartbeat          ][4022287216]             Heartbeat report for Client (0x09a4ac50) min: 001 ms max: 066 ms avg: 2.375367 ms std_dev: 4.452624 ms
[ 12:55:16.721714][ER][CVSConnectionClient::process            ][4022287216]             dc (0x09a4ac50)
[ 12:55:16.734005][ER][CVSConnectionClient::process            ][4051676016]             dc (0x09b3e728)
[ 12:55:16.927007][DB][CVSConnectionClient::Notify             ][4099898224]             Notify on Client (0xe68dea00)
[ 12:55:16.927302][DB][CVSConnectionClient::handle_output      ][4097796976]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:16.939759][ER][CVSConnectionClient::process            ][4036995952]             dc (0xe68dea00)
[ 12:55:16.955995][DB][CVSConnectionClient::Notify             ][4013882224]             Notify on Client (0xe6527370)
[ 12:55:16.956178][DB][CVSConnectionClient::handle_output      ][4108303216]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:16.975586][ER][CVSConnectionClient::process            ][4062182256]             dc (0xe6527370)
[ 12:55:17.062927][DB][CVSConnectionClient::Notify             ][4076784496]             Notify on Client (0xe6c94e18)
[ 12:55:17.063142][DB][CVSConnectionClient::handle_output      ][4068379504]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:17.066166][DB][CVSConnectionClient::Heartbeat          ][4047502192]             Heartbeat report for Client (0xe6c94e18) min: 001 ms max: 340 ms avg: 4.087963 ms std_dev: 23.046584 ms
[ 12:55:17.066225][ER][CVSConnectionClient::process            ][4047502192]             dc (0xe6c94e18)
[ 12:55:17.076017][DB][CVSConnectionClient::Notify             ][4072582000]             Notify on Client (0xe65073e8)
[ 12:55:17.076228][DB][CVSConnectionClient::handle_output      ][4114606960]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:17.077231][ER][CVSConnectionClient::process            ][4057979760]             dc (0xe65073e8)
[ 12:55:17.235802][DB][CVSConnectionClient::Notify             ][4060081008]             Notify on Client (0xe6ab63b0)
[ 12:55:17.236060][DB][CVSConnectionClient::handle_output      ][4032793456]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:17.236725][ER][CVSConnectionClient::process            ][4055878512]             dc (0xe6ab63b0)
[ 12:55:17.390181][DB][CVSConnectionClient::Notify             ][4085189488]             Notify on Client (0x09b0ea38)
[ 12:55:17.390654][DB][CVSConnectionClient::handle_output      ][4106201968]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:17.560306][DB][CVSConnectionClient::Notify             ][4108303216]             Notify on Client (0xe6de1708)
[ 12:55:17.560530][DB][CVSConnectionClient::handle_output      ][4062182256]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:17.578211][ER][CVSConnectionClient::process            ][4070480752]             dc (0xe6de1708)
[ 12:55:17.786409][DB][CVSConnectionClient::Notify             ][4053777264]             Notify on Client (0xe6c99470)
[ 12:55:17.786698][DB][CVSConnectionClient::handle_output      ][4076784496]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:17.802975][ER][CVSConnectionClient::process            ][4068379504]             dc (0xe6c99470)
[ 12:55:17.949148][DB][CVSConnectionClient::Notify             ][4047502192]             Notify on Client (0x09ae97b8)
[ 12:55:17.949412][DB][CVSConnectionClient::handle_output      ][4045400944]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:17.951662][DB][CVSConnectionClient::Heartbeat          ][4083088240]             Heartbeat report for Client (0x09ae97b8) min: 001 ms max: 040 ms avg: 2.031281 ms std_dev: 2.933109 ms
[ 12:55:17.951723][ER][CVSConnectionClient::process            ][4083088240]             dc (0x09ae97b8)
[ 12:55:18.169637][DB][CVSConnectionClient::Notify             ][4053777264]             Notify on Client (0xe6d6e9b0)
[ 12:55:18.169930][DB][CVSConnectionClient::handle_output      ][4076784496]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:18.170401][ER][CVSConnectionClient::process            ][4068379504]             dc (0xe6d6e9b0)
[ 12:55:18.270598][DB][CVSConnectionClient::Notify             ][4047502192]             Notify on Client (0xe6a14940)
[ 12:55:18.270826][DB][CVSConnectionClient::handle_output      ][4045400944]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:18.280499][ER][CVSConnectionClient::process            ][4083088240]             dc (0xe6a14940)
[ 12:55:18.365054][DB][CVSConnectionClient::Notify             ][4022287216]             Notify on Client (0xe6da4668)
[ 12:55:18.365303][DB][CVSConnectionClient::handle_output      ][4051676016]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:18.367615][ER][CVSConnectionClient::process            ][4099898224]             dc (0xe6da4668)
[ 12:55:18.375662][DB][CVSConnectionClient::Notify             ][4080986992]             Notify on Client (0xe6cab6b0)
[ 12:55:18.375903][DB][CVSConnectionClient::handle_output      ][4041198448]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:18.376489][DB][CVSConnectionClient::Heartbeat          ][4022287216]             Heartbeat report for Client (0xe6cab6b0) min: 001 ms max: 039 ms avg: 1.783333 ms std_dev: 3.619814 ms
[ 12:55:18.376553][ER][CVSConnectionClient::process            ][4022287216]             dc (0xe6cab6b0)
[ 12:55:18.644590][DB][CVSConnectionClient::Notify             ][4047502192]             Notify on Client (0xe6ea7c38)
[ 12:55:18.644828][DB][CVSConnectionClient::handle_output      ][4045400944]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:18.679126][ER][CVSConnectionClient::process            ][4083088240]             dc (0x09b0ea38)
[ 12:55:18.862693][ER][CVSConnectionClient::process            ][4074683248]             dc (0xe6ea7c38)
[ 12:55:19.092830][DB][Main                                    ][4137060080] total allocated space: 7172584 (Diff +9704)
    non-mmapped space allocated from system: 8396800
    number of free chunks: 96
    number of fastbin blocks: 2
    number of mmapped regions: 0
    space in mmapped regions: 0
    maximum total allocated space: 0
    space available in freed fastbin blocks: 88
    total free space: 1224216
[ 12:55:19.092930][NT][ObjectTracker                           ][4137060080] ---------------------------------------------------------
[ 12:55:19.092962][NT][ObjectTracker                           ][4137060080] CUserConversation                274
[ 12:55:19.092981][NT][ObjectTracker                           ][4137060080] CUserConversationCache           110
[ 12:55:19.093012][NT][ObjectTracker                           ][4137060080] CUser                            110
[ 12:55:19.093032][NT][ObjectTracker                           ][4137060080] CMPResult                        60
[ 12:55:19.093051][NT][ObjectTracker                           ][4137060080] CClientConnection                39
[ 12:55:19.093076][NT][ObjectTracker                           ][4137060080] CMediaProcessingInterface        30
[ 12:55:19.093099][NT][ObjectTracker                           ][4137060080] CUserCallHistory                 4
[ 12:55:19.093118][NT][ObjectTracker                           ][4137060080] CUserConnection                  3
[ 12:55:19.093136][NT][ObjectTracker                           ][4137060080] CInternationalization            2
[ 12:55:19.093153][NT][ObjectTracker                           ][4137060080] MediaProcessingInterfaceMEBState 1
[ 12:55:19.093210][NT][ObjectTracker                           ][4137060080] CUserVoiceMailMessage            1
[ 12:55:19.093239][NT][ObjectTracker                           ][4137060080] CUserVMProfile                   1
[ 12:55:19.101103][DB][CVSConnectionClient::Notify             ][4039097200]             Notify on Client (0xe6a15158)
[ 12:55:19.101328][DB][CVSConnectionClient::handle_output      ][4091493232]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:19.202330][DB][CVSConnectionClient::Notify             ][4018084720]             Notify on Client (0xe7098378)
[ 12:55:19.202540][DB][CVSConnectionClient::handle_output      ][4011780976]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:19.233450][ER][CVSConnectionClient::process            ][4080986992]             dc (0xe7098378)
[ 12:55:19.239637][DB][Siemens::handle_input                   ][3982486384]             Data received: 26 80 2B A1 29 02 02 57 7E 02 01 33 30 20 E1 1E 06 06 2B 0C 02 88 53 0F 04 14 1A 04 06 C4 22 04 02 01 B8 06 00 06 08 15 B9 06 00 0C 37 13
[ 12:55:19.239837][DB][Siemens::OnRequest_Escape               ][3982486384]             Hearbeat received.
[ 12:55:19.270498][ER][CVSConnectionClient::process            ][4041198448]             dc (0xe6a15158)
[ 12:55:19.616230][DB][CVSConnectionClient::Notify             ][4047502192]             Notify on Client (0xe70605f8)
[ 12:55:19.616474][DB][CVSConnectionClient::handle_output      ][4045400944]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:19.634976][ER][CVSConnectionClient::process            ][4083088240]             dc (0xe70605f8)
[ 12:55:19.749732][DB][CVSConnectionClient::Notify             ][4024388464]             Notify on Client (0xe6f4e330)
[ 12:55:19.749938][DB][CVSConnectionClient::handle_output      ][4089391984]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:19.750662][ER][CVSConnectionClient::process            ][4093594480]             dc (0xe6f4e330)
[ 12:55:20.005214][DB][CVSConnectionClient::Notify             ][4034894704]             Notify on Client (0xe650e0b0)
[ 12:55:20.005500][DB][CVSConnectionClient::handle_output      ][4072582000]             Removing WRITE_MASK, 1 notifications sent.
[ 12:55:20.008052][DB][CVSConnectionClient::Heartbeat          ][4114606960]             Heartbeat report for Client (0xe650e0b0) min: 000 ms max: 041 ms avg: 2.014663 ms std_dev: 2.002633 ms
[CODE] TAG [/CODE] gesetzt
Mich wundert, dass das Problem hier noch besteht, es sollte bereits seit V2R5 FR1 - 1st EEQS (V2 R5.1.0_013) gelöst sein.:
Incident Ticket: NA15830388 NA15953157 NA15930256
Problem Ticket: NA15922762 NA15969129 NA15930353
Telekom Testcenter QC-1396: Problem with Voicemail and RTP supervision
Das Problem war/ist hier, dass die Unify bei der Voicemail-Annahme kein RTP und RTCP aussendet und dann die RTP supervision im Mobilfunknetz/VoLTE-Netz der Telekom den Ruf auslöst. Mit V2 R5.1.0_013 wurde das Verhalten eigentlich angepasst und sollte nicht mehr auftreten.
Tritt das Problem auch auf, wenn der Anrufer im 2G-Netz ist?
Wie bitte soll ich denn einen 2G Anruf initieren? Hat doch keiner mehr...
Von intern nach intern (Unify IP Telefon) geht es problemlos, hab ich gerade mit einer Voicemail >30 Sekunden getestet.
ich glaube hier verwechselst Du was. 3G ist/wurde abgeschaltet. Für 2G mußt Du nur die "Datendienste" im Smartphone ausschalten.
Gruß S
;) ok.
Hab ich getestet, die Aufnahme wird nach wie vor nach 13 Sekunden beendet.
Hier das Trace dazu
[ 08:05:17.491477][DB][Siemens::CMEBEvents::OnMessage          ][3980385136]         Message: 530
[ 08:05:17.491519][DB][CSISMEBForwarder_OnMessage              ][3980385136]             Received 530 message type!
[ 08:05:17.491528][DB][CSISMEBForwarder_OnMessage              ][3980385136]             Unhandled Incoming Message, type 530
[ 08:05:17.567940][DB][Siemens::CMEBEvents::OnMessage          ][3980385136]         Message: 1020
[ 08:05:17.567967][DB][CSISMEBForwarder_OnMessage              ][3980385136]             Received 1020 message type!
[ 08:05:17.567974][DB][CMediaProcessingManager::OnConnected    ][3980385136]             callid '800000d3'
[ 08:05:17.568017][DB][CMPMEB::OnConnected                     ][3980385136]             MEB reports CSTA callid is: 35947
[ 08:05:17.568035][DB][CMPMEB::OnConnected                     ][3980385136]             calling:  called: 7777 established:  answering:
[ 08:05:17.574015][DB][Siemens::handle_input                   ][3982486384]             Data received: 26 80 79 A1 77 02 02 0D B1 02 01 15 30 6E 55 02 03 01 A0 68 A6 66 6B 11 30 0F 80 04 00 00 8C 6B A1 07 30 05 80 03 33 33 31 63 07 30 05 80 03 33 33 31 63 08 30 06 80 04 37 37 37 37 64 02 87 00 4E 01 03 0A 01 08 67 02 87 00 68 12 30 10 A3 0E 81 0C 34 39 38 39 37 34 35 37 39 33 33 31 65 08 30 06 80 04 37 38 38 35 7E 12 A0 10 18 0E 32 30 32 31 30 38 31 30 30 38 30 35 31 37
[ 08:05:17.574221][DB][CallsCollection::OnSwitchCallDiverted   ][3982486384]                 NetworkCallingDevice: , NetworkCalledDevice: 498974579331
[ 08:05:17.574361][DB][CCallManager::OnCallDiverted            ][3982486384]                     Call Diverted. MonitorID = 769, MonitorDeviceID = 7885, Timestamp = 20210810080517, InvokeID = 3505, DivertedConnection.ConnectionID = 35947, DivertedConnection.DeviceID = 331, DivertingDevice = N331, DestinationDevice = N7777, EventCause = CALLFORWARDNOANSWER
[ 08:05:17.574514][DB][CMonitorMap::ConnectionState            ][3982486384]                     Extension 7885 changing Connection State. Previous : 'Ringing', New: 'Diverted'
[ 08:05:17.574811][DB][CCall::Extension                        ][3982486384]                     Call 35947 is now on extension '7777'
[ 08:05:17.574843][DB][CCallHandler::Notify                    ][3982486384]                         Notify started!
[ 08:05:17.574860][DB][CCallHandler::Notify                    ][3982486384]                         Notify finished!
[ 08:05:17.607439][DB][Siemens::handle_input                   ][3982486384]             Data received: 26 80 79 A1 77 02 02 0D B0 02 01 15 30 6E 55 02 48 00 A0 68 A6 66 6B 11 30 0F 80 04 00 00 8C 6B A1 07 30 05 80 03 33 33 31 63 07 30 05 80 03 33 33 31 63 08 30 06 80 04 37 37 37 37 64 02 87 00 4E 01 00 0A 01 08 67 02 87 00 68 12 30 10 A3 0E 81 0C 34 39 38 39 37 34 35 37 39 33 33 31 65 08 30 06 80 04 37 38 38 35 7E 12 A0 10 18 0E 32 30 32 31 30 38 31 30 30 38 30 35 31 37
[ 08:05:17.607734][DB][CallsCollection::OnSwitchCallDiverted   ][3982486384]                 NetworkCallingDevice: , NetworkCalledDevice: 498974579331
[ 08:05:17.607858][DB][CallsCollection::Device::StateShiftConnection][3982486384]                     Device 331[(35947 / 331: NullState)]: Alerting => NullState
[ 08:05:17.607983][DB][CallsCollection::Device::RemoveConnection][3982486384]                     Device 331: Connections ()
[ 08:05:17.608014][DB][CallsCollection::Call::RemoveDeviceOnCall][3982486384]                 Call dd77030c-f9a0-11eb-c000-0050569b6388-3982486384-21407(35947): Removed 331, Devices (7885)
[ 08:05:17.608311][DB][CCallManager::OnCallDiverted            ][3982486384]                     Call Diverted. MonitorID = 18432, MonitorDeviceID = 331, Timestamp = 20210810080517, InvokeID = 3504, DivertedConnection.ConnectionID = 35947, DivertedConnection.DeviceID = 331, DivertingDevice = N331, DestinationDevice = N7777, EventCause = CALLFORWARDNOANSWER
[ 08:05:17.608407][DB][CMonitorMap::ConnectionState            ][3982486384]                     Extension 331 changing Connection State. Previous : 'Ringing', New: 'Diverted'
[ 08:05:17.608859][DB][CCall::Extension                        ][3982486384]                     Call 35947 is now on extension '7777'
[ 08:05:17.608930][DB][CCallHandler::Notify                    ][3982486384]                         Notify started!
[ 08:05:17.608955][DB][CCallHandler::Notify                    ][3982486384]                         Notify finished!
[ 08:05:17.610142][DB][CUser::OnCallDiverted                   ][3978283888]         for user:331
[ 08:05:17.610174][DB][CUser::OnCallDiverted                   ][3978283888]         User extension '331' changing ConnectionState to Terminated because it was Diverted (CallID = 35947), and cause:8, new dest:7777
[ 08:05:17.610236][DB][CUser::OnCallDiverted                   ][3978283888]         tmp:7777
[ 08:05:17.611685][DB][CUser::OnCallDiverted                   ][3978283888]         Call to vm diverted
[ 08:05:17.611765][DB][CUser::ResolveParamContact              ][3978283888]                 number to search '', type:3
[ 08:05:17.614189][DB][CVSDatabase::update_call_history        ][3978283888]                 check existing: select ch_local_id :#1<int>from tblcallhistory where ch_local_id = 35947 AND ch_start_time>='2021-08-10 08:00:00' AND ch_user_id=351
[ 08:05:17.639830][DB][CVSDatabase::update_call_history        ][3978283888]                 insert into tblcallhistory (ch_call_id, ch_switch_id, ch_local_id, ch_user_id, ch_calling_number, ch_called_number, ch_direction, ch_internal_external, ch_start_time, ch_end_time, ch_talk_time_seconds, ch_contact_cache_id, ch_conversation_id, ch_cc_call_id,ch_call_attribute,ch_attribute_param,ch_attribute_param_contact_cache) values (740050, 2, 35947, 351, '', 'N331', 0, 1, '2021-08-10 08:04:47', '2021-08-10 08:05:17', 0, 0, 0, 0,1,'',0);
[ 08:05:17.641860][DB][VSNQ::N                                 ][3978283888]                 qn 1:0x09b3e6d8
[ 08:05:17.641887][DB][VSNQ::N                                 ][3978283888]                 qn 2:0x09b3e6d8
[ 08:05:17.641901][DB][VSNotificationQueue::dtor               ][3978283888]             Flushing Queue...
[ 08:05:17.641928][DB][CVSConnectionClient::Notify             ][3978283888]                 Notify on Client (0xe67ffb10)
[ 08:05:17.641967][DB][VSNotificationQueue::dtor               ][3978283888]             Queue Empty.
[ 08:05:17.641998][DB][CVSConnectionClient::Notify             ][3978283888]             Notify on Client (0xe67ffb10)
[ 08:05:17.642032][DB][CUser::PrintCurrentConnections          ][3978283888]         User Connections:
Extension = 331, Current Connections = 0, Current State = Terminated
[ 08:05:42.600283][DB][CMediaProcessingManager::DumpCalls      ][3971980144]         ------------------------------------------------------------------------------------------
[ 08:05:42.600314][DB][CMediaProcessingManager::DumpCalls      ][3971980144]         Channel: channel_00 Application: None State: Idle MEB CallID: 1, CSTA CallID: -2147483647
[ 08:05:42.600341][DB][CMediaProcessingManager::DumpCalls      ][3971980144]         Channel: channel_01 Application: Voicemail State: Idle MEB CallID: 800000d3, CSTA CallID: 35947
[ 08:05:42.600364][DB][CMediaProcessingManager::DumpCalls      ][3971980144]         ------------------------------------------------------------------------------------------
[ 08:05:42.625830][DB][CMPMEB::svc                             ][3971980144]         Received a 'Result' notification, current state = 5
[ 08:05:42.625899][DB][CMPMEB::svc                             ][3971980144]         Received a 3 result
[ 08:05:42.640994][DB][CMPMEB::Record                          ][3862952816]                         Recording file '/var/system/vsl/audio/voicemail/mailboxes/00000351/messages/fe96b906-f9a0-11eb-c000-0050569b6388-3862952816-21407'
[ 08:05:42.641082][DB][CHVoicemail::SubMenu                    ][3862952816]                     Switching to SubMenu 2
[ 08:05:42.641163][DB][CMPMEB::svc                             ][3971980144]         Received a 'Record' notification, current state = 5
[ 08:05:42.641194][DB][CMediaProcessingInterface::SetChannelState][3971980144]         Channel channel_01 is now Recording
[ 08:05:42.641226][DB][CMediaProcessingManager::DumpCalls      ][3971980144]         ------------------------------------------------------------------------------------------
[ 08:05:42.641251][DB][CMediaProcessingManager::DumpCalls      ][3971980144]         Channel: channel_00 Application: None State: Idle MEB CallID: 1, CSTA CallID: -2147483647
[ 08:05:42.641285][DB][CMediaProcessingManager::DumpCalls      ][3971980144]         Channel: channel_01 Application: Voicemail State: Recording MEB CallID: 800000d3, CSTA CallID: 35947
[ 08:05:42.641311][DB][CMediaProcessingManager::DumpCalls      ][3971980144]         ------------------------------------------------------------------------------------------
[ 08:05:42.651214][DB][CUser::NotifyAMState                    ][3862952816]                     Notifying state 'Recording' to user '331'
[ 08:05:42.651297][DB][VSNQ::N                                 ][3862952816]                     qn 1:0xe6fda1e8
[ 08:05:42.651325][DB][VSNQ::N                                 ][3862952816]                     qn 2:0xe6fda1e8
[ 08:05:42.651349][DB][VSNotificationQueue::dtor               ][3862952816]                     Flushing Queue...
[ 08:05:42.651411][DB][CVSConnectionClient::Notify             ][3862952816]                         Notify on Client (0xe67ffb10)
[ 08:05:42.651470][DB][VSNotificationQueue::dtor               ][3862952816]                     Queue Empty.
Hat vielleicht jemand ne Ahnung oder nen kleinen Hinweis in welche Richtung ich hier weiterkomme?
oli50
