Kurzwahl funktioniert nicht?
akw
17 Dez 2004
Hallo!
Ich habe folgendes Problem.
Ich habe ein T-Sinus 701S ISDN Dect Telefon am S0-Bus der FRITZ!Box 7050 (Firmware 14.03.61)angeschlossen.
Ich würde gerne die Kurzwahl-Funktion der Fritz!Box nutzen.
Allerdings scheinen die Sonderzeichen * und # nicht korrekt übertragen zu werden.
Hier das Protokoll nach der Wahl von **701#
May 14 13:09:26 voipd[422]: incoming(5:appl=2 plci=0x405 ncci=0x0 incoming): 10 49441701 <- 0
May 14 13:09:26 voipd[422]: allowed bandwidth 144000 for sip:[email protected]
May 14 13:09:26 voipd[422]: >>> Request: INVITE sip:[email protected]
May 14 13:09:26 voipd[422]: dns: sip.1und1.de: query
May 14 13:09:26 voipd[422]: dns: sip.1und1.de: 212.227.15.197 ttl=214 from 192.168.180.1.
May 14 13:09:26 voipd[422]: <<< Status: 407 Proxy Authentication Required
May 14 13:09:26 voipd[422]: >>> Request: ACK sip:[email protected]
May 14 13:09:26 voipd[422]: <<< Status: 100 Trying
May 14 13:09:30 voipd[422]: <<< Status: 404 Not Found
May 14 13:09:30 voipd[422]: >>> Request: ACK sip:[email protected]
May 14 13:09:30 voipd[422]: ocfree: fail 0 normal 0 small 0 large 0
May 14 13:09:30 voipd[422]:         underrun 0 max_ackqueuelen 0
May 14 13:09:30 voipd[422]:         small packets merged 0, output 0 and consumed from CNG 0
May 14 13:09:30 voipd[422]: ocmode: normal 0 merged 0 delayed 0
May 14 13:09:30 voipd[422]: dropped 0 packets with 0 samples and 1 sample in 0 packets
May 14 13:09:30 voipd[422]: generated noise: 0
May 14 13:09:30 voipd[422]:         capiqueue[0]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:         capiqueue[1]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:         capiqueue[2]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:         capiqueue[3]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:         capiqueue[4]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:         capiqueue[5]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:         capiqueue[6]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:         capiqueue[7]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[0ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[10ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[20ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[30ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[40ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[50ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[60ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[70ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[80ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[90ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[100ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[110ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[120ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[130ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[140ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[150ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[160ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[170ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[180ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[190ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[200ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[210ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[220ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]:        txqueue[230ms]: 0 (  0.0%)
May 14 13:09:30 voipd[422]: CONNECT_RESP with sip value 404
May 14 13:09:30 voipd[422]: call to sip:[email protected] terminated (404)
May 14 13:09:30 voipd[422]: EVENT(78): Fehler bei der Internettelefonie bei Verbindung mit sip:[email protected]. Fehlergrund: 404
May 14 13:09:31 voipd[422]: <<< Status: 404 Not Found
May 14 13:09:31 voipd[422]: >>> Request: ACK sip:[email protected]
May 14 13:09:33 voipd[422]: <<< Status: 404 Not Found
May 14 13:09:33 voipd[422]: >>> Request: ACK sip:[email protected]
May 14 13:09:34 voipd[422]: disconnected(appl=2 plci=0x405 ncci=0x0 incoming): remote: 0x3490 (0x0000) - Normal call clearing
May 14 13:09:37 voipd[422]: <<< Status: 404 Not Found
May 14 13:09:37 voipd[422]: >>> Request: ACK sip:[email protected]
May 14 13:09:41 voipd[422]: <<< Status: 404 Not Found
May 14 13:09:41 voipd[422]: no transaction for status: 404 Not Found
Mit sieht also an Request: ACK sip:[email protected], dass nur 701 gewählt wurde und nicht die gespeicherte Kurzwahl. (0441 ist meine Ortsvorwahl)
Was muss ich machen, damit die Steuercodes * und # funktionieren?
Ciao, Arno
Weiß ich nicht genau, aber da T-Sinus ja Siemens ist,
solltest du irgendwo "Auto. Keypad" am Telefon einstellen können!?
Jedenfalls wurde hier im Forum schon mehrfach erwähnt, dass es so funktionieren soll. ;)
Nachtrag: Neuste Erkenntnisse! :D
the-duke
